Gönderen Konu: Radeon Fence Wait Timed Out  (Okunma sayısı 6575 defa)
Çevrimdışı green
  • İleti: 54
  • Dağıtım: linux mint 20
  • Grafik Kartı: r5 m230
  • İşlemci: a6-6310
« : 08 Temmuz 2020, 18:25:48 »
Bilgisayar açılırken başlıkta belirttiğim hata kodu ve resimdeki uyarılar görünüp kayboluyor. Sistemde herhangi bir sıkıntı yok gibi görünüyor. Sistem raporlarında da ciddi bir çökme yok.
[System:
  Host: green Kernel: 5.4.0-39-generic x86_64 bits: 64
  Desktop: Cinnamon 4.6.6 Distro: Linux Mint 20 Ulyana
Machine:
  Type: Portable System: Dell product: Inspiron 3541 v: N/A
  serial: <superuser/root required>
  Mobo: Dell model: Inspiron 3541 v: A07 serial: <superuser/root required>
  UEFI: Dell v: A07 date: 11/27/2015
Battery:
  ID-1: BAT0 charge: 6.1 Wh condition: 6.1/41.4 Wh (15%)
CPU:
  Topology: Quad Core model: AMD A6-6310 APU with AMD Radeon R4 Graphics
  bits: 64 type: MCP L2 cache: 2048 KiB
  Speed: 1008 MHz min/max: 1000/1800 MHz Core speeds (MHz): 1: 998 2: 998
  3: 998 4: 998
Graphics:
  Device-1: AMD Mullins [Radeon R4/R5 Graphics] driver: radeon v: kernel
  Device-2: AMD Sun PRO [Radeon HD 8570A/8570M] driver: radeon v: kernel
  Display: x11 server: X.Org 1.20.8 driver: ati,radeon
  unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz
  OpenGL: renderer: AMD KABINI (DRM 2.50.0 5.4.0-39-generic LLVM 9.0.1)
  v: 4.5 Mesa 20.0.4
Audio:
  Device-1: AMD Kabini HDMI/DP Audio driver: snd_hda_intel
  Device-2: AMD FCH Azalia driver: snd_hda_intel
  Sound Server: ALSA v: k5.4.0-39-generic
Network:
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
  IF: enp2s0 state: down mac: 34:e6:d7:fe:67:87
  Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
  driver: ath9k
  IF: wlp3s0 state: up mac: 4c:bb:58:45:08:b6
  Device-3: Qualcomm Atheros type: USB driver: btusb
Drives:
  Local Storage: total: 465.76 GiB used: 95.38 GiB (20.5%)
  ID-1: /dev/sda vendor: Toshiba model: MQ01ABF050 size: 465.76 GiB
Partition:
  ID-1: / size: 341.19 GiB used: 95.38 GiB (28.0%) fs: ext4 dev: /dev/sda3
  ID-2: swap-1 size: 4.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda2
Sensors:
  System Temperatures: cpu: 51.0 C mobo: 51.0 C
  Fan Speeds (RPM): cpu: 3934
  GPU: device: radeon temp: 48 C device: radeon temp: 51 C
Info:
  Processes: 195 Uptime: 18m Memory: 3.28 GiB used: 1.25 GiB (38.2%)
  Shell: bash inxi: 3.0.38
[url=https://ibb.co/YtD63qs][img]https://i.ibb.co/YtD63qs/Ekran-G-r-nt-s-2020-07-08-18-15-12.png[/img][/url]
Hocam ilk iletide resimi yükleyemediğim için bu mesajda eklemeye çalıştım.
