Gönderen Konu: Yeniden başlat veya kapata bastığımda işlem yapılmaması  (Okunma sayısı 2277 defa)
Çevrimdışı fikretugur
  • İleti: 46
System:
  Host: HP-Pavilion-g6-Notebook-PC Kernel: 5.0.0-37-generic x86_64
  bits: 64 compiler: gcc v: 7.4.0 Desktop: MATE 1.22.2 wm: marco dm: LightDM
Machine:
  Type: Laptop System: Hewlett-Packard product: HP Pavilion g6 Notebook PC
  v: 0692120000204610000610100 serial: <filter> Chassis: type: 10
  serial: <filter>
  Mobo: Hewlett-Packard model: 1670 v: 09.36 serial: <filter>
  BIOS: Hewlett-Packard v: F.30 date: 06/21/2011
CPU:
  Topology: Dual Core model: Intel Core i5-2430M bits: 64 type: MT MCP
  arch: Sandy Bridge rev: 7 L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19155
  Speed: 798 MHz min/max: 800/3000 MHz Core speeds (MHz): 1: 798 2: 798
  3: 798 4: 798
Graphics:
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
  vendor: Hewlett-Packard driver: i915 v: kernel bus ID: 00:02.0
  chip ID: 8086:0116
  Device-2: AMD Seymour [Radeon HD 6400M/7400M Series]
  vendor: Hewlett-Packard driver: radeon v: kernel bus ID: 01:00.0
  chip ID: 1002:6760
  Display: x11 server: X.Org 1.20.4 driver: ati,modesetting,radeon
  unloaded: fbdev,vesa compositor: marco resolution: 1366x768~60Hz
  OpenGL: renderer: Mesa DRI Intel Sandybridge Mobile v: 3.3 Mesa 19.0.8
Audio:
  Device-1: Intel 6 Series/C200 Series Family High Definition Audio
  vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  chip ID: 8086:1c20
  Sound Server: ALSA v: k5.0.0-37-generic
Network:
  Device-1: Broadcom and subsidiaries BCM4313 802.11bgn Wireless Network
  Adapter
  vendor: Hewlett-Packard driver: wl v: kernel port: 4000 bus ID: 04:00.0
  chip ID: 14e4:4727
  IF: wlp4s0 state: up mac: <filter>
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet
  vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus ID: 05:00.0
  chip ID: 10ec:8136
  IF: eno1 state: down mac: <filter>
Drives:
  Local Storage: total: 298.09 GiB used: 21.80 GiB (7.3%)
  ID-1: /dev/sda vendor: Seagate model: ST320LT020-9YG142 size: 298.09 GiB
Partition:
  ID-1: / size: 292.41 GiB used: 21.80 GiB (7.5%) fs: ext4 dev: /dev/sda1
Sensors:
  System Temperatures: cpu: 68.0 C mobo: N/A gpu: radeon temp: 55 C
  Fan Speeds (RPM): N/A
Info:
  Processes: 210 Uptime: 35m Memory: 3.80 GiB used: 1.71 GiB (45.0%)
  Init: systemd v: 237 runlevel: 5 Compilers: gcc:
  Bazen normal bir şekilde gerçekleşiyor bazen ise açıklayacağım şekilde sorun oluyor. Yeniden başlat veya kapata bastığımda bu işlemi yaptığım çıkış penceresi kapanıyor. Kapanacak sanıyorum ama bir işlem gerçekleşmiyor. En son bıraktığım şekilde kalıyor ekran, varsa programlar. İkinci defa çıkış penceresine girip yeniden başlat veya kapat dediğimde işlem gerçekleşiyor. Her zaman olmuyor ama sık oluyor bu problem. Nasıl düzeltebilirim?
Ynt: Yeniden başlat veya kapata bastığımda işlem yapılmaması
« Yanıtla #1 : 02 Ocak 2020, 21:24:10 »
Açtığınız diğer konuda Xorg sürümünü 1.19.x sürüme düşürmüştük, bu çıktıda 1.20.x olarak görünüyor. Bu sorun düşürdüğümüz sürümde devam ediyor mu, güncel durum nedir?
  • İleti: 46
« Yanıtla #2 : 02 Ocak 2020, 23:27:46 »
Pardon kopyala yapıştır yapmıştım. Evet devam ediyor sorun.
« Yanıtla #3 : 03 Ocak 2020, 14:43:12 »
Aşağıdaki komutlarla acpi=force değişkenini açılışa eklemeyi deneyebilirsiniz.
echo 'GRUB_CMDLINE_LINUX="$GRUB_CMDLINE_LINUX acpi=force"' | sudo tee  /etc/default/grub.d/acpi-force.cfg
sudo update-grub
Ardından sistemi yeniden başlatıp, durumu gözlemlersiniz.
Geri dönüş yapılmadığı için konu kilitlenmiştir.
« Son Düzenleme: 06 Şubat 2020, 17:13:56 Gönderen: Butterfly »
