Gönderen Konu: Linux Mint 19.3 Yavaş Açılış Sorunu  (Okunma sayısı 13009 defa)
Çevrimdışı sebastianhawk
  • İleti: 28
Ynt: Linux Mint 19.3 Yavaş Açılış Sorunu
« Yanıtla #30 : 06 Ocak 2020, 23:27:21 »
       25.638s ModemManager.service
         20.860s networkd-dispatcher.service
         19.453s dev-sda1.device
         18.326s systemd-journal-flush.service
         17.545s udisks2.service
         16.928s NetworkManager.service
         16.742s accounts-daemon.service
          8.652s systemd-resolved.service
          8.057s apparmor.service
          8.008s grub-common.service
          7.796s systemd-udevd.service
          7.759s ubuntu-system-adjustments.service
          7.707s ufw.service
          7.288s polkit.service
          7.151s networking.service
          6.895s lightdm.service
          6.890s plymouth-quit-wait.service
          6.657s preload.service
          5.967s wpa_supplicant.service
          5.732s systemd-logind.service
          5.688s avahi-daemon.service
          5.686s bluetooth.service
          5.685s zram-config.service
          5.681s thermald.service
          5.675s hddtemp.service
          5.644s pppd-dns.service
          5.204s rsyslog.service
          5.012s gpu-manager.service
          4.581s lm-sensors.service
          3.856s lvm2-monitor.service
          3.077s systemd-tmpfiles-setup-dev.service
          2.967s dnsmasq.service
          2.939s dns-clean.service
          2.588s systemd-timesyncd.service
          1.763s keyboard-setup.service
          1.700s systemd-sysctl.service
          1.645s systemd-tmpfiles-setup.service
          1.631s systemd-modules-load.service
          1.136s user@1000.service
          1.001s systemd-random-seed.service
           953ms swapfile.swap
           702ms systemd-udev-trigger.service
           670ms systemd-rfkill.service
           635ms dev-mqueue.mount
           631ms systemd-journald.service
           586ms systemd-backlight@backlight:intel_backlight.service
           568ms systemd-update-utmp.service
           544ms systemd-remount-fs.service
           523ms blk-availability.service
           520ms dev-hugepages.mount
           520ms sys-kernel-debug.mount
           497ms kmod-static-nodes.service
           398ms console-setup.service
           290ms speech-dispatcher.service
           282ms kerneloops.service
           249ms upower.service
           209ms setvtrgb.service
           141ms systemd-tmpfiles-clean.service
           137ms packagekit.service
           121ms systemd-user-sessions.service
            97ms motd-news.service
            26ms dev-zram0.device
            24ms alsa-restore.service
            22ms dev-zram1.device
            21ms colord.service
            15ms plymouth-start.service
            11ms plymouth-read-write.service
             8ms systemd-update-utmp-runlevel.service
             7ms ureadahead-stop.service
             6ms rtkit-daemon.service
             6ms openvpn.service
             4ms sys-kernel-config.mount
             3ms sys-fs-fuse-connections.mount
graphical.target @58.463s
└─multi-user.target @58.463s
  └─getty.target @58.463s
    └─getty@tty1.service @58.462s
      └─system-getty.slice @58.460s
        └─setvtrgb.service @58.249s +209ms
          └─systemd-user-sessions.service @51.230s +121ms
            └─network.target @51.221s
              └─NetworkManager.service @34.292s +16.928s
                └─dbus.service @29.821s
                  └─basic.target @28.557s
                    └─paths.target @28.557s
                      └─cups.path @28.557s
                        └─sysinit.target @28.242s
                          └─systemd-timesyncd.service @25.653s +2.588s
                            └─systemd-tmpfiles-setup.service @23.812s +1.645s
                              └─systemd-journal-flush.service @5.482s +18.326s
                                └─systemd-remount-fs.service @4.935s +544ms
                                  └─systemd-journald.socket @4.507s
                                    └─system.slice @4.506s
                                      └─-.slice @4.460s
-- Logs begin at Sun 2018-01-28 18:58:22 +03, end at Mon 2020-01-06 23:26:44 +03. --
Oca 06 20:38:16 SEBASTIAN kernel: ACPI Error: Needed type [Reference], found [Integer] (____ptrval____) (20190703/exresop-69)
Oca 06 20:38:16 SEBASTIAN kernel: ACPI Error: AE_AML_OPERAND_TYPE, While resolving operands for [Store] (20190703/dswexec-427)
Oca 06 20:38:16 SEBASTIAN kernel: ACPI Error: Aborting method \_PR.CPU0._PDC due to previous error (AE_AML_OPERAND_TYPE) (20190703/psparse-531)
Oca 06 20:38:48 SEBASTIAN bluetoothd[841]: Failed to set mode: Blocked through rfkill (0x12)
Oca 06 20:39:06 SEBASTIAN dnsmasq[1604]: failed to create listening socket for port 53: Adres zaten kullanımda
Oca 06 20:39:06 SEBASTIAN dnsmasq[1604]: FAILED to start up
Oca 06 20:39:06 SEBASTIAN systemd[1]: Failed to start dnsmasq - A lightweight DHCP and caching DNS server.
