Gönderen Konu: kali linuxda ısınma sorunu  (Okunma sayısı 2734 defa)
Çevrimdışı cozal
  • İleti: 2
  • Dağıtım: linux mint
  • Grafik Kartı: gtx 1050
  • İşlemci: intel i7
« : 24 Kasım 2018, 21:55:18 »
Şurdaki kurulumu yapmıştımhttps://www.pcsuggest.com/install-and-configure-nvidia-optimus-with-bumblebee-in-debian/. ısınma sorunum var sebebini görebiliyor musunuz?
sensors
coretemp-isa-0000
Adapter: ISA adapter
Package id 0:  +49.0°C  (high = +100.0°C, crit = +100.0°C)
Core 0:        +48.0°C  (high = +100.0°C, crit = +100.0°C)
Core 1:        +48.0°C  (high = +100.0°C, crit = +100.0°C)
Core 2:        +47.0°C  (high = +100.0°C, crit = +100.0°C)
Core 3:        +47.0°C  (high = +100.0°C, crit = +100.0°C)
acpitz-virtual-0
Adapter: Virtual device
temp1:        +49.0°C
iwlwifi-virtual-0
temp1:        +46.0°C
pch_skylake-virtual-0
temp1:        +44.0°C
inxi -SMGxx
System:
  Host: computer Kernel: 4.18.0-kali2-amd64 x86_64 bits: 64 compiler: gcc v: 7.3.0
  Desktop: KDE Plasma 5.13.5 tk: Qt 5.11.1 wm: kwin_x11 dm: SDDM
  Distro: Kali GNU/Linux 2018.4 base: Debian testing
Machine:
  Type: Laptop System: HP product: HP Pavilion Power Laptop 15-cb0xx
  v: Type1ProductConfigId serial: <root required> Chassis: type: 10
  Mobo: HP model: 836B v: 46.23 serial: <root required> UEFI: Insyde v: F.13
  date: 11/03/2017
Graphics:
  Device-1: Intel vendor: Hewlett-Packard driver: i915 v: kernel bus ID: 00:02.0
  chip ID: 8086:591b
  Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Hewlett-Packard
  driver: nvidia v: 390.87 bus ID: 01:00.0 chip ID: 10de:1c8d
  Display: x11 server: X.Org 1.20.1 driver: modesetting unloaded: fbdev,vesa
  compositor: kwin_x11 resolution: 1920x1080~60Hz
  OpenGL: renderer: Mesa DRI Intel HD Graphics 630 (Kaby Lake GT2)
  v: 4.5 Mesa 18.1.7 compat-v: 3.0 direct render: Yes
OpenGL renderer string: Mesa DRI Intel(R) HD Graphics 630 (Kaby Lake GT2)
00:02.0 VGA compatible controller: Intel Corporation Device 591b (rev 04)
01:00.0 VGA compatible controller: NVIDIA Corporation GP107M [GeForce GTX 1050 Mobile] (rev a1)
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 8192 x 8192
eDP-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
   1920x1080     60.02*+  40.03
ii  bumblebee                                     3.2.1-17                                amd64        NVIDIA Optimus support for Linux
ii  bumblebee-nvidia                              3.2.1-17                                amd64        NVIDIA Optimus support using the proprietary NVIDIA driver
ii  glx-alternative-nvidia                        0.8.8                                   amd64        allows the selection of NVIDIA as GLX provider
ii  libegl-nvidia0:amd64                          390.87-3                                amd64        NVIDIA binary EGL library
ii  libegl1-nvidia:amd64                          390.87-3                                amd64        NVIDIA binary EGL library (non-GLVND variant)
ii  libgl1-nvidia-glx:amd64                       390.87-3                                amd64        NVIDIA binary OpenGL/GLX library (non-GLVND variant)
ii  libgles-nvidia1:amd64                         390.87-3                                amd64        NVIDIA binary OpenGL|ES 1.x library
ii  libgles-nvidia2:amd64                         390.87-3                                amd64        NVIDIA binary OpenGL|ES 2.x library
ii  libglx-nvidia0:amd64                          390.87-3                                amd64        NVIDIA binary GLX library
ii  libnvidia-cfg1:amd64                          390.87-3                                amd64        NVIDIA binary OpenGL/GLX configuration library
ii  libnvidia-egl-wayland1:amd64                  390.87-3                                amd64        NVIDIA binary Wayland EGL external platform library
ii  libnvidia-eglcore:amd64                       390.87-3                                amd64        NVIDIA binary EGL core libraries
ii  libnvidia-glcore:amd64                        390.87-3                                amd64        NVIDIA binary OpenGL/GLX core libraries
ii  libnvidia-ml1:amd64                           390.87-3                                amd64        NVIDIA Management Library (NVML) runtime library
