Gönderen Konu: [Çözüldü] Giriş Ekranında Dokunmatik Panelin Çalışmaması Sorunu  (Okunma sayısı 2413 defa)
Çevrimdışı fikretugur
  • İleti: 46
System:
  Host: HP-Pavilion-g6-Notebook-PC Kernel: 5.0.0-37-generic x86_64
  bits: 64 compiler: gcc v: 7.4.0 Desktop: MATE 1.22.2 wm: marco dm: LightDM
Machine:
  Type: Laptop System: Hewlett-Packard product: HP Pavilion g6 Notebook PC
  v: 0692120000204610000610100 serial: <filter> Chassis: type: 10
  serial: <filter>
  Mobo: Hewlett-Packard model: 1670 v: 09.36 serial: <filter>
  BIOS: Hewlett-Packard v: F.30 date: 06/21/2011
CPU:
  Topology: Dual Core model: Intel Core i5-2430M bits: 64 type: MT MCP
  arch: Sandy Bridge rev: 7 L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19155
  Speed: 798 MHz min/max: 800/3000 MHz Core speeds (MHz): 1: 798 2: 798
  3: 798 4: 798
Graphics:
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
  vendor: Hewlett-Packard driver: i915 v: kernel bus ID: 00:02.0
  chip ID: 8086:0116
  Device-2: AMD Seymour [Radeon HD 6400M/7400M Series]
  vendor: Hewlett-Packard driver: radeon v: kernel bus ID: 01:00.0
  chip ID: 1002:6760
  Display: x11 server: X.Org 1.20.4 driver: ati,modesetting,radeon
  unloaded: fbdev,vesa compositor: marco resolution: 1366x768~60Hz
  OpenGL: renderer: Mesa DRI Intel Sandybridge Mobile v: 3.3 Mesa 19.0.8
Audio:
  Device-1: Intel 6 Series/C200 Series Family High Definition Audio
  vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  chip ID: 8086:1c20
  Sound Server: ALSA v: k5.0.0-37-generic
Network:
  Device-1: Broadcom and subsidiaries BCM4313 802.11bgn Wireless Network
  Adapter
  vendor: Hewlett-Packard driver: wl v: kernel port: 4000 bus ID: 04:00.0
  chip ID: 14e4:4727
  IF: wlp4s0 state: up mac: <filter>
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet
  vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus ID: 05:00.0
  chip ID: 10ec:8136
  IF: eno1 state: down mac: <filter>
Drives:
  Local Storage: total: 298.09 GiB used: 21.80 GiB (7.3%)
  ID-1: /dev/sda vendor: Seagate model: ST320LT020-9YG142 size: 298.09 GiB
Partition:
  ID-1: / size: 292.41 GiB used: 21.80 GiB (7.5%) fs: ext4 dev: /dev/sda1
Sensors:
  System Temperatures: cpu: 68.0 C mobo: N/A gpu: radeon temp: 55 C
  Fan Speeds (RPM): N/A
Info:
  Processes: 210 Uptime: 35m Memory: 3.80 GiB used: 1.71 GiB (45.0%)
  Init: systemd v: 237 runlevel: 5 Compilers: gcc:
Kullanıcı değiştirme ekranında kullanıcılara fare ile tıklanmıyor, klavyedeki aşağı yukarı tuşları ile işlem yapabiliyorum. Bunu nasıl düzeltebilirim?
Düzenleme: Konu başlığı
« Son Düzenleme: 03 Ocak 2020, 04:46:07 Gönderen: fikretugur »
Ne tür fare kullanıyorsunuz, kablosuz/bluetooth fare midir?
  • İleti: 46
 Pardon. Fare değil. Touchpad diye geçiyor sanırım ismi. Dizüstü bilgisayarlarda klavyenin altında bulunan dokunmatik bölge.
Ynt: Giriş Ekranında Dokunmatik Panelin Çalışmaması Sorunu
« Yanıtla #3 : 02 Ocak 2020, 17:27:50 »
Bu sorun sisteminizi ilk açtığınızda mı oluyor? Oturumu kapatıp açınca durum ne oluyor?
Ayrıca aşağıdaki komutla xserver-xorg-input-synaptics paketni kurup sistemi yeniden başlatmayı deneyebilirsiniz.
sudo apt install xserver-xorg-input-synaptics
  • İleti: 46
« Yanıtla #4 : 03 Ocak 2020, 04:45:35 »
 Her iki durumda da dediğim sorun oluyordu. Dediğinizi yaptım sorun çözüldü. Teşekkürler.
