Gönderen Konu: [Çözüldü] gtx 760 (1024 x 768) çözünülürlükte kaldı  (Okunma sayısı 13917 defa)
Çevrimdışı bymuto
  • İleti: 60
  • Dağıtım: mint
  • Grafik Kartı: gtx 760
  • İşlemci: i7 2600k
Merhaba ekranım 1080p destekliyor fakat 1024 x 768 de kaldı surucu yöneticisinden önerileni secinçe 1024 dustu çözünürlük geri açık koduylu sectım olmadı elle yüklenmiş sürücüye devam et yazıyor
System:    Host: bymuto-System-Product-Name Kernel: 4.15.0-38-generic x86_64
           bits: 64 gcc: 7.3.0
           Desktop: Cinnamon 3.8.8 (Gtk 3.22.30-1ubuntu1) dm: lightdm
           Distro: Linux Mint 19 Tara
Machine:   Device: desktop Mobo: ASUSTeK model: Z77-A v: Rev X.0x serial: N/A
           UEFI: American Megatrends v: 0603 date: 07/12/2013
Graphics:  Card: NVIDIA GK104 [GeForce GTX 760]
           bus-ID: 01:00.0 chip-ID: 10de:1187
           drivers: fbdev,nouveau (unloaded: modesetting,vesa)
           Resolution: 1024x768@76.00hz
           OpenGL: renderer: llvmpipe (LLVM 6.0, 256 bits)
           version: 3.3 Mesa 18.0.5 (compat-v: 3.0) Direct Render: Yes
OpenGL renderer string: llvmpipe (LLVM 6.0, 256 bits)
01:00.0 VGA compatible controller: NVIDIA Corporation GK104 [GeForce GTX 760] (rev a1)
Screen 0: minimum 1024 x 768, current 1024 x 768, maximum 1024 x 768
default connected primary 1024x768+0+0 0mm x 0mm
   1024x768      76.00*
fglrx'
ii  libnvidia-cfg1-390:amd64                   390.77-0ubuntu0.18.04.1                     amd64        NVIDIA binary OpenGL/GLX configuration library
ii  libnvidia-common-390                       390.77-0ubuntu0.18.04.1                     all          Shared files used by the NVIDIA libraries
ii  libnvidia-compute-390:amd64                390.77-0ubuntu0.18.04.1                     amd64        NVIDIA libcompute package
ii  libnvidia-compute-390:i386                 390.77-0ubuntu0.18.04.1                     i386         NVIDIA libcompute package
ii  libnvidia-decode-390:amd64                 390.77-0ubuntu0.18.04.1                     amd64        NVIDIA Video Decoding runtime libraries
ii  libnvidia-decode-390:i386                  390.77-0ubuntu0.18.04.1                     i386         NVIDIA Video Decoding runtime libraries
ii  libnvidia-encode-390:amd64                 390.77-0ubuntu0.18.04.1                     amd64        NVENC Video Encoding runtime library
ii  libnvidia-encode-390:i386                  390.77-0ubuntu0.18.04.1                     i386         NVENC Video Encoding runtime library
ii  libnvidia-fbc1-390:amd64                   390.77-0ubuntu0.18.04.1                     amd64        NVIDIA OpenGL-based Framebuffer Capture runtime library
ii  libnvidia-fbc1-390:i386                    390.77-0ubuntu0.18.04.1                     i386         NVIDIA OpenGL-based Framebuffer Capture runtime library
ii  libnvidia-gl-390:amd64                     390.77-0ubuntu0.18.04.1                     amd64        NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii  libnvidia-gl-390:i386                      390.77-0ubuntu0.18.04.1                     i386         NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii  libnvidia-ifr1-390:amd64                   390.77-0ubuntu0.18.04.1                     amd64        NVIDIA OpenGL-based Inband Frame Readback runtime library
ii  libnvidia-ifr1-390:i386                    390.77-0ubuntu0.18.04.1                     i386         NVIDIA OpenGL-based Inband Frame Readback runtime library
ii  nvidia-compute-utils-390                   390.77-0ubuntu0.18.04.1                     amd64        NVIDIA compute utilities
ii  nvidia-dkms-390                            390.77-0ubuntu0.18.04.1                     amd64        NVIDIA DKMS package