« Son Düzenleme: 08 Temmuz 2020, 18:30:57 Gönderen: green »
Ynt: Radeon Fence Wait Timed Out
« Yanıtla #1 : 08 Temmuz 2020, 23:07:06 »
Aşağıdaki komutun çıktısını da paylaşın.
dmesg | nc termbin.com 9999
Çevrimdışı green
  • İleti: 54
  • İşlemci: a6-6310
« Yanıtla #2 : 09 Temmuz 2020, 13:08:22 »
https://termbin.com/evth
« Yanıtla #3 : 09 Temmuz 2020, 14:15:12 »
[   36.023658] radeon 0000:01:00.0: WB enabled
[   36.023664] radeon 0000:01:00.0: fence driver on ring 0 use gpu addr 0x0000000080000c00 and cpu addr 0x00000000fa3414cd
[   36.023668] radeon 0000:01:00.0: fence driver on ring 1 use gpu addr 0x0000000080000c04 and cpu addr 0x00000000f50aea4c
[   36.023671] radeon 0000:01:00.0: fence driver on ring 2 use gpu addr 0x0000000080000c08 and cpu addr 0x00000000865089a8
[   36.023673] radeon 0000:01:00.0: fence driver on ring 3 use gpu addr 0x0000000080000c0c and cpu addr 0x000000005694485e
[   36.023676] radeon 0000:01:00.0: fence driver on ring 4 use gpu addr 0x0000000080000c10 and cpu addr 0x00000000c9c09fa9
[   36.439206] [drm] ring test on 0 succeeded in 1 usecs
[   36.439217] [drm] ring test on 1 succeeded in 1 usecs
[   36.439225] [drm] ring test on 2 succeeded in 1 usecs
[   36.439241] [drm] ring test on 3 succeeded in 4 usecs
[   36.439252] [drm] ring test on 4 succeeded in 4 usecs
[   36.439298] [drm] ib test on ring 0 succeeded in 0 usecs
[   36.439412] [drm] ib test on ring 1 succeeded in 0 usecs
[   36.439500] [drm] ib test on ring 2 succeeded in 0 usecs
[   36.439530] [drm] ib test on ring 3 succeeded in 0 usecs
[   36.439546] [drm] ib test on ring 4 succeeded in 0 usecs
Buradaki öneriyi dener misiniz?
Çevrimdışı green
  • İleti: 54
  • İşlemci: a6-6310
« Yanıtla #4 : 09 Temmuz 2020, 18:47:53 »
Butterfly reis verdiğin bağlantıdaki yöntemi uyguladım. Ama sorunun çözülüp çözülmediğini nasıl anlayacam? Çünkü bu hata uyarısını 5 açılıştan 1 inde veriyordu.
cat /var/log/Xorg.0.log | egrep 'DRI|Accel'
[   669.682] (**) RADEON(0): Option "AccelMethod" "exa"
[   669.682] (**) RADEON(0): Option "DRI" "2"
[   669.981] (II) RADEON(0): [DRI2] Setup complete
[   669.981] (II) RADEON(0): [DRI2]   DRI driver: radeonsi
[   669.981] (II) RADEON(0): [DRI2]   VDPAU driver: radeonsi
[   669.981] (**) RADEON(0): DRI3 disabled
[   669.998] (II) RADEON(0): Acceleration enabled
[   670.019] (II) RADEON(G0): [DRI2] Setup complete
[   670.019] (II) RADEON(G0): [DRI2]   DRI driver: radeonsi
[   670.019] (II) RADEON(G0): [DRI2]   VDPAU driver: radeonsi
[   670.029] (II) RADEON(G0): Acceleration enabled
[   670.035] (II) Initializing extension DRI3
[   670.046] (II) GLX: Initialized DRI2 GL provider for screen 0
[   670.046] (II) Initializing extension XFree86-DRI
[   670.046] (II) Initializing extension DRI2
[   670.669] (**) Option "AccelerationScheme" "none"
exa yazıyor.
« Yanıtla #5 : 09 Temmuz 2020, 20:34:47 »
Alıntıladığım kısım, dmesg çıktısında görünmüyorsa sorun çözülmüş olabilir. Benim radeon GPU'ya sahip bir sistemimde de benzer bir sorun vardı ve rastgele biçimde askıdan uyanırken çökme oluşuyordu. Yapılandırma ile hem bu sorun hem de ilgili çıktılar düzelmişti. Pek çok kaynağı incelediğim halde sorunu çözememiştim, deneme yanılma ile bağlantısını verdiğim yapılandırma dosyası ile EXA hızlandırma ve DRI2 ile sorun çözülmüş oldu. Bu bir miktar başarımı azaltsa da, sistemin daha kararlı çalışmasına yardımcı oldu. Sanırım sorunun temelinde Glamor hızlandırma metodu yatıyor.
