Gönderen Konu: Yazıcı - CUPS Sunucu Hatası  (Okunma sayısı 5828 defa)
Çevrimdışı infeyk
  • İleti: 18
  • Dağıtım: mint 19.3
« : 20 Ocak 2020, 16:52:54 »
linuc mint menüden yazıcıları açmaya çalıştığım zaman bu uyarıyı alıyorum
CUPS Sunucusuna bağlan diyince de bu hatayı alıyorum
Ynt: Yazıcı - CUPS Sunucu Hatası
« Yanıtla #1 : 20 Ocak 2020, 17:33:46 »
Komutların çıktılarını paylaşınız.
systemctl status cups --no-page -l
systemctl list-unit-files | egrep 'disabled|masked'
Çevrimdışı infeyk
  • İleti: 18
« Yanıtla #2 : 21 Ocak 2020, 09:03:20 »
Kod Çıktısı
● cups.service - CUPS Scheduler
   Loaded: loaded (/lib/systemd/system/cups.service; enabled; vendor preset: enabled)
   Active: failed (Result: start-limit-hit) since Tue 2020-01-21 08:51:12 +03; 10min ago
     Docs: man:cupsd(8)
  Process: 2702 ExecStart=/usr/sbin/cupsd -l (code=killed, signal=TERM)
 Main PID: 2702 (code=killed, signal=TERM)
Oca 21 08:51:12 infeyk-mint systemd[1]: cups.service: Service hold-off time over, scheduling restart.
Oca 21 08:51:12 infeyk-mint systemd[1]: cups.service: Scheduled restart job, restart counter is at 5.
Oca 21 08:51:12 infeyk-mint systemd[1]: Stopped CUPS Scheduler.
Oca 21 08:51:12 infeyk-mint systemd[1]: cups.service: Start request repeated too quickly.
Oca 21 08:51:12 infeyk-mint systemd[1]: cups.service: Failed with result 'start-limit-hit'.
Oca 21 08:51:12 infeyk-mint systemd[1]: Failed to start CUPS Scheduler.
Kod Çıktısı
acpid.service                                                    disabled
alsa-utils.service                                               masked
bootlogd.service                                                 masked
bootlogs.service                                                 masked
bootmisc.service                                                 masked
brltty.service                                                   disabled
checkfs.service                                                  masked
checkroot-bootclean.service                                      masked
checkroot.service                                                masked
console-getty.service                                            disabled
cryptdisks-early.service                                         masked
cryptdisks.service                                               masked
debug-shell.service                                              disabled
fuse.service                                                     masked
halt.service                                                     masked
hostname.service                                                 masked
hwclock.service                                                  masked
killprocs.service                                                masked
lvm2.service                                                     masked
mintupdate-automation-upgrade.service                            disabled
motd.service                                                     masked
mountall-bootclean.service                                       masked
mountall.service                                                 masked
mountdevsubfs.service                                            masked
mountkernfs.service                                              masked
mountnfs-bootclean.service                                       masked
mountnfs.service                                                 masked
openvpn-client@.service                                          disabled
openvpn-server@.service                                          disabled
openvpn@.service                                                 disabled
rc.service                                                       masked
rcS.service                                                      masked
reboot.service                                                   masked
rmnologin.service                                                masked
rtkit-daemon.service                                             disabled
saned.service                                                    masked
sendsigs.service                                                 masked
serial-getty@.service                                            disabled
single.service                                                   masked
stop-bootlogd-single.service                                     masked
stop-bootlogd.service                                            masked
sudo.service                                                     masked
systemd-networkd-wait-online.service                             disabled
systemd-networkd.service                                         disabled
systemd-timesyncd.service                                        disabled
umountfs.service                                                 masked
umountnfs.service                                                masked
umountroot.service                                               masked
upower.service                                                   disabled
wpa_supplicant-wired@.service                                    disabled
wpa_supplicant@.service                                          disabled
x11-common.service                                               masked
saned.socket                                                     disabled
systemd-networkd.socket                                          disabled
ctrl-alt-del.target                                              disabled
exit.target                                                      disabled
halt.target                                                      disabled
kexec.target                                                     disabled
poweroff.target                                                  disabled
reboot.target                                                    disabled
remote-cryptsetup.target                                         disabled
runlevel0.target                                                 disabled
runlevel6.target                                                 disabled
mintupdate-automation-autoremove.timer                           disabled
mintupdate-automation-upgrade.timer                              disabled
« Yanıtla #3 : 21 Ocak 2020, 13:18:56 »
Aşağıdaki komutların çıktılarına da bakalım.
cat /etc/systemd/system.conf
cat /etc/cups/cupsd.conf
dpkg -l | grep cups
Bu arada aşağıdaki komutla Cups servisini elle başlatmayı deneyebilirsiniz.
