Gönderen Konu: Intel + Nvidia Hibrit Sistemde Harici GPU'yu Kullanma  (Okunma sayısı 2354 defa)
Çevrimdışı Sieben
  • İleti: 4
« : 08 Ağustos 2019, 01:09:50 »
öncelikle linux konusunda yeniyim. ancak beni sistemimde iki ekrankarti var. sistem ise varolan olarak intelskyline ekran kartini kullaniyor. ben ise nvidia 940m ekran kartini kullanmak istiyorum. ancak sistemden nasil ayarlanacagini bilmiyorum.
yardimci olursaniz sevinirim
tesekkürler
seven@seven-Aspire-E5-574G:~$ inxi -SMGxx
System:
  Host: seven-Aspire-E5-574G Kernel: 4.15.0-55-generic x86_64 bits: 64
  compiler: gcc v: 7.4.0 Desktop: Cinnamon 4.2.3 wm: muffin dm: LightDM
Machine:
  Type: Laptop System: Acer product: Aspire E5-574G v: V1.14
  serial: <root required>
  Mobo: Acer model: Zoro_SL v: V1.14 serial: <root required> UEFI: Insyde
  v: 1.14 date: 03/04/2016
Graphics:
  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Acer Incorporated ALI
  driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:1916
  Device-2: NVIDIA GM108M [GeForce 940M] vendor: Acer Incorporated ALI
  driver: N/A bus ID: 01:00.0 chip ID: 10de:1347
  resolution: 1366x768~60Hz
  OpenGL: renderer: Mesa DRI Intel HD Graphics 520 (Skylake GT2)
  v: 4.5 Mesa 19.0.2 compat-v: 3.0 direct render: Yes
seven@seven-Aspire-E5-574G:~$ glxinfo | grep render
OpenGL renderer string: Mesa DRI Intel(R) HD Graphics 520 (Skylake GT2)
    GL_NV_conditional_render, GL_NV_depth_clamp,
    GL_EXT_render_snorm, GL_EXT_robustness, GL_EXT_sRGB_write_control,
seven@seven-Aspire-E5-574G:~$ lspci | egrep 'VGA|3D|Display'
00:02.0 VGA compatible controller: Intel Corporation Skylake GT2 [HD Graphics 520] (rev 07)
01:00.0 3D controller: NVIDIA Corporation GM108M [GeForce 940M] (rev a2)
seven@seven-Aspire-E5-574G:~$ xrandr
eDP-1 connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
   1366x768      60.00*+
   1360x768      59.80    59.96
   1024x768      60.04    60.00
   960x720       60.00
   928x696       60.05
   896x672       60.01
   960x600       59.93    60.00
   840x525       60.01    59.88
   864x486       59.92    59.57
   800x512       60.17
   700x525       59.98
   800x450       59.95    59.82
   640x512       60.02
   720x450       59.89
   700x450       59.96    59.88
   640x480       60.00    59.94
   720x405       59.51    58.99
   684x384       59.88    59.85
   680x384       59.80    59.96
   640x400       59.88    59.98
   576x432       60.06
   512x384       60.00
   512x288       60.00    59.92
   480x270       59.63    59.82
   400x300       60.32    56.34
   432x243       59.92    59.57
   320x240       60.05
   360x202       59.51    59.13
   320x180       59.84    59.32
seven@seven-Aspire-E5-574G:~$ cat /etc/X11/xorg.conf
seven@seven-Aspire-E5-574G:~$ dpkg -l | egrep 'nvidia|bumblebee|primus|prime|virtualgl|fglrx|amdgpu'
rc  bumblebee                                    3.2.1-17                                    amd64        NVIDIA Optimus support for Linux
rc  bumblebee-nvidia                             3.2.1-17                                    amd64        NVIDIA Optimus support using the proprietary NVIDIA driver
ii  libdrm-amdgpu1:amd64                         2.4.97-1ubuntu1~18.04.1                     amd64        Userspace interface to amdgpu-specific kernel DRM services -- runtime
ii  libdrm-amdgpu1:i386                          2.4.97-1ubuntu1~18.04.1                     i386         Userspace interface to amdgpu-specific kernel DRM services -- runtime
ii  libnvidia-cfg1-430:amd64                     430.26-0ubuntu0.18.04.2                     amd64        NVIDIA binary OpenGL/GLX configuration library
ii  libnvidia-common-390                         390.116-0ubuntu0.18.04.1                    all          Shared files used by the NVIDIA libraries
ii  libnvidia-common-430                         430.26-0ubuntu0.18.04.2                     all          Shared files used by the NVIDIA libraries
rc  libnvidia-compute-390:amd64                  390.116-0ubuntu0.18.04.1                    amd64        NVIDIA libcompute package
rc  libnvidia-compute-390:i386                   390.116-0ubuntu0.18.04.1                    i386         NVIDIA libcompute package
ii  libnvidia-compute-430:amd64                  430.26-0ubuntu0.18.04.2                     amd64        NVIDIA libcompute package
ii  libnvidia-compute-430:i386                   430.26-0ubuntu0.18.04.2                     i386         NVIDIA libcompute package
ii  libnvidia-decode-430:amd64                   430.26-0ubuntu0.18.04.2                     amd64        NVIDIA Video Decoding runtime libraries