Oca 06 20:39:08 SEBASTIAN wpa_supplicant[931]: dbus: wpa_dbus_get_object_properties: failed to get object properties: (none) none
Oca 06 20:39:08 SEBASTIAN wpa_supplicant[931]: dbus: Failed to construct signal
Oca 06 20:39:29 SEBASTIAN pulseaudio[2554]: [pulseaudio] backend-ofono.c: Failed to register as a handsfree audio agent with ofono: org.freedesktop.DBus.Error.ServiceUnknown: The name org.ofono was not provided by any .service files
Oca 06 20:39:29 SEBASTIAN pulseaudio[2581]: [pulseaudio] pid.c: Daemon already running.
Oca 06 21:40:28 SEBASTIAN kernel: mce: CPU0: Core temperature above threshold, cpu clock throttled (total events = 1)
Oca 06 21:40:28 SEBASTIAN kernel: mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 1)
Oca 06 21:40:28 SEBASTIAN kernel: mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 1)
Oca 06 21:45:28 SEBASTIAN kernel: mce: CPU1: Core temperature above threshold, cpu clock throttled (total events = 3516)
Oca 06 21:45:28 SEBASTIAN kernel: mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 5166)
Oca 06 21:45:28 SEBASTIAN kernel: mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 5166)
Oca 06 21:53:19 SEBASTIAN kernel: mce: CPU0: Core temperature above threshold, cpu clock throttled (total events = 4455)
Oca 06 21:53:19 SEBASTIAN kernel: mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 8955)
Oca 06 21:53:19 SEBASTIAN kernel: mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 8955)
Oca 06 21:58:19 SEBASTIAN kernel: mce: CPU1: Core temperature above threshold, cpu clock throttled (total events = 16549)
Oca 06 21:58:19 SEBASTIAN kernel: mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 23696)
Oca 06 21:58:19 SEBASTIAN kernel: mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 23696)
Oca 06 22:03:19 SEBASTIAN kernel: mce: CPU0: Core temperature above threshold, cpu clock throttled (total events = 13222)
Oca 06 22:03:20 SEBASTIAN kernel: mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 33007)
Oca 06 22:03:20 SEBASTIAN kernel: mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 33007)
Oca 06 22:10:13 SEBASTIAN kernel: mce: CPU0: Core temperature above threshold, cpu clock throttled (total events = 16067)
Oca 06 22:10:13 SEBASTIAN kernel: mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 40714)
Oca 06 22:10:13 SEBASTIAN kernel: mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 40714)
Oca 06 22:15:29 SEBASTIAN kernel: mce: CPU0: Core temperature above threshold, cpu clock throttled (total events = 18214)
Oca 06 22:15:29 SEBASTIAN kernel: mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 46061)
Oca 06 22:15:29 SEBASTIAN kernel: mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 46061)
Oca 06 22:21:27 SEBASTIAN kernel: mce: CPU1: Core temperature above threshold, cpu clock throttled (total events = 34055)
Oca 06 22:21:27 SEBASTIAN kernel: mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 50181)
Oca 06 22:21:27 SEBASTIAN kernel: mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 50181)
Oca 06 22:29:01 SEBASTIAN kernel: mce: CPU0: Core temperature above threshold, cpu clock throttled (total events = 23146)
Oca 06 22:29:01 SEBASTIAN kernel: mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 57243)
Oca 06 22:29:01 SEBASTIAN kernel: mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 57244)
Oca 06 22:34:07 SEBASTIAN kernel: mce: CPU0: Core temperature above threshold, cpu clock throttled (total events = 39307)
Oca 06 22:34:07 SEBASTIAN kernel: mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 83402)
Oca 06 22:34:07 SEBASTIAN kernel: mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 83403)
Oca 06 22:39:27 SEBASTIAN kernel: mce: CPU0: Core temperature above threshold, cpu clock throttled (total events = 43936)
Oca 06 22:39:28 SEBASTIAN kernel: mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 92186)
Oca 06 22:39:28 SEBASTIAN kernel: mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 92185)
