Gönderen Konu: [Çözüldü] Lubuntu 18.04'te Ekran Parlaklığı Değişmiyor.  (Okunma sayısı 6377 defa)
Çevrimdışı panan
  • İleti: 65
    • potasyumsiyanur
  • Masaüstü Ortamı: Cİnnamon
  • Grafik Kartı: İntel Uhd Graphics 620
  • İşlemci: İntel Core İ3
Merhabalar eski dizüstü bilgisayarıma Lubuntu kurdum fakat Linux Mint kurduğumda yaşadığım sorunun aynısını yine yaşıyorum. Parlaklığı ne kadar ayarlarsam ayarlayayım değiştiremiyorum.
https://forum.linuxmint.net.tr/index.php?topic=10798.msg65916#msg65916
System:    Host: hirasevilay Kernel: 4.15.0-128-generic x86_64
           bits: 64 gcc: 7.5.0
           Desktop: LXDE (Openbox 3.6.1) dm: lightdm
           Distro: Ubuntu 18.04.5 LTS
Machine:   Device: laptop System: Acer product: Aspire 5742G v: V1.18 serial: N/A
           Mobo: Acer model: Aspire 5742G v: V1.18 serial: N/A
           BIOS: Acer v: V1.18 date: 03/14/2011
Graphics:  Card-1: Intel Core Processor Integrated Graphics Controller
           bus-ID: 00:02.0 chip-ID: 8086:0046
           Card-2: NVIDIA GF119M [GeForce GT 520M]
           bus-ID: 01:00.0 chip-ID: 10de:1050
           drivers: modesetting,nouveau (unloaded: fbdev,vesa)
           Resolution: 1366x768@60.00hz
           OpenGL: renderer: Mesa DRI Intel HD Graphics (ILK)
           version: 2.1 Mesa 20.0.8 Direct Render: Yes
    GLX_MESA_query_renderer, GLX_MESA_swap_control, GLX_OML_swap_method,
OpenGL renderer string: Mesa DRI Intel(R) HD Graphics (ILK)
    GL_KHR_robustness, GL_NV_conditional_render, GL_NV_draw_buffers,
00:02.0 VGA compatible controller: Intel Corporation Core Processor Integrated Graphics Controller (rev 02)
01:00.0 VGA compatible controller: NVIDIA Corporation GF119M [GeForce GT 520M] (rev a1)
LVDS-1 connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
   1366x768      60.00*+
   1360x768      59.80    59.96
   1024x768      60.04    60.00
   960x720       60.00
   928x696       60.05
   896x672       60.01
   960x600       59.93    60.00
   840x525       60.01    59.88
   864x486       59.92    59.57
   800x512       60.17
   700x525       59.98
   800x450       59.95    59.82
   640x512       60.02
   720x450       59.89
   700x450       59.96    59.88
   640x480       60.00    59.94
   720x405       59.51    58.99
   684x384       59.88    59.85
   680x384       59.80    59.96
   640x400       59.88    59.98
   576x432       60.06
   512x384       60.00
   512x288       60.00    59.92
   480x270       59.63    59.82
   400x300       60.32    56.34
   432x243       59.92    59.57
   320x240       60.05
   360x202       59.51    59.13
   320x180       59.84    59.32
VGA-1-2 connected (normal left inverted right x axis y axis)
   1024x768      60.00
   800x600       60.32    56.25
   848x480       60.00
   640x480       59.94
  1024x768 (0x43) 65.000MHz -HSync -VSync
        h: width  1024 start 1048 end 1184 total 1344 skew    0 clock  48.36KHz
        v: height  768 start  771 end  777 total  806           clock  60.00Hz
  800x600 (0x44) 40.000MHz +HSync +VSync
        h: width   800 start  840 end  968 total 1056 skew    0 clock  37.88KHz
        v: height  600 start  601 end  605 total  628           clock  60.32Hz
  800x600 (0x45) 36.000MHz +HSync +VSync
        h: width   800 start  824 end  896 total 1024 skew    0 clock  35.16KHz
        v: height  600 start  601 end  603 total  625           clock  56.25Hz
  640x480 (0x47) 25.175MHz -HSync -VSync
        h: width   640 start  656 end  752 total  800 skew    0 clock  31.47KHz
        v: height  480 start  490 end  492 total  525           clock  59.94Hz
lgl|fglrx|amdgpu'
ii  libdrm-amdgpu1:amd64                   2.4.101-2~18.04.1                                amd64        Userspace interface to amdgpu-specific kernel DRM services -- runtime
ii  xserver-xorg-video-amdgpu              18.0.1-1                                         amd64        X.Org X server -- AMDGPU display driver
dkms status ile bir çıktı vermedi.
« Son Düzenleme: 18 Aralık 2020, 11:15:15 Gönderen: panan »
Ynt: Lubuntu 18.04'te Ekran Parlaklığı Değişmiyor.
« Yanıtla #1 : 17 Aralık 2020, 11:42:07 »
sudo apt-get install -y xbacklight
kurulumdan sonra, aşağıdaki şekilde sayıyı değiştirerek, (1-100 arası) parlaklığı ayarlamaya çalışın
xbacklight -set 45
Çevrimdışı panan
  • İleti: 65
    • potasyumsiyanur
« Yanıtla #2 : 17 Aralık 2020, 12:17:31 »
Dediğinizi yaptım fakat etkili olmadı. En son kodu girince de şöyle bir yazı geldi
No outputs have backlight property
« Yanıtla #3 : 17 Aralık 2020, 22:45:33 »
Bağlantısını verdiğiniz konudaki önerileri neden denemediniz?
Çevrimdışı panan
  • İleti: 65
    • potasyumsiyanur
« Yanıtla #4 : 18 Aralık 2020, 11:14:44 »
Oradakileri de denedim tabii ki.Onlar da işe yaramadığından yeni konu açma gereği duydum.  Şu yolları izleyerek sorunu çözebildim.
Yazılım güncelleştiricisinden sürümü Lubuntu 20.04 LTS'ye güncelledim.Nvidia X settings kısmından inteli seçip yeniden başlattım. Daha sonra şunları terminale girdim.
sudo touch /usr/share/X11/xorg.conf.d/20-intel.conf
sudo gedit /usr/share/X11/xorg.conf.d/20-intel.confAçılan pencereye şunları yapıştırım kaydettim.
        Identifier  "card0"
        Driver      "intel"
        Option      "Backlight"  "intel_backlight"
        BusID       "PCI:0:2:0"
Bunları yapınca ekran parlaklığı fn tuşları ile ayarlanabilir hâle geldi.
