Gönderen Konu: [Çözüldü] Lenovo ideapad 520-15IKB - Nvidia GPU Sürücü Yükleme Sorunu  (Okunma sayısı 2796 defa)
Çevrimdışı onurm
  • İleti: 16
Dün cinnamon çöktü. Bu gün tekrar yükledim. Nvidia ekran kartını aktif edemiyorum. İstenilen çıktılar aşağıda.
inxi -SMGxx
System:    Host: yaw-Lenovo-ideapad-520-15IKB Kernel: 4.15.0-20-generic x86_64
           bits: 64 gcc: 7.3.0
           Desktop: Cinnamon 3.8.9 (Gtk 3.22.30-1ubuntu3) dm: lightdm
           Distro: Linux Mint 19 Tara
Machine:   Device: laptop System: LENOVO product: 81BF v: Lenovo ideapad 520-15IKB serial: N/A
           Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: N/A
           UEFI [Legacy]: LENOVO v: 6JCN23WW date: 01/23/2018
           Chassis: type: 10 v: Lenovo ideapad 520-15IKB serial: N/A
Graphics:  Card: Intel UHD Graphics 620 bus-ID: 00:02.0 chip-ID: 8086:5917
           drivers: modesetting (unloaded: fbdev,vesa)
           Resolution: 1920x1080@60.03hz
           OpenGL: renderer: Mesa DRI Intel UHD Graphics 620 (Kabylake GT2)
           version: 4.5 Mesa 19.0.2 (compat-v: 3.0) Direct Render: Yes
OpenGL renderer string: Mesa DRI Intel(R) UHD Graphics 620 (Kabylake GT2)
    GL_NV_conditional_render, GL_NV_depth_clamp,
    GL_EXT_render_snorm, GL_EXT_robustness, GL_EXT_sRGB_write_control,
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics 620 (rev 07)
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 8192 x 8192
eDP-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
   1920x1080     60.03*+  60.01    59.97    59.96    59.93
   1680x1050     59.95    59.88
   1600x1024     60.17
   1400x1050     59.98
   1280x1024     60.02
   1440x900      59.89
   1400x900      59.96    59.88
   1280x960      60.00
   1440x810      60.00    59.97
   1368x768      59.88    59.85
   1360x768      59.80    59.96
   1152x864      60.00
   1024x768      60.04    60.00
   960x720       60.00
   928x696       60.05
   896x672       60.01
   960x600       59.93    60.00
   840x525       60.01    59.88
   864x486       59.92    59.57
   800x512       60.17
   700x525       59.98
   800x450       59.95    59.82
   640x512       60.02
   720x450       59.89
   700x450       59.96    59.88
   640x480       60.00    59.94
   720x405       59.51    58.99
   684x384       59.88    59.85
   680x384       59.80    59.96
   640x400       59.88    59.98
   576x432       60.06
   512x384       60.00
   512x288       60.00    59.92
   480x270       59.63    59.82
   400x300       60.32    56.34
   432x243       59.92    59.57
   320x240       60.05
   360x202       59.51    59.13
   320x180       59.84    59.32
ii  libdrm-amdgpu1:amd64                       2.4.97-1ubuntu1~18.04.1             amd64        Userspace interface to amdgpu-specific kernel DRM services -- runtime
ii  nvidia-prime-applet                        1.0.7                               all          An applet for NVIDIA Prime
ii  xserver-xorg-video-amdgpu                  18.0.1-1                            amd64        X.Org X server -- AMDGPU display driver
dkms status
boş
Düzenleme: Konu başlığı
« Son Düzenleme: 05 Temmuz 2019, 20:51:53 Gönderen: onurm »
Ynt: Ekran kartı ayarları
« Yanıtla #1 : 05 Temmuz 2019, 18:56:46 »
Lütfen açtığınız konularda aşağıdaki hususlara özen gösteriniz, örneğin konu başlığını daha belirleyici yapınız.
Sisteminizde Nvidia GPU olmadığı için etkinleştirememiş olmanız ve buna rağmen Nvidia GPU sürücüsü kurduğunuzda çökme yaşanması normal.
Çevrimdışı onurm
  • İleti: 16
« Yanıtla #2 : 05 Temmuz 2019, 18:58:08 »
Ekran kartı yanmış olabilir mi? Normal de var.
« Yanıtla #3 : 05 Temmuz 2019, 19:01:01 »
Bu hususla ilgili bir şey söyleme imkanımız yok. Teknik servisten destek alabilirsiniz. Ya da BIOS/EFI ayarlarında harici GPU'yu pasifleştirme ile ilgili bir seçenek varsa, bunu değiştirmeyi deneyebilirsiniz.
Şu an ki çıktılara göre Nvidia GPU görünmüyor.
Çevrimdışı onurm
  • İleti: 16
Ynt: Lenovo ideapad 520-15IKB - Nvidia GPU Sürücü Yükleme Sorunu
« Yanıtla #4 : 05 Temmuz 2019, 19:14:06 »
Biostan kapatmışım dün. Kafam çok karışıktı. Tekrar paylaşıyorum.
inxi -SMGxx
System:    Host: yaw-Lenovo-ideapad-520-15IKB Kernel: 4.15.0-54-generic x86_64
           bits: 64 gcc: 7.4.0
Graphics:  Card-1: Intel UHD Graphics 620 bus-ID: 00:02.0 chip-ID: 8086:5917
           Card-2: NVIDIA GP108M [GeForce MX150]
           bus-ID: 01:00.0 chip-ID: 10de:1d10
           drivers: modesetting,nouveau (unloaded: fbdev,vesa)
01:00.0 3D controller: NVIDIA Corporation GP108M [GeForce MX150] (rev a1)
   1600x1024     60.17
   1400x1050     59.98
   1280x1024     60.02
   1440x900      59.89
   1280x960      60.00
   1152x864      60.00
   960x720       60.00
   928x696       60.05
   896x672       60.01
   960x600       59.93    60.00
   840x525       60.01    59.88
   864x486       59.92    59.57
   800x512       60.17
   700x525       59.98
   800x450       59.95    59.82
   640x512       60.02
   720x450       59.89
   700x450       59.96    59.88
   640x480       60.00    59.94
   720x405       59.51    58.99
   684x384       59.88    59.85
   680x384       59.80    59.96
   640x400       59.88    59.98
   576x432       60.06
   512x384       60.00
   512x288       60.00    59.92
   480x270       59.63    59.82
   400x300       60.32    56.34
   432x243       59.92    59.57
   320x240       60.05
   360x202       59.51    59.13
   320x180       59.84    59.32
dkms status
boş
Bir sitedeki kodu girince 430'u öneriyordu. Belki 430 oluyordu, yanlış yaptım. Nvidia'nın kendi sitesinde de 430 u öneriyor. 430'u kurmayı çalışıyordum hep. Bumblebee yi kurabildim. mx150 yi sürücülerde aratırsanız nvidia nın sitesinde görebilirsiniz.
« Son Düzenleme: 05 Temmuz 2019, 20:51:24 Gönderen: onurm »
Sistemde Intel+Nvidia hibrit GPU varsa, sitesindeki sürücüyü indirip elle kurmayı önermiyoruz. Yapılması gereken Sürücü Yöneticisi ile önerilen sürücüyü kurmak olacaktır. Güncel sürücüler için Nvidia PPA deposu eklenebilir, forumda bununla ilgili konular mevcut.