Oca 06 22:44:46 SEBASTIAN kernel: mce: CPU0: Core temperature above threshold, cpu clock throttled (total events = 45862)
Oca 06 22:44:46 SEBASTIAN kernel: mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 95417)
Oca 06 22:44:46 SEBASTIAN kernel: mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 95418)
Oca 06 22:49:58 SEBASTIAN kernel: mce: CPU0: Core temperature above threshold, cpu clock throttled (total events = 45900)
Oca 06 22:49:58 SEBASTIAN kernel: mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 95460)
Oca 06 22:49:58 SEBASTIAN kernel: mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 95461)
Oca 06 22:53:22 SEBASTIAN kernel: mce: CPU1: Core temperature above threshold, cpu clock throttled (total events = 58362)
Oca 06 22:54:58 SEBASTIAN kernel: mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 97042)
Oca 06 22:54:58 SEBASTIAN kernel: mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 97041)
Oca 06 23:03:39 SEBASTIAN kernel: mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 97096)
Oca 06 23:03:39 SEBASTIAN kernel: mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 97097)
Oca 06 23:08:43 SEBASTIAN kernel: mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 102756)
Oca 06 23:08:43 SEBASTIAN kernel: mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 102757)
Oca 06 23:10:38 SEBASTIAN kernel: mce: CPU1: Core temperature above threshold, cpu clock throttled (total events = 61542)
Oca 06 23:14:07 SEBASTIAN kernel: mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 104383)
Oca 06 23:14:07 SEBASTIAN kernel: mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 104382)
Oca 06 23:16:35 SEBASTIAN kernel: mce: CPU1: Core temperature above threshold, cpu clock throttled (total events = 62527)
Oca 06 23:20:22 SEBASTIAN kernel: mce: CPU0: Core temperature above threshold, cpu clock throttled (total events = 51754)
Oca 06 23:20:23 SEBASTIAN kernel: mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 106028)
Oca 06 23:20:23 SEBASTIAN kernel: mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 106029)
Oca 06 23:21:35 SEBASTIAN kernel: mce: CPU1: Core temperature above threshold, cpu clock throttled (total events = 64539)
https://termbin.com/hawt
« Yanıtla #31 : 07 Ocak 2020, 19:10:27 »
Ağ servisi çok bekleme yapıyor, aşağıdaki komutun çıktsına bakalım.
systemctl status NetworkManager.service
Bu arada, Cinnamon masaüstündeki eklenti ile ilgili sorunu çözemediyseniz, yeni bir konu açabilirsiniz. Daha önce belirttiğimi gibi, bu konudan bağımsız bir husus.
« Son Düzenleme: 07 Ocak 2020, 19:12:25 Gönderen: Butterfly »
  • İleti: 28
« Yanıtla #32 : 07 Ocak 2020, 20:51:04 »
● NetworkManager.service - Network Manager
   Loaded: loaded (/lib/systemd/system/NetworkManager.service; enabled; vendor preset: enabled)
   Active: active (running) since Tue 2020-01-07 16:00:06 +03; 4h 47min ago
     Docs: man:NetworkManager(8)
 Main PID: 794 (NetworkManager)
    Tasks: 4 (limit: 4269)
   CGroup: /system.slice/NetworkManager.service
           ├─ 794 /usr/sbin/NetworkManager --no-daemon
           └─1741 /sbin/dhclient -d -q -sf /usr/lib/NetworkManager/nm-dhcp-helper -pf /run/dhclient-enp3s0.pid -lf /var/lib/NetworkManager/dhclient-436cafb2-bd35-4cb6-91
Oca 07 20:15:40 SEBASTIAN dhclient[1741]: bound to 192.168.1.104 -- renewal in 1474 seconds.
Oca 07 20:40:15 SEBASTIAN dhclient[1741]: DHCPREQUEST of 192.168.1.104 on enp3s0 to 192.168.1.1 port 67 (xid=0x1870a414)
Oca 07 20:40:15 SEBASTIAN dhclient[1741]: DHCPACK of 192.168.1.104 from 192.168.1.1
Oca 07 20:40:18 SEBASTIAN NetworkManager[794]: <info>  [1578418818.1457] dhcp4 (enp3s0):   address 192.168.1.104
Oca 07 20:40:18 SEBASTIAN NetworkManager[794]: <info>  [1578418818.2901] dhcp4 (enp3s0):   plen 24 (255.255.255.0)
Oca 07 20:40:18 SEBASTIAN NetworkManager[794]: <info>  [1578418818.2902] dhcp4 (enp3s0):   gateway 192.168.1.1
Oca 07 20:40:18 SEBASTIAN NetworkManager[794]: <info>  [1578418818.2903] dhcp4 (enp3s0):   lease time 3600
Oca 07 20:40:19 SEBASTIAN dhclient[1741]: bound to 192.168.1.104 -- renewal in 1779 seconds.
