Gönderen Konu: [Çözüldü] Güncelleme Yöneticisi Uzun Bekleme ve Güncellemeleri Göstermeme Sorunu  (Okunma sayısı 5555 defa)
Çevrimdışı cashflow67
  • İleti: 33
  • Dağıtım: Mint Cinammon 20.1
  • Masaüstü Ortamı: Cinammon
  • Grafik Kartı: Intel HD 5600 ve GTX960M 2GB DDR5 128bit
  • İşlemci: Intel i7-5700HQ 2.70-3.5 Ghz
Merhabalar, Güncelleme Yöneticisinden yenile dediğimde güncellemeleri bulmuyor ve saatlerce bekliyor.
mrt@mrt-PE60-2QE:~$ inxi -Sr
System:
  Host: mrt-PE60-2QE Kernel: 5.4.0-60-generic x86_64 bits: 64
  Desktop: Xfce 4.16.0 Distro: Linux Mint 20.1 Ulyssa
Repos:
  No active apt repos in: /etc/apt/sources.list
  Active apt repos in: /etc/apt/sources.list.d/kelebek333-xfce-4_16-focal.list
  1: deb http://ppa.launchpad.net/kelebek333/xfce-4.16/ubuntu focal main
  Active apt repos in: /etc/apt/sources.list.d/libreoffice-libreoffice-7-0-focal.list
  1: deb http://ppa.launchpad.net/libreoffice/libreoffice-7-0/ubuntu focal main
  Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
  1: deb http://packages.linuxmint.com ulyssa main upstream import backport
  2: deb http://ubuntu.saglayici.com/ubuntu focal main restricted universe multiverse
  3: deb http://ubuntu.saglayici.com/ubuntu focal-updates main restricted universe multiverse
  4: deb http://ubuntu.saglayici.com/ubuntu focal-backports main restricted universe multiverse
  5: deb http://security.ubuntu.com/ubuntu/ focal-security main restricted universe multiverse
  6: deb http://archive.canonical.com/ubuntu/ focal partner
  Active apt repos in: /etc/apt/sources.list.d/yannubuntu-boot-repair-focal.list
  1: deb http://ppa.launchpad.net/yannubuntu/boot-repair/ubuntu focal main
mrt@mrt-PE60-2QE:~$ sudo apt-get update
[sudo] mrt için parola:
E: Could not get lock /var/lib/apt/lists/lock. It is held by process 1740 (synaptic)
N: Be aware that removing the lock file is not a solution and may break your system.
E: /var/lib/apt/lists/ dizini kilitlenemiyor
mrt@mrt-PE60-2QE:~$ sudo apt-get install -f
  hwinfo libhd21 libx86emu2 shim
0 paket yükseltilecek, 0 yeni paket kurulacak, 0 paket kaldırılacak ve 12 paket yükseltilmeyecek.
« Son Düzenleme: 13 Ocak 2021, 14:54:09 Gönderen: cashflow67 »
I aspire to inspire before I expire...
Command-not-found paketi ile ilgili, Türkçe gibi ascii desteği olmayan dillerde görülen bir sorun var. Linux Mint 20'de bu paket kurulu gelmiyordu, Linux Mint 20.1'e tekrar eklendi. Paketi PPA depomuzdan güncellerseniz, sorun çözülecektir.
[warning][Nasıl] Linux Mint 20.x Düzeltmeler PPA Deposu[/warning]
PPA deposunu ekledikten sonra, geçici olarak aşağıdaki komutu çalıştırın.
LC_ALL=C apt update
  • İleti: 33
Teşekkürler dediklerinizi yaptım sorun çözülmüştür.
