Gönderen Konu: Chicony Electronics Co., Ltd 1.3M-Webcam Sürücüsü  (Okunma sayısı 12993 defa)
Çevrimdışı indirdivx1967
  • İleti: 183
  • Grafik Kartı: Device-1: Intel vendor: Acer Incorporated ALI
  • İşlemci: Dual Core model: Intel Celeron N4000 bits: 64 type
web cam için Peynir uygulamayı indirdim kurdum ama web-cam görmüyor , HardInfo 0.6-alpha uygulaması ile USB cihazları kontrol ettim orada görünüyor ama sürücüsü yüklü onu anlayamadım. ekran çıktısı resmi  ektedir.
daha önce açtığım konudaki komutları denedim aşağıdaki sunucu aldım https://forum.linuxmint.net.tr/index.php?topic=11074.0
emachines@emachines-eMachines-E527:~$ LD_PRELOAD=/usr/lib/x86_64-linux-gnu/libv4l/v4l2convert.so cheese
** (cheese:29887): CRITICAL **: 00:35:07.994: cheese_preferences_dialog_on_source_change: assertion '_tmp2_ > ((guint) 0)' failed
(cheese:29887): cheese-CRITICAL **: 00:35:07.994: cheese_camera_device_get_name: assertion 'CHEESE_IS_CAMERA_DEVICE (device)' failed
(cheese:29887): GLib-CRITICAL **: 00:35:07.994: g_variant_new_string: assertion 'string != NULL' failed
(cheese:29887): GLib-CRITICAL **: 00:35:07.994: g_variant_ref_sink: assertion 'value != NULL' failed
(cheese:29887): GLib-GIO-CRITICAL **: 00:35:07.994: g_settings_schema_key_type_check: assertion 'value != NULL' failed
(cheese:29887): GLib-CRITICAL **: 00:35:07.994: g_variant_get_type_string: assertion 'value != NULL' failed
(cheese:29887): GLib-GIO-CRITICAL **: 00:35:07.994: g_settings_set_value: key 'camera' in 'org.gnome.Cheese' expects type 's', but a GVariant of type '(null)' was given
(cheese:29887): GLib-CRITICAL **: 00:35:07.994: g_variant_unref: assertion 'value != NULL' failed
** (cheese:29887): CRITICAL **: 00:35:07.994: cheese_preferences_dialog_setup_resolutions_for_device: assertion 'device != NULL' failed
(cheese:29887): cheese-WARNING **: 00:35:08.027: Kaynaktan okunamadı.: gstv4l2bufferpool.c(1126): gst_v4l2_buffer_pool_poll (): /GstCameraBin:camerabin/GstWrapperCameraBinSrc:camera_source/GstBin:bin18/GstV4l2Src:v4l2src1:
poll error 1: Geçersiz bağımsız değişken (22)
Ynt: Chicony Electronics Co., Ltd 1.3M-Webcam Sürücüsü
« Yanıtla #1 : 02 Ocak 2021, 01:27:34 »
Aşağıdaki komutla deneyin bakalım.
env LD_PRELOAD=/usr/lib/libv4l/v4l1compat.so cheese
  • İleti: 183
« Yanıtla #2 : 02 Ocak 2021, 06:54:24 »
Komut ile uç biriminde çalıştırınca biraz siyah ekranda bekledikten sonra , görüntü geldi sonra 2 dakika sonra dondu, uç birimi kapattım. Tekrar uygulamalar kısmından başlattım görüntü normal olarak geldi. 2 dakika sonra gitti. cihazı tekrar başlattım. HardInfo üzerinden baktım web-cam görünmüyordu. tekrar başlattım ,  HardInfo tekrar kontrol ettim  görünmeye başladı, normal açtım  HardInfo de wb-cam devreye giriyor-cıkıyor ama peynir de siyah ekran , aynı şeyi uç birimden komut ile yaptım onda da aynı tepkiyi verdi bir süre sonra HardInfo da web-cam  kayboldu. tekrar başlattım , HardInfo açtım kontrol ettim web-cam var , normal uygulamadan peyniri açtım görüntü normal bu mesajı yazana kadar geçen sürede normal çalışmaya devam ediyordu 5 dakika gibi sanki donanımsal bir sorun var gibi , nasıl bir sonuç yazacağımı bilemedim ne önerirsiniz şu an için uç birimi komutsuz normal uygulamadan açınca çalışıyor.