Oca 07 20:40:18 SEBASTIAN NetworkManager[794]: <info>  [1578418818.2903] dhcp4 (enp3s0):   nameserver '192.168.1.1'
Oca 07 20:40:18 SEBASTIAN NetworkManager[794]: <info>  [1578418818.2903] dhcp4 (enp3s0): state changed bound -> bound
lines 1-20/20 (END)
O sorunu hallettim.Bilmediğim bir şekilde ama yaptım.Yukardaki kod çıktısında
lines 1-20/20 (END)
bu vardı.Umarım eksik bir şey atmamışımdır.
« Yanıtla #33 : 07 Ocak 2020, 22:03:31 »
Aşağıdaki komutla ya da menüden aratarak "Ağ Bağlantıları" aracını açın.
nm-connection-editor
Bağlantınızı seçip çift tıklayın ve açılan düzenleme penceresinde IPV4 sekmesini açın.
Yöntem kısmından Elle seçeneğini seçin ve Ekle düğmesine tıklayın.
Eklenen kısmı aşağıdaki şekillde doldurup, düzenlemeleri kaydedersiniz.
Adres: 192.168.1.104
Ağ Maskesi: 255.255.255.0
Ağ Geçidi: 192.168.1.1
DNS Sunucuları: İsterseniz belilediğiniz DNS sunucusunu yazabilirsiniz.
Bu şekilde ağ servisi ile ilgili gecikmeyi önlemeyi deneyebilirsiniz.
  • İleti: 28
« Yanıtla #34 : 08 Ocak 2020, 02:04:28 »
O ayarları yaptığımda internet bağlantımda sorun oluştu.Eski haline getirdim.Hızlandırmak için başka yapabileceğim bir şey var mı yoksa bu kadar mı?
« Yanıtla #35 : 08 Ocak 2020, 12:30:33 »
Ağ yöneticisi ile ilgili durumu anlamaya çalışıyorum, klasik HDD cihazlarda açılış süresinin 35-45 saniye aralığında olması normal sayılabilir. Sizin sistemde bunun biraz üstünde bir sürede açıldığını görüyoruz. Çıktılardan edindiğim intibaya göre bunun ağ yöneticisi ile ilgili bir husus olabileceğinden şüphelendim, daha doğrusu DNS/DHCP ile ilgili bir husus olabilir. Bu sebeple yukarıda otomatik DHCP yerine elle IP atamayı önerdim. Eğer ayarları bahsettiğim şekilde yaptıysanız, internetle ilgili bir sorun yaşanmaması gerekirdi. Ama ağ yönetimi ile ilgili olarak, daha önce yaptığınız düzenlemeler varsa, bunlar sebebiyle IP atama ile ilgili bir olumsuzluk yaşanmış olabilir. Eğer bu tür düzenlemeler varsa bunları foruma aktarınız.
« Son Düzenleme: 08 Ocak 2020, 15:15:00 Gönderen: Butterfly »
  • İleti: 28
« Yanıtla #36 : 08 Ocak 2020, 16:36:32 »
Daha önce hiçbir düzenleme yapmadım.İşletim sistemimi kurduğumdan beri ağ ile ilgili bir sorun yaşamadım.Geçenlerde Kablosuz erişim noktasının adını değiştirmeyle ilgili bir sorun yaşamıştım onuda farklı bir programla düzelttim.Şuan tekrardan elle yapılandırdım dün gece hata veriyordu.Tekrardan test ediyorum.
Maalesef hala hata alıyorum.Ayarları yaptıktan sonra kısa süreli bir bağlantı sağlıyor fakat anlamadığım şekilde sonra bağlantım gidiyor.
« Son Düzenleme: 09 Ocak 2020, 02:25:06 Gönderen: sebastianhawk »
« Yanıtla #37 : 09 Ocak 2020, 18:07:38 »
Aynı modeme bağlı farklı aygıtlar varsa, sizden önce sabitlediğiniz IP farklı bir aygıta atanıyor olabilir. Bu durumda IP çakışması sebebiyle erişim sorunu yaşıyor olabilirsiniz. IPV4 ayarlarında adres kısmını değiştirmeyi deneyebilirsiniz, örneğin DHCP tarafından atanması daha zor olabilecek aşağıdaki IP adresi denenebilir. Tabii modeme bağlanan çok sayıda aygıt varsa, bu adreste DHCP tarafından farklı bir aygıta atanabilir, eğer aygıt sayısı azsa uygun olacaktır.
