Gönderen Konu: [Çözüldü] Elementary OS Donma Problemi  (Okunma sayısı 2646 defa)
Çevrimdışı frkntlgyc
  • İleti: 33
    • furkantolgayuce
    • furkantolgayuce
  • Masaüstü Ortamı: Xfce
  • Grafik Kartı: İntel
« : 08 Temmuz 2019, 18:54:45 »
Kullandığım sistem ElementaryOS Juno sistemde bir kaç program açınca donmalar takılmalar başladı. Hatta kilitleniyor. Aşağıda çeşitli çıktılar mevcut sorun neden kaynaklanıyor olabilir?
inxi -Fxxz
System:    Host: tolga-eos Kernel: 4.15.0-54-generic x86_64 bits: 64 gcc: 7.4.0
           Desktop: Gnome  (Gtk 3.22.30-1ubuntu3) dm: lightdm Distro: elementary OS 5.0 Juno
Machine:   Device: laptop System: LENOVO product: 20HNS0AF00 v: ThinkPad X270 serial: N/A
           Mobo: LENOVO model: 20HNS0AF00 v: SDK0J40679 WIN serial: N/A
           UEFI [Legacy]: LENOVO v: R0IET38W (1.16 ) date: 05/31/2017
           Chassis: type: 10 serial: N/A
Battery    BAT0: charge: 17.6 Wh 79.5% condition: 22.1/23.2 Wh (95%) volts: 12.1/11.1
           model: SONY 45N1111 serial: <filter>status: N/A
           BAT1: charge: 19.7 Wh 89.5% condition: 22.0/23.5 Wh (94%) volts: 12.7/11.4
           model: LGC 45N1127 serial: <filter>status: Charging
CPU:       Dual core Intel Core i5-7200U (-MT-MCP-) arch: Kaby Lake rev.9 cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 10848
           clock speeds: min/max: 400/3100 MHz 1: 800 MHz 2: 800 MHz 3: 800 MHz 4: 800 MHz
Graphics:  Card: Intel HD Graphics 620 bus-ID: 00:02.0 chip-ID: 8086:5916
           Display Server: x11 (X.Org 1.19.6 ) drivers: modesetting (unloaded: fbdev,vesa)
           Resolution: 1366x768@60.00hz
           OpenGL: renderer: Mesa DRI Intel HD Graphics 620 (Kaby Lake GT2)
           version: 4.5 Mesa 19.0.2 (compat-v: 3.0) Direct Render: Yes
Audio:     Card Intel Sunrise Point-LP HD Audio driver: snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:9d71
           Sound: Advanced Linux Sound Architecture v: k4.15.0-54-generic
Network:   Card-1: Intel Ethernet Connection (4) I219-V
           driver: e1000e v: 3.2.6-k bus-ID: 00:1f.6 chip-ID: 8086:15d8
           IF: enp0s31f6 state: down mac: <filter>
           Card-2: Intel Wireless 8265 / 8275 driver: iwlwifi bus-ID: 03:00.0 chip-ID: 8086:24fd
Drives:    HDD Total Size: 750.2GB (39.5% used)
           ID-1: /dev/sda model: HITACHI_HTS54757 size: 750.2GB serial: <filter> temp: 35C
Partition: ID-1: / size: 96G used: 25G (28%) fs: ext4 dev: /dev/sda1
           Unused Devices: none
Sensors:   System Temperatures: cpu: 44.0C mobo: N/A
           Fan Speeds (in rpm): cpu: 3906
Info:      Processes: 248 Uptime: 2:43 Memory: 2186.8/3612.9MB Init: systemd v: 237 runlevel: 5 Gcc sys: 7.4.0
           Client: Shell (bash 4.4.201 running in io.elementary.t) inxi: 2.3.56
OpenGL renderer string: Mesa DRI Intel(R) HD Graphics 620 (Kaby Lake GT2)
    GL_NV_conditional_render, GL_NV_depth_clamp,
    GL_EXT_render_snorm, GL_EXT_robustness, GL_EXT_sRGB_write_control,
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 620 (rev 02)
ii  libdrm-amdgpu1:amd64                          2.4.97-1ubuntu1~18.04.1                            amd64        Userspace interface to amdgpu-specific kernel DRM services -- runtime
ii  xserver-xorg-video-amdgpu                     18.0.1-1                                           amd64        X.Org X server -- AMDGPU display driver
bcmwl, 6.30.223.271+bdcom, 4.15.0-52-generic, x86_64: installed
bcmwl, 6.30.223.271+bdcom, 4.15.0-54-generic, x86_64: installed
« Son Düzenleme: 09 Temmuz 2019, 00:04:23 Gönderen: frkntlgyc »
Ynt: Elementary OS Donma Problemi
« Yanıtla #1 : 08 Temmuz 2019, 20:53:44 »
Swappiness ayarını 10 olarak değiştirmeyi deneyin, forumda nasıl yapılacağı ile ilgili konu mevcut.
  • İleti: 33
    • furkantolgayuce
    • furkantolgayuce
« Yanıtla #2 : 09 Temmuz 2019, 00:04:07 »
Bilgisayar çok akıcı hale geldi. Çok teşekkür ederim.
Ynt: [Çözüldü] Elementary OS Donma Problemi
« Yanıtla #3 : 09 Temmuz 2019, 00:06:40 »
Rica ederiz.
