Gönderen Konu: Lubuntu - Ekranda donma ve takılma sorunu  (Okunma sayısı 5110 defa)
Çevrimdışı harkail_rad
  • İleti: 115
  • Dağıtım: linux mint
« : 27 Kasım 2018, 11:40:10 »
Arkadaşlar merhaba,
eski bir bilgisayara lubuntu kurdum. Ekranda donma ve kasmalar var. Sekmeler arası geçişlerde takılmalar oluyor, bir pencereyi bir yerden başka bir yere taşırken de takılmalar meydana geliyor.
System:    Host: WS-LIN-03 Kernel: 4.13.0-46-generic i686 bits: 32 gcc: 7.2.0
           Desktop: LXDE (Openbox 3.6.1) Distro: Ubuntu 17.10
Machine:   Device: desktop Mobo: ASUSTeK model: K8V-MX serial: N/A
           BIOS: American Megatrends v: 0204 date: 10/14/2005
CPU:       Single core AMD Sempron 2800+ (-UP-) arch: K8 rev.E cache: 256 KB
           flags: (lm nx pae sse sse2 sse3) bmips: 3200 speed: 1600 MHz (max)
Graphics:  Card: VIA K8M800/K8N800/K8N800A [S3 UniChrome Pro] bus-ID: 01:00.0
           Display Server: x11 (X.Org 1.19.5 )
           drivers: fbdev (unloaded: modesetting,vesa)
           Resolution: 1280x800@76.00hz
           OpenGL: renderer: llvmpipe (LLVM 5.0, 128 bits)
           version: 3.3 Mesa 17.2.8 Direct Render: Yes
Audio:     Card VIA VT8233/A/8235/8237 AC97 Audio Controller
           driver: snd_via82xx port: b400 bus-ID: 00:11.5
           Sound: Advanced Linux Sound Architecture v: k4.13.0-46-generic
Network:   Card: VIA VT6102/VT6103 [Rhine-II]
           driver: via-rhine port: b000 bus-ID: 00:12.0
           IF: enp0s18 state: unknown speed: 100 Mbps duplex: full
           mac: <filter>
Drives:    HDD Total Size: 1120.2GB (86.0% used)
           ID-1: /dev/sda model: ESA3SMD2HSLB120G size: 120.0GB
           ID-2: USB /dev/sdb model: M3_Portable size: 1000.2GB
Partition: ID-1: / size: 110G used: 6.0G (6%) fs: ext4 dev: /dev/sda1
Sensors:   System Temperatures: cpu: 32.0C mobo: 29.0C
           Fan Speeds (in rpm): cpu: 2960 psu: 0 sys-1: 0
Info:      Processes: 124 Uptime: 4 min Memory: 342.2/934.5MB
           Init: systemd runlevel: 5 Gcc sys: N/A
           Client: Shell (bash 4.4.121) inxi: 2.3.37
inxi -SMGxx
           Desktop: LXDE (Openbox 3.6.1) dm: lightdm Distro: Ubuntu 17.10
           bus-ID: 01:00.0 chip-ID: 1106:3108
           version: 3.3 Mesa 17.2.8 (compat-v: 3.0) Direct Render: Yes
OpenGL renderer string: llvmpipe (LLVM 5.0, 128 bits)
user@WS-LIN-03:~$ lspci | egrep 'VGA|3D|Display'
01:00.0 VGA compatible controller: VIA Technologies, Inc. K8M800/K8N800/K8N800A [S3 UniChrome Pro] (rev 01)
Ynt: Lubuntu - Ekranda donma ve takılma sorunu
« Yanıtla #1 : 27 Kasım 2018, 12:03:24 »
Öncelikle destek süresi biten bir sürümü kullandığınızı belirtelim. Desteği devam eden güncel bir sürümü kurduktan sonra, sorun devam ediyorsa bu konudan devam edelim.
Buradaki öneri uygulanabilir, pluma yerine sistemdeki metün düzenleyeciyi yazacaksınız.
  • İleti: 115
« Yanıtla #2 : 28 Kasım 2018, 10:28:50 »
Hocam güncellemeyi yaptım ve dediğiniz yerde ki komutu çalıştırdım.
           Desktop: LXDE (Openbox 3.6.1) Distro: Ubuntu 18.04.1 LTS
           flags: (lm nx pae sse sse2 sse3) bmips: 3199 speed: 1599 MHz (max)
           drivers: openchrome (unloaded: modesetting,fbdev,vesa)
           Resolution: 1600x900@60.00hz
           mac: <filter>
Drives:    HDD Total Size: 120.0GB (7.4% used)
Partition: ID-1: / size: 110G used: 8.3G (8%) fs: ext4 dev: /dev/sda1
Sensors:   System Temperatures: cpu: 28.0C mobo: 26.0C
           Fan Speeds (in rpm): cpu: 46551 psu: 0 sys-1: 0
Info:      Processes: 128 Uptime: 47 min Memory: 450.8/934.