sudo systemctl restart cups
« Son Düzenleme: 21 Ocak 2020, 13:20:18 Gönderen: Butterfly »
Çevrimdışı infeyk
  • İleti: 18
« Yanıtla #4 : 21 Ocak 2020, 13:23:07 »
#  This file is part of systemd.
#  systemd is free software; you can redistribute it and/or modify it
#  under the terms of the GNU Lesser General Public License as published by
#  the Free Software Foundation; either version 2.1 of the License, or
#  (at your option) any later version.
# Entries in this file show the compile time defaults.
# You can change settings by editing this file.
# Defaults can be restored by simply deleting this file.
# See systemd-system.conf(5) for details.
[Manager]
#LogLevel=info
#LogTarget=journal-or-kmsg
#LogColor=yes
#LogLocation=no
#DumpCore=yes
#ShowStatus=yes
#CrashChangeVT=no
#CrashShell=no
#CrashReboot=no
#CtrlAltDelBurstAction=reboot-force
#CPUAffinity=1 2
#JoinControllers=cpu,cpuacct net_cls,net_prio
#RuntimeWatchdogSec=0
#ShutdownWatchdogSec=10min
#CapabilityBoundingSet=
#SystemCallArchitectures=
#TimerSlackNSec=
#DefaultTimerAccuracySec=1min
#DefaultStandardOutput=journal
#DefaultStandardError=inherit
#DefaultTimeoutStartSec=90s
#DefaultTimeoutStopSec=90s
#DefaultRestartSec=100ms
#DefaultStartLimitIntervalSec=10s
#DefaultStartLimitBurst=5
#DefaultEnvironment=
#DefaultCPUAccounting=no
#DefaultIOAccounting=no
#DefaultIPAccounting=no
#DefaultBlockIOAccounting=no
#DefaultMemoryAccounting=no
#DefaultTasksAccounting=yes
#DefaultTasksMax=
#DefaultLimitCPU=
#DefaultLimitFSIZE=
#DefaultLimitDATA=
#DefaultLimitSTACK=
#DefaultLimitCORE=
#DefaultLimitRSS=
#DefaultLimitNOFILE=
#DefaultLimitAS=
#DefaultLimitNPROC=
#DefaultLimitMEMLOCK=
#DefaultLimitLOCKS=
#DefaultLimitSIGPENDING=
#DefaultLimitMSGQUEUE=
#DefaultLimitNICE=
#DefaultLimitRTPRIO=
#DefaultLimitRTTIME=
#IPAddressAllow=
#IPAddressDeny=
cat: /etc/cups/cupsd.conf: Erişim engellendi
sudo yetkisiyle kullandığım zaman çıktı aşağıdaki gibi oldu
sudo cat /etc/cups/cupsd.conf
[sudo] password for infeyk:
PreserveJobFiles Yes
dpkg -l | grep cups
ii  cups                                       2.2.7-1ubuntu2.7                                amd64        Common UNIX Printing System(tm) - PPD/driver support, web interface
ii  cups-backend-bjnp                          2.0.1-1                                         amd64        printer backend for Canon BJNP protocol
ii  cups-browsed                               1.20.2-0ubuntu3.1                               amd64        OpenPrinting CUPS Filters - cups-browsed
ii  cups-bsd                                   2.2.7-1ubuntu2.7                                amd64        Common UNIX Printing System(tm) - BSD commands
ii  cups-client                                2.2.7-1ubuntu2.7                                amd64        Common UNIX Printing System(tm) - client programs (SysV)
ii  cups-common                                2.2.7-1ubuntu2.7                                all          Common UNIX Printing System(tm) - common files
ii  cups-core-drivers                          2.2.7-1ubuntu2.7                                amd64        Common UNIX Printing System(tm) - driverless printing
ii  cups-daemon                                2.2.7-1ubuntu2.7                                amd64        Common UNIX Printing System(tm) - daemon
ii  cups-filters                               1.20.2-0ubuntu3.1                               amd64        OpenPrinting CUPS Filters - Main Package
ii  cups-filters-core-drivers                  1.20.2-0ubuntu3.1                               amd64        OpenPrinting CUPS Filters - Driverless printing
ii  cups-ipp-utils                             2.2.7-1ubuntu2.7                                amd64        Common UNIX Printing System(tm) - IPP developer/admin utilities
ii  cups-pk-helper                             0.2.6-1ubuntu1.2                                amd64        PolicyKit helper to configure cups with fine-grained privileges
ii  cups-ppdc                                  2.2.7-1ubuntu2.7                                amd64        Common UNIX Printing System(tm) - PPD manipulation utilities
ii  cups-server-common                         2.2.7-1ubuntu2.7                                all          Common UNIX Printing System(tm) - server common files
ii  cups-tea4cups                              3.13~alpha0+svn3565-4                           all          Swiss Army's knife of advanced CUPS administrators
ii  cups-x2go                                  3.0.1.3-2                                       all          Virtual X2Go printer for CUPS
