Gönderen Konu: [Çözüldü] Initramfs unpacking failed decoding failed  (Okunma sayısı 2418 defa)
Çevrimdışı green
  • İleti: 54
  • Dağıtım: linux mint 20
  • Grafik Kartı: r5 m230
  • İşlemci: a6-6310
Linux mint 20 yükledikten sonra başlıkta belirttiğim uyarı her açılışta ekranda beliriyor. Sistem açılıyor ve hiçbir sorun yok gibi görünüyor. Bu uyarı linux mint 20 live usb den boot edildiğinde de çıkıyor.
System:
  Host: green Kernel: 5.4.0-39-generic x86_64 bits: 64
  Desktop: Cinnamon 4.6.6 Distro: Linux Mint 20 Ulyana
Machine:
  Type: Portable System: Dell product: Inspiron 3541 v: N/A
  serial: <superuser/root required>
  Mobo: Dell model: Inspiron 3541 v: A07 serial: <superuser/root required>
  UEFI: Dell v: A07 date: 11/27/2015
Battery:
  ID-1: BAT0 charge: 6.1 Wh condition: 6.1/41.4 Wh (15%)
CPU:
  Topology: Quad Core model: AMD A6-6310 APU with AMD Radeon R4 Graphics
  bits: 64 type: MCP L2 cache: 2048 KiB
  Speed: 998 MHz min/max: 1000/1800 MHz Core speeds (MHz): 1: 1089 2: 1113
  3: 1133 4: 1101
Graphics:
  Device-1: AMD Mullins [Radeon R4/R5 Graphics] driver: radeon v: kernel
  Device-2: AMD Sun PRO [Radeon HD 8570A/8570M] driver: radeon v: kernel
  Display: x11 server: X.Org 1.20.8 driver: ati,radeon
  unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz
  OpenGL: renderer: AMD KABINI (DRM 2.50.0 5.4.0-39-generic LLVM 9.0.1)
  v: 4.5 Mesa 20.0.4
Audio:
  Device-1: AMD Kabini HDMI/DP Audio driver: snd_hda_intel
  Device-2: AMD FCH Azalia driver: snd_hda_intel
  Sound Server: ALSA v: k5.4.0-39-generic
Network:
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
  IF: enp2s0 state: down mac: 34:e6:d7:fe:67:87
  Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
  driver: ath9k
  IF: wlp3s0 state: up mac: 4c:bb:58:45:08:b6
  Device-3: Qualcomm Atheros type: USB driver: btusb
Drives:
  Local Storage: total: 465.76 GiB used: 93.17 GiB (20.0%)
  ID-1: /dev/sda vendor: Toshiba model: MQ01ABF050 size: 465.76 GiB
Partition:
  ID-1: / size: 341.19 GiB used: 93.16 GiB (27.3%) fs: ext4 dev: /dev/sda3
  ID-2: swap-1 size: 4.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda2
Sensors:
  System Temperatures: cpu: 48.0 C mobo: 48.0 C
  Fan Speeds (RPM): cpu: 3075
  GPU: device: radeon temp: 44 C device: radeon temp: 48 C
Info:
  Processes: 189 Uptime: 9m Memory: 3.28 GiB used: 1.10 GiB (33.6%)
  Shell: bash inxi: 3.0.38
« Son Düzenleme: 01 Temmuz 2020, 13:27:21 Gönderen: green »
Ynt: Initramfs unpacking failed decoding failed
« Yanıtla #1 : 01 Temmuz 2020, 13:14:15 »
Beta sürüm sürecinde konuşmuştuk. Burada düzenlemeyi yapmayı deneyebilir ya da sorunun güncelleme ile çözülmesini bekleyebilirsiniz.
Çevrimdışı green
  • İleti: 54
  • İşlemci: a6-6310
« Yanıtla #2 : 01 Temmuz 2020, 13:26:51 »
Konuyu açmadan önce arattım. Sonuç çıkmayınca açtım butterfly. Gönderdiğin linkteki çözüm yolu işe yaradı. İyi günler.
Ynt: [Çözüldü] Initramfs unpacking failed decoding failed
« Yanıtla #3 : 01 Temmuz 2020, 13:34:47 »
Size de iyi günler.
Aslında farklı hususlar için farklı konular açılmasını bu sebeple istiyoruz. Ayrı konular arama sonuçlarında daha iyi çıkıyor ve aynı anda bir çok hususun konuşulduğu konuların içinde saklı kalmıyor. Bir de bizim arama sistemi tam kelime araması yapıyor, arama motorları gibi gelişmiş olmadığı için olası içerikleri sunamıyor. Bu sebeple de hata çıktılarının tam olarak aktarılması önemli oluyor. Mesela "Initramfs unpacking failed decoding failed" şeklinde aratınca artık bu konu sonuçlarda çıkıyor, bağlantısını verdiğim konuya ise "initramfs decoding failed" kelimelerinin arama sonucu ile ulaşmak mümkün oluyor.
[okay]Sorun çözüldüğü için başlık kilitlenmiştir.[/okay]
