Gönderen Konu: Mint 19.1 Cinnomon GT 240 M Ekran kartında Donma Sorunu  (Okunma sayısı 7001 defa)
Çevrimdışı tolstoy
  • İleti: 38
  • Dağıtım: Linux Mint 17.2 Rafaela
  • Masaüstü Ortamı: Kde
  • Grafik Kartı: Nvidia GEFORCE GT 240M CUDA 1GB
  • İşlemci: İntel Core 2 Due Processor T9600
Hayırlı Akşamlar
Nvidia 340 kurulumundan sonra kısa süre içinde ekran donma oluyor. Driver 'ı eksik mi kuruyorum. Sorunu çözme konusun da yardımlarınızı rica ediyorum.
Saygılar
Mevcut  Ayrıntılar;
  inxi -SMGxx
System:
  Host: cengiz-EasyNote-TJ65 Kernel: 4.18.0-15-generic x86_64 bits: 64
  compiler: gcc v: 7.3.0 Desktop: Cinnamon 4.0.9 wm: muffin dm: LightDM
Machine:
  Type: Laptop System: Packard Bell product: EasyNote TJ65 v: 0100
  serial: <root required> Chassis: type: 10 serial: <root required>
  Mobo: Packard Bell model: SJV50MV v: Rev serial: <root required>
  BIOS: Phoenix v: 1.27 date: 09/28/2009
Graphics:
  Device-1: NVIDIA GT216M [GeForce GT 240M] vendor: Acer Incorporated ALI
  driver: nvidia v: 340.107 bus ID: 01:00.0 chip ID: 10de:0a34
  Display: x11 server: X.Org 1.19.6 driver: nvidia
  unloaded: fbdev,modesetting,nouveau,vesa resolution: 1366x768~60Hz
  OpenGL: renderer: GeForce GT 240M/PCIe/SSE2 v: 3.3.0 NVIDIA 340.107
  direct render: Yes
OpenGL renderer string: GeForce GT 240M/PCIe/SSE2
    GL_NV_ES1_1_compatibility, GL_NV_blend_square, GL_NV_conditional_render,
01:00.0 VGA compatible controller: NVIDIA Corporation GT216M [GeForce GT 240M] (rev a2)
Screen 0: minimum 8 x 8, current 1366 x 768, maximum 8192 x 8192
LVDS-0 connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
   1366x768      60.00*+
rc  bumblebee                                     3.2.1+git20181231-102~bionicppa1       amd64        NVIDIA Optimus support for Linux
rc  bumblebee-nvidia                              3.2.1+git20181231-102~bionicppa1       amd64        NVIDIA Optimus support using the proprietary NVIDIA driver
ic  libnvidia-compute-390:amd64                   390.87-0ubuntu0~gpu18.04.1             amd64        NVIDIA libcompute package
ii  nvidia-340                                    340.107-0ubuntu0.18.04.1               amd64        NVIDIA binary driver - version 340.107
ii  nvidia-common                                 1:0.5.2.2                              amd64        transitional package for ubuntu-drivers-common
ii  nvidia-opencl-icd-340                         340.107-0ubuntu0.18.04.1               amd64        NVIDIA OpenCL ICD
ii  nvidia-settings                               415.27-0ubuntu0~gpu18.04.1             amd64        Tool for configuring the NVIDIA graphics driver
ii  primus-libs:amd64                             0~20150328-6                           amd64        Shared libraries for primus
  dpkg -l | grep intel
ii  intel-microcode                               3.20180807a.0ubuntu0.18.04.1           amd64        Processor microcode firmware for Intel CPUs
ii  libdrm-intel1:amd64                           2.4.95-1~18.04.1                       amd64        Userspace interface to intel-specific kernel DRM services -- runtime
ii  xserver-xorg-video-intel                      2:2.99.917+git20171229-1               amd64        X.Org X server -- Intel i8xx, i9xx display driver
  sudo dpkg -l | grep nvidia
  nvidia-smi
Wed Feb 13 23:49:33 2019
| NVIDIA-SMI 340.107    Driver Version: 340.107        |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|   0  GeForce GT 240M     Off  | 0000:01:00.0     N/A |                  N/A |
| N/A   38C    P8    N/A /  N/A |    198MiB /  1023MiB |     N/A      Default |
| Compute processes:                                               GPU Memory |
|  GPU       PID  Process name                                     Usage      |
|    0            Not Supported                                               |
Ynt: Mint 19.1 Cinnomon GT 240 M Ekran kartında Donma Sorunu
« Yanıtla #1 : 14 Şubat 2019, 00:33:35 »
Size de iyi akşamlar.