  • İleti: 183
« Yanıtla #3 : 14 Ocak 2021, 07:01:21 »
Bugün tekrar denedim  aygıt bulunmadı mesajı veriyor ama hardinfo a cihaz görünüyor.
emachines@emachines-eMachines-E527:~$ env LD_PRELOAD=/usr/lib/libv4l/v4l1compat.so cheese
ERROR: ld.so: object '/usr/lib/libv4l/v4l1compat.so' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
** Message: 06:56:09.446: cheese-application.vala:214: Error during camera setup: Aygıt bulunamadı
(cheese:7283): cheese-CRITICAL **: 06:56:09.470: cheese_camera_device_get_name: assertion 'CHEESE_IS_CAMERA_DEVICE (device)' failed
(cheese:7283): GLib-CRITICAL **: 06:56:09.470: g_variant_new_string: assertion 'string != NULL' failed
(cheese:7283): GLib-CRITICAL **: 06:56:09.470: g_variant_ref_sink: assertion 'value != NULL' failed
(cheese:7283): GLib-GIO-CRITICAL **: 06:56:09.470: g_settings_schema_key_type_check: assertion 'value != NULL' failed
(cheese:7283): GLib-CRITICAL **: 06:56:09.471: g_variant_get_type_string: assertion 'value != NULL' failed
(cheese:7283): GLib-GIO-CRITICAL **: 06:56:09.471: g_settings_set_value: key 'camera' in 'org.gnome.Cheese' expects type 's', but a GVariant of type '(null)' was given
(cheese:7283): GLib-CRITICAL **: 06:56:09.471: g_variant_unref: assertion 'value != NULL' failed
** (cheese:7283): CRITICAL **: 06:56:09.471: cheese_preferences_dialog_setup_resolutions_for_device: assertion 'device != NULL' failed
bir daha denedim uç birimdeki mesaj değişti.
** (cheese:7761): CRITICAL **: 07:03:24.218: cheese_preferences_dialog_on_source_change: assertion '_tmp2_ > ((guint) 0)' failed
(cheese:7761): cheese-CRITICAL **: 07:03:24.218: cheese_camera_device_get_name: assertion 'CHEESE_IS_CAMERA_DEVICE (device)' failed
(cheese:7761): GLib-CRITICAL **: 07:03:24.219: g_variant_new_string: assertion 'string != NULL' failed
(cheese:7761): GLib-CRITICAL **: 07:03:24.219: g_variant_ref_sink: assertion 'value != NULL' failed
(cheese:7761): GLib-GIO-CRITICAL **: 07:03:24.219: g_settings_schema_key_type_check: assertion 'value != NULL' failed
(cheese:7761): GLib-CRITICAL **: 07:03:24.219: g_variant_get_type_string: assertion 'value != NULL' failed
(cheese:7761): GLib-GIO-CRITICAL **: 07:03:24.219: g_settings_set_value: key 'camera' in 'org.gnome.Cheese' expects type 's', but a GVariant of type '(null)' was given
(cheese:7761): GLib-CRITICAL **: 07:03:24.219: g_variant_unref: assertion 'value != NULL' failed
** (cheese:7761): CRITICAL **: 07:03:24.219: cheese_preferences_dialog_setup_resolutions_for_device: assertion 'device != NULL' failed
(cheese:7761): cheese-WARNING **: 07:03:24.275: Kaynaktan okunamadı.: gstv4l2bufferpool.c(1126): gst_v4l2_buffer_pool_poll (): /GstCameraBin:camerabin/GstWrapperCameraBinSrc:camera_source/GstBin:bin18/GstV4l2Src:v4l2src1:
« Son Düzenleme: 14 Ocak 2021, 07:05:20 Gönderen: indirdivx1967 »
« Yanıtla #4 : 14 Ocak 2021, 07:29:58 »
Aşağıdaki komutu deneyin.
