Gönderen Konu: Android X86 yı bir türlü Grub a ekleyemiyorum.  (Okunma sayısı 4958 defa)
Çevrimdışı jaws61
  • İleti: 29
  • Dağıtım: Manjaro-Deepin-Mint
  • Masaüstü Ortamı: Cinnamon-Deepin
  • Grafik Kartı: Nvidia optimus Gt 540 M
  • İşlemci: İntel
« : 20 Aralık 2020, 16:04:36 »
Dizüstü bilgisyarıma Android X86 kurdum, hatta grubu da kurdum fakat bir türlü açılmadı. Pc de Mx Linux ve Windows 10 kurulu idi. Bir de Android x86 kurdum ama internette araştırdığım yöntemlere rağmen bir türlü Android i Grub a ekleyemedim. Yardımcı olur musunuz ?
sedat@jawsmxpc:~
$ inxi -Fxxz
System:    Host: jawsmxpc Kernel: 5.8.0-3-amd64 x86_64 bits: 64 compiler: N/A
           Desktop: Xfce 4.14.2 tk: Gtk 3.24.5 wm: xfwm4 dm: LightDM
           Distro: MX-19.3_ahs_x64 patito feo November 11  2020
           base: Debian GNU/Linux 10 (buster)
Machine:   Type: Laptop System: TOSHIBA product: Portable PC v: Version 1.0 serial: <filter>
           Chassis: type: 10 v: Version 1.0 serial: <filter>
           Mobo: TOSHIBA model: Portable PC v: Version A0 serial: <filter> BIOS: TOSHIBA
           v: Version 2.00 date: 11/10/2011
Battery:   ID-1: BAT1 charge: 22.7 Wh condition: 24.9/47.1 Wh (53%) volts: 11.0/10.8
           model: G71C000AJ410 serial: <filter> status: Charging
CPU:       Topology: Dual Core model: Intel Core i5-2410M bits: 64 type: MT MCP
           arch: Sandy Bridge rev: 7 L2 cache: 3072 KiB
           flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 18357
           Speed: 1046 MHz min/max: 800/2900 MHz Core speeds (MHz): 1: 1059 2: 1304 3: 1489
           4: 1719
Graphics:  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
           vendor: Toshiba America Info Systems driver: i915 v: kernel bus ID: 00:02.0
           chip ID: 8086:0116
           Device-2: NVIDIA GF108M [GeForce GT 540M] vendor: Toshiba America Info Systems
           driver: N/A bus ID: 01:00.0 chip ID: 10de:0df4
           Display: x11 server: X.Org 1.20.9 driver: modesetting unloaded: fbdev,vesa
           resolution: 1366x768~60Hz
           OpenGL: renderer: Mesa DRI Intel HD Graphics 3000 (SNB GT2) v: 3.3 Mesa 20.1.8
Audio:     Device-1: Intel 6 Series/C200 Series Family High Definition Audio
           vendor: Toshiba America Info Systems driver: snd_hda_intel v: kernel bus ID: 00:1b.0
           chip ID: 8086:1c20
           Device-2: NVIDIA GF108 High Definition Audio driver: snd_hda_intel v: kernel
           bus ID: 01:00.1 chip ID: 10de:0bea
           Sound Server: ALSA v: k5.8.0-3-amd64
Network:   Device-1: Intel Centrino Wireless-N 1000 [Condor Peak] driver: iwlwifi v: kernel
           port: 3000 bus ID: 03:00.0 chip ID: 8086:0083
           Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
           vendor: Toshiba America Info Systems driver: r8169 v: kernel port: 2000
           bus ID: 04:00.0 chip ID: 10ec:8168
Drives:    Local Storage: total: 1.17 TiB used: 16.34 GiB (1.4%)
           ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB
           ID-2: /dev/sdb vendor: Western Digital model: WD7500BPKX-75HPJT0 size: 698.64 GiB
           ID-3: /dev/sdc type: USB vendor: Kingston model: DataTraveler 3.0 size: 28.82 GiB
           serial: <filter>
Partition: ID-1: / size: 181.63 GiB used: 16.34 GiB (9.0%) fs: ext4 dev: /dev/sdb7
Sensors:   System Temperatures: cpu: 56.0 C mobo: N/A
           Fan Speeds (RPM): N/A
Info:      Processes: 206 Uptime: 23m Memory: 7.68 GiB used: 941.9 MiB (12.0%) Init: SysVinit
           v: 2.93 runlevel: 5 default: 5 Compilers: gcc: 8.3.0 alt: 8 Shell: bash v: 5.0.3
           running in: xfce4-terminal inxi: 3.0.36
sedat@jawsmxpc:~
sedat@jawsmxpc:~
$ sudo fdisk -l
[sudo] password for sedat:
Disk /dev/sdb: 698,7 GiB, 750156374016 bytes, 1465149168 sectors
Disk model: WDC WD7500BPKX-7
Disklabel type: dos
Disk identifier: 0xd604f8b5
Device     Boot      Start        End    Sectors   Size Id Type
/dev/sdb1             2048 1465145343 1465143296 698,7G  f W95 Ext'd (LBA)
/dev/sdb5        368646144  994105343  625459200 298,2G  7 HPFS/NTFS/exFAT
/dev/sdb6        994107392 1076025343   81917952  39,1G  7 HPFS/NTFS/exFAT
/dev/sdb7       1076027392 1465145343  389117952 185,6G 83 Linux
Disk /dev/sdc: 28,8 GiB, 30943995904 bytes, 60437492 sectors
Disk model: DataTraveler 3.0
Disklabel type: dos
Disk identifier: 0x0000efed
/dev/sdc1  *     2048 60437491 60435444 28,8G  c W95 FAT32 (LBA)
Disk /dev/sda: 465,8 GiB, 500107862016 bytes, 976773168 sectors
Disk model: Samsung SSD 860
Disklabel type: dos
Disk identifier: 0xaf653db0
/dev/sda1  *         2048   3074047   3072000   1,5G 27 Hidden NTFS WinRE
/dev/sda2         3074048 296673279 293599232   140G  7 HPFS/NTFS/exFAT
/dev/sda3       296675328 976769023 680093696 324,3G  7 HPFS/NTFS/exFAT
sedat@jawsmxpc:~