Hafiten donamlar yine var. Bilgisayarı yeniden başlatında çok geç açılmaya başladı bu sefer.
systemd-analyze blame
         25.217s udisks2.service
          5.289s dev-sda1.device
          1.128s NetworkManager-wait-online.service
          1.110s ModemManager.service
          1.020s keyboard-setup.service
           949ms swapfile.swap
           822ms systemd-journald.service
           759ms accounts-daemon.service
           757ms systemd-udev-trigger.service
           599ms NetworkManager.service
           586ms avahi-daemon.service
           560ms grub-common.service
           515ms apparmor.service
           451ms wpa_supplicant.service
           447ms apport.service
           444ms systemd-logind.service
           396ms upower.service
           377ms systemd-modules-load.service
           374ms snapd.service
           355ms rsyslog.service
           346ms user@1000.service
           323ms lm-sensors.service
           265ms systemd-udevd.service
lines 1-23...skipping...
           949ms swapfile.swap
           949ms swapfile.swap
           374ms snapd.service
           257ms systemd-resolved.service
           255ms lightdm.service
           213ms snapd.seeded.service
           211ms gpu-manager.service
           163ms hddtemp.service
           137ms sys-kernel-debug.mount
           136ms dev-hugepages.mount
           135ms ufw.service
           133ms dev-mqueue.mount
           126ms systemd-user-sessions.service
           117ms kmod-static-nodes.service
           110ms polkit.service
           109ms systemd-sysctl.service
           107ms systemd-tmpfiles-setup.service
           105ms kerneloops.service
            98ms systemd-tmpfiles-setup-dev.service
            93ms systemd-tmpfiles-clean.service
            92ms systemd-timesyncd.service
            85ms systemd-remount-fs.service
            81ms pppd-dns.service
            70ms systemd-update-utmp.service
            67ms systemd-random-seed.service
            64ms systemd-journal-flush.service
            52ms plymouth-quit-wait.service
ilk sırada ki şey mi geç açılmasını sağlıyor anlayamadım.
cat /etc/fstab
# / was on /dev/sda1 during installation
UUID=73c51042-f87c-4cbb-965a-cd9ce03b6761 /               ext4    errors=remount-ro 0       1
/swapfile                                 none            swap    sw              0       0
/dev/fd0        /media/floppy0  auto    rw,user,noauto,exec,utf8 0       0
« Son Düzenleme: 28 Kasım 2018, 11:34:26 Gönderen: harkail_rad »
« Yanıtla #3 : 28 Kasım 2018, 13:26:45 »
[member=5305]harkail_rad[/member] , lütfen bu konuya sadece başlıktaki sorundan devam edelim, açılış sorunu için yeni bir konu açabilirsiniz. Açılış, Kapanış ve Oturum Açma
Güncelleme sonrası çekirdek sürümü 4.13'te kalmış, bunu da güncellemeyi dener misiniz? Ayrıca 4.13.x sürüm çekirdeğin destek süresi bittiiği için güvenlik riski oluşturabilir.
  • İleti: 115
« Yanıtla #4 : 29 Kasım 2018, 07:47:07 »
iki farklı başlıkta açmak gerek haklısın.
lubuntu yüklemekten vazgeçtim , xfce yükleyip gözlemleyeceğim.
Vakit ayırdığın için teşekkürler.
« Yanıtla #5 : 29 Kasım 2018, 13:09:25 »
Son düzenlemeden sonra openchrome sürücüsünün etkinleştiği görülüyor. Aslında bununla ilgili bir kaç değişken daha deneyebiliriz. Bence Lxde, Xfce'den daha hafif bir ortam olduğu için bu sisteme daha uygun olabilir.
xorg.conf dosyasını aşağıdaki şekilde düzenlemeyi deneyebilirsiniz.
        Identifier "Configured Video Device"
        Driver "openchrome"
        Option     "EnableAGPDMA"               "false"
        Option "AccelMethod" "XAA"
Section "Module"
        Load  "dri"
  • İleti: 115
« Yanıtla #6 : 29 Kasım 2018, 14:46:42 »
x.org dosyası nerede hocam.
xfce ağır geldi haklısınız. eskisine döneyim tekrardan.. b
çok uğraştırıyor :(
« Yanıtla #7 : 29 Kasım 2018, 17:14:32 »
Önceki mesajda dosyanın olutuşturulması ile ilgili bağlantı vermiştim. Dosya içeriğini en son verdiğim şekilde oluşturun.
        Driver "openchrome"
Section "Module"
        Load  "dri"
« Son Düzenleme: 29 Kasım 2018, 17:15:46 Gönderen: Butterfly »