ii  nvidia-kernel-common-390                   390.77-0ubuntu0.18.04.1                     amd64        Shared files used with the kernel module
ii  nvidia-kernel-source-390                   390.77-0ubuntu0.18.04.1                     amd64        NVIDIA kernel source package
ii  nvidia-prime                               0.8.8.1                                     all          Tools to enable NVIDIA's Prime
ii  nvidia-prime-applet                        1.0.7                                       all          An applet for NVIDIA Prime
ii  nvidia-settings                            390.77-0ubuntu0.18.04.1                     amd64        Tool for configuring the NVIDIA graphics driver
ii  nvidia-utils-390                           390.77-0ubuntu0.18.04.1                     amd64        NVIDIA driver support binaries
ii  xserver-xorg-video-nvidia-390              390.77-0ubuntu0.18.04.1                     amd64        NVIDIA binary Xorg driver
« Son Düzenleme: 30 Ekim 2018, 15:08:55 Gönderen: bymuto »
Ynt: gtx 760 (1024 x 768) çözünülürlükte kaldı
« Yanıtla #1 : 27 Ekim 2018, 20:03:47 »
Çıktılara göre, şu an sistem yazılımsal işleme kipinde çalışıyor, yani işlemler GPU yerine CPU üzerinden yapılıyor. Bu sürücü ile ilgili bir sorundan kaynaklı olabilir.
Aşağıdaki komutu uçbirimde çalıştrıp sistemi yeniden başlatmayı deneyiniz.
sudo nvidia-xconfig
Çevrimdışı bymuto
  • İleti: 60
  • Dağıtım: mint
  • İşlemci: i7 2600k
« Yanıtla #2 : 27 Ekim 2018, 20:06:43 »
sudo nvidia-xconfig
uyguladım halen aynı
« Yanıtla #3 : 27 Ekim 2018, 20:11:18 »
Uygulamış olsaydınız, /etc/X11/xorg.conf dosyası oluşurdu. Eğer yeni uyguladısanız sistemi yeniden başlatın.
Bir de forumda yazım kurallarına uygulmasını önemsiyoruz, bu hususa da özen gösterilse mutlu oluruz.
Çevrimdışı bymuto
  • İleti: 60
  • Dağıtım: mint
  • İşlemci: i7 2600k
« Yanıtla #4 : 27 Ekim 2018, 20:17:06 »
Dediklerinizi harfiyen uyguladım, düzelmedi. Satır komutuna yazdım ve restart attım.
Düzenleme: Yazım kuralları
« Son Düzenleme: 27 Ekim 2018, 20:19:40 Gönderen: Butterfly »
« Yanıtla #5 : 27 Ekim 2018, 20:18:59 »
Komutu yeniden çalıştırıp çıktısını paylaşınız.
Çevrimdışı bymuto
  • İleti: 60
  • Dağıtım: mint
  • İşlemci: i7 2600k
« Yanıtla #6 : 27 Ekim 2018, 20:42:07 »
komple driver kaldırdım tekrar elle kurdum görüntü düzeldi çıktılarım nasıl sizce
           bits: 64 gcc: 7.3.0
           drivers: nouveau (unloaded: modesetting,fbdev,vesa)
           Resolution: 1920x1080@60.00hz
           OpenGL: renderer: NVE4
           version: 4.3 Mesa 18.0.5 (compat-v: 3.0) Direct Render: Yes
OpenGL renderer string: NVE4
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
DVI-D-1 disconnected (normal left inverted right x axis y axis)
HDMI-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 476mm x 268mm
   1920x1080     60.00*+  50.00    59.94
   1920x1080i    60.00    50.00    59.94
   1680x1050     59.88
   1280x1024     75.02    60.02
   1440x900      59.90
   1360x768      59.95
   1280x800      59.91
   1152x864      75.00    59.97
   1280x720      60.00    50.00    59.94
   832x624       74.55
   720x576       50.00
   720x480       60.00    59.94
   640x480       75.00    72.81    66.67    60.00    59.94
   720x400       70.08
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 390.77  (buildmeister@swio-display-x64-rhel04-14)  Tue Jul 10 23:19:22 PDT 2018
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
Section "Files"
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Identifier     "Keyboard0"
    Driver         "kbd"
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Unknown"
    HorizSync       28.0 - 33.0
    VertRefresh     43.0 - 72.0
    Option         "DPMS"
    Identifier     "Device0"
    Driver         "nvidia"
