Gönderen Konu: [Çözüldü]Hesap Açılırken Hata  (Okunma sayısı 3957 defa)
Çevrimdışı dev@mehmet
  • İleti: 189
  • Dağıtım: Linux Mint 19
« : 03 Temmuz 2014, 17:33:27 »
Demin hesabımı açmaya çalıştığımda "10 saniye önce oturumunuz sonlandırıldı." dedi. .xsession-errors dosyasını aşağıdaki gibi:
/etc/mdm/Xsession: Beginning session setup...
localuser:mehmet being added to access control list
Script for none started at run_im.
Script for auto started at run_im.
Script for default started at run_im.
Failed to connect to the VirtualBox kernel service
GNOME_KEYRING_CONTROL=/run/user/1000/keyring-IHwUWQ
SSH_AUTH_SOCK=/run/user/1000/keyring-IHwUWQ/ssh
GPG_AGENT_INFO=/run/user/1000/keyring-IHwUWQ/gpg:0:1
(cinnamon-settings-daemon:2489): media-keys-plugin-WARNING **: Grab failed for some keys, another application may already have access the them.
Window manager warning: Log level 16: g_object_set_valist: object class 'ClutterSettings' has no property named 'window-scaling-factor'
      JS LOG: About to start Cinnamon
nm-applet-Message: using fallback from indicator to GtkStatusIcon
** (nemo:2728): WARNING **: Can not get _NET_WORKAREA
** (nemo:2728): WARNING **: Can not determine workarea, guessing at layout
Window manager warning: Trying to remove non-existent custom keybinding "magnifier-zoom-in".
Window manager warning: Trying to remove non-existent custom keybinding "magnifier-zoom-out".
      JS LOG: Cinnamon started at Thu Jul 03 2014 17:28:08 GMT+0300 (EEST)
(cinnamon:2709): St-CRITICAL **: st_widget_get_theme_node called on the widget [0x9cdcd28 StBoxLayout.menu-selected-app-box] which is not in the stage.
      JS LOG: network applet: Cannot find connection for active (or connection cannot be read)
      JS LOG: network applet: Found connection for active
Conky: /home/mehmet/.conkyrc: 6: no such configuration: 'border_margin'
Conky: /home/mehmet/.conkyrc: 24: config file error
Conky: forked to background, pid is 2838
Conky: desktop window (1600033) is subwindow of root window (25b)
Conky: window type - normal
Conky: drawing to created window (0x2200002)
Conky: drawing to double buffer
(mintUpdate.py:2854): libglade-WARNING **: unknown attribute `swapped' for <signal>.
Tekrar denediğimde hesabımı açabildim.
« Son Düzenleme: 12 Ekim 2014, 09:09:19 Gönderen: metrekup »
