Gönderen Konu: [Çözüldü] Burg Kurulumda Sorun. (Windows Grub Menüsünde Görünmüyor)  (Okunma sayısı 4620 defa)
Çevrimdışı quem4R
  • İleti: 14
  • Dağıtım: Linux Mint 17 Cinnamon 64-bit
Mint 17 cinnamon 64 bit kurulumu yaptım. Başlangıçta GRUB menüsünde Windows'u göremedim.
Biraz araştırdım burg denilen şey ile halloluyomuş heralde. :) Ancak burg kurulumunu gerçekleştiremedim.
Sorunumun çıktısı budur arkadaşlar.
muhayyel@muhayyel ~ $ sudo su
muhayyel muhayyel # sudo add-apt-repository -y ppa:n-muench/burg
You are about to add the following PPA to your system:
 sudo add-apt-repository ppa:n-muench/burg
Burg (Maverick packaging) has been copied from the original repo (https://launchpad.net/~bean123ch/+archive/burg), and rebuilt for Natty.  Nothing has been changed, just a basic copy and rebuild.
This should hold you until that repo is update for Natty (if there ever is one).
The packaging has known to work well, so I won't push the newest revision (which is currently at 1844).
This repo was made specifically made so you can use Natty-built burg and not Maverick-built burg.
I will be doing a rebuild of both packages for Oneiric.  The changes are as follows:
-Append existing entry.
-Adjust the versioning
 *To get rid of "+maverick" (for the main package)
 *Up the revision to "-2"
-Add line to debian/rules so that it can build successfully with GCC-4.6 (LP: #775460).  I've encountered this issue before, and I know how to fix it.
Soon (probably after the release of Oneiric), I am going to create a second Burg PPA.  It will be used to try out the newest revision of the package (with Oneiric and maybe Natty).  And to see if there were any new bugs added in the newer revisions.  I have minimal programming skills, so I can't add anything new to the package.
This will occur somewhere around the official release of Oneiric.
 More info: https://launchpad.net/~n-muench/+archive/burg
Executing: gpg --ignore-time-conflict --no-options --no-default-keyring --secret-keyring /tmp/tmp.TIpUBLnfXT/secring.gpg --trustdb-name /tmp/tmp.TIpUBLnfXT/trustdb.gpg --no-auto-check-trustdb --trust-model always --keyring /etc/apt/trusted.gpg --primary-keyring /etc/apt/trusted.gpg --keyring /etc/apt/trusted.gpg.d/debian-archive-squeeze-automatic.gpg --keyring /etc/apt/trusted.gpg.d/debian-archive-squeeze-stable.gpg --keyring /etc/apt/trusted.gpg.d/debian-archive-wheezy-automatic.gpg --keyring /etc/apt/trusted.gpg.d/debian-archive-wheezy-stable.gpg --keyserver keyserver.ubuntu.com --recv-keys EAE0D85C
gpg: EAE0D85C anahtarı keyserver.ubuntu.com sunucusunun hkp adresinden isteniyor
gpg: anahtar EAE0D85C: "Launchpad PPA for Nate Muench" değişmedi
gpg:                    değişmedi: 1
muhayyel muhayyel # sudo apt-get update
Yoksay    http://ppa.launchpad.net testing InRelease
Yoksay    http://ppa.launchpad.net testing Release.gpg
Yoksay    http://extra.linuxmint.com debian InRelease
Yoksay    http://packages.linuxmint.com debian InRelease
Bağlandı  http://debian.linuxmint.com testing InRelease
Yoksay    http://extra.linuxmint.com debian Release.gpg
Alınıyor: 1 http://packages.linuxmint.com debian Release.gpg [198 B]
Bağlandı  http://debian.linuxmint.com testing/updates InRelease
Alınıyor: 2 http://extra.linuxmint.com debian Release [2.275 B]
Alınıyor: 3 http://packages.linuxmint.com debian Release [16,8 kB]
Yoksay    http://extra.linuxmint.com debian/main amd64 Packages/DiffIndex
Bağlandı  http://debian.linuxmint.com testing/main amd64 Packages/DiffIndex
Alınıyor: 4 http://packages.linuxmint.com debian/main amd64 Packages [26,1 kB]
Bağlandı  http://debian.linuxmint.com testing/contrib amd64 Packages/DiffIndex
Yoksay    http://extra.linuxmint.com debian/main i386 Packages/DiffIndex
Bağlandı  http://debian.linuxmint.com testing/non-free amd64 Packages/DiffIndex
Alınıyor: 5 http://packages.linuxmint.com debian/upstream amd64 Packages [18,1 kB]
Bağlandı  http://debian.linuxmint.com testing/main i386 Packages/DiffIndex
Alınıyor: 6 http://packages.linuxmint.com debian/import amd64 Packages [53,6 kB]