Öncelikle aşağıdaki komutla sizin sistemle ilgili olmayan paketleri ve yapılandırmalarını kaldırın.
sudo apt purge bumblebee bumblebee-nvidia libnvidia-compute-390 primus-libs
Ardından aşağıdaki komutu uçbirimde çalıştırıp, sistemi yeniden başlatmayı deneyin.
sudo nvidia-xconfig
Yukarıdaki komut xorg.conf yapılandırma dosyası oluşturarak bu sorunu çözebilir. Buna ek olarak aşağıdaki şekilde Nvidia GPU ile Cinnamon performansını artırmayı deneyebilirsiniz.
Nvidia Ayar Yöneticisini açın ve X Server Display Configuration sekmesine gelerek aşağıdaki seçenekleri işaretleyin ve Save to X configuration file düğmesine tıklayarak ayarları kaydedin.
Force Composition Pipeline
Force Full Composition Pipeline
Ardından, Cinnamon Sistam Ayarları => Genel seçeneğini açıp; VBlank Etkin seçeneğini pasifleştirin ve sistemi Nvidia Ayarlarının da etkin olması için yeniden başlatın. Ya da CTRL+ALT+ESC tuş kombinasyonu ile X sunucusunu yeniden başlatın.
Not: Bu ayarlar sisteminde hibrit GPU olmayan sistemler içindir.
« Son Düzenleme: 14 Şubat 2019, 00:45:27 Gönderen: Butterfly »
Çevrimdışı tolstoy
  • İleti: 38
« Yanıtla #2 : 14 Şubat 2019, 11:30:41 »
Merhaba
xorg.conf yapılandırması ve belirtilen ayarlar neticesinde ,maalesef donma sorunu devam ediyor.
Efendim kısa bir not eklemek istedim.Normalleşmeye döndü gibi.
Nvidia-340 driveri kaldırıp tekrar yükledim.Belirttiğiniz yapılandırma neticesinde  nvidia setings 415 driverin Nvidia settings-390 olarak değişmiş,
cat /etc/X11/xorg.conf dosyasına kaydetmiş.Ekran donması durmuş gibi,henüz belirtmek erken gibi.Verileri paylaşmak istedim.
İlk çıkan veri;   version 415.27
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings:  version 415.27
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 340.107  (buildmeister@swio-display-x64-rhel04-13)  Thu May 24 22:29:58 PDT 2018
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
    Option         "Xinerama" "0"
Section "Files"
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Identifier     "Keyboard0"
    Driver         "kbd"
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Seiko/Epson"
    HorizSync       30.0 - 75.0
    VertRefresh     59.0
    Option         "DPMS"
    Identifier     "Device0"
    Driver         "nvidia"
    BoardName      "GeForce GT 240M"
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "nvidiaXineramaInfoOrder" "DFP-0"
    Option         "metamodes" "nvidia-auto-select +0+0"
    Option         "SLI" "Off"
    Option         "MultiGPU" "Off"
    Option         "BaseMosaic" "off"
    SubSection     "Display"
        Depth       24
    EndSubSection
İkinci veri (Driver yeniden yüklenmesi)  version 390.77
# nvidia-settings:  version 390.77  (buildd@lcy01-amd64-022)  Thu Sep  6 07:51:39 UTC 2018
Section "Files"
    Identifier     "Mouse0"
    Driver         "mouse"
    Driver         "kbd"
Section "Monitor"
    VertRefresh     59.0
    Option         "DPMS"
    Driver         "nvidia"
Section "Screen"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "SLI" "Off"
        Depth       24
    EndSubSection
« Son Düzenleme: 14 Şubat 2019, 12:57:18 Gönderen: tolstoy »
« Yanıtla #3 : 14 Şubat 2019, 17:26:04 »
Nvidia PPA deposunu sisteme eklediğiniz için, nvidia-settings paketinin güncel sürümümü PPA deposundan kurulmuştur. Bizim yaptığımız işlemle bu ür bir değişiklik yapmaya imkan yok. Ama Nvidia-340 sürücüsünün güncel sürümü resmi depoda olduğu için, PPS deposundaki sürümü kurmamışsınızdır. Nvidia-settings paketinin güncel sürümünün sorunu çözmeye etki etmesi olasılığı görece olarak düşük. Sorun çözüldüyse belki belirtmeyi gözardı ettiğiniz bir sebepten dolayı olabilir.