env LD_PRELOAD=/usr/lib/x86_64-linux-gnu/libv4l/v4l1compat.so cheese
  • İleti: 183
« Yanıtla #5 : 14 Ocak 2021, 21:14:28 »
denedim , web kamarasında viedoynatırken bir hata oluştu mesajı yazıyor Peynirin içinde. uç birimde veren hata aşağıda.
emachines@emachines-eMachines-E527:~$ env LD_PRELOAD=/usr/lib/x86_64-linux-gnu/libv4l/v4l1compat.so cheese
(cheese:16319): GStreamer-CRITICAL **: 21:10:31.896: gst_element_message_full_with_details: assertion 'GST_IS_ELEMENT (element)' failed
** (cheese:16319): CRITICAL **: 21:10:32.539: cheese_preferences_dialog_on_source_change: assertion '_tmp2_ > ((guint) 0)' failed
(cheese:16319): cheese-CRITICAL **: 21:10:32.540: cheese_camera_device_get_name: assertion 'CHEESE_IS_CAMERA_DEVICE (device)' failed
(cheese:16319): GLib-CRITICAL **: 21:10:32.540: g_variant_new_string: assertion 'string != NULL' failed
(cheese:16319): GLib-CRITICAL **: 21:10:32.540: g_variant_ref_sink: assertion 'value != NULL' failed
(cheese:16319): GLib-GIO-CRITICAL **: 21:10:32.540: g_settings_schema_key_type_check: assertion 'value != NULL' failed
(cheese:16319): GLib-CRITICAL **: 21:10:32.540: g_variant_get_type_string: assertion 'value != NULL' failed
(cheese:16319): GLib-GIO-CRITICAL **: 21:10:32.540: g_settings_set_value: key 'camera' in 'org.gnome.Cheese' expects type 's', but a GVariant of type '(null)' was given
(cheese:16319): GLib-CRITICAL **: 21:10:32.540: g_variant_unref: assertion 'value != NULL' failed
** (cheese:16319): CRITICAL **: 21:10:32.540: cheese_preferences_dialog_setup_resolutions_for_device: assertion 'device != NULL' failed
(cheese:16319): GStreamer-CRITICAL **: 21:10:40.833: gst_element_message_full_with_details: assertion 'GST_IS_ELEMENT (element)' failed
** (cheese:16319): CRITICAL **: 21:10:41.215: cheese_preferences_dialog_on_source_change: assertion '_tmp2_ > ((guint) 0)' failed
(cheese:16319): cheese-CRITICAL **: 21:10:41.215: cheese_camera_device_get_name: assertion 'CHEESE_IS_CAMERA_DEVICE (device)' failed
(cheese:16319): GLib-CRITICAL **: 21:10:41.215: g_variant_new_string: assertion 'string != NULL' failed
(cheese:16319): GLib-CRITICAL **: 21:10:41.215: g_variant_ref_sink: assertion 'value != NULL' failed
(cheese:16319): GLib-GIO-CRITICAL **: 21:10:41.215: g_settings_schema_key_type_check: assertion 'value != NULL' failed
(cheese:16319): GLib-CRITICAL **: 21:10:41.215: g_variant_get_type_string: assertion 'value != NULL' failed
(cheese:16319): GLib-GIO-CRITICAL **: 21:10:41.215: g_settings_set_value: key 'camera' in 'org.gnome.Cheese' expects type 's', but a GVariant of type '(null)' was given
(cheese:16319): GLib-CRITICAL **: 21:10:41.215: g_variant_unref: assertion 'value != NULL' failed
** (cheese:16319): CRITICAL **: 21:10:41.215: cheese_preferences_dialog_setup_resolutions_for_device: assertion 'device != NULL' failed
(cheese:16319): cheese-WARNING **: 21:10:41.266: Kaynaktan okunamadı.: gstv4l2bufferpool.c(1126): gst_v4l2_buffer_pool_poll (): /GstCameraBin:camerabin/GstWrapperCameraBinSrc:camera_source/GstBin:bin19/GstV4l2Src:v4l2src2:
(cheese:16319): GStreamer-CRITICAL **: 21:10:50.590: gst_element_message_full_with_details: assertion 'GST_IS_ELEMENT (element)' failed
« Yanıtla #6 : 15 Ocak 2021, 05:36:35 »
Lütfen geri dönüşlerde ayrıntılı bilgi paylaşınız. Son komutla web kamerasına görüntü geliyor mu?
