Gönderen Konu: Linux Mint 19.3 Yavaş Açılma Sorunu Yaşıyorum  (Okunma sayısı 2813 defa)
Çevrimdışı HALDUNHİTAY
  • İleti: 89
  • Dağıtım: LİNUX MİNT
  • Grafik Kartı: Intel Haswell Mobile
  • İşlemci: Intel Core i5-4210U CPU
Değerli üstadım, ben de aynı dertten muzdaribim. Linux Mint'in açılması 3-4 dakika sürüyor.Yardımcı olursanız sevinirim.Çıktılar şöyle:
haldun[member=3507]Haldun[/member]-PU551LD:~$ systemd-analyze
Startup finished in 7.849s (kernel) + 3min 3.925s (userspace) = 3min 11.774s
graphical.target reached after 1min 37.791s in userspace
haldun[member=3507]Haldun[/member]-PU551LD:~$ systemd-analyze --no-pager critical-chain
The time after the unit is active or started is printed after the "@" character.
The time the unit takes to start is printed after the "+" character.
graphical.target @1min 37.791s
└─multi-user.target @1min 37.791s
  └─getty.target @1min 37.790s
    └─getty@tty1.service @1min 37.790s
      └─system-getty.slice @1min 37.790s
        └─setvtrgb.service @1min 37.684s +105ms
          └─systemd-user-sessions.service @1min 36.656s +3ms
            └─network.target @1min 36.654s
              └─NetworkManager.service @1min 33.800s +2.853s
                └─dbus.service @1min 33.750s
                  └─basic.target @1min 33.725s
                    └─sockets.target @1min 33.725s
                      └─acpid.socket @1min 33.725s
                        └─sysinit.target @1min 33.674s
                          └─systemd-timesyncd.service @19.418s +672ms
                            └─systemd-tmpfiles-setup.service @19.228s +188ms
                              └─systemd-journal-flush.service @4.124s +15.103s
                                └─systemd-journald.service @3.628s +494ms
                                  └─systemd-journald-dev-log.socket @3.627s
                                    └─system.slice @3.566s
                                      └─-.slice @3.533s
haldun[member=3507]Haldun[/member]-PU551LD:~$ systemctl status NetworkManager.service --no-pager -l
● NetworkManager.service - Network Manager
   Loaded: loaded (/lib/systemd/system/NetworkManager.service; enabled; vendor preset: enabled)
   Active: active (running) since Wed 2020-01-15 10:00:23 +03; 28min ago
     Docs: man:NetworkManager(8)
 Main PID: 814 (NetworkManager)
    Tasks: 4 (limit: 4501)
   CGroup: /system.slice/NetworkManager.service
           ├─ 814 /usr/sbin/NetworkManager --no-daemon
           └─1868 /sbin/dhclient -d -q -sf /usr/lib/NetworkManager/nm-dhcp-helper -pf /run/dhclient-wlp4s0.pid -lf /var/lib/NetworkManager/dhclient-e9190190-18f5-4a47-bef9-91c9239530a4-wlp4s0.lease -cf /var/lib/NetworkManager/dhclient-wlp4s0.conf wlp4s0
Oca 15 10:26:49 haldun-PU551LD NetworkManager[814]: <info>  [1579073209.8451] dhcp4 (wlp4s0): state changed unknown -> bound
Oca 15 10:26:49 haldun-PU551LD NetworkManager[814]: <info>  [1579073209.8484] device (wlp4s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Oca 15 10:26:49 haldun-PU551LD NetworkManager[814]: <info>  [1579073209.8495] device (wlp4s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Oca 15 10:26:49 haldun-PU551LD NetworkManager[814]: <info>  [1579073209.8500] device (wlp4s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Oca 15 10:26:49 haldun-PU551LD NetworkManager[814]: <info>  [1579073209.8503] manager: NetworkManager state is now CONNECTED_LOCAL
Oca 15 10:26:49 haldun-PU551LD dhclient[1868]: bound to 192.168.0.13 -- renewal in 246691 seconds.