Çevrimdışı tolstoy
  • İleti: 38
« Yanıtla #4 : 14 Şubat 2019, 19:07:11 »
Merhaba
Haklısınız ,Karar vermede biraz erken oldu.Ekran donması devam ediyor.Cihaz kapatıp açtığımızda bu kez fallback kipinde açılıyor.Yeniden başlattğımda sistem normal açılıyor.Fakat bir süre sonra tekrar donma oluyor.Ancak sistemi kapatarak olumsuzluğu giderme durumunda kalıyorum.
Bu arada konsoldan
sudo apt install nvidia-340 nvidia-settings nvidia-prime nvidia-common
yükledim.
Desteğinize teşekkür ederim.
« Yanıtla #5 : 14 Şubat 2019, 20:00:00 »
Komutların çıktısına bakalım. nvidia-prime paketini kurmanıza gerek yok, bu paket hibrit GPU'lu sistemler için.
dpkg -l | egrep "nvidia|linux-headers"
apt policy nvidia-340 nvidia-settings
inxi -Gxx
dkms status
« Son Düzenleme: 14 Şubat 2019, 20:02:14 Gönderen: Butterfly »
Çevrimdışı tolstoy
  • İleti: 38
« Yanıtla #6 : 14 Şubat 2019, 22:55:13 »
İyi akşamlar,
nvidia-prime paketini kaldırdım.
Mevcut veriler;
ii  linux-headers-4.18.0-15                       4.18.0-15.16~18.04.1                   all          Header files related to Linux kernel version 4.18.0
ii  linux-headers-4.18.0-15-generic               4.18.0-15.16~18.04.1                   amd64        Linux kernel headers for version 4.18.0 on 64 bit x86 SMP
ii  linux-headers-generic-hwe-18.04               4.18.0.15.65                           amd64        Generic Linux kernel headers
rc  nvidia-prime                                  0.8.8.2                                all          Tools to enable NVIDIA's Prime
ii  nvidia-settings                               390.77-0ubuntu0.18.04.1                amd64        Tool for configuring the NVIDIA graphics driver
nvidia-340:
  Kurulu: 340.107-0ubuntu0.18.04.1
  Aday:   340.107-0ubuntu0.18.04.1
  Sürüm çizelgesi:
 *** 340.107-0ubuntu0.18.04.1 500
        500 http://archive.ubuntu.com/ubuntu bionic-updates/restricted amd64 Packages
        100 /var/lib/dpkg/status
     340.106-0ubuntu3 500
        500 http://archive.ubuntu.com/ubuntu bionic/restricted amd64 Packages
nvidia-settings:
  Kurulu: 390.77-0ubuntu0.18.04.1
  Aday:   390.77-0ubuntu0.18.04.1
  Sürüm çizelgesi:
 *** 390.77-0ubuntu0.18.04.1 500
        500 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 Packages
     390.42-0ubuntu1 500
        500 http://archive.ubuntu.com/ubuntu bionic/main amd64 Packages
inxi -Gxx
Graphics:
  Display: x11 server: X.Org 1.19.6 driver: nvidia resolution: 1366x768~60Hz
  direct render: Yes
  dkms status
nvidia-340, 340.107, 4.18.0-15-generic, x86_64: installed
« Yanıtla #7 : 15 Şubat 2019, 00:05:24 »
Sorun çekirdeğin 4.18.x serisinden kaynaklanıyor olabilir. Aşağıdaki komutla çekirdeğin 4.15.x serisini kurup,
sudo apt install linux-generic
ardından aşağıdaki komutla Nvidia sürücüsünü bu çekirdek için kurmayı deneyiniz.
sudo dkms install nvidia-340/340.107 -k 4.15.0-45-generic
Sonrasında sistemi 4.15.x çekirdek sürümü ile açıp, durumu gözlemleyiniz.
Çevrimdışı tolstoy
  • İleti: 38
« Yanıtla #8 : 15 Şubat 2019, 11:36:57 »
İyi günler,
Uygulamaları tamamlayıp sistemi başlattıktan sonra fallback kipinde açılıyor.Maalesef
normale dönmedi.