Peynir uygulamasının çökmesi, görüntü gelip gelmemesinden bağımsız bir durum olabilir.
Peki uygulamayı aşağıdaki komutla açınca durum ne oluyor?
sudo env LD_PRELOAD=/usr/lib/x86_64-linux-gnu/libv4l/v4l1compat.so cheese
Eğer ekran görüntüsü bu şekilde geliyorsa, aşağıdaki komutla kullanıcıyı video grubuna ekleyip, sistemi yeniden başlatın.
sudo usermod  -a -G video $USER
Sistemi yeniden başlattıktan sonra, komutu başında sudo olmadan çalıştırmayı deneyin.
« Son Düzenleme: 15 Ocak 2021, 05:40:34 Gönderen: Butterfly »
  • İleti: 183
« Yanıtla #7 : 15 Ocak 2021, 10:35:22 »
Merhaba verdiğiniz komut ile uygulama Açılıyor ama görüntü gelmiyor. Görüntü ekranın  ortasında   " web kamarasından video oynatırken bir hata oluştu"  yazıyor. ilk komut çalışmadığı için diğer komutları çalıştırmadın. uç birimindeki son durum aşağıdadır.
emachines@emachines-eMachines-E527:~$ sudo env LD_PRELOAD=/usr/lib/x86_64-linux-gnu/libv4l/v4l1compat.so cheese
[sudo] emachines için parola:
(cheese:9722): GStreamer-CRITICAL **: 10:19:01.805: gst_element_message_full_with_details: assertion 'GST_IS_ELEMENT (element)' failed
libv4l2: error setting pixformat: Girdi/Çıktı hatası
** (cheese:9722): CRITICAL **: 10:19:04.500: cheese_preferences_dialog_on_source_change: assertion '_tmp2_ > ((guint) 0)' failed
(cheese:9722): cheese-CRITICAL **: 10:19:04.500: cheese_camera_device_get_name: assertion 'CHEESE_IS_CAMERA_DEVICE (device)' failed
(cheese:9722): GLib-CRITICAL **: 10:19:04.500: g_variant_new_string: assertion 'string != NULL' failed
(cheese:9722): GLib-CRITICAL **: 10:19:04.501: g_variant_ref_sink: assertion 'value != NULL' failed
(cheese:9722): GLib-GIO-CRITICAL **: 10:19:04.501: g_settings_schema_key_type_check: assertion 'value != NULL' failed
(cheese:9722): GLib-CRITICAL **: 10:19:04.501: g_variant_get_type_string: assertion 'value != NULL' failed
(cheese:9722): GLib-GIO-CRITICAL **: 10:19:04.501: g_settings_set_value: key 'camera' in 'org.gnome.Cheese' expects type 's', but a GVariant of type '(null)' was given
(cheese:9722): GLib-CRITICAL **: 10:19:04.501: g_variant_unref: assertion 'value != NULL' failed
** (cheese:9722): CRITICAL **: 10:19:04.501: cheese_preferences_dialog_setup_resolutions_for_device: assertion 'device != NULL' failed
(cheese:9722): cheese-WARNING **: 10:19:04.501: '/dev/video0' aygıtı başlatma sırasında başarısız oldu: gstv4l2object.c(3782): gst_v4l2_object_set_format_full (): /GstCameraBin:camerabin/GstWrapperCameraBinSrc:camera_source/GstBin:bin18/GstV4l2Src:v4l2src1:
Call to S_FMT failed for BGR3 @ 320x240: Girdi/Çıktı hatası
(cheese:9722): GStreamer-CRITICAL **: 10:19:46.733: gst_element_message_full_with_details: assertion 'GST_IS_ELEMENT (element)' failed
« Yanıtla #8 : 15 Ocak 2021, 16:26:39 »
VLC üzerinden deneyin bakalım, görüntü alabiliyor musun?
env LD_PRELOAD=/usr/lib/x86_64-linux-gnu/libv4l/v4l1compat.so vlc
VLC => Ortam menüsü => Yakalama Aygıtı Aç kısmından Görüntü aygıtını seçin ve oynatın.