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    SubSection     "Display"
        Depth       24
    EndSubSection
ii  libnvidia-cfg1-390:amd64                   390.87-0ubuntu0~gpu18.04.1                  amd64        NVIDIA binary OpenGL/GLX configuration library
ii  libnvidia-compute-390:amd64                390.87-0ubuntu0~gpu18.04.1                  amd64        NVIDIA libcompute package
ii  libnvidia-compute-390:i386                 390.87-0ubuntu0~gpu18.04.1                  i386         NVIDIA libcompute package
ii  libnvidia-decode-390:amd64                 390.87-0ubuntu0~gpu18.04.1                  amd64        NVIDIA Video Decoding runtime libraries
ii  libnvidia-decode-390:i386                  390.87-0ubuntu0~gpu18.04.1                  i386         NVIDIA Video Decoding runtime libraries
ii  libnvidia-encode-390:amd64                 390.87-0ubuntu0~gpu18.04.1                  amd64        NVENC Video Encoding runtime library
ii  libnvidia-encode-390:i386                  390.87-0ubuntu0~gpu18.04.1                  i386         NVENC Video Encoding runtime library
ii  libnvidia-fbc1-390:amd64                   390.87-0ubuntu0~gpu18.04.1                  amd64        NVIDIA OpenGL-based Framebuffer Capture runtime library
ii  libnvidia-fbc1-390:i386                    390.87-0ubuntu0~gpu18.04.1                  i386         NVIDIA OpenGL-based Framebuffer Capture runtime library
ii  libnvidia-gl-390:amd64                     390.87-0ubuntu0~gpu18.04.1                  amd64        NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii  libnvidia-gl-390:i386                      390.87-0ubuntu0~gpu18.04.1                  i386         NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii  libnvidia-ifr1-390:amd64                   390.87-0ubuntu0~gpu18.04.1                  amd64        NVIDIA OpenGL-based Inband Frame Readback runtime library
ii  libnvidia-ifr1-390:i386                    390.87-0ubuntu0~gpu18.04.1                  i386         NVIDIA OpenGL-based Inband Frame Readback runtime library
ii  nvidia-390                                 390.87-0ubuntu0~gpu18.04.1                  amd64        Transitional package for nvidia-driver-390
ii  nvidia-compute-utils-390                   390.87-0ubuntu0~gpu18.04.1                  amd64        NVIDIA compute utilities
ii  nvidia-dkms-390                            390.87-0ubuntu0~gpu18.04.1                  amd64        NVIDIA DKMS package
ii  nvidia-driver-390                          390.87-0ubuntu0~gpu18.04.1                  amd64        NVIDIA driver metapackage
ii  nvidia-kernel-common-390                   390.87-0ubuntu0~gpu18.04.1                  amd64        Shared files used with the kernel module
ii  nvidia-kernel-source-390                   390.87-0ubuntu0~gpu18.04.1                  amd64        NVIDIA kernel source package
ii  nvidia-utils-390                           390.87-0ubuntu0~gpu18.04.1                  amd64        NVIDIA driver support binaries
ii  xserver-xorg-video-nvidia-390              390.87-0ubuntu0~gpu18.04.1                  amd64        NVIDIA binary Xorg driver
« Yanıtla #7 : 27 Ekim 2018, 20:59:51 »
Şu an açık kaynak sürücüsü etkin görünüyor. Bu işlemlerden sonra sistemi yeniden başlattınız mı?
Çevrimdışı bymuto
  • İleti: 60
  • Dağıtım: mint
  • İşlemci: i7 2600k
« Yanıtla #8 : 27 Ekim 2018, 21:09:21 »
evet yeniden başlatmiştim bu açık kaynak sürücüsü ile tam verimli çalışmaz mı?
« Son Düzenleme: 27 Ekim 2018, 21:10:51 Gönderen: bymuto »
« Yanıtla #9 : 27 Ekim 2018, 22:56:55 »
Oyunlar gibi yüksek işlem gücü gerektiren uygulamalarla kullanamazsınız çünkü reclock desteği yok , gpu minimal hızda çalışır. Nvidia'ya has bir durum.