Adres: 192.168.1.120
Aslında burada aygıtın IP alma sürecinin açılışı nasıl etkilelediğini görmek istiyoruz. Alternatif olarak, ağ yöneticisinden bağlantınızı silip sistemi bu şekilde açın. Yani kablolu ya da kablosuz olarak tanımlı, otomatik olarak bağlantı kurmaya çalışacak bir bağlantınız olmasın. Sistemi bu şekilde açtıktan sonra, aşağıdaki komutların çıktılarına bir daha bakabiliriz. Sonuca göre araştırma yapıp çöüzm önerisi sunulabilir.
systemd-analyze --no-pager critical-chain
journalctl --no-pager -b -p3
systemctl status NetworkManager.service --no-pager
dmesg | nc termbin.com 9999
  • İleti: 28
« Yanıtla #38 : 09 Ocak 2020, 23:15:32 »
24.691s networkd-dispatcher.service
         23.295s ModemManager.service
         19.078s dev-sda1.device
         19.018s NetworkManager.service
         16.284s ubuntu-system-adjustments.service
         13.505s systemd-journal-flush.service
         12.254s udisks2.service
         10.527s accounts-daemon.service
          9.919s systemd-tmpfiles-setup.service
          9.564s lightdm.service
          9.559s plymouth-quit-wait.service
          8.413s ufw.service
          7.726s apparmor.service
          7.642s systemd-udevd.service
          6.944s networking.service
          6.833s wpa_supplicant.service
          6.666s thermald.service
          6.091s rsyslog.service
          5.801s gpu-manager.service
          5.471s avahi-daemon.service
          4.533s dnsmasq.service
          4.178s grub-common.service
          3.447s lvm2-monitor.service
          3.398s systemd-tmpfiles-setup-dev.service
          3.327s polkit.service
          2.995s preload.service
          2.857s dns-clean.service
          2.285s zram-config.service
          2.081s bluetooth.service
          2.009s systemd-sysctl.service
          1.983s systemd-modules-load.service
          1.880s speech-dispatcher.service
          1.759s lm-sensors.service
          1.488s keyboard-setup.service
          1.344s systemd-rfkill.service
          1.250s systemd-journald.service
          1.207s systemd-logind.service
          1.009s hddtemp.service
           866ms kerneloops.service
           712ms swapfile.swap
           711ms pppd-dns.service
           597ms user@1000.service
           513ms console-setup.service
           474ms systemd-remount-fs.service
           384ms systemd-timesyncd.service
           368ms sys-kernel-debug.mount
           366ms blk-availability.service
           356ms systemd-random-seed.service
           350ms systemd-resolved.service
           342ms upower.service
           314ms kmod-static-nodes.service
           244ms systemd-user-sessions.service
           230ms dev-hugepages.mount
           228ms dev-mqueue.mount
           182ms systemd-backlight@backlight:intel_backlight.service
           181ms systemd-update-utmp.service
           180ms setvtrgb.service
            89ms systemd-udev-trigger.service
            18ms colord.service
            15ms ureadahead-stop.service
            14ms plymouth-start.service
            11ms alsa-restore.service
             5ms sys-fs-fuse-connections.mount
             4ms rtkit-daemon.service
             3ms openvpn.service
             2ms sys-kernel-config.mount
graphical.target @59.827s
└─multi-user.target @59.827s
  └─getty.target @59.827s
    └─getty@tty1.service @59.826s
      └─system-getty.slice @59.824s
        └─setvtrgb.service @59.643s +180ms
          └─systemd-user-sessions.service @49.834s +244ms
            └─network.target @49.833s
              └─NetworkManager.service @30.814s +19.018s
                └─dbus.service @29.917s
                  └─basic.target @29.916s
                    └─sockets.target @29.916s
                      └─cups.socket @29.916s
                        └─sysinit.target @29.809s
                          └─systemd-timesyncd.service @29.425s +384ms
                            └─systemd-tmpfiles-setup.service @19.469s +9.919s
                              └─systemd-journal-flush.service @5.963s +13.505s
                                └─systemd-journald.service @4.711s +1.250s
                                  └─syslog.socket @4.709s
                                    └─system.slice @4.572s
                                      └─-.slice @4.526s
-- Logs begin at Sun 2018-01-28 18:58:22 +03, end at Thu 2020-01-09 23:09:09 +03. --
Oca 09 23:03:55 SEBASTIAN kernel: ACPI Error: Needed type [Reference], found [Integer] (____ptrval____) (20190703/exresop-69)
Oca 09 23:03:55 SEBASTIAN kernel: ACPI Error: AE_AML_OPERAND_TYPE, While resolving operands for [Store] (20190703/dswexec-427)
Oca 09 23:03:55 SEBASTIAN kernel: ACPI Error: Aborting method \_PR.CPU0._PDC due to previous error (AE_AML_OPERAND_TYPE) (20190703/psparse-531)
Oca 09 23:04:25 SEBASTIAN bluetoothd[886]: Failed to set mode: Blocked through rfkill (0x12)
Oca 09 23:04:44 SEBASTIAN dnsmasq[1433]: failed to create listening socket for port 53: Adres zaten kullanımda
Oca 09 23:04:44 SEBASTIAN dnsmasq[1433]: FAILED to start up
Oca 09 23:04:44 SEBASTIAN systemd[1]: Failed to start dnsmasq - A lightweight DHCP and caching DNS server.