Oca 15 10:26:49 haldun-PU551LD NetworkManager[814]: <info>  [1579073209.9222] manager: NetworkManager state is now CONNECTED_SITE
Oca 15 10:26:49 haldun-PU551LD NetworkManager[814]: <info>  [1579073209.9224] policy: set 'Otomatik NetMASTER Uydunet-4F9C' (wlp4s0) as default for IPv4 routing and DNS
Oca 15 10:26:49 haldun-PU551LD NetworkManager[814]: <info>  [1579073209.9231] device (wlp4s0): Activation: successful, device activated.
Oca 15 10:26:51 haldun-PU551LD NetworkManager[814]: <info>  [1579073211.3110] manager: NetworkManager state is now CONNECTED_GLOBAL
haldun[member=3507]Haldun[/member]-PU551LD:~$ dmesg | nc termbin.com 9999
https://termbin.com/nw43
Tek bildiğim, hiçbir şey bilmediğimdir.
Ynt: Linux Mint 19.3 Yavaş Açılma Sorunu Yaşıyorum
« Yanıtla #1 : 15 Ocak 2020, 12:42:23 »
[member=502]HALDUNHİTAY[/member] , sizin açtığınız konuyu bölerek yeni bir konu oluşturdum. Sorunlar benzer de olsa, ayrı başlıkta çözüm aranmasını istiyoruz. Zira sorunun nedeni farklı olabilir ve her soruna farklı çözüm önerisi sunulabilir.
[   25.470367] USB Video Class driver (1.1.1)
[   26.285865] FAT-fs (sda2): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[  101.687680] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Mesela sizin sistemde, sda olarak görünen disk ya da USB bellek de dosya sistemi sorunu olduğu anlaşılıyor. Sistemi USB belleği çıkartıp açmayı deneyiniz. Eğer sorun çözülmezse farklı çıktılar da isteyebiliriz.
USB bellekteki dosya sistemini ise aşağıdaki komutlarla düzeltmeyi deneyebilirsiniz.
sudo umount /dev/sdb1
sudo dosfsck -t -a -w /dev/sdb1
  • İleti: 89
« Yanıtla #2 : 15 Ocak 2020, 17:21:13 »
Bluetooth ve ağ bağlantısını pasif duruma getirip , usb belleği verdiğiniz komutlarla formatladım. Sonra usb belleği çıkarıp sistemi yeniden başlattığımda , 2 dak. 20 sn. sonra giriş gerçekleşti. Bu süre normal midir ?
« Yanıtla #3 : 15 Ocak 2020, 17:32:03 »
Süre normal değil, aşağaıdaki komutların çıktılarını paylaşın.
