Gönderen Konu: [Çözüldü] Giriş Ekranından Sonra Masaüstünün Gelmemesi Sorunu  (Okunma sayısı 6182 defa)
Çevrimdışı sayz
  • İleti: 4
Herkese merhaba.
Bu sabah bir problemle karşılaştım. Şöyle ki; bilgisayarı açınca giriş ekranı geliyor karşıma. Sonra şifremi giriyorum bomboş bi ekran başka bir şey yok. Şu anda bu yazıyı güvenli moddan yazıyorum. Yani güvenli modla açınca bir problem yok, ama normal olarak açamıyorum bilgisayarı.
sayz@caravasar$  lspci
00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09)
00:01.1 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09)
00:14.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller (rev 04)
00:16.0 Communication controller: Intel Corporation 7 Series/C210 Series Chipset Family MEI Controller #1 (rev 04)
00:1a.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #2 (rev 04)
00:1b.0 Audio device: Intel Corporation 7 Series/C210 Series Chipset Family High Definition Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 1 (rev c4)
00:1c.2 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 3 (rev c4)
00:1c.3 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 4 (rev c4)
00:1d.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation HM76 Express Chipset LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation 7 Series Chipset Family 6-port SATA Controller [AHCI mode] (rev 04)
00:1f.3 SMBus: Intel Corporation 7 Series/C210 Series Chipset Family SMBus Controller (rev 04)
01:00.0 VGA compatible controller: NVIDIA Corporation GF108M [GeForce GT 635M] (rev a1)
04:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8723AE PCIe Wireless Network Adapter
05:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. Device 5289 (rev 01)
05:00.2 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 0a)
sayz@caravasar$  uname -a
Linux caravasar 3.13.0-24-generic #47-Ubuntu SMP Fri May 2 23:30:00 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
sayz@caravasar$  cat /etc/lsb-release
DISTRIB_ID=LinuxMint
DISTRIB_RELEASE=17
DISTRIB_CODENAME=qiana
DISTRIB_DESCRIPTION="Linux Mint 17 Qiana"
sayz@caravasar$
Önerilerinizi bekliyorum, teşekkürler.
Düzenleme : Çözüldü etiketi, imla ve başlık
« Son Düzenleme: 16 Ağustos 2014, 22:40:49 Gönderen: Butterfly »
Ynt: Giriş Ekranından Sonra Masaüstünün Gelmemesi Sorunu
« Yanıtla #1 : 13 Temmuz 2014, 13:44:49 »
Öncelikle aşağıdaki komut ile Cinnamon ayarlarını sıfırlamak denebilir.
Sorun uyumsuz bir eklenti ya da uygulamacıktan kaynaklanıyor olabilir.
Sorundan önce eklenti ya da uygulamacık eklemiş miydiniz?
« Son Düzenleme: 13 Temmuz 2014, 13:55:53 Gönderen: Butterfly »
Çevrimdışı sayz
  • İleti: 4
« Yanıtla #2 : 13 Temmuz 2014, 14:48:17 »
Maalesef işe yaramadı. Hiçbir eklenti falan da yüklemedim. Dün normal olarak kapatmıştım bilgisayarı. Bu sabah açınca böyle bi sorunla karşılaştım işte.
Düzenleme : İmla
Cümle başları
« Son Düzenleme: 13 Temmuz 2014, 15:11:16 Gönderen: Butterfly »
« Yanıtla #3 : 13 Temmuz 2014, 15:14:00 »
Aşağıdaki komut ile Cinnamon ve MDM'yi yeniden kurmayı deneyiniz.
sudo apt-get update && sudo apt-get install --reinstall cinnamon* mdm
Çevrimdışı sayz
  • İleti: 4
« Yanıtla #4 : 13 Temmuz 2014, 16:05:07 »
yine bir değişiklik olmadı. yalnız şöyle bir durum var bir kullanıcı daha var bu bilgisayarda. o kullanıcı ile giriş yaptığım zaman her şey normal, yani ekran geliyor.
« Yanıtla #5 : 13 Temmuz 2014, 16:32:37 »
Aşağıdaki komut ile ayar dosyalarını silmeyi deneyiniz.
(kullanıcı_adı yerine oturum açılmayan kullanıcının adını yazınız.)
cd /home/kullanıcı_adı
rm -rf .config .cache .cinnamon .local
Çevrimdışı sayz
  • İleti: 4
« Yanıtla #6 : 15 Temmuz 2014, 19:09:39 »
problem böyle çözüldü teşekkürler...