Bağlandı  http://debian.linuxmint.com testing/contrib i386 Packages/DiffIndex
Bağlandı  http://debian.linuxmint.com testing/non-free i386 Packages/DiffIndex
Bağlandı  http://debian.linuxmint.com testing/contrib Translation-en/DiffIndex
Bağlandı  http://debian.linuxmint.com testing/main Translation-tr
Alınıyor: 7 http://packages.linuxmint.com debian/main i386 Packages [26,1 kB]
Bağlandı  http://debian.linuxmint.com testing/main Translation-en/DiffIndex
Bağlandı  http://debian.linuxmint.com testing/non-free Translation-en/DiffIndex
Bağlandı  http://debian.linuxmint.com testing/updates/main amd64 Packages
Alınıyor: 8 http://packages.linuxmint.com debian/upstream i386 Packages [18,1 kB]
Hata      http://ppa.launchpad.net testing/main Sources
  404  Not Found
Bağlandı  http://debian.linuxmint.com testing/updates/contrib amd64 Packages
Hata      http://ppa.launchpad.net testing/main amd64 Packages
  404  Not Found
Alınıyor: 9 http://packages.linuxmint.com debian/import i386 Packages [53,6 kB]
Hata      http://ppa.launchpad.net testing/main i386 Packages
  404  Not Found
Bağlandı  http://debian.linuxmint.com testing/updates/non-free amd64 Packages
Yoksay    http://ppa.launchpad.net testing/main Translation-tr_TR
Bağlandı  http://debian.linuxmint.com testing/updates/main i386 Packages
Yoksay    http://ppa.launchpad.net testing/main Translation-en
Bağlandı  http://debian.linuxmint.com testing/updates/contrib i386 Packages
Bağlandı  http://debian.linuxmint.com testing/updates/non-free i386 Packages
Bağlandı  http://debian.linuxmint.com testing/updates/contrib Translation-en
Bağlandı  http://debian.linuxmint.com testing/updates/main Translation-en
Bağlandı  http://debian.linuxmint.com testing/updates/non-free Translation-en
Alınıyor: 10 http://extra.linuxmint.com debian/main amd64 Packages [20 B]
Alınıyor: 11 http://extra.linuxmint.com debian/main i386 Packages [20 B]
Yoksay    http://extra.linuxmint.com debian/main Translation-tr_TR
Yoksay    http://extra.linuxmint.com debian/main Translation-en
Yoksay    http://debian.linuxmint.com testing/main Translation-tr_TR
Yoksay    http://debian.linuxmint.com testing/main Translation-en
Yoksay    http://debian.linuxmint.com testing/non-free Translation-tr_TR
Yoksay    http://debian.linuxmint.com testing/non-free Translation-en
Yoksay    http://packages.linuxmint.com debian/import Translation-tr_TR
Yoksay    http://packages.linuxmint.com debian/import Translation-en
Yoksay    http://packages.linuxmint.com debian/main Translation-tr_TR
Yoksay    http://packages.linuxmint.com debian/main Translation-en
Yoksay    http://packages.linuxmint.com debian/upstream Translation-tr_TR
Yoksay    http://packages.linuxmint.com debian/upstream Translation-en
19 sn.'de 215 kB alındı (11,3 kB/s)
W: http://ppa.launchpad.net/n-muench/burg/ubuntu/dists/testing/main/source/Sources ağdan alınamadı. 404  Not Found
W: http://ppa.launchpad.net/n-muench/burg/ubuntu/dists/testing/main/binary-amd64/Packages ağdan alınamadı. 404  Not Found
W: http://ppa.launchpad.net/n-muench/burg/ubuntu/dists/testing/main/binary-i386/Packages ağdan alınamadı. 404  Not Found
E: Bazı indeks dosyaları indirilemedi. Bu dosyalar yok sayıldılar ya da önceki sürümleri kullanıldı.
[100]muhayyel muhayyel # sudo apt-get install burg burg-themes
Düzenleme : Konu başlığı
« Son Düzenleme: 04 Temmuz 2014, 18:49:07 Gönderen: Butterfly »
Ynt: Burg Kurulumda Sorun..
« Yanıtla #1 : 04 Temmuz 2014, 16:28:37 »
[member=531]quem4R[/member], siz Linux mint 17 yerine, Linux Mint Debian Sürümü (LMDE) kurmusunuz. LMDE'ye bu şekilde PPA deposu ekleyerek uygulama kuramazsınız. Yeni kullanıcıların LMDE yerine Linux Mint 17 kurmaları daha uygun olacaktır.
Bunun haricinde aşağıdaki komut ile Windows'u Grub menüsüne eklemeyi deneyebilirsiniz.
sudo update-grub
Ek olarak aşağıdaki komutlar ile burg deposunu kaldırmanız gerekecek.
sudo rm -rf /etc/apt/sources.list.d/*burg*
Çevrimdışı quem4R
  • İleti: 14
« Yanıtla #2 : 04 Temmuz 2014, 16:54:19 »
sudo update-grub
Teşekkürler şuanda win sisteminden yazıyorum sayenizde.
Nasıl öyle bir hata yapmışım anlamadım :)
