Gönderen Konu: R5 M420 Adlandırma Ve Driver Sorunu  (Okunma sayısı 11098 defa)
Çevrimdışı emirhansenel
  • İleti: 13
  • Dağıtım: Ubuntu
  • Masaüstü Ortamı: Unity
  • Grafik Kartı: Amd R5 M420
  • İşlemci: Amd A9-9410 Apu
« : 24 Ocak 2019, 14:33:38 »
Öncelikle herkese selamlar. Benim gpu modelim r5 m420/hd8500m olmasına rağmen r5 m230/hd8550m olarak göstermekte. gpu benchmark yaptım, dahili ve harici gpu'ları test ettim ikisinde de sonuç aynı. yardımcı olursanız sevinirim.
işlemci a9-9410 apu
root[member=2866]emir[/member]-X555BP:/home/emir# inxi -SMGxx
System:
  Host: emir-X555BP Kernel: 4.18.0-13-generic x86_64 bits: 64 compiler: gcc
  v: 7.3.0 Desktop: Cinnamon 4.0.9 wm: muffin dm: LightDM
Machine:
  Type: Laptop System: ASUSTeK product: X555BP v: 1.0
  serial: H6N0CV00M15522D
  Mobo: ASUSTeK model: X555BP v: 1.0 serial: BSN12345678901234567
  UEFI: American Megatrends v: X555BP.322 date: 01/15/2018
Graphics:
  Device-1: AMD Stoney [Radeon R2/R3/R4/R5 Graphics] vendor: ASUSTeK
  driver: amdgpu v: kernel bus ID: 00:01.0 chip ID: 1002:98e4
  Device-2: AMD Sun LE [Radeon HD 8550M / R5 M230] vendor: ASUSTeK
  driver: amdgpu v: kernel bus ID: 01:00.0 chip ID: 1002:666f
  Display: x11 server: X.Org 1.19.6 driver: amdgpu,ati
  unloaded: fbdev,modesetting,radeon,vesa resolution: 1366x768~60Hz
  OpenGL: renderer: AMD STONEY (DRM 3.26.0 4.18.0-13-generic LLVM 7.0.1)
  v: 4.5 Mesa 19.0.0-devel (git-74c9c90 2019-01-24 bionic-oibaf-ppa)
  direct render: Yes
root[member=2866]emir[/member]-X555BP:/home/emir# glxinfo | grep render
OpenGL renderer string: AMD STONEY (DRM 3.26.0, 4.18.0-13-generic, LLVM 7.0.1)
    GL_NVX_gpu_memory_info, GL_NV_conditional_render, GL_NV_depth_clamp,
    GL_EXT_render_snorm, GL_EXT_robustness, GL_EXT_semaphore,
root[member=2866]emir[/member]-X555BP:/home/emir# lspci | egrep 'VGA|3D|Display'
00:01.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Stoney [Radeon R2/R3/R4/R5 Graphics] (rev c1)
01:00.0 Display controller: Advanced Micro Devices, Inc. [AMD/ATI] Sun LE [Radeon HD 8550M / R5 M230]
root[member=2866]emir[/member]-X555BP:/home/emir# xrandr
eDP connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
   1366x768      60.05*+
   1280x720      60.05
   1024x768      60.05
   800x600       60.05
   640x480       60.05
HDMI-A-0 disconnected (normal left inverted right x axis y axis)
root[member=2866]emir[/member]-X555BP:/home/emir# cat /etc/X11/xorg.conf
root[member=2866]emir[/member]-X555BP:/home/emir# dpkg -l | egrep 'nvidia|bumblebee|primus|prime|virtualgl|fglrx'
ii  nvidia-prime-applet                                         1.0.7                                       all          An applet for NVIDIA Prime
« Son Düzenleme: 24 Ocak 2019, 17:41:29 Gönderen: emirhansenel »
Ynt: R5 M420 Adlandırma Ve Driver Sorunu
« Yanıtla #1 : 24 Ocak 2019, 15:35:22 »
Test ettiğiniz uygulamaları ve benchmarkları DRI_PRIME=1 değişkeni ile başlatın. İkincil kartı kullanacaktır.
Ayrıca gördüğüm kadarıyla Mesa 19 kullanıyorsunuz. Geliştirme sürümü olduğu için regresyonlara açık olduğunu unutmayın.
Mesa 18.3 kullanmanız daha uygun olacaktır.
  • İleti: 13
  • Dağıtım: Ubuntu
« Yanıtla #2 : 24 Ocak 2019, 15:46:35 »
Verdiğiniz kodu zaten kullanmaktayım. fakat işe yaramıyor. performans hala düşük.
