Gönderen Konu: Asus Strix Rx 580 ekran kartı kurulumu  (Okunma sayısı 9599 defa)
Çevrimdışı fozaltun
  • İleti: 15
  • Dağıtım: Ubuntu 14.04 / Linux Mint 17.2
« : 29 Ekim 2018, 20:16:41 »
Merhaba arkadaşlar. Yeni bir kasa topladım. Ekran kartı olarak Rx 580 kullanıyorum. Linux mint yükledim fakat Rx 480 olarak görüyor. Ekran dalgalanma yapıyor.Sürücü arama kısmında herhangi bir sürücü yok. Doğrusunu nasıl kurabilirim ?
inxi -SMGxx
System:    Host: ryzenn Kernel: 4.15.0-38-generic x86_64 bits: 64 gcc: 7.3.0
           Desktop: Cinnamon 3.8.9 (Gtk 3.22.30-1ubuntu1) dm: lightdm
           Distro: Linux Mint 19 Tara
Machine:   Device: desktop Mobo: Micro-Star model: B450 TOMAHAWK (MS-7C02) v: 1.0 serial: N/A
           UEFI: American Megatrends v: 1.20 date: 09/21/2018
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX 470/480]
           bus-ID: 1c:00.0 chip-ID: 1002:67df
           drivers: ati,amdgpu (unloaded: modesetting,fbdev,vesa,radeon)
           Resolution: 1920x1080@74.97hz
           OpenGL: renderer: Radeon RX 580 Series (POLARIS10 / DRM 3.23.0 / 4.15.0-38-generic, LLVM 6.0.0)
           version: 4.5 Mesa 18.0.5 (compat-v: 3.0) Direct Render: Yes
OpenGL renderer string: Radeon RX 580 Series (POLARIS10 / DRM 3.23.0 / 4.15.0-38-generic, LLVM 6.0.0)
1c:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere [Radeon RX 470/480] (rev e7)
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
DisplayPort-1 disconnected (normal left inverted right x axis y axis)
HDMI-A-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 480mm x 270mm
   1920x1080     74.97*+  60.00    50.00    59.94
   1680x1050     59.88
   1400x1050     59.95
   1600x900      60.00
   1280x1024     75.02    60.02
   1440x900      59.90
   1280x800      59.91
   1152x864      75.00
   1280x720      60.00    50.00    59.94
   1024x768      75.03    60.00
   800x600       75.00    60.32
   720x576       50.00
   720x480       60.00    59.94
   640x480       75.00    60.00    59.94
   720x400       70.08
HDMI-A-1 disconnected (normal left inverted right x axis y axis)
DVI-D-0 disconnected (normal left inverted right x axis y axis)
Cinnamon başlat menüsü değişsin  artık!
Ynt: Asus Strix Rx 580 ekran kartı kurulumu
« Yanıtla #1 : 29 Ekim 2018, 20:24:47 »
Aşağıdaki komutları uçbirimde çalıştırıp,
sudo mkdir -p /etc/X11/xorg.conf.d/
sudo xed /etc/X11/xorg.conf.d/20-amdgpu.conf
açılan dosyaya aşağıdaki satırları yapıştırıp dosyayı kaydediniz.
     Identifier "AMD"
     Driver "amdgpu"
     Option "TearFree" "true"
Ardından sistemi yeniden başlatmayı deneyiniz.
« Yanıtla #2 : 30 Ekim 2018, 00:10:28 »
RX480 yazması normal , sanıyorum kullandıkları firmware'a kadar aynı. Sadece saat hızları farklı.
OpenGL renderer kısmına bakarsanız ilk çıktıda : RX 580 yazmakta.
Sürücünüzü güncellemek isterseniz oyun bölümündeki konuya bakabilirsiniz.
Butterfly hocamızın önerisi ekran yırtılmasını çözecektir.
« Son Düzenleme: 30 Ekim 2018, 00:13:36 Gönderen: Leopard »
Çevrimdışı fozaltun
  • İleti: 15
« Yanıtla #3 : 30 Ekim 2018, 22:28:01 »
Her iki öneriyi de uyguladım . Düzelmedi. Başka ne yapabilirim?
