Gönderen Konu: [Çözüldü] Steam oyun çılmıyor siyah ekran sorunu  (Okunma sayısı 5548 defa)
Çevrimdışı elifednah
  • İleti: 24
  • Dağıtım: linux mint 19
  • Masaüstü Ortamı: mate
  • Grafik Kartı: Intel® HD Graphics 4200
  • İşlemci: Intel(R) Core(TM) i3-4020Y CPU @ 1.50GHz
Merhaba arkadaşlar
Steam üzerinden tropico 4 ü yükledim. Oyunu başlat diyince siyah ekran geliyor ve sonra hemen kapanıyor.
Çözümü ne olabilir?
System:    Host: Toshiba Kernel: 4.15.0-20-generic x86_64 bits: 64 gcc: 7.3.0
           Desktop: MATE 1.20.1 (Gtk 3.22.30-1ubuntu1) dm: lightdm
           Distro: Linux Mint 19 Tara
Machine:   Device: laptop System: TOSHIBA product: SATELLITE W30t-A v: PSD22E-00600RTE serial: N/A
           Mobo: Type2 - Board Vendor Name1 model: Type2 - Board Product Name1 v: Type2 - Board Version serial: N/A
           UEFI: Insyde v: 1.20 date: 02/13/2014
Graphics:  Card: Intel Device 0a1e bus-ID: 00:02.0 chip-ID: 8086:0a1e
           drivers: modesetting (unloaded: fbdev,vesa)
           Resolution: 1366x768@60.06hz
           OpenGL: renderer: Mesa DRI Intel Haswell
           version: 4.5 Mesa 18.0.5 (compat-v: 3.0) Direct Render: Yes
OpenGL renderer string: Mesa DRI Intel(R) Haswell
00:02.0 VGA compatible controller: Intel Corporation Device 0a1e (rev 0b)
eDP-1 connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 293mm x 165mm
   1366x768      60.06*+
   1360x768      59.80    59.96
   1024x768      60.04    60.00
   960x720       60.00
   928x696       60.05
   896x672       60.01
   960x600       59.93    60.00
   840x525       60.01    59.88
   864x486       59.92    59.57
   800x512       60.17
   700x525       59.98
   800x450       59.95    59.82
   640x512       60.02
   720x450       59.89
   700x450       59.96    59.88
   640x480       60.00    59.94
   720x405       59.51    58.99
   684x384       59.88    59.85
   680x384       59.80    59.96
   640x400       59.88    59.98
   576x432       60.06
   512x384       60.00
   512x288       60.00    59.92
   480x270       59.63    59.82
   400x300       60.32    56.34
   432x243       59.92    59.57
   320x240       60.05
   360x202       59.51    59.13
   320x180       59.84    59.32
Identifier "Configured Video Device"
Driver "vesa"
Section "Monitor"
Identifier "Configured Monitor"
Section "Screen"
Identifier "Default Screen"
Monitor "Configured Monitor"
Device "Configured Video Device"
ii  nvidia-prime-applet                           1.0.7                               all          An applet for NVIDIA Prime
« Son Düzenleme: 08 Ekim 2018, 14:20:49 Gönderen: elifednah »
Ynt: Steam oyun çılmıyor siyah ekran sorunu
« Yanıtla #1 : 06 Ekim 2018, 15:16:21 »
Buradaki konuda Feral Interactive oyunları ile ilgili düzenlemeyi yapmayı deneyebilirsiniz.
  • İleti: 24
« Yanıtla #2 : 06 Ekim 2018, 16:17:33 »
Çok teşekkür ederim. Oyun açıldı
Fakat sağda ve solda boşluklar mevcut. Böyle mi olmakta
« Yanıtla #3 : 06 Ekim 2018, 16:28:48 »
Forumda çözüme ulaşmış önerileri olan bir husus, lütfen forum içi arama yapmayı ihmal etmeyelim.
Buradaki konuyu inceleyebilirsiniz. LVDS1 yerine xrandr komutunun çıktısındaki, görüntü çıkış arabirimi olarak görünen eDP-1 yazmalısınız.
  • İleti: 24
« Yanıtla #4 : 06 Ekim 2018, 23:23:49 »
Tam olarak anlamadım ? Biraz daha ayrıntılı yazabilir misiniz ?
« Yanıtla #5 : 06 Ekim 2018, 23:30:12 »
Bağlantıdaki komutta LVDS1 yerine eDP-1 yazacaksınız.
  • İleti: 24
« Yanıtla #6 : 08 Ekim 2018, 14:20:36 »
yaptım fakat işe yaramadı.
Oyundaki çözünürlük ayarlarını değiştirince oldu