« Yanıtla #3 : 24 Ocak 2019, 16:09:25 »
Bu testleri yaparken işlemci hızınız ne alemde oluyor? Zira güncel Intel işlemcilerde bu gerekmemekle birlikte eski Intel işlemciler ve AMD işlemcilerin hepsinde cpu governor'u ondemand veya performance'a almanız gerekiyor.
https://wiki.archlinux.org/index.php/CPU_frequency_scaling#Scaling_governors
  • İleti: 13
  • Dağıtım: Ubuntu
« Yanıtla #4 : 24 Ocak 2019, 16:15:03 »
glmark2 ve unigine heaven ile sadece basit gpu testleri yaptım. cpu sıcaklığından haberim olmadı.
emir[member=2866]emir[/member]-X555BP:~$ DRI_PRIME=0 glmark2
    glmark2 2014.03+git20150611.fa71af2d
    OpenGL Information
    GL_VENDOR:     X.Org
    GL_RENDERER:   AMD STONEY (DRM 3.26.0, 4.18.0-13-generic, LLVM 7.0.1)
    GL_VERSION:    4.5 (Compatibility Profile) Mesa 19.0.0-devel (git-74c9c90 2019-01-24 bionic-oibaf-ppa)
[build] use-vbo=false: FPS: 918 FrameTime: 1.089 ms
                                  glmark2 Score: 918
emir[member=2866]emir[/member]-X555BP:~$ DRI_PRIME=1 glmark2
    OpenGL Information
    GL_VENDOR:     X.Org
    GL_RENDERER:   AMD Radeon HD 8500M (HAINAN, DRM 3.26.0, 4.18.0-13-generic, LLVM 7.0.1)
[build] use-vbo=false: FPS: 449 FrameTime: 2.227 ms
                                  glmark2 Score: 449
glmark2'de harici gpu'yu çalıştırdığımda 8500m olarak gösteriyor. fakat fps ve frametime, dahili gpu'dan daha düşük.
bu arada cpu profilini ondemand olarak ayarladım.
« Son Düzenleme: 24 Ocak 2019, 16:31:23 Gönderen: emirhansenel »
« Yanıtla #5 : 24 Ocak 2019, 16:40:50 »
İlginç bir sorun. Normalde dediğiniz gibi HD8850 daha güçlü.
Acaba RadeonSI üstünde sonuç ne alemde , zira AMDGPU'yu manuel olarak aktive ettiniz sanırım.
  • İleti: 13
  • Dağıtım: Ubuntu
« Yanıtla #6 : 24 Ocak 2019, 16:45:59 »
Forumda bulunan adımları takip ederek aktif etmiştim. Deneyebileceğim bir şeyler yok mu ?
Unigine heaven sonuçları
dahili:
harici:
bu testte harici gpu da 2-3 fpslik bir artış var fakat yeterli bir sonuç değil. hala bir sorun var.
Yardım edebilecek birisi var mı ?
« Son Düzenleme: 24 Ocak 2019, 18:07:19 Gönderen: emirhansenel »
« Yanıtla #7 : 24 Ocak 2019, 18:32:19 »
Bu tür gerekli olmayan mesajlardan kaçınalım lütfen. Hepimiz gönüllü olarak destek veriyoruz, 7/24 forumda olmamız mümkün olmuyor maalesef.
Aşağıdaki komutla Radeon Profile uygulamasını kurup, güç yönetimi ve performans ile ilgili ince ayarları yapmayı deneyebilirsiniz.
sudo add-apt-repository ppa:trebelnik-stefina/radeon-profile
sudo apr install radeon-profile
  • İleti: 13
  • Dağıtım: Ubuntu
« Yanıtla #8 : 24 Ocak 2019, 19:08:08 »
Kusura bakmayın özür dilerim. Şuan ubuntu'ya geçtim. Sorun devam ederse deneyeceğim.
Sorun hala devam etmekte...
« Son Düzenleme: 24 Ocak 2019, 22:18:42 Gönderen: emirhansenel »
« Yanıtla #9 : 25 Ocak 2019, 21:06:31 »
Bu dönüş ne yaptığınız ile ilgili herhangi bir somut veri içermiyor. Geri dönüşlerde ayrıntılı bilgi paylaşınız.