inxi -Fxxz
systemd-analyze time
journalctl --no-pager -b -p3
systemctl --no-pager --state=failed
cat /etc/fstab
sudo blkid
cat /etc/initramfs-tools/conf.d/resume
  • İleti: 89
« Yanıtla #4 : 15 Ocak 2020, 17:56:26 »
Buyrun :
haldun[member=3507]Haldun[/member]-PU551LD:~$ inxi -Fxxz
System:
  Host: haldun-PU551LD Kernel: 4.15.0-74-generic x86_64 bits: 64
  compiler: gcc v: 7.4.0 Desktop: Cinnamon 4.4.8 wm: muffin dm: LightDM
Machine:
  Type: Laptop System: ASUSTeK product: PU551LD v: 1.0 serial: <filter>
  Mobo: ASUSTeK model: PU551LD v: 1.0 serial: <filter>
  BIOS: American Megatrends v: PU551LD.211 date: 04/24/2019
Battery:
  ID-1: BAT0 charge: 27.6 Wh condition: 28.3/37.4 Wh (76%) volts: 14.4/14.4
  model: ASUSTeK PU45026 serial: <filter> status: Not charging
CPU:
  Topology: Dual Core model: Intel Core i5-4210U bits: 64 type: MT MCP
  arch: Haswell rev: 1 L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19155
  Speed: 898 MHz min/max: 800/2700 MHz Core speeds (MHz): 1: 854 2: 812
  3: 853 4: 840
Graphics:
  Device-1: Intel Haswell-ULT Integrated Graphics vendor: ASUSTeK
  driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0a16
  Device-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT
  620M/625M/630M/720M]
  vendor: ASUSTeK driver: nouveau v: kernel bus ID: 05:00.0
  chip ID: 10de:1140
  Display: x11 server: X.Org 1.20.4 driver: modesetting unloaded: fbdev,vesa
  resolution: 1366x768~60Hz
  OpenGL: renderer: Mesa DRI Intel Haswell Mobile v: 4.5 Mesa 19.0.8
Audio:
  Device-1: Intel Haswell-ULT HD Audio driver: snd_hda_intel v: kernel
  bus ID: 00:03.0 chip ID: 8086:0a0c
  Device-2: Intel 8 Series HD Audio vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus ID: 00:1b.0 chip ID: 8086:9c20
  Sound Server: ALSA v: k4.15.0-74-generic
Network:
  vendor: ASUSTeK driver: r8169 v: 2.3LK-NAPI port: e000 bus ID: 03:00.0
  chip ID: 10ec:8168
  IF: enp3s0 state: down mac: <filter>
  Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
  vendor: AzureWave driver: ath9k v: kernel port: e000 bus ID: 04:00.0
  chip ID: 168c:0036
  IF: wlp4s0 state: up mac: <filter>
Drives:
  Local Storage: total: 465.76 GiB used: 98.07 GiB (21.1%)
  ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS545050A7E680
  size: 465.76 GiB speed: 6.0 Gb/s serial: <filter>
Partition:
  ID-1: / size: 185.44 GiB used: 53.33 GiB (28.8%) fs: ext4 dev: /dev/sda1
Sensors:
  System Temperatures: cpu: 40.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 2200
Info:
  Processes: 197 Uptime: 42m Memory: 3.73 GiB used: 942.7 MiB (24.7%)
  Init: systemd v: 237 runlevel: 5 target: graphical.target Compilers:
  gcc: 7.4.0 alt: 7 Shell: bash v: 4.4.20 running in: gnome-terminal
  inxi: 3.0.32
https://termbin.com/s7b8
haldun[member=3507]Haldun[/member]-PU551LD:~$ systemd-analyze time
Startup finished in 7.968s (kernel) + 3min 4.028s (userspace) = 3min 11.997s
graphical.target reached after 1min 40.921s in userspace
haldun[member=3507]Haldun[/member]-PU551LD:~$ systemd-analyze --no-pager blame
         15.470s systemd-journal-flush.service
         13.529s dev-sda1.device
         12.989s lvm2-monitor.service
         12.796s ufw.service
         11.850s keyboard-setup.service
         11.846s systemd-modules-load.service
         11.727s systemd-tmpfiles-setup-dev.service
          7.019s ubuntu-system-adjustments.service
          4.209s networkd-dispatcher.service
          3.522s udisks2.service
          2.139s NetworkManager.service
          1.829s ModemManager.service
          1.809s accounts-daemon.service
          1.667s dns-clean.service
          1.654s gpu-manager.service
          1.491s systemd-random-seed.service