Çevrimdışı green
  • İleti: 54
  • İşlemci: a6-6310
« Yanıtla #6 : 09 Temmuz 2020, 22:54:07 »
butterfly reis 5-6 kez aç kapa yaptım. hata görünmüyor. bende biraz araştırdım bu uyarıyı bazı kernellerde verebiliyormuş. genelde yabancı kaynaklarda çekirdek güncellemesiyle çözümü bekleyin diye tavsiyede bulunmuşlar. çekirdek güncellemesi olunca otomatik çözülme olabildiğine göre, glamor ve exa arasında nasıl geçiş yapabiliriz? iyi akşamlar.
alıntıladığınız bölüm dmesg de görünüyor. ama sistem günlüklerinde problem görünmüyor. bu problem sadece sistem uykudan uyanınca mı oluyor?
« Son Düzenleme: 09 Temmuz 2020, 23:00:59 Gönderen: green »
« Yanıtla #7 : 09 Temmuz 2020, 23:08:06 »
Evet benim sistemimde, uykudan uyandırıldığında dmesg komutunun çıktısında ring test ile başlayan hataları alıyordum. İlk bir kaç uyandırma ile sorun yaşanmazken, belirsiz bir sayı sonrasında radeon sürücüsü çöküyordu ve ekran karışık renkler göstererek kullanılmaz duruma geliyordu. Yapılandırma dosyası ile bir daha benzer bir sorun yaşamadım, sistem oldukça sorunsuz çalışıyor.
EXA hızlandırmayı pasifleştirip varsayılana dönmek isterseniz, tek yapmanız gereken aşağıdaki komutla yapılandırma dosyasını silip, sistemi yeniden başlatmaktır.
sudo rm -f /etc/X11/xorg.conf.d/20-radeon.conf
« Son Düzenleme: 09 Temmuz 2020, 23:11:00 Gönderen: Butterfly »
Çevrimdışı green
  • İleti: 54
  • İşlemci: a6-6310
« Yanıtla #8 : 09 Temmuz 2020, 23:15:20 »
butteryfly verdiğin çözüm yolu bende daha çok probleme neden oldu. artık uyarı vermiyor fakat ekranda açılışta dalgalanma, mouse'un üzerine geldiği yerlerde resimdeki gibi bozulma, menü geçişlerinde yavaşlama ve yer yer donma gibi sorunlar oluştu. eski haline getirip çekirdek güncellemesi beklemek daha mantıklı gibi geldi.
« Yanıtla #9 : 09 Temmuz 2020, 23:22:11 »
Dosya içeriğini aşağıdaki şekilde değiştirmeyi deneyebilirsiniz. Ben EXAPixmaps ile ilgili satırı pasif tutuyordum, bu satır ile EXAPixmaps özelliği pasifleştirilerek, bazı görüntü bozulmları engellenebiliyormuş. Tercih sizin, ama öncelikle denemenizi öneririm.
    Identifier "Radeon"
    Driver "radeon"
    Option "MigrationHeuristic" "greedy"
    Option "EXAPixmaps" "off"
    Option "EXAVSync" "yes"
    Option "DRI" "2"
Değişiklik sonrası CTRL+ALT+GERİ (BACKSPACE) tuşlarına basarak X sunucusunu yeniden başlatmak yeterli.
Çevrimdışı green
  • İleti: 54
  • İşlemci: a6-6310
« Yanıtla #10 : 09 Temmuz 2020, 23:33:01 »
butterfly uğraştığın için sağol. eski haline getirdim günlükleri kontrol ettim hata raporu göremedim. bu şekilde devam etmek daha mantıklı geldi. iyi geceler