ii  libcups2:amd64                             2.2.7-1ubuntu2.7                                amd64        Common UNIX Printing System(tm) - Core library
ii  libcups2-dev:amd64                         2.2.7-1ubuntu2.7                                amd64        Common UNIX Printing System(tm) - Development files CUPS library
ii  libcupscgi1:amd64                          2.2.7-1ubuntu2.7                                amd64        Common UNIX Printing System(tm) - CGI library
ii  libcupsfilters1:amd64                      1.20.2-0ubuntu3.1                               amd64        OpenPrinting CUPS Filters - Shared library
ii  libcupsimage2:amd64                        2.2.7-1ubuntu2.7                                amd64        Common UNIX Printing System(tm) - Raster image library
ii  libcupsimage2-dev:amd64                    2.2.7-1ubuntu2.7                                amd64        Common UNIX Printing System(tm) - Development files CUPS image library
ii  libcupsmime1:amd64                         2.2.7-1ubuntu2.7                                amd64        Common UNIX Printing System(tm) - MIME library
ii  libcupsppdc1:amd64                         2.2.7-1ubuntu2.7                                amd64        Common UNIX Printing System(tm) - PPD manipulation library
ii  printer-driver-cups-pdf                    3.0.1-5                                         amd64        printer driver for PDF writing via CUPS
ii  printer-driver-hpcups                      3.17.10+repack0-5                               amd64        HP Linux Printing and Imaging - CUPS Raster driver (hpcups)
ii  python3-cups                               1.9.73-2                                        amd64        Python3 bindings for CUPS
ii  python3-cupshelpers                        1.5.11-1ubuntu2                                 all          Python utility modules around the CUPS printing system
sudo systemctl restart cupsbu komut herhangi bir çıktı vermedi
« Son Düzenleme: 21 Ocak 2020, 13:25:35 Gönderen: infeyk »
« Yanıtla #5 : 21 Ocak 2020, 13:55:09 »
Aşağıdaki komutlarla cupsd.conf dosyasını varsayılan ayarlarına döndürmeyi deneyiniz.
sudo rm -f /etc/cups/cupsd.conf
sudo cp /usr/share/cups/cupsd.conf.default /usr/share/cups/cupsd.conf.default
Ardından cups servisini yeniden başlatınız, bu herhangi bir çıktı vermeyecek. Sonra Yazıcılar aracını açmayı deneyebilirsiniz.
Çevrimdışı infeyk
  • İleti: 18
« Yanıtla #6 : 21 Ocak 2020, 14:04:16 »
komutları uyguladım fakat işe yaramadı
« Yanıtla #7 : 21 Ocak 2020, 14:05:06 »
Sistemi yeniden başlatıp, ilk olarak istenen komut çıktılarını yeniden paylaşaınız.
Çevrimdışı infeyk
  • İleti: 18
« Yanıtla #8 : 21 Ocak 2020, 14:16:48 »
   Active: failed (Result: exit-code) since Tue 2020-01-21 14:02:02 +03; 13min ago
     Docs: man:cupsd(8)
  Process: 890 ExecStart=/usr/sbin/cupsd -l (code=exited, status=1/FAILURE)
 Main PID: 890 (code=exited, status=1/FAILURE)
Oca 21 14:02:02 infeyk-mint systemd[1]: Stopped CUPS Scheduler.
Oca 21 14:02:02 infeyk-mint systemd[1]: Started CUPS Scheduler.
Oca 21 14:02:02 infeyk-mint systemd[1]: cups.service: Main process exited, code=exited, status=1/FAILURE
Oca 21 14:02:02 infeyk-mint systemd[1]: cups.service: Failed with result 'exit-code'.
Oca 21 14:02:02 infeyk-mint systemd[1]: cups.service: Service hold-off time over, scheduling restart.
Oca 21 14:02:02 infeyk-mint systemd[1]: cups.service: Scheduled restart job, restart counter is at 5.
Oca 21 14:02:02 infeyk-mint systemd[1]: cups.service: Start request repeated too quickly.
Oca 21 14:02:02 infeyk-mint systemd[1]: Failed to start CUPS Scheduler.
fuse.service                                                     masked
halt.service                                                     masked
lvm2.service                                                     masked
motd.service                                                     masked
rc.service                                                       masked
rcS.service                                                      masked
sudo.service                                                     masked
« Yanıtla #9 : 21 Ocak 2020, 15:48:59 »
journalctl -b | grep -i "cups\|printer"
sudo cat /usr/share/cups/cupsd.conf.default
Çevrimdışı infeyk
  • İleti: 18
« Yanıtla #10 : 22 Ocak 2020, 08:25:43 »
iş yeri bilgisayarı olduğu için mecburen linux mint 19.2 yükledim ve yazıcılar ile ilgili herhangi bir sorun kalmadı.
Yazıcıya çok ihtiyacım olduğundan dolayı, mecburen yükledim.
Emeğiniz için çok teşekkür ederim.