ii  nvidia-alternative                            390.87-3                                amd64        allows the selection of NVIDIA as GLX provider
ii  nvidia-driver                                 390.87-3                                amd64        NVIDIA metapackage
ii  nvidia-driver-bin                             390.87-3                                amd64        NVIDIA driver support binaries
ii  nvidia-driver-libs-nonglvnd:amd64             390.87-3                                amd64        NVIDIA metapackage (non-GLVND OpenGL/GLX/EGL/GLES libraries)
ii  nvidia-egl-common                             390.87-3                                amd64        NVIDIA binary EGL driver - common files
ii  nvidia-egl-icd:amd64                          390.87-3                                amd64        NVIDIA EGL installable client driver (ICD)
ii  nvidia-egl-wayland-common                     390.87-3                                amd64        NVIDIA binary Wayland EGL external platform - common files
ii  nvidia-egl-wayland-icd:amd64                  390.87-3                                amd64        NVIDIA Wayland EGL external platform library (ICD)
ii  nvidia-installer-cleanup                      20151021+8                              amd64        cleanup after driver installation with the nvidia-installer
ii  nvidia-kernel-common                          20151021+8                              amd64        NVIDIA binary kernel module support files
ii  nvidia-kernel-dkms                            390.87-3                                amd64        NVIDIA binary kernel module DKMS source
ii  nvidia-kernel-support                         390.87-3                                amd64        NVIDIA binary kernel module support files
ii  nvidia-legacy-check                           390.87-3                                amd64        check for NVIDIA GPUs requiring a legacy driver
ii  nvidia-modprobe                               390.25-1                                amd64        utility to load NVIDIA kernel modules and create device nodes
ii  nvidia-nonglvnd-vulkan-common                 390.87-3                                amd64        NVIDIA Vulkan driver - common files (non-GLVND variant)
ii  nvidia-nonglvnd-vulkan-icd:amd64              390.87-3                                amd64        NVIDIA Vulkan ICD (non-GLVND variant)
ii  nvidia-persistenced                           390.25-1                                amd64        daemon to maintain persistent software state in the NVIDIA driver
ii  nvidia-settings                               390.67-1                                amd64        tool for configuring the NVIDIA graphics driver
ii  nvidia-support                                20151021+8                              amd64        NVIDIA binary graphics driver support files
ii  nvidia-vdpau-driver:amd64                     390.87-3                                amd64        Video Decode and Presentation API for Unix - NVIDIA driver
ii  nvidia-xconfig                                390.25-1                                amd64        deprecated X configuration tool for non-free NVIDIA drivers
ii  primus                                        0~20150328-6                            amd64        client-side GPU offloading for NVIDIA Optimus
ii  primus-libs:amd64                             0~20150328-6                            amd64        Shared libraries for primus
ii  virtualgl                                     2.6-20180824                            amd64        A toolkit for displaying OpenGL applications to thin clients
ii  xserver-xorg-video-nvidia                     390.87-3                                amd64        NVIDIA binary Xorg driver
Ynt: kali linuxda ısınma sorunu
« Yanıtla #1 : 24 Kasım 2018, 22:37:48 »
Forum kuralları:
https://forum.linuxmint.net.tr/index.php?topic=140.0
Madde 12:
- Forumda penetrasyon (sızma) testi ile ilgili dağıtım ve yazılımlara destek verilmemektedir. Böyle içereğe sahip konu ve mesajlar tespit edilmesi veya bildirilmesi durumunda bildirimde bulunulmaksızın kaldırılacaktır.
       Not1: Bu tarz dağıtımlara ait depoların eklenmesi sonrası oluşacak sorunlara forumda destek verilmemektedir.
       Not2: Bu tür dağıtım ve yazılımlar hakkında destek isteyenler (bunları kullandığı anlaşılan yeni üyeler) forumdan yasaklanabilir.
