Gönderen Konu: [Çözüldü] Freecad Açılıp hemen kapanıyor  (Okunma sayısı 4481 defa)
Çevrimdışı mesut24
  • İleti: 60
  • Dağıtım: Linux Mint 19
  • Grafik Kartı: NVDİA
  • İşlemci: İNTEL
« : 11 Ocak 2019, 00:18:02 »
Merhaba.  Mint 19.1 sistemimde Freecad'in en son sürümü yüklü. Program açılır açılmaz kendiliğinden kapanıyor. Teşekkürler
erden@erdenler:~$ inxi -Fxxz
System:
  Host: erdenler Kernel: 4.15.0-43-generic x86_64 bits: 64 compiler: gcc
  v: 7.3.0 Desktop: Cinnamon 4.0.9 wm: muffin dm: LightDM
Machine:
  Type: Desktop Mobo: ASUSTeK model: Z77-A v: Rev X.0x serial: <filter>
  BIOS: American Megatrends v: 0402 date: 01/18/2013
CPU:
  Topology: Quad Core model: Intel Core i5-3330 bits: 64 type: MCP
  arch: Ivy Bridge rev: 9 L2 cache: 6144 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 24069
  Speed: 1605 MHz min/max: 1600/3200 MHz Core speeds (MHz): 1: 1605 2: 1605
  3: 1606 4: 1604
Graphics:
  Device-1: NVIDIA GK106 [GeForce GTX 660] vendor: ASUSTeK driver: nvidia
  v: 390.77 bus ID: 01:00.0 chip ID: 10de:11c0
  Display: x11 server: X.Org 1.19.6 driver: nvidia
  unloaded: fbdev,modesetting,nouveau,vesa resolution: 1920x1080~60Hz
  OpenGL: renderer: GeForce GTX 660/PCIe/SSE2 v: 4.6.0 NVIDIA 390.77
  direct render: Yes
Audio:
  Device-1: Intel 7 Series/C216 Family High Definition Audio
  vendor: ASUSTeK ASUS P8Z77-V LX driver: snd_hda_intel v: kernel
  bus ID: 00:1b.0 chip ID: 8086:1e20
  Device-2: NVIDIA GK106 HDMI Audio vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus ID: 01:00.1 chip ID: 10de:0e0b
  Sound Server: ALSA v: k4.15.0-43-generic
Network:
  vendor: ASUSTeK P8 series driver: r8169 v: 2.3LK-NAPI port: d000
  bus ID: 03:00.0 chip ID: 10ec:8168
  IF: enp3s0 state: down mac: <filter>
  Device-2: Realtek RTL8192CU 802.11n WLAN Adapter type: USB
  driver: rtl8192cu bus ID: 3-3:2 chip ID: 0bda:8178
  IF: wlx081076fa73ae state: up mac: <filter>
Drives:
  Local Storage: total: 1.36 TiB used: 196.43 GiB (14.1%)
  ID-1: /dev/sda vendor: Hitachi model: HTS543225L9A300 size: 232.89 GiB
  ID-2: /dev/sdb vendor: Seagate model: ST1000DM003-9YN162 size: 931.51 GiB
  ID-3: /dev/sdc vendor: Toshiba model: MK2561GSYN size: 232.89 GiB
Partition:
  ID-1: / size: 228.23 GiB used: 45.71 GiB (20.0%) fs: ext4 dev: /dev/sda1
Sensors:
  System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 35 C
  Fan Speeds (RPM): cpu: 0 gpu: nvidia fan: 10%
Info:
  Processes: 202 Uptime: 1h 26m Memory: 7.74 GiB used: 1.62 GiB (21.0%)
  Init: systemd v: 237 runlevel: 5 Compilers: gcc: 7.3.0 alt: 7 Shell: bash
  v: 4.4.19 running in: gnome-terminal inxi: 3.0.27
« Son Düzenleme: 12 Ocak 2019, 14:24:58 Gönderen: mesut24 »
Ynt: Freecad Açılıp hemen kapanıyor
« Yanıtla #1 : 11 Ocak 2019, 00:35:03 »
Sitesindeki AppImage biçimindeki dosyayı mı indirip kullandınız?
Çevrimdışı mesut24
  • İleti: 60
  • İşlemci: İNTEL
« Yanıtla #2 : 11 Ocak 2019, 00:49:54 »
Hayır depodan kurdum
sudo add-apt-repository ppa:freecad-maintainers/freecad-stable
sudo apt-get install freecad freecad-doc && sudo apt-get upgrade
« Son Düzenleme: 11 Ocak 2019, 00:51:37 Gönderen: mesut24 »
« Yanıtla #3 : 11 Ocak 2019, 01:30:04 »
PPA deposuna baktım, şu an yeni bir paket inşa ediliyordu. Paket hazırlandıktan sonra glen güncellemelere göre duruma bakarız.
Çevrimdışı mesut24
  • İleti: 60
  • İşlemci: İNTEL
« Yanıtla #4 : 11 Ocak 2019, 01:55:04 »
O zaman ben beklemede kalıyorum . Güncelleme gelince sorun büyük ihtimal hallolur. Teşekkürler ilginize
Bugün freecad güncellemesi geldi. Güncellemeyi yükledim ama sorun devam ediyor.
« Son Düzenleme: 11 Ocak 2019, 13:47:06 Gönderen: mesut24 »
« Yanıtla #5 : 11 Ocak 2019, 15:16:20 »
Uygulamayı aşağıdaki komutla başlatıp, uçbirimdeki çıktıları foruma aktarınız.
freecad
Çevrimdışı mesut24
  • İleti: 60
  • İşlemci: İNTEL
« Yanıtla #6 : 11 Ocak 2019, 21:52:24 »
erden@erdenler:~$ freecad
FreeCAD 0.17, Libs: 0.17R13541 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2018
A3 not available
(freecad:1793): Gtk-WARNING **: 21:51:19.227: Theme directory 2x22@2x/animations of theme Papirus-Light has no size field
freecad: SoType.cpp:739: SbBool SoType::isDerivedFrom(SoType) const: Assertion `!this->isBad()' failed.
Aborted (core dumped)
« Yanıtla #7 : 11 Ocak 2019, 23:11:18 »
Buradaki öneriyi deneyelim, sanırım python-pivy paketinin sürümü ile ilgili bir sorun varmış. Aşağıdaki komutlarla paketin sürümünü düşürüp kilitlemeyi uygulamayı deneyebilirsiniz.
apt install python-pivy=0.5.0~v609hg-4
apt hold python-pivy
Çevrimdışı egetun
  • İleti: 8
    • egetun
    • EGETUN.com
  • Masaüstü Ortamı: Xfce
  • Grafik Kartı: Nvidia GeForce GT 740M
  • İşlemci: Intel i5
« Yanıtla #8 : 12 Ocak 2019, 00:51:39 »
merhabalar.
sitesindeki appimage uzantısı ile sorunsuz bir biçimde çalıştı. eğer ihtiyacınız acil ise; muhtemelen bu şekilde de sizin bilgisayarınızda çalışacaktır.
Deniz Ege Tunçay
Çevrimdışı mesut24
  • İleti: 60
  • İşlemci: İNTEL
« Yanıtla #9 : 12 Ocak 2019, 14:24:40 »
Bugün gelen son freecad güncellemsinden sonra sorunsuz çalıştı. İlgilenenlere teşekkür ederim..
