Gönderen Konu: [Çözüldü] (Command 'chmod' not found") hatası  (Okunma sayısı 3502 defa)
Çevrimdışı Docea37
  • İleti: 25
merhaba
mint 19 mate kurdum. chmod hatası alıyorum.
docea37[member=1843]Docea37[/member]-K:~/Masaüstü$ chmod 775 -R test && ipkg-build test
Command 'chmod' not found, did you mean:
  command 'chmod' from deb coreutils
Try: sudo apt install <deb name>
docea37[member=1843]Docea37[/member]-K:~/Masaüstü$ sudo apt install chmod
[sudo] password for docea37:
E: chmod paketi bulunamadı
docea37[member=1843]Docea37[/member]-K:~/Masaüstü$ inxi -Sr
System:    Host: docea37-K Kernel: 4.15.0-38-generic x86_64 bits: 64
           Desktop: MATE 1.20.1  Distro: Linux Mint 19 Tara
Repos:     Active apt sources in file: /etc/apt/sources.list.d/official-package-repositories.list
           deb http://packages.linuxmint.com tara main upstream import backport #id:linuxmint_main
           deb http://archive.ubuntu.com/ubuntu bionic main restricted universe multiverse
           deb http://archive.ubuntu.com/ubuntu bionic-updates main restricted universe multiverse
           deb http://archive.ubuntu.com/ubuntu bionic-backports main restricted universe multiverse
           deb http://security.ubuntu.com/ubuntu/ bionic-security main restricted universe multiverse
           deb http://archive.canonical.com/ubuntu/ bionic partner
           Active apt sources in file: /etc/apt/sources.list.d/skype-stable.list
           deb [arch=amd64] https://repo.skype.com/deb stable main
           Active apt sources in file: /etc/apt/sources.list.d/teamviewer.list
           deb http://linux.teamviewer.com/deb stable main
           deb http://linux.teamviewer.com/deb preview main
docea37[member=1843]Docea37[/member]-K:~/Masaüstü$ sudo apt-get update
Aynı:  1 http://archive.canonical.com/ubuntu bionic InRelease
İndir: 2 http://security.ubuntu.com/ubuntu bionic-security InRelease [83,2 kB]
Aynı:  3 http://archive.ubuntu.com/ubuntu bionic InRelease
İndir: 4 http://archive.ubuntu.com/ubuntu bionic-updates InRelease [88,7 kB]
Aynı:  5 https://repo.skype.com/deb stable InRelease
Yoksay:6 http://packages.linuxmint.com tara InRelease
Aynı:  7 http://linux.teamviewer.com/deb stable InRelease
İndir: 8 http://archive.ubuntu.com/ubuntu bionic-backports InRelease [74,6 kB]
Aynı:  9 http://packages.linuxmint.com tara Release
Aynı:  10 http://linux.teamviewer.com/deb preview InRelease
2 sn.'de 247 kB alındı (159 kB/s)
docea37[member=1843]Docea37[/member]-K:~/Masaüstü$ sudo apt-get install -f
bunun bir çözümü varmı yoksa yeni bir kurulummu yapmam lazım
kolay gelsin
« Son Düzenleme: 06 Kasım 2018, 22:32:31 Gönderen: Docea37 »
Ynt: (Command 'chmod' not found") hatası
« Yanıtla #1 : 05 Kasım 2018, 21:52:33 »
Bu sorunun "Paket Yönetimi, Güncelleme ve Depo Sorunları" bölümüyle ilgisi nedir? Lütfen konuları uygun bölümlere açmaya özen gösteriniz. Konu uygun bir bölüme taşınmıştır.
Komutun hangi pakette olduğu çıktıda yazıyor, bu paketi kurmayı deneyiniz. Bu paket sistemle kurulu gelir. Aorun büyük ihtimalle sizin yaptığınız bir işlemin sonucu olarak paketin kaldırılmasından kaynaklanıyordur.
Çevrimdışı Docea37
  • İleti: 25
« Yanıtla #2 : 05 Kasım 2018, 22:00:05 »
özür dilerim yanlış yere açtığım için.
docea37[member=1843]Docea37[/member]-K:~/Masaüstü$ sudo apt install coreutils
coreutils zaten en yeni sürümde (8.28-1ubuntu1).
« Yanıtla #3 : 05 Kasım 2018, 22:08:28 »
which chmod
Yukarıdaki komut, komut dosyasının nerede olduğunu söyler, tam yolu ile çalıştırmayı deneyebilrisiniz. chmod komutunu tek başına çalıştırdığınızda aşağıdaki çıktıyı veriyorsa,  sistemde mevcut demektir. Bu durumda düzenlediğiniz komut satırı hatalı demektir.
Try 'chmod --help' for more information.
Çevrimdışı Docea37
  • İleti: 25
« Yanıtla #4 : 05 Kasım 2018, 22:19:37 »
ustam böyle bir çıktı aldım
ustam linux konusunda acemi sayılırım.
docea37[member=1843]Docea37[/member]-K:~/Masaüstü$ which chmod
/bin/chmod
docea37[member=1843]Docea37[/member]-K:~/Masaüstü$ /bin/chmod 775 -R test && ipkg-build test
bash: /bin/chmod: Böyle bir dosya ya da dizin yok
/bin/chmod: eksik işlenen
Try '/bin/chmod --help' for more information.
docea37[member=1843]Docea37[/member]-K:~/Masaüstü$ /bin/chmod 775 -R test && opkg-build test
Düzenleme: Kod etiketi
« Son Düzenleme: 05 Kasım 2018, 22:23:37 Gönderen: Butterfly »
« Yanıtla #5 : 05 Kasım 2018, 22:22:41 »
Masaüstünde test isimli bir dizin yokmuş. Test dizini nerdeyse uçbirimi onun üst dizininde çalıştırmayı deneyiniz. Ya da test dizinini Masaüstüne taşıyın.
cd /test/dizinin/üst/dizini
Çevrimdışı Docea37
  • İleti: 25
« Yanıtla #6 : 05 Kasım 2018, 22:28:53 »
ustam doğru yerdede hata var.
« Yanıtla #7 : 05 Kasım 2018, 23:09:50 »
Ne yapmaya çalıştığınızı ayrıntısıyla anlatır mısınız? OPKG sistem değişkenlerini etkileyebiliyor. Bununla ilgili forumda konular mevcut.
Çevrimdışı Docea37
  • İleti: 25
« Yanıtla #8 : 05 Kasım 2018, 23:14:55 »
ipk dosyası hazırlamaya çalışıyorum.
« Yanıtla #9 : 05 Kasım 2018, 23:19:54 »
Bu ayrıntılı bir bilgi değil.
Çevrimdışı Docea37
  • İleti: 25
« Yanıtla #10 : 06 Kasım 2018, 22:32:11 »
merhaba chmdo hatasını  linux mint 18.3 mate 64bit e geçerek giderdim.
Ynt: [Çözüldü] (Command 'chmod' not found") hatası
« Yanıtla #11 : 06 Kasım 2018, 22:36:28 »
İyi de sorunun nedeni dağıtım ya da sürümü değil ki, çok büyük ihtimalle OPKG'nin ortam değişkenleri ile ilgili bir takım değişiklikler yapmış olması. Bu sebeple Linux Mint 18.3'e OPKG kurduğunuzda da aynı sorunla karşılacaksınız. Neyse sorunun çözüldüğüne kanaat getirdiğinize göre konuyu etkiketlemeden kilitleyelim. Başlığı açtırmak isterseniz bu mesajdaki rapor et kısayolundan bildirimde bulunabilirsiniz.
