Disk /dev/sda: 32.0 GB, 32017047552 bytes
255 heads, 63 sectors/track, 3892 cylinders, total 62533296 sectors
Disk identifier: 0xc2d351af
Device Boot Start End Blocks Id System
/dev/sda1 * 2048 206847 102400 7 HPFS/NTFS/exFAT
/dev/sda2 206848 62529535 31161344 7 HPFS/NTFS/exFAT
Disk /dev/sdb: 500.1 GB, 500107862016 bytes
Disk identifier: 0xc2d351ab
/dev/sdb1 2048 409602047 204800000 7 HPFS/NTFS/exFAT
/dev/sdb2 * 409602048 833409023 211903488 7 HPFS/NTFS/exFAT
/dev/sdb3 833411071 935811071 51200000+ f W95 Ext'd (LBA)
Partition 3 does not start on physical sector boundary.
/dev/sdb4 935811072 976361471 20275200 12 Compaq diagnostics
/dev/sdb5 833411072 935811071 51200000 7 HPFS/NTFS/exFAT
Disk /dev/sdc: 4022 MB, 4022337024 bytes
255 heads, 63 sectors/track, 489 cylinders, total 7856127 sectors
Disk identifier: 0xff6e4d6f
/dev/sdc1 * 38 7839719 3919841 c W95 FAT32 (LBA)
Düzenleme: Kod etiketi
