Gönderen Konu: [Çözüldü] Sub-process /usr/bin/dpkg returned an error code (1) hatası  (Okunma sayısı 3226 defa)
Çevrimdışı mesut24
  • İleti: 60
  • Dağıtım: Linux Mint 19
  • Grafik Kartı: NVDİA
  • İşlemci: İNTEL
Merhaba sistemde böyle bir hata alıyorum ayrıca 4 adet bozuk paket uyarısı veriyor hiçbirşey kaldırıp yada yükleme yapamıyorum
erden@erdenler:~$ inxi -Sr
System:    Host: erdenler Kernel: 4.15.0-43-generic x86_64 bits: 64
           Desktop: Cinnamon 3.8.9  Distro: Linux Mint 19 Tara
Repos:     Active apt sources in file: /etc/apt/sources.list.d/freecad-maintainers-freecad-stable-bionic.list
           deb http://ppa.launchpad.net/freecad-maintainers/freecad-stable/ubuntu bionic main
           deb-src http://ppa.launchpad.net/freecad-maintainers/freecad-stable/ubuntu bionic main
           Active apt sources in file: /etc/apt/sources.list.d/js-reynaud-kicad-5-bionic.list
           deb http://ppa.launchpad.net/js-reynaud/kicad-5/ubuntu bionic main
           deb-src http://ppa.launchpad.net/js-reynaud/kicad-5/ubuntu bionic main
           deb http://packages.linuxmint.com tessa main upstream import backport #id:linuxmint_main
           deb http://archive.ubuntu.com/ubuntu bionic main restricted universe multiverse
           deb http://archive.ubuntu.com/ubuntu bionic-updates main restricted universe multiverse
           deb http://archive.ubuntu.com/ubuntu bionic-backports main restricted universe multiverse
           deb http://security.ubuntu.com/ubuntu/ bionic-security main restricted universe multiverse
           deb http://archive.canonical.com/ubuntu/ bionic partner
           Active apt sources in file: /etc/apt/sources.list.d/rvm-smplayer-bionic.list
           deb http://ppa.launchpad.net/rvm/smplayer/ubuntu bionic main
           deb-src http://ppa.launchpad.net/rvm/smplayer/ubuntu bionic main
           Active apt sources in file: /etc/apt/sources.list.d/webupd8team-java-bionic.list
           deb http://ppa.launchpad.net/webupd8team/java/ubuntu bionic main
           deb-src http://ppa.launchpad.net/webupd8team/java/ubuntu bionic main
erden@erdenler:~$ sudo apt-get update
[sudo] password for erden:
Get:1 http://security.ubuntu.com/ubuntu bionic-security InRelease [83,2 kB]
Hit:2 http://ppa.launchpad.net/freecad-maintainers/freecad-stable/ubuntu bionic InRelease
Hit:3 http://archive.ubuntu.com/ubuntu bionic InRelease
Get:4 http://archive.ubuntu.com/ubuntu bionic-updates InRelease [88,7 kB]
Hit:5 http://ppa.launchpad.net/js-reynaud/kicad-5/ubuntu bionic InRelease
Hit:6 http://archive.canonical.com/ubuntu bionic InRelease
Ign:7 http://packages.linuxmint.com tessa InRelease
Hit:8 http://ppa.launchpad.net/rvm/smplayer/ubuntu bionic InRelease
Get:9 http://archive.ubuntu.com/ubuntu bionic-backports InRelease [74,6 kB]
Hit:10 http://ppa.launchpad.net/webupd8team/java/ubuntu bionic InRelease
Hit:11 http://packages.linuxmint.com tessa Release
Fetched 247 kB in 1s (230 kB/s)
Reading package lists... Done
erden@erdenler:~$ sudo apt-get install -f
Building dependency tree
Correcting dependencies... Done
The following additional packages will be installed:
  file
The following NEW packages will be installed:
  file
0 upgraded, 1 newly installed, 0 to remove and 102 not upgraded.
1 not fully installed or removed.
Need to get 0 B/22,1 kB of archives.
After this operation, 81,9 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Setting up install-info (6.5.0.dfsg.1-2) ...
/usr/sbin/update-info-dir: 4: /etc/environment: source: not found
dpkg: error processing package install-info (--configure):
 installed install-info package post-installation script subprocess returned error exit status 127
 install-info
« Son Düzenleme: 02 Ocak 2019, 12:08:02 Gönderen: mesut24 »
Ynt: Sub-process /usr/bin/dpkg returned an error code (1) hatası
« Yanıtla #1 : 01 Ocak 2019, 23:04:24 »
Çıktısına bakalım.
cat /etc/environment
Çevrimdışı mesut24
  • İleti: 60
  • İşlemci: İNTEL
« Yanıtla #2 : 02 Ocak 2019, 00:48:44 »
erden@erdenler:~$ cat /etc/environment
PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games"
JAVA_HOME="/usr/lib/jvm/java-8-oracle"
source /etc/environment
echo $JAVA_HOME
« Yanıtla #3 : 02 Ocak 2019, 01:39:57 »
Konu açmadan önce, sistemde yaptığınız düzenlemeleri belirtmeye dikkat edelim.
/etc/environment dosyasındaki aşağıdaki satırları siliniz, bu satırlar ilgili dosyadaki değişkenleri yükleyip, ardından değişkeni kontrol amacıyla basmak için kullanılıyor olabilir. Bunları ilgili dosyaya eklemeye gerek yok.
echo $JAVA_HOME
Ardından aşağıdaki komutu çalıştırınız.
apt install -f
« Son Düzenleme: 02 Ocak 2019, 01:50:48 Gönderen: Butterfly »
Çevrimdışı mesut24
  • İleti: 60
  • İşlemci: İNTEL
« Yanıtla #4 : 02 Ocak 2019, 12:07:51 »
Teşekkür ederim sorunum çözüldü