Oca 09 23:05:07 SEBASTIAN pulseaudio[2492]: [pulseaudio] backend-ofono.c: Failed to register as a handsfree audio agent with ofono: org.freedesktop.DBus.Error.ServiceUnknown: The name org.ofono was not provided by any .service files
Oca 09 23:05:07 SEBASTIAN pulseaudio[2521]: [pulseaudio] pid.c: Daemon already running.
   Active: active (running) since Thu 2020-01-09 23:04:39 +03; 4min 58s ago
 Main PID: 848 (NetworkManager)
    Tasks: 3 (limit: 4269)
           └─848 /usr/sbin/NetworkManager --no-daemon
Oca 09 23:04:45 SEBASTIAN NetworkManager[848]: <info>  [1578600285.5867] dev…l')
Oca 09 23:04:45 SEBASTIAN NetworkManager[848]: <info>  [1578600285.6264] wif…rol
Oca 09 23:04:45 SEBASTIAN NetworkManager[848]: <info>  [1578600285.6270] dev…ode
Oca 09 23:04:45 SEBASTIAN NetworkManager[848]: <info>  [1578600285.6296] man…/3)
Oca 09 23:04:45 SEBASTIAN NetworkManager[848]: <info>  [1578600285.6317] dev…l')
Oca 09 23:04:45 SEBASTIAN NetworkManager[848]: <info>  [1578600285.7209] mod…ble
Oca 09 23:04:45 SEBASTIAN NetworkManager[848]: <info>  [1578600285.7213] blu…n 5
Oca 09 23:04:45 SEBASTIAN NetworkManager[848]: <info>  [1578600285.7231] sup…ing
Oca 09 23:04:45 SEBASTIAN NetworkManager[848]: <info>  [1578600285.7244] blu…:C2
Oca 09 23:04:51 SEBASTIAN NetworkManager[848]: <info>  [1578600291.6006] man…ete
Hint: Some lines were ellipsized, use -l to show in full.
https://termbin.com/e26bh
« Yanıtla #39 : 10 Ocak 2020, 00:48:13 »
Aşğaıdaki komutla, açtığınız diğer konuda önerdiğim Create-ap-gui uygulamasını kaldırmayı dener misiniz? Sanırım bununla birlikte kurulan  dnsmasq ile ilgili bir sorun yaşanıyor. Burada da bununla ilgili bir hata kaydı da açılmış.
sudo apt purge bridge-utils create-ap create-ap-gui dnsmasq hostapd
Ardından sistemi yeniden başlatıp aşağıdaki komutların çıktılarını yeniden paylaşırsınız.