           969ms wpa_supplicant.service
           847ms systemd-resolved.service
           845ms systemd-timesyncd.service
           760ms avahi-daemon.service
           682ms mnt-0057\x2dAA27.mount
           671ms grub-common.service
           652ms networking.service
           627ms colord.service
           603ms polkit.service
           394ms apparmor.service
           347ms kmod-static-nodes.service
           320ms thermald.service
           310ms systemd-journald.service
           306ms systemd-logind.service
           302ms kerneloops.service
           302ms lm-sensors.service
           299ms lightdm.service
           297ms plymouth-quit-wait.service
           286ms systemd-sysctl.service
           259ms rsyslog.service
           201ms packagekit.service
           196ms systemd-tmpfiles-setup.service
           185ms systemd-remount-fs.service
           179ms upower.service
           152ms setvtrgb.service
           144ms sys-kernel-debug.mount
           141ms dev-hugepages.mount
           132ms systemd-tmpfiles-clean.service
           122ms user@1000.service
           121ms hddtemp.service
           105ms dev-mqueue.mount
            95ms systemd-udev-trigger.service
            86ms pppd-dns.service
            84ms blk-availability.service
            82ms bluetooth.service
            80ms speech-dispatcher.service
            68ms alsa-restore.service
            66ms rng-tools.service
            65ms systemd-update-utmp.service
            58ms systemd-udevd.service
            52ms systemd-rfkill.service
            14ms plymouth-start.service
            12ms plymouth-read-write.service
             9ms rtkit-daemon.service
             6ms systemd-update-utmp-runlevel.service
             6ms sys-fs-fuse-connections.mount
             5ms ureadahead-stop.service
             4ms systemd-backlight@backlight:intel_backlight.service
             4ms systemd-user-sessions.service
             2ms sys-kernel-config.mount
             2ms console-setup.service
             1ms openvpn.service
graphical.target @1min 40.921s
└─multi-user.target @1min 40.921s
  └─ubuntu-system-adjustments.service @1min 33.901s +7.019s
    └─basic.target @1min 33.891s
      └─sockets.target @1min 33.891s
        └─dbus.socket @1min 33.891s
          └─sysinit.target @1min 33.778s
            └─systemd-timesyncd.service @19.620s +845ms
              └─systemd-tmpfiles-setup.service @19.417s +196ms
                └─systemd-journal-flush.service @3.946s +15.470s
                  └─systemd-journald.service @3.634s +310ms
                    └─systemd-journald-audit.socket @3.631s
                      └─system.slice @3.588s
                        └─-.slice @3.555s
haldun[member=3507]Haldun[/member]-PU551LD:~$ journalctl --no-pager -b -p3
-- Logs begin at Thu 2019-12-19 16:58:49 +03, end at Wed 2020-01-15 17:53:14 +03. --
Oca 15 17:10:02 haldun-PU551LD systemd[1]: Timed out waiting for device dev-disk-by\x2duuid-34d220b0\x2d6f0a\x2d4054\x2dbd8d\x2dbec9a9355d41.device.
Oca 15 17:10:02 haldun-PU551LD systemd[1]: Timed out waiting for device dev-disk-by\x2duuid-c38d6150\x2db268\x2d4f46\x2da8b1\x2d33b8731ff7b2.device.
Oca 15 17:10:02 haldun-PU551LD systemd[1]: Timed out waiting for device dev-disk-by\x2did-usb\x2dKingston_DataTraveler_3.0_C03FD5F2F334F260E99E0BA4\x2d0:0\x2dpart1.device.
Oca 15 17:10:02 haldun-PU551LD systemd[1]: Timed out waiting for device dev-disk-by\x2did-usb\x2dKingston_DataTraveler_3.0_C03FD5F2F334F260E99E0BA4\x2d0:0.device.
Oca 15 17:10:02 haldun-PU551LD systemd[1]: Timed out waiting for device dev-disk-by\x2duuid-df0d3493\x2d4175\x2d4d42\x2da483\x2d13f5b82a94d2.device.