  • İleti: 13
  • Dağıtım: Ubuntu
« Yanıtla #10 : 25 Ocak 2019, 23:09:18 »
emir[member=2866]emir[/member]-X555BP:~/Masaüstü/GpuTest_Linux_x64_0.7.0$ inxi -Gxx
Graphics:  Card-1: Advanced Micro Devices [AMD/ATI] Stoney [Radeon R2/R3/R4/R5 Graphics]
           bus-ID: 00:01.0 chip-ID: 1002:98e4
           Card-2: Advanced Micro Devices [AMD/ATI] Sun LE [Radeon HD 8550M / R5 M230]
           bus-ID: 01:00.0 chip-ID: 1002:666f
           Display Server: x11 (X.Org 1.19.6 ) drivers: amdgpu,radeon
           Resolution: 1366x768@60.05hz
           OpenGL: renderer: AMD STONEY (DRM 3.23.0, 4.15.0-44-generic, LLVM 8.0.0)
           version: 4.5 Mesa 19.0.0-devel - padoka PPA Direct Render: Yes
« Yanıtla #11 : 25 Ocak 2019, 23:36:27 »
Bu ayrıntılı bir dönüş değil. Şu an hangi dağıtımdasınız? Güç yönetimi ile ilgili ne yaptınız? Bu tür bilgileri geri dönüşler ayrıntılı olarak paylaşınız. Bunları siz paylaşmadan bilmemize imkan yok. Daha fazla ayrıntı, daha fazla olasılığı elemek anlamına gelebilir.
Ayrıca bu hususu dikkate alınız.
« Son Düzenleme: 26 Ocak 2019, 00:35:53 Gönderen: Butterfly »
  • İleti: 13
  • Dağıtım: Ubuntu
« Yanıtla #12 : 26 Ocak 2019, 19:22:45 »
18.3 sürümünü yüklememe yardımcı olur musunuz ? büyük ihtimal dediğiniz gibi bundan kaynaklanmakta.
« Yanıtla #13 : 26 Ocak 2019, 20:49:17 »
Aşağıdaki komutlarla eklediğiniz PPA deposunu kaldırıp paket sürümlerini düşürmeyi deneyiniz.
sudo apt install ppa-purge
sudo ppa-purge -d bionic ppa:paulo-miguel-dias/mesa
Ardından aşağıdaki komutlarla 18.3 sürümün bulunduğu kararlı PPA deposunu ekleyip sistemi güncellemeyi deneyebilirsiniz.
sudo add-apt-repository ppa:paulo-miguel-dias/pkppa
Önceki mesajda altını çizdiğim bilgiler için geri dönüş yapmamışsınız.
  • İleti: 13
  • Dağıtım: Ubuntu
« Yanıtla #14 : 27 Ocak 2019, 17:32:58 »
Şuan Ubuntu 18 kullanmaktayım. mesa sürümünü 18.3 yaptım bir fark olmadı. Bu arada bir şey farkettim. m420 ve m230'un device id'si aynı 666f.
[/b][/i][/u]
emir[member=2866]emir[/member]-X555BP:~$ inxi -SMGxx
System:    Host: emir-X555BP Kernel: 4.15.0-44-generic x86_64
           bits: 64 gcc: 7.3.0
           Desktop: Gnome 3.28.3 (Gtk 3.22.30-1ubuntu1) dm: gdm3
           Distro: Ubuntu 18.04.1 LTS
Machine:   Device: laptop System: ASUSTeK product: X555BP v: 1.0 serial: N/A
           Mobo: ASUSTeK model: X555BP v: 1.0 serial: N/A
           OpenGL: renderer: AMD STONEY (DRM 3.23.0, 4.15.0-44-generic, LLVM 7.0.0)
           version: 4.5 Mesa 18.3.1 - padoka PPA Direct Render: Yes
emir[member=2866]emir[/member]-X555BP:~$ glxinfo | grep render
OpenGL renderer string: AMD STONEY (DRM 3.23.0, 4.15.0-44-generic, LLVM 7.0.0)
emir[member=2866]emir[/member]-X555BP:~$ lspci | egrep 'VGA|3D|Display'
01:00.0 Display controller: Advanced Micro Devices, Inc. [AMD/ATI] Sun LE [Radeon HD 8550M / R5 M230] (rev ff)
emir[member=2866]emir[/member]-X555BP:~$ xrandr
   1366x768      60.05*+
   1280x720      60.05
   1024x768      60.05
   800x600       60.05
   640x480       60.05
emir[member=2866]emir[/member]-X555BP:~$ cat /etc/X11/xorg.conf
emir[member=2866]emir[/member]-X555BP:~$ sudo dpkg -l | egrep 'nvidia|bumblebee|primus|prime|virtualgl|fglrx'
« Son Düzenleme: 27 Ocak 2019, 18:22:44 Gönderen: emirhansenel »