systemd-analyze
systemctl status NetworkManager.service --no-pager -l
« Son Düzenleme: 10 Ocak 2020, 01:04:29 Gönderen: Butterfly »
  • İleti: 28
« Yanıtla #40 : 10 Ocak 2020, 16:47:01 »
Startup finished in 7.085s (kernel) + 53.081s (userspace) = 1min 166ms
graphical.target reached after 53.063s in userspace
graphical.target @53.063s
└─multi-user.target @53.063s
  └─getty.target @53.063s
    └─getty@tty1.service @53.062s
      └─system-getty.slice @53.060s
        └─setvtrgb.service @52.686s +371ms
          └─systemd-user-sessions.service @38.282s +75ms
            └─network.target @38.276s
              └─NetworkManager.service @28.013s +10.262s
                └─dbus.service @22.389s
                  └─basic.target @22.289s
                    └─sockets.target @22.289s
                      └─uuidd.socket @22.289s
                        └─sysinit.target @22.136s
                          └─systemd-timesyncd.service @21.666s +470ms
                            └─systemd-tmpfiles-setup.service @19.642s +1.900s
                              └─systemd-journal-flush.service @5.514s +14.123s
                                └─systemd-journald.service @4.756s +756ms
                                  └─systemd-journald-audit.socket @4.755s
                                    └─system.slice @4.473s
                                      └─-.slice @4.427s
   Active: active (running) since Fri 2020-01-10 16:39:16 +03; 7min ago
 Main PID: 887 (NetworkManager)
    Tasks: 5 (limit: 4269)
           ├─ 887 /usr/sbin/NetworkManager --no-daemon
           └─1634 /sbin/dhclient -d -q -sf /usr/lib/NetworkManager/nm-dhcp-helper -pf /run/dhclient-enp3s0.pid -lf /var/lib/NetworkManager/dhclient-7179f7d4-718d-4107-947b-94e1443765c6-enp3s0.lease -cf /var/lib/NetworkManager/dhclient-enp3s0.conf enp3s0
Oca 10 16:39:34 SEBASTIAN NetworkManager[887]: <info>  [1578663574.9284] dhcp4 (enp3s0): state changed unknown -> bound
Oca 10 16:39:34 SEBASTIAN NetworkManager[887]: <info>  [1578663574.9306] device (enp3s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Oca 10 16:39:34 SEBASTIAN NetworkManager[887]: <info>  [1578663574.9319] device (enp3s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Oca 10 16:39:34 SEBASTIAN NetworkManager[887]: <info>  [1578663574.9323] device (enp3s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Oca 10 16:39:34 SEBASTIAN NetworkManager[887]: <info>  [1578663574.9325] manager: NetworkManager state is now CONNECTED_LOCAL
Oca 10 16:39:35 SEBASTIAN dhclient[1634]: bound to 192.168.1.104 -- renewal in 1576 seconds.
Oca 10 16:39:35 SEBASTIAN NetworkManager[887]: <info>  [1578663575.0234] manager: NetworkManager state is now CONNECTED_SITE
Oca 10 16:39:35 SEBASTIAN NetworkManager[887]: <info>  [1578663575.0237] policy: set 'Otomatik Ethernet' (enp3s0) as default for IPv4 routing and DNS
Oca 10 16:39:35 SEBASTIAN NetworkManager[887]: <info>  [1578663575.0260] device (enp3s0): Activation: successful, device activated.
Oca 10 16:39:47 SEBASTIAN NetworkManager[887]: <info>  [1578663587.3784] manager: NetworkManager state is now CONNECTED_GLOBAL
Kaldırdım ama benim böyle bir yazılıma ihtiyacım var.Önerebileceğiniz başka yazılım var mı?
« Yanıtla #41 : 10 Ocak 2020, 17:23:15 »
Şu an günlükleme servisi ile ilgili gecikme kalmış görünüyor. Aşağıdaki komutlarla günlükleme dosyalarını temizleyip,
sudo journalctl --vacuum-time=2d
sudo journalctl --vacuum-size=200M
aşağıdaki şekilde günlükleme ile ilgili dosya sınırlaması yapmayı deneyiniz. Bunun için aşağıdaki komutları uçbirimde çalıştırınız.
sudo mkdir -p /etc/systemd/journald.conf.d/
sudo xed /etc/systemd/journald.conf.d/00-journal-size.conf
Açılan dosyaya aşağıdaki satırları ekleyip, dosyayı kaydediniz.
SystemMaxFileSize=200M
SystemMaxFiles=5
Create-ap-gui uygulaması ile kurulan dnsmasq ile systemd-resolve servisinin kullandığı portlar çakışıyormuş. Bunu aşamak için aşağıdaki komutla systemd-resolved servisini pasifleştirebilirsiniz.
sudo systemctl disable systemd-resolved
Ardından Create-ap-gui uygulamasını kurabilirsiniz.
Tüm bu işlemlerden ardından, sistemi yeniden başlattıktan sonra, bir önceki mesajda istenen komutların çıktılarını paylaşırsanız, sonucu kontrol edebiliriz.
« Son Düzenleme: 10 Ocak 2020, 17:26:57 Gönderen: Butterfly »
  • İleti: 28
« Yanıtla #42 : 10 Ocak 2020, 21:16:47 »
Bu komutu çalıştırdıktan sonra yeniden başlattım.Açıldığında internet bağlantım kesilmişti.Enable yaparak düzelttim.Çalıştırdığımda internete bağlanamıyorum.