Oca 15 17:10:03 haldun-PU551LD bluetoothd[845]: Failed to set mode: Blocked through rfkill (0x12)
Oca 15 17:10:06 haldun-PU551LD wpa_supplicant[855]: dbus: wpa_dbus_get_object_properties: failed to get object properties: (none) none
Oca 15 17:10:06 haldun-PU551LD wpa_supplicant[855]: dbus: Failed to construct signal
Oca 15 17:10:09 haldun-PU551LD kernel: nouveau 0000:05:00.0: bus: MMIO write of 0000041f FAULT at 6013d4 [ IBUS ]
Oca 15 17:10:09 haldun-PU551LD kernel: nouveau 0000:05:00.0: bus: MMIO write of badf1001 FAULT at 50405c [ IBUS ]
Oca 15 17:10:13 haldun-PU551LD pulseaudio[1238]: [pulseaudio] backend-ofono.c: Failed to register as a handsfree audio agent with ofono: org.freedesktop.DBus.Error.ServiceUnknown: The name org.ofono was not provided by any .service files
Oca 15 17:10:13 haldun-PU551LD pulseaudio[1302]: [pulseaudio] pid.c: Daemon already running.
Oca 15 17:10:21 haldun-PU551LD bluetoothd[845]: Failed to set mode: Blocked through rfkill (0x12)
Oca 15 17:11:32 haldun-PU551LD systemd[1]: Timed out waiting for device dev-disk-by\x2did-usb\x2dKingston_DataTraveler_3.0_C03FD5F2F334F260E99E0BA4\x2d0:0\x2dpart1.device.
Oca 15 17:11:32 haldun-PU551LD systemd[1]: Timed out waiting for device dev-disk-by\x2did-usb\x2dKingston_DataTraveler_3.0_C03FD5F2F334F260E99E0BA4\x2d0:0.device.
Oca 15 17:11:32 haldun-PU551LD systemd[1]: Timed out waiting for device dev-disk-by\x2duuid-df0d3493\x2d4175\x2d4d42\x2da483\x2d13f5b82a94d2.device.
Oca 15 17:11:32 haldun-PU551LD systemd[1]: Timed out waiting for device dev-disk-by\x2duuid-34d220b0\x2d6f0a\x2d4054\x2dbd8d\x2dbec9a9355d41.device.
Oca 15 17:11:32 haldun-PU551LD systemd[1]: Timed out waiting for device dev-disk-by\x2duuid-c38d6150\x2db268\x2d4f46\x2da8b1\x2d33b8731ff7b2.device.
Oca 15 17:22:12 haldun-PU551LD systemd[1]: Timed out waiting for device dev-disk-by\x2duuid-c38d6150\x2db268\x2d4f46\x2da8b1\x2d33b8731ff7b2.device.
Oca 15 17:22:12 haldun-PU551LD systemd[1]: Timed out waiting for device dev-disk-by\x2duuid-34d220b0\x2d6f0a\x2d4054\x2dbd8d\x2dbec9a9355d41.device.
Oca 15 17:22:12 haldun-PU551LD systemd[1]: Timed out waiting for device dev-disk-by\x2did-usb\x2dKingston_DataTraveler_3.0_C03FD5F2F334F260E99E0BA4\x2d0:0.device.
Oca 15 17:22:12 haldun-PU551LD systemd[1]: Timed out waiting for device dev-disk-by\x2did-usb\x2dKingston_DataTraveler_3.0_C03FD5F2F334F260E99E0BA4\x2d0:0\x2dpart1.device.
Oca 15 17:22:12 haldun-PU551LD systemd[1]: Timed out waiting for device dev-disk-by\x2duuid-df0d3493\x2d4175\x2d4d42\x2da483\x2d13f5b82a94d2.device.
