Gönderen Konu: Arada bir mause imlecinin takılması/donması  (Okunma sayısı 2360 defa)
Çevrimdışı yinemimail
  • İleti: 262
« : 02 Nisan 2020, 17:28:04 »
Günlük kullanımda birkaç (özellikle) birkaç pencere açıkken mause imlecinin takılması/donması sorunu yaşamaktayım. Ne yapabilirim?
System:
  Host: sonrisa-SVE1513G1EW Kernel: 5.3.0-45-generic x86_64 bits: 64
  compiler: gcc v: 7.5.0 Desktop: Cinnamon 4.4.8 wm: muffin dm: LightDM
Machine:
  Type: Laptop System: Sony product: SVE1513G1EW v: C10GEX2T
  serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: Sony model: VAIO serial: <filter> UEFI: Insyde v: R0180D5
  date: 03/19/2013
Battery:
  ID-1: BAT1 charge: 0 Wh condition: 6.5/45.0 Wh (14%) volts: 2.8/10.8
  model: SONY Corp. VGP-BPS26 serial: <filter> status: Charging
CPU:
  Topology: Dual Core model: Intel Core i3-3120M bits: 64 type: MT MCP
  arch: Ivy Bridge rev: 9 L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19955
  Speed: 1198 MHz min/max: 1200/2500 MHz Core speeds (MHz): 1: 1197 2: 1200
  3: 1199 4: 1196
Graphics:
  Device-1: Intel 3rd Gen Core processor Graphics vendor: Sony driver: i915
  v: kernel bus ID: 00:02.0 chip ID: 8086:0166
  Display: x11 server: X.Org 1.20.5 driver: modesetting unloaded: fbdev,vesa
  resolution: 1366x768~60Hz
  OpenGL: renderer: Mesa DRI Intel Ivybridge Mobile v: 4.2 Mesa 19.2.8
Audio:
  Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Sony
  driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
  Sound Server: ALSA v: k5.3.0-45-generic
Network:
  Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter
  vendor: Foxconn Unex DHXA-225 driver: ath9k v: kernel port: 3040
  bus ID: 01:00.0 chip ID: 168c:0032
  IF: wlp1s0 state: up mac: <filter>
  Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
  vendor: Sony driver: r8169 v: kernel port: 2000 bus ID: 03:00.0
  chip ID: 10ec:8168
  IF: enp3s0 state: down mac: <filter>
Drives:
  Local Storage: total: 465.76 GiB used: 56.71 GiB (12.2%)
  ID-1: /dev/sda vendor: Toshiba model: MQ01ABD050 size: 465.76 GiB
Partition:
  ID-1: / size: 456.96 GiB used: 56.71 GiB (12.4%) fs: ext4 dev: /dev/sda2
Sensors:
  System Temperatures: cpu: 53.0 C mobo: N/A
  Fan Speeds (RPM): N/A
Info:
  Processes: 228 Uptime: 8m Memory: 3.73 GiB used: 1.30 GiB (35.0%)
  Init: systemd v: 237 runlevel: 5 Compilers: gcc: 7.5.0 alt: 7 Shell: bash
Ynt: Arada bir mause imlecinin takılması/donması
« Yanıtla #1 : 02 Nisan 2020, 19:18:54 »
Öncelikle şunu uygulamayı deneyebilirsiniz. [Nasıl] Takas Alanı Kullanımını Ayarlama(Swappiness)
  • İleti: 262
« Yanıtla #2 : 03 Nisan 2020, 16:18:29 »
Bilgisayara format atıldığında bu işlem sıfırlanıyor, değil mi?
Ek olarak şunu da belirteyim. Sorun internetten bağımsız olarak çok pencere açık olmasından ziyade, internette işler olurken, mesela tarayıcıda penceler yüklenirken ve ya download edilirken sorunlar yaşanıyor. İnternette herhangi bir işlem yapılmadığında sorun olmuyor.
Yukarıdaki söylenileni yaptım, bilgisayarı tekar açıp teyit de ettim.
« Son Düzenleme: 03 Nisan 2020, 16:24:02 Gönderen: yinemimail »
« Yanıtla #3 : 03 Nisan 2020, 19:00:53 »
Sisteminizi yeniden kurduğunuzda, doğal olarak yaptığınız tüm düzenlemeler kayboluyor.
Sistem gözlemcisini açıp, bahsettiğiniz donma sırasında takas alanının kullanılıp kullanılmadığını gözlemleyiniz. Eğer sorunun takas alanı kullanımı ile bağlantılı olmadığını tespit ederseniz, aşağıdaki komutla GPU için bir yapılandırma dosyasını oluşturmayı denersiniz. Ardından sistemi yeniden başlatmanız gerekir.
sudo mkdir -p /etc/X11/xorg.conf.d/ && echo -e 'Section "Device"\n Identifier "Intel Graphics"\n Driver "Intel"\n Option "AccelMethod" "uxa"\n Option "TearFree" "true"\nEndSection' | sudo tee /etc/X11/xorg.conf.d/20-intel.conf
