Gönderen Konu: Kaydırırken Görüntünün Buğulu Gibi Olması / Dalgalanma Sorunu [Çözüldü]  (Okunma sayısı 4749 defa)
Çevrimdışı Majardoma
  • İleti: 5
  • Dağıtım: Linux mint
Mint kurdum tarayıcı veya masaüstünde kaydırma yaparken bugulu birşey oluyor, dalgalanıyor kısaca , daha önce manjaro,parrot os kullandım böyle sorun yoktu
https://www.youtube.com/watch?v=kqih3n1tReo videoda ki gibi oluyor tarayıcı ve desktopta
inxi -SMGxx
System:
  Host: maj0x7a Kernel: 4.15.0-55-generic x86_64 bits: 64 compiler: gcc
  v: 7.4.0 Desktop: Xfce 4.12.3 tk: Gtk 2.24.31 wm: xfwm4 dm: LightDM
Machine:
  Type: Laptop System: Sony product: VGN-NS21Z_S v: C6U0XX9D
  serial: <root required> Chassis: type: 10 serial: <root required>
  Mobo: Sony model: VAIO serial: <root required> BIOS: American Megatrends
  v: R1040Y3 date: 08/27/2009
Graphics:
  Device-1: AMD RV620/M82 [Mobility Radeon HD 3410/3430] vendor: Sony
  driver: radeon v: kernel bus ID: 01:00.0 chip ID: 1002:95c2
  Display: x11 server: X.Org 1.19.6 driver: ati,radeon
  unloaded: fbdev,modesetting,vesa resolution: 1280x800~60Hz
  OpenGL: renderer: AMD RV620 (DRM 2.50.0 / 4.15.0-55-generic LLVM 8.0.0)
  v: 3.3 Mesa 19.0.2 compat-v: 3.0 direct render: Yes
OpenGL renderer string: AMD RV620 (DRM 2.50.0 / 4.15.0-55-generic, LLVM 8.0.0)
    GL_NVX_gpu_memory_info, GL_NV_conditional_render, GL_NV_depth_clamp,
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] RV620/M82 [Mobility Radeon HD 3410/3430]
Screen 0: minimum 320 x 200, current 1280 x 800, maximum 8192 x 8192
VGA-0 disconnected primary (normal left inverted right x axis y axis)
LVDS connected 1280x800+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
   1280x800      59.77*+
   1280x720      59.97
   1152x768      59.95
   1024x768      59.95
   800x600       59.96
   848x480       59.94
   720x480       59.94
   640x480       59.94
ii  libdrm-amdgpu1:amd64                       2.4.97-1ubuntu1~18.04.1                         amd64        Userspace interface to amdgpu-specific kernel DRM services -- runtime
ii  nvidia-prime-applet                        1.0.7                                           all          An applet for NVIDIA Prime
ii  xserver-xorg-video-amdgpu                  18.0.1-1                                        amd64        X.Org X server -- AMDGPU display driver
dkms status
Çıktı vermedi
« Son Düzenleme: 06 Ağustos 2019, 23:03:15 Gönderen: Majardoma »
Kurulum Öncesi ve Sonrası
Kurulum aşamasında ve sonrasında yaşadığınız sorunlara ait yardım alabileceğiniz forum alanı. Lütfen bu bölüme kurulum ile ilgisi olmayan hususlarda konu açmayınız.
Lütfen konuları uygun bölümde açmaya özen gösteriniz, bölüm açıklamalarında açılabilecek/açılamayacak hususlar belirtiliyor.
Masaüstü Ayarları aracından Compton birleştiricisini etkinleştirmeyi denediniz mi?
Ayrıca radeon sürücüsünü kullanan GPU'lar için burada önerilen yapılandırma dosyası hazırlanabilir. Bu yapılandırma dosyasının performansa etkisi de olacaktır.
« Son Düzenleme: 06 Ağustos 2019, 16:26:03 Gönderen: Butterfly »
  • İleti: 5
Compton birleştiricisi etkin gözüküyor , yeni kurdum zaten, radeon ayarını denemedim cat: /etc/X11/xorg.conf: Böyle bir dosya ya da dizin yok
hatası alıyorum bunla ilgili olabilir mi
Zaten xorg.conf diye bir dosya olmayacak, xorg yapılandırma dosyası ile ilgili yönlendirmeleri uygulamayı deneyiniz.
Bir de aşağıdaki komutların çıktısını paylaşınız.
wm-detect
xrabdr
  • İleti: 5
wm-detect
xrabdr
wm-detect
Desktop environment: XFCE
Window manager: xfwm4 (3501)
Compositing: enabled
   1280x800      59.77*+
   1280x720      59.97
   1152x768      59.95
   1024x768      59.95
   800x600       59.96
   848x480       59.94
   720x480       59.94
   640x480       59.94
Paylaştığınız çıktıya göre Compton etkin görünmüyor. Paylaştığım bağlantıda nasıl etkinleştirileceği anlatılıyor.
  • İleti: 5
Sagolun hocam düzeldi.
[member=6700]Majardoma[/member] , rica ederiz.
Başlığı etiketlerseniz, konuyu kilitleyelim.
[okay] Çözülen başlıkların etiketlenmesi hakkında.[/okay]
« Son Düzenleme: 06 Ağustos 2019, 21:51:42 Gönderen: Butterfly »
  • İleti: 5
Kapatabilirsiniz