Oca 15 17:50:34 haldun-PU551LD kernel: nouveau 0000:05:00.0: bus: MMIO write of ffff951f FAULT at 6013d4 [ IBUS ]
Oca 15 17:50:34 haldun-PU551LD kernel: nouveau 0000:05:00.0: bus: MMIO write of badf1001 FAULT at 50405c [ IBUS ]
Oca 15 17:50:35 haldun-PU551LD sudo[3516]:   haldun : a password is required ; TTY=pts/0 ; PWD=/home/haldun ; USER=root ; COMMAND=/usr/sbin/hddtemp -nq -u C /dev/sda
haldun[member=3507]Haldun[/member]-PU551LD:~$ systemctl --no-pager --state=failed
haldun[member=3507]Haldun[/member]-PU551LD:~$ cat /etc/fstab
# / was on /dev/sda1 during installation
UUID=f5fcd831-0d30-47df-9e80-c726f9d3e489 /               ext4    errors=remount-ro 0       1
# swap was on /dev/sda3 during installation
UUID=34d220b0-6f0a-4054-bd8d-bec9a9355d41 none            swap    sw              0       0
/dev/disk/by-uuid/c38d6150-b268-4f46-a8b1-33b8731ff7b2 /mnt/c38d6150-b268-4f46-a8b1-33b8731ff7b2 auto nosuid,nodev,nofail,x-gvfs-show 0 0
/dev/disk/by-uuid/0057-AA27 /mnt/0057-AA27 auto nosuid,nodev,nofail,x-gvfs-show 0 0
/dev/disk/by-uuid/df0d3493-4175-4d42-a483-13f5b82a94d2 /mnt/df0d3493-4175-4d42-a483-13f5b82a94d2 auto nosuid,nodev,nofail,x-gvfs-show 0 0
/dev/disk/by-id/usb-Kingston_DataTraveler_3.0_C03FD5F2F334F260E99E0BA4-0:0 /mnt/usb-Kingston_DataTraveler_3.0_C03FD5F2F334F260E99E0BA4-0:0 auto nosuid,nodev,nofail,x-gvfs-show 0 0
/dev/disk/by-id/usb-Kingston_DataTraveler_3.0_C03FD5F2F334F260E99E0BA4-0:0-part1 /mnt/usb-Kingston_DataTraveler_3.0_C03FD5F2F334F260E99E0BA4-0:0-part1 auto nosuid,nodev,nofail,x-gvfs-show 0 0
haldun[member=3507]Haldun[/member]-PU551LD:~$ sudo blkid
[sudo] password for haldun:
/dev/sda1: LABEL="Mint" UUID="f5fcd831-0d30-47df-9e80-c726f9d3e489" TYPE="ext4" PARTUUID="741d2acd-01"
/dev/sda2: LABEL="DM-DM-0SK2" UUID="0057-AA27" TYPE="vfat" PARTUUID="741d2acd-02"
/dev/sda3: UUID="17743a01-ee8e-4986-8e9e-f33aa68be507" TYPE="swap" PARTUUID="741d2acd-03"
/dev/sda4: LABEL="DEBIAN 10" UUID="fe3d283a-86b1-43e9-9e5e-9f7580db31a9" TYPE="ext4" PARTUUID="741d2acd-04"
haldun[member=3507]Haldun[/member]-PU551LD:~$ cat /etc/initramfs-tools/conf.d/resume
RESUME=none
« Yanıtla #5 : 15 Ocak 2020, 18:22:06 »
Açılışta otomatik bağlanma için ayarladığınız disk bölümlerinin tümünü pasifleştirmeyi deneyiniz. Bazıları artık mevcut değil görünüyor, bazıları için çift girdi eklenmiş. Sorunun kaynağı bu olabilir. Özellikle USB bellek gibi aygıtların açılışta otomatik bağlanması ile ilgili ayarlar uygun olmaz. Bu aygıtlar takılı olmadığında fstab dosyası sebebiyle açılış sorunları yaşanabilir.
« Son Düzenleme: 15 Ocak 2020, 18:24:48 Gönderen: Butterfly »
  • İleti: 89
« Yanıtla #6 : 15 Ocak 2020, 22:48:08 »
Ne yaptıysam olmadı.Tricia'yı yeniden kurdum ve şu anda sorun yok. İlginize teşekkür ederim.