« Yanıtla #4 : 30 Ekim 2018, 22:32:33 »
Yırtılma/dalgalanma sorunu için şu öneriyi deneyebilirsiniz. https://forum.linuxmint.net.tr/index.php?topic=250.0
Çevrimdışı fozaltun
  • İleti: 15
« Yanıtla #5 : 02 Kasım 2018, 20:21:05 »
Sanırım başka önerisi olan yok. Bu problemden dolayı kullanamıyorum.
« Yanıtla #6 : 02 Kasım 2018, 20:29:05 »
En son sunulan öneri ile ilgili dönüş yapmamışsınız ki farklı bir öneri sunulsun. Geri dönüşünüzden sunulan öneriyi uygulayıp uygulamadığınız konusunda net bir sonuç çıkaramıyorum. Bu hususu belirtirseniz, yönlendirme yapmaya çalışalım.
Bir de aşağıdaki komutun çıktısını paylaşın.
cat /var/log/Xorg.0.log
« Son Düzenleme: 02 Kasım 2018, 21:16:56 Gönderen: Butterfly »
Çevrimdışı fozaltun
  • İleti: 15
« Yanıtla #7 : 04 Kasım 2018, 14:02:00 »
Konudaki önerileri de uyguladım. Uygulamadım değil. Ama düzelmedi maalesef.
Son istediğiniz komutun çıktıları çok uzun hepsini paylaşamıyorum. 30.000 karakter sınırı var. 2 ye bölsem de gönderemiyorum.
Dosya halinde paylaşmak zorundayım.
https://docs.google.com/document/d/1m5oGtNZoZ16rKtHLUY0wz4WYDedH_d6tdyffDPBdlQE/edit?usp=sharing
« Son Düzenleme: 04 Kasım 2018, 14:06:06 Gönderen: fozaltun »
« Yanıtla #8 : 04 Kasım 2018, 16:30:56 »
[     5.642] (**) AMDGPU(0): Option "TearFree" "true"
[     5.749] (**) AMDGPU(0): TearFree property default: on
Ekran yırtılmasını çözüm olacak Terar Free seçeneği etkin görünüyor.
Aşağıdaki komutları sırasıyla uçbirimde çalıştırıp sistemi yeniden başlatmayı dener misiniz?
echo 'GRUB_CMDLINE_LINUX="$GRUB_CMDLINE_LINUX amdgpu.dc=0"' | sudo tee  /etc/default/grub.d/amdgpu-dc.cfg
sudo update-grub
Çevrimdışı fozaltun
  • İleti: 15
« Yanıtla #9 : 24 Şubat 2019, 22:15:33 »
Arkadaşlar şunu farkettim , 1080p de kullandığım zaman bu ekranda görüntü bozulmaları oluyor fakat 1600*900 kullandığım zaman titreme olmuyor. 1080p ile ilgili nasıl bir problem olabilir?
« Yanıtla #10 : 24 Şubat 2019, 22:28:29 »
Kernel güncellemenizi tavsiye ederim. Yeni kernellerde AMDGPU düzeltmeleri mevcut.
Çevrimdışı fozaltun
  • İleti: 15
« Yanıtla #11 : 24 Şubat 2019, 23:26:26 »
Kernel güncellemesi de yaptım ama bir değişiklik olmadı. Bende ona umut bağlamıştım. 4.18 kurulu.
Çevrimdışı fozaltun
  • İleti: 15
« Yanıtla #12 : 01 Mart 2019, 17:40:03 »
Zamanla farkettiğim deneyimi de paylaşmak istedim. Belki birilerine faydası dokunur.
Öncelikle 1080p bir ekranım var.
Mint ayarlarından display 1080p de sistem açılıyor. Ekran titreme yapıyordu.Mouse tıklaması yada hareketi bu görüntü bozulma dalgalarını arttırıyordu.
Hiç fareyi ellemezsen azalıyordu. Böyle garip bir şey vardı.
1- Görüntü ayarlarını 1600*900 e düşürünce titreme kesiliyor.
2- 1600*900 sistemi yeniden başlatınca yine bir sorun yok.
3- Böyle olunca tekrar bir 1080p deneyim dedim. Görüntü bu sefer titreme yapmaz oldu.
4- Fakat 1080p de kullandıktan sonra yeniden başlatınca titreme yeniden geldi.
1600*900 hiçbir zaman titreme yok.