ii  libnvidia-decode-430:i386                    430.26-0ubuntu0.18.04.2                     i386         NVIDIA Video Decoding runtime libraries
ii  libnvidia-encode-430:amd64                   430.26-0ubuntu0.18.04.2                     amd64        NVENC Video Encoding runtime library
ii  libnvidia-encode-430:i386                    430.26-0ubuntu0.18.04.2                     i386         NVENC Video Encoding runtime library
ii  libnvidia-fbc1-430:amd64                     430.26-0ubuntu0.18.04.2                     amd64        NVIDIA OpenGL-based Framebuffer Capture runtime library
ii  libnvidia-fbc1-430:i386                      430.26-0ubuntu0.18.04.2                     i386         NVIDIA OpenGL-based Framebuffer Capture runtime library
ii  libnvidia-gl-430:amd64                       430.26-0ubuntu0.18.04.2                     amd64        NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii  libnvidia-gl-430:i386                        430.26-0ubuntu0.18.04.2                     i386         NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii  libnvidia-ifr1-430:amd64                     430.26-0ubuntu0.18.04.2                     amd64        NVIDIA OpenGL-based Inband Frame Readback runtime library
ii  libnvidia-ifr1-430:i386                      430.26-0ubuntu0.18.04.2                     i386         NVIDIA OpenGL-based Inband Frame Readback runtime library
rc  nvidia-compute-utils-390                     390.116-0ubuntu0.18.04.1                    amd64        NVIDIA compute utilities
ii  nvidia-compute-utils-430                     430.26-0ubuntu0.18.04.2                     amd64        NVIDIA compute utilities
rc  nvidia-dkms-390                              390.116-0ubuntu0.18.04.1                    amd64        NVIDIA DKMS package
ii  nvidia-dkms-430                              430.26-0ubuntu0.18.04.2                     amd64        NVIDIA DKMS package
ii  nvidia-driver-430                            430.26-0ubuntu0.18.04.2                     amd64        NVIDIA driver metapackage
rc  nvidia-kernel-common-390                     390.116-0ubuntu0.18.04.1                    amd64        Shared files used with the kernel module
ii  nvidia-kernel-common-430                     430.26-0ubuntu0.18.04.2                     amd64        Shared files used with the kernel module
ii  nvidia-kernel-source-430                     430.26-0ubuntu0.18.04.2                     amd64        NVIDIA kernel source package
rc  nvidia-prime                                 0.8.8.2                                     all          Tools to enable NVIDIA's Prime
ii  nvidia-prime-applet                          1.0.7                                       all          An applet for NVIDIA Prime
ii  nvidia-settings                              390.77-0ubuntu0.18.04.1                     amd64        Tool for configuring the NVIDIA graphics driver
ii  nvidia-utils-430                             430.26-0ubuntu0.18.04.2                     amd64        NVIDIA driver support binaries
rc  primus                                       0~20150328-6                                amd64        client-side GPU offloading for NVIDIA Optimus
ii  primus-libs:amd64                            0~20150328-6                                amd64        Shared libraries for primus
ii  xserver-xorg-video-amdgpu                    18.0.1-1                                    amd64        X.Org X server -- AMDGPU display driver
ii  xserver-xorg-video-nvidia-430                430.26-0ubuntu0.18.04.2                     amd64        NVIDIA binary Xorg driver
seven@seven-Aspire-E5-574G:~$ dkms status
bbswitch, 0.8, 4.15.0-55-generic, x86_64: installed
nvidia, 430.26, 4.15.0-55-generic, x86_64: installed
« Son Düzenleme: 09 Ağustos 2019, 00:41:16 Gönderen: Sieben »
Ynt: Intel + Nvidia Hibrit Sistemde Harici GPU'yu Kullanma
« Yanıtla #1 : 08 Ağustos 2019, 02:01:31 »
[member=5071]Sieben[/member] , mevcut konulara mesaj gönderme yerine, yeni bir konu açınız. Konu açarken ve mevcut konulara mesaj gönderirken dikkat edilmesi gerekenler için şu konumuzu inceleyiniz. Gönderdiğiniz mesaj bölünerek yeni bir konu oluşturuldu.
Ayrıca aşağıdaki bağlantıyı inceleyip, eksik komutların çıktılarını paylaşınız.
« Yanıtla #2 : 09 Ağustos 2019, 01:13:14 »
Çıktıları düzenlemişsiniz. Bunlardan anlaşıldığı kadarıyla Bumblebee'yi kurup kaldırmışsınız. Öncelikle sisteminizde Bumblebee'yi mi yoksa Nvdia Prime seçeneğini mi kullanmak istediğinize karar verin. Buna göre yönlendirelim. Forumdaki Nvidia Pime konusu içinde arasındaki farklardan bahsediliyor.