Ayrıca CUDA kullanmak istiyorsanız o da sadece kapalı kaynak sürücü ile mümkün.
Çevrimdışı bymuto
  • İleti: 60
  • Dağıtım: mint
  • İşlemci: i7 2600k
« Yanıtla #10 : 28 Ekim 2018, 22:08:23 »
peki üstat nasıl düzüun ekran kartımı kurarım ?
« Yanıtla #11 : 28 Ekim 2018, 22:21:51 »
Sürücüler kurulu görünüyor, bu durumda secure boot etkin olduğu için çekirdeğe sonradan eklenen sürücüyü engelliyor olabilir.  BIOS'tan secure boot özelliğini kapatıp sistemi başlatmayı deneyebilirsiniz.
Çevrimdışı bymuto
  • İleti: 60
  • Dağıtım: mint
  • İşlemci: i7 2600k
« Yanıtla #12 : 29 Ekim 2018, 00:08:07 »
Kapattım, görüntü hantallaştı, neden acaba?
Düzenleme: Yazım kuralları  İmla ve Yazım Kuralları
« Son Düzenleme: 29 Ekim 2018, 00:16:07 Gönderen: Butterfly »
« Yanıtla #13 : 29 Ekim 2018, 00:17:29 »
Siz gerekli çıktıları paylaşmadıkça, durum hakkında bir yorumda bulunmak zor.
Çevrimdışı bymuto
  • İleti: 60
  • Dağıtım: mint
  • İşlemci: i7 2600k
« Yanıtla #14 : 29 Ekim 2018, 00:25:44 »
           bits: 64 gcc: 7.3.0
           Display Server: x11 (X.Org 1.19.6 ) driver: nvidia
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 16384 x 16384
DVI-I-0 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 476mm x 268mm
   1920x1080     60.00*+  59.94    50.00    60.05    60.00    50.04
   1680x1050     59.95
   1440x900      59.89
   1360x765      60.00
   1280x800      59.81
   1280x720      60.00    59.94    50.00
   1152x864      60.00
   800x600       75.00    72.19    60.32    56.25
   720x576       50.00
   720x480       59.94
   640x480       75.00    72.81    59.94    59.93
DP-0 disconnected (normal left inverted right x axis y axis)
DVI-D-0 disconnected (normal left inverted right x axis y axis)
Section "Files"
    Identifier     "Mouse0"
    Driver         "mouse"
    Driver         "kbd"
Section "Monitor"
    ModelName      "Unknown"
    Option         "DPMS"
    Driver         "nvidia"
Section "Screen"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
        Depth       24
    EndSubSection
ii  libnvidia-common-396                       396.54-0ubuntu0~gpu18.04.1                  all          Shared files used by the NVIDIA libraries
rc  libnvidia-compute-396:amd64                396.54-0ubuntu0~gpu18.04.1                  amd64        NVIDIA libcompute package
rc  libnvidia-compute-396:i386                 396.54-0ubuntu0~gpu18.04.1                  i386         NVIDIA libcompute package
iU  libnvidia-ifr1-390:amd64                   390.87-0ubuntu0~gpu18.04.1                  amd64        NVIDIA OpenGL-based Inband Frame Readback runtime library
iU  libnvidia-ifr1-390:i386                    390.87-0ubuntu0~gpu18.04.1                  i386         NVIDIA OpenGL-based Inband Frame Readback runtime library
rc  nvidia-compute-utils-396                   396.54-0ubuntu0~gpu18.04.1                  amd64        NVIDIA compute utilities
rc  nvidia-dkms-396                            396.54-0ubuntu0~gpu18.04.1                  amd64        NVIDIA DKMS package
iU  nvidia-driver-390                          390.87-0ubuntu0~gpu18.04.1                  amd64        NVIDIA driver metapackage
rc  nvidia-kernel-common-396                   396.54-0ubuntu0~gpu18.04.1                  amd64        Shared files used with the kernel module
rc  nvidia-opencl-icd-340                      340.107-0ubuntu0.18.04.1                    amd64        NVIDIA OpenCL ICD
ii  nvidia-settings                            410.73-0ubuntu0~gpu18.04.1                  amd64        Tool for configuring the NVIDIA graphics driver
Şuan da aldım