« Yanıtla #9 : 15 Şubat 2019, 14:13:58 »
Bu sorunu çekirdeğin 4.15.x sürümü ile mi yaşadınız? Eğer öyleyse, sorun sürücünün ilgili çekirdek için yüklenmemesinden kaynaklanıyordur. Çekirdek 4.15.x ile .ıktılara bakalım.
inxi -SGxx
dkms status
Xorg'un 1.20 sürümü (buna uygun Nvidia-340 sürümü ile birlikte) depoya girmiş bu arada. Aşağıdaki komutla Xorg sürümünü de güncellemek gerekebilir. Nvidia-340 sürücüsünü güncellemeyi de atlamayınız.
sudo apt-get install --install-recommends xserver-xorg-hwe-18.04
« Son Düzenleme: 15 Şubat 2019, 14:31:05 Gönderen: Butterfly »
Çevrimdışı tolstoy
  • İleti: 38
« Yanıtla #10 : 15 Şubat 2019, 15:59:09 »
Merhaba
Açıkçası 4.15 çekirdeğin kurulmasıyle 4.18 çekirdeğini kaldıracağını düşünmüştüm.
ikisi de kurulu.
inxi -SGxx
System:
  compiler: gcc v: 7.3.0 Desktop: Cinnamon 4.0.9 wm: Metacity dm: LightDM
Graphics:
  Display: x11 server: X.Org 1.19.6 driver: fbdev,modesetting,nouveau
  unloaded: vesa alternate: nvidia resolution: 640x480~73Hz
  OpenGL: renderer: N/A v: N/A direct render: N/A
dkms status
nvidia-340, 340.107, 4.15.0-45-generic, x86_64: installed
E: xserver-xorg-hwe-18.04 paketi bulunamadı
E: 'xserver-xorg-hwe-18.04' ifadesine eşleşen herhangi bir paket bulunamadı
E: 'xserver-xorg-hwe-18.04' düzenli ifadesini içeren herhangi bir paket bulunamadı
« Yanıtla #11 : 15 Şubat 2019, 16:03:21 »
Xorg güncellemesini apt önbelleğini aşağıdaki güncellemelisiniz, ardından Xorg sürümü ile ilgili paketleri kurabilirsiniz..
apt update
Sistemi çekirdeğin 4.15.x sürümü ile açmayı dener misiniz? Şu an 4.15.x çekirdek kurulu ve Nvidia sürücüsü 4.15.x için yüklenmiş görünüyor.
Çevrimdışı tolstoy
  • İleti: 38
« Yanıtla #12 : 15 Şubat 2019, 17:19:18 »
Sistemi 4.15 ile açamadım.Tekrar 4.18 ile açıldı. Xorg güncellemesini updateyle yaptım.Fakat xorg paketlerinin hangilerinin yüklenmesi doğru olur.
Xorg sürümü ile ilgili paket yüklemesinde sıkıntı olabilir.Hangisinin 340 versiyonunu destek verir bilmiyorum.mevcut görünenlerin hespsini yüklesem muhtemelen yanlışım olabilir.
« Yanıtla #13 : 15 Şubat 2019, 17:48:29 »
Grub menüsü => gelişmiş seçenekler altından, çekirdeğin 4.15.x serisini seçerek açmayı denediniz mi?
Xorg güncellemesile ilgili komut gerekli tüm paketleri yükseltecek ve eski paketleri kaldıracaktır, ek bir işlem yapmanıza gerek yok.
Nvidia-340 sürücüsünün, Xorg 1.20 ile uyumlu hale getirilmiş sürümünün depoya eklendiğini söylemiştim. Bunu kurduysanız, güncel Xorg sürümü ile sorun yaşamazsınız.
Çevrimdışı tolstoy
  • İleti: 38
« Yanıtla #14 : 18 Şubat 2019, 14:57:15 »
İyi günler
Muhteşem oldu.Tamamdır.
Sistemi temiz yüklemeden sonra,belirttiğiniz uygulamayı yaptım.Setting ayarları üzerinde önceden üzerinde pek fazla durmadım.En büyük etkinin
yeri burası .
sudo nvidia-xconfig
İlginize,Desteğinize teşekkür ederim.
Saygılar