  • İleti: 183
« Yanıtla #9 : 15 Ocak 2021, 19:50:31 »
Verdiğiniz komutlarla denedim , Görüntü aygıtını adı seçmek için her girdiğimde iki tane seçenek çıktı;
/dev/video1
/dev/video2
VLC hiç tepki göstermeyince tekrar denedim Görüntü aygıtını adı seçeneği aşağıdaki gibi göründü
/dev/video0
/dev/video2
/dev/video0 ve /dev/video1  denedim  VLC alt onatma çubuğu bir sağa solo gitti bir şey çıkmadı bende kapadım.
/dev/video2 denediğim de  VLC nin içinde aşağıdaki hata mesajı çıktı.
Seçtiğiniz giriş açılamadı:
VLC, 'v4l2:///dev/video2' ortam kaynağı adresini (MRL) açamıyor. Ayrıntılar için günlük dosyasına bakın.
bu işleri yaparken uç birimdeki mesajlar aşağıdadır.
emachines@emachines-eMachines-E527:~$ env LD_PRELOAD=/usr/lib/x86_64-linux-gnu/libv4l/v4l1compat.so vlc
VLC media player 3.0.9.2 Vetinari (revision 3.0.9.2-0-gd4c1aefe4d)
[0000556b4ed8d5b0] main libvlc: vlc yazıldığında, varsayılan arayüz çalışır. Arayüz olmadan çalıştırmak için 'cvlc' kullanın.
qt5ct: using qt5ct plugin
qt5ct: D-Bus global menu: no
qt5ct: D-Bus system tray: yes
[0000556b4ee2b030] main playlist: playlist is empty
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1939, resource id: 8478838, major code: 40 (TranslateCoords), minor code: 0
QXcbClipboard: Unable to receive an event from the clipboard manager in a reasonable time
QObject::~QObject: Timers cannot be stopped from another thread
[000055c76f9905b0] main libvlc: vlc yazıldığında, varsayılan arayüz çalışır. Arayüz olmadan çalıştırmak için 'cvlc' kullanın.
[000055c76fa2e030] main playlist: playlist is empty
[000055928ee7e5b0] main libvlc: vlc yazıldığında, varsayılan arayüz çalışır. Arayüz olmadan çalıştırmak için 'cvlc' kullanın.
[000055928ef1c030] main playlist: playlist is empty
[00007efd68001180] v4l2 demux error: cannot open device '/dev/video2': Invalid argument
[00007efd68002860] v4l2 stream error: cannot open device '/dev/video2': Invalid argument
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1502, resource id: 8485049, major code: 40 (TranslateCoords), minor code: 0
[00007efd680026d0] v4l2 stream error: cannot open device '/dev/video2': Invalid argument
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4164, resource id: 8485757, major code: 40 (TranslateCoords), minor code: 0
« Yanıtla #10 : 17 Ocak 2021, 12:48:30 »
Bu aygıt için, depodan Guvcview uygulamasını kurup kullanmayı deneyebilirsiniz.
  • İleti: 183
« Yanıtla #11 : 17 Ocak 2021, 14:12:13 »
Merhaba  onu kurdum sonuç aynı fakat bu uygulama da iki kamera varmış gibi görünüyor, ekran resimlerini paylaşıyorum ayrıca bir kaç denemeden sonra cihazı bulamadım diye hata mesajı verdi.Peyniri normal yerden açtım 1 saniye görüntü gelir gibi  oluyor,  sonar malum mesaj çıkıyor gene " web kamarasından video oynatırken bir hata oluştu"
« Yanıtla #12 : 23 Ocak 2021, 20:50:53 »
Aşağıdaki komutların çıktısını paylaşın, bakalım internette aygıta ait bir ipucu bulabilecek miyiz?
lsusb
lsmod
  • İleti: 183
« Yanıtla #13 : 24 Ocak 2021, 00:01:19 »
Uç birim çıktıları ektedir.
