Gönderen Konu: Kurulum sonrası son kontrol ve wifi ağı yavaşlığı  (Okunma sayısı 2029 defa)
Çevrimdışı harkail_rad
  • İleti: 115
  • Dağıtım: linux mint
Arkadaşlar merhabalar,
Bir dizüstü bilgisayara 19.1 cinanmon kurulumu yaptım. Eksik bir şey görünüyor mu acaba?
Bir de wifi bağlantısında bir sorun var sanki. Yavaşlık gibi.
Anlayamadım.
System:
  Host: WS-LIN-25 Kernel: 4.15.0-43-generic x86_64 bits: 64 compiler: gcc
  v: 7.3.0 Desktop: Cinnamon 4.0.8 Distro: Linux Mint 19.1 Tessa
  base: Ubuntu 18.04 bionic
Machine:
  Type: Laptop System: Dell product: Inspiron 5379 v: N/A serial: <filter>
  Mobo: Dell model: 09NT72 v: A00 serial: <filter> UEFI: Dell v: 1.7.0
  date: 02/09/2018
Battery:
  ID-1: BAT0 charge: 39.9 Wh condition: 39.9/42.0 Wh (95%)
  model: SMP DELL Y3F7Y6B status: Full
CPU:
  Topology: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP
  arch: Kaby Lake rev: A L2 cache: 8192 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 31872
  Speed: 795 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 745 2: 744
  3: 796 4: 746 5: 744 6: 744 7: 702 8: 791
Graphics:
  Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
  bus ID: 00:02.0
  resolution: 1920x1080~60Hz
  OpenGL: renderer: Mesa DRI Intel UHD Graphics 620 (Kabylake GT2)
  v: 4.5 Mesa 18.0.5 direct render: Yes
Audio:
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell
  driver: snd_hda_intel v: kernel bus ID: 00:1f.3
  Sound Server: ALSA v: k4.15.0-43-generic
Network:
  Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
  vendor: Dell driver: ath10k_pci v: kernel port: f040 bus ID: 01:00.0
  IF: wlp1s0 state: up mac: <filter>
  Device-2: Atheros type: USB driver: btusb bus ID: 1-7:7
  IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Drives:
  Local Storage: total: 1.20 TiB used: 570.33 GiB (46.4%)
  ID-1: /dev/sda vendor: Toshiba model: KSG60ZMV256G M.2 2280 256GB
  ID-2: /dev/sdb type: USB vendor: Samsung model: M3 Portable
  ID-3: /dev/sdc type: USB vendor: SanDisk model: Cruzer Fit size: 59.62 GiB
Partition:
  ID-1: / size: 233.24 GiB used: 16.91 GiB (7.3%) fs: ext4 dev: /dev/sda2
Sensors:
  System Temperatures: cpu: 46.0 C mobo: 45.0 C sodimm: 38.0 C
  Fan Speeds (RPM): cpu: 3492
Info:
  Processes: 258 Uptime: 49m Memory: 7.54 GiB used: 2.35 GiB (31.2%)
  Init: systemd runlevel: 5 Compilers: gcc: 7.3.0 Shell: bash v: 4.4.19
  inxi: 3.0.27
Ynt: Kurulum sonrası son kontrol ve wifi ağı yavaşlığı
« Yanıtla #1 : 21 Aralık 2018, 23:05:50 »
Eğer tepki yavaşlığı ile ilgili sorun yaşarsanız, daha önceki konudaki gibi Intel GPU ile ilgili düzenlemeyi yaparsınız.
Forumda aynı başlıkta farklı sorunları konuşmadığımız için, kablosuz ağ sorunu ile ilgili yeni bir konu açmanızı rica edelim.