Startup finished in 7.203s (kernel) + 56.519s (userspace) = 1min 3.723s
graphical.target reached after 56.505s in userspace
graphical.target @56.505s
└─multi-user.target @56.505s
  └─getty.target @56.505s
    └─getty@tty1.service @56.504s
      └─system-getty.slice @56.502s
        └─setvtrgb.service @56.308s +191ms
          └─systemd-user-sessions.service @39.825s +95ms
            └─network.target @39.817s
              └─NetworkManager.service @25.448s +14.368s
                └─dbus.service @16.337s
                  └─basic.target @16.203s
                    └─sockets.target @16.203s
                      └─acpid.socket @16.203s
                        └─sysinit.target @15.510s
                          └─systemd-backlight@backlight:intel_backlight.service @28.062s +1.083s
                            └─system-systemd\x2dbacklight.slice @28.061s
                              └─system.slice @4.594s
                                └─-.slice @4.558s
   Active: active (running) since Fri 2020-01-10 20:57:32 +03; 18min ago
 Main PID: 821 (NetworkManager)
           ├─ 821 /usr/sbin/NetworkManager --no-daemon
           └─1667 /sbin/dhclient -d -q -sf /usr/lib/NetworkManager/nm-dhcp-helper -pf /run/dhclient-enp3s0.pid -lf /var/lib/NetworkManager/dhclient-9b6b288b-1f48-49b5-bf58-782e658b7fc8-enp3s0.lease -cf /var/lib/NetworkManager/dhclient-enp3s0.conf enp3s0
Oca 10 20:57:56 SEBASTIAN NetworkManager[821]: <info>  [1578679076.7659] manager: NetworkManager state is now CONNECTED_SITE
Oca 10 20:57:56 SEBASTIAN NetworkManager[821]: <info>  [1578679076.7666] policy: set 'Otomatik Ethernet' (enp3s0) as default for IPv4 routing and DNS
Oca 10 20:57:56 SEBASTIAN NetworkManager[821]: <info>  [1578679076.7684] device (enp3s0): Activation: successful, device activated.
Oca 10 20:57:58 SEBASTIAN NetworkManager[821]: <info>  [1578679078.0857] manager: NetworkManager state is now CONNECTED_GLOBAL
Oca 10 21:04:01 SEBASTIAN NetworkManager[821]: <info>  [1578679441.8711] wifi-nl80211: (ap0): using nl80211 for WiFi device control
Oca 10 21:04:01 SEBASTIAN NetworkManager[821]: <info>  [1578679441.8713] device (ap0): driver supports Access Point (AP) mode
Oca 10 21:04:01 SEBASTIAN NetworkManager[821]: <info>  [1578679441.8726] manager: (ap0): new 802.11 WiFi device (/org/freedesktop/NetworkManager/Devices/4)
Oca 10 21:04:01 SEBASTIAN NetworkManager[821]: <info>  [1578679441.8899] devices added (path: /sys/devices/pci0000:00/0000:00:1c.1/0000:02:00.0/net/ap0, iface: ap0)
Oca 10 21:04:01 SEBASTIAN NetworkManager[821]: <info>  [1578679441.8899] device added (path: /sys/devices/pci0000:00/0000:00:1c.1/0000:02:00.0/net/ap0, iface: ap0): no ifupdown configuration found.
Oca 10 21:14:04 SEBASTIAN NetworkManager[821]: <info>  [1578680044.8989] devices removed (path: /sys/devices/pci0000:00/0000:00:1c.1/0000:02:00.0/net/ap0, iface: ap0)
« Yanıtla #43 : 10 Ocak 2020, 22:56:55 »
Aşağıdaki komutlarla systemd-resolved servisini pasifleştirin ve durdurun.
sudo systemctl stop systemd-resolved
Ardından aşağıdaki komutla ağ yöneticisinin ayar dosyasını açın.
sudo xed /etc/NetworkManager/NetworkManager.conf
Açılan yapılandırma dosyasının [main] kısmına aşağıdaki satırı ekleyin.
dns=default
Dosya aşağıdaki gibi görünecek.
[main]
plugins=ifupdown,keyfile
dns=default
[ifupdown]
managed=false
[device]
wifi.scan-rand-mac-address=no
En son olarak, aşğaıdaki komutla /etc/resolv.conf dosyasını silin.
sudo rm -f /etc/resolv.conf
Sistemi yeniden başlattığınızda ya da aşağıdaki komutla ağ yöneticisini yeniden başlattığınızda, DNS işlevini ağ yöneticisi üstlenecektir.
sudo systemctl restart NetworkManager
Kaynak
« Son Düzenleme: 10 Ocak 2020, 22:58:01 Gönderen: Butterfly »
  • İleti: 28
« Yanıtla #44 : 13 Ocak 2020, 17:24:59 »
Yaptım, şimdi eski attığınız ayarları tekrar mı uygulayayım ?