emachines@emachines-eMachines-E527:~$ lsusb
Bus 002 Device 003: ID 04f2:b1d8 Chicony Electronics Co., Ltd 1.3M Webcam
Bus 003 Device 002: ID 0458:00a1 KYE Systems Corp. (Mouse Systems) 2.4G Wireless Mouse and Keyboard
emachines@emachines-eMachines-E527:~$ lsmod
ccm                    20480  3
uvcvideo               98304  0
videobuf2_vmalloc      20480  1 uvcvideo
videobuf2_memops       20480  1 videobuf2_vmalloc
videobuf2_common       53248  2 videobuf2_v4l2,uvcvideo
snd_hda_codec_realtek   126976  1
videodev              237568  3 videobuf2_v4l2,uvcvideo,videobuf2_common
nf_log_ipv6            16384  5
ip6t_REJECT            16384  1
snd_hda_codec_generic    81920  1 snd_hda_codec_realtek
nf_reject_ipv6         20480  1 ip6t_REJECT
mc                     57344  4 videodev,videobuf2_v4l2,uvcvideo,videobuf2_common
ledtrig_audio          16384  1 snd_hda_codec_generic
ath9k                 151552  0
snd_hda_intel          53248  3
snd_intel_dspcfg       24576  1 snd_hda_intel
ath9k_common           36864  1 ath9k
acer_wmi               24576  0
ath9k_hw              483328  2 ath9k_common,ath9k
snd_hda_codec         139264  3 snd_hda_codec_generic,snd_hda_intel,snd_hda_codec_realtek
xt_hl                  16384  22
coretemp               20480  0
ath                    36864  3 ath9k_common,ath9k,ath9k_hw
mac80211              905216  1 ath9k
snd_hda_core           94208  4 snd_hda_codec_generic,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek
ip6t_rt                20480  3
snd_pcm               114688  3 snd_hda_intel,snd_hda_codec,snd_hda_core
cfg80211              778240  4 ath9k_common,ath9k,ath,mac80211
snd_seq_midi           20480  0
libarc4                16384  1 mac80211
sparse_keymap          16384  1 acer_wmi
snd_rawmidi            36864  1 snd_seq_midi
serio_raw              20480  0
wmi_bmof               16384  0
snd_seq                69632  2 snd_seq_midi,snd_seq_midi_event
nf_log_ipv4            16384  5
snd_seq_device         16384  3 snd_seq,snd_seq_midi,snd_rawmidi
snd_timer              40960  2 snd_seq,snd_pcm
nf_log_common          16384  2 nf_log_ipv4,nf_log_ipv6
snd                    94208  16 snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_pcm,snd_rawmidi
ipt_REJECT             16384  1
xt_LOG                 20480  10
xt_limit               16384  13
xt_tcpudp              20480  22
xt_conntrack           16384  16
nf_conntrack          147456  1 xt_conntrack
nf_defrag_ipv6         24576  1 nf_conntrack
nf_defrag_ipv4         16384  1 nf_conntrack
ip6_tables             32768  53 ip6table_filter
sch_fq_codel           20480  2
bpfilter              884736  0
parport_pc             45056  0
ppdev                  24576  0
parport                65536  3 parport_pc,lp,ppdev
ip_tables              32768  9 iptable_filter
x_tables               45056  13 ip6table_filter,xt_conntrack,iptable_filter,xt_LOG,xt_tcpudp,xt_addrtype,ip6t_rt,ip6_tables,ipt_REJECT,ip_tables,xt_limit,xt_hl,ip6t_REJECT
autofs4                45056  2
btrfs                1290240  0
blake2b_generic        20480  0
libcrc32c              16384  2 nf_conntrack,btrfs
mxm_wmi                16384  0
i915                 2195456  13
drm_kms_helper        217088  1 i915
cec                    53248  2 drm_kms_helper,i915
rc_core                57344  1 cec
i2c_i801               32768  0
drm                   552960  7 drm_kms_helper,i915
psmouse               155648  0
ahci                   40960  2
libahci                36864  1 ahci
i2c_smbus              20480  1 i2c_i801
usbhid                 57344  0
hid                   135168  2 usbhid,hid_generic
atl1c                  53248  0
wmi                    32768  3 acer_wmi,wmi_bmof,mxm_wmi
video                  49152  2 acer_wmi,i915
« Yanıtla #14 : 24 Ocak 2021, 01:11:36 »
Secureboot etkinse, BIOS/EFI ayarlarından kapatmayı dener misiniz?
