Gönderen Konu: [Çözüldü]Notebook bekleme modu sorunu  (Okunma sayısı 13310 defa)
Çevrimdışı efulim
  • İleti: 26
  • Dağıtım: Linux Mint 17 Cinnamon
« : 14 Ağustos 2014, 17:04:39 »
Merhabalar linux mint 16 cinnamon kullanıyorum. Notebook'u kapağından kapatıp bekleme moduna alıyorum. Ancak açtığımda ekran gelmiyor. Siyah bir ekran var
Bu sorunu nasıl düzeltebilirim
« Son Düzenleme: 17 Ağustos 2014, 00:28:51 Gönderen: efulim »
Ynt: Notebook bekleme modu sorunu
« Yanıtla #1 : 14 Ağustos 2014, 17:50:30 »
inxi -Fx
Çevrimdışı efulim
  • İleti: 26
« Yanıtla #2 : 14 Ağustos 2014, 18:32:11 »
System:    Host: EFULIM Kernel: 3.11.0-12-generic x86_64 (64 bit, gcc: 4.8.1) Desktop: Gnome Distro: Linux Mint 16 Petra
Machine:   System: Sony product: SVE17133CTB version: C9059QY5
           Mobo: Sony model: VAIO Bios: Insyde version: R0170D6 date: 03/13/2012
CPU:       Quad core Intel Core i7-3632QM CPU (-HT-MCP-) cache: 6144 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 17558.1
           Clock Speeds: 1: 1200.00 MHz 2: 1200.00 MHz 3: 1200.00 MHz 4: 1200.00 MHz 5: 1200.00 MHz 6: 1200.00 MHz 7: 1200.00 MHz 8: 1400.00 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Thames [Radeon HD 7550M/7570M/7650M] bus-ID: 01:00.0
           X.Org: 1.14.3 driver: fglrx Resolution: 1920x1080@60.0hz
           GLX Renderer: AMD Radeon HD 7500M/7600M Series GLX Version: 4.2.12337 - CPC 13.101 Direct Rendering: Yes
Audio:     Card-1: Intel 7 Series/C210 Series Chipset Family High Definition Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
           Card-2: Advanced Micro Devices [AMD/ATI] Turks/Whistler HDMI Audio [Radeon HD 6000 Series] driver: snd_hda_intel bus-ID: 01:00.1
           Sound: Advanced Linux Sound Architecture ver: k3.11.0-12-generic
           driver: r8169 ver: 2.3LK-NAPI port: 2000 bus-ID: 0e:00.0
           IF: eth0 state: down mac: 54:53:ed:3c:05:5b
           Card-2: Qualcomm Atheros AR9485 Wireless Network Adapter driver: ath9k bus-ID: 02:00.0
           IF: wlan0 state: up mac: b8:76:3f:fb:89:db
Drives:    HDD Total Size: 750.2GB (2.6% used) 1: id: /dev/sda model: Hitachi_HTS54107 size: 750.2GB
Partition: ID: / size: 47G used: 19G (42%) fs: ext4 ID: swap-1 size: 81.19GB used: 0.00GB (0%) fs: swap
Sensors:   System Temperatures: cpu: 55.0C mobo: 42.0C gpu: 49.50C
Info:      Processes: 204 Uptime: 2 min Memory: 634.3/7935.9MB Runlevel: 2 Gcc sys: 4.8.1 Client: Shell inxi: 1.8.4
Bu çıktıyı vermişken bi sorun daha var. Bilgisayar her açılışta ekran parlaklığı en düşük seviyede açılıyor.
Bu konu hakkında da yardımcı olabilirmisiniz.
« Yanıtla #3 : 14 Ağustos 2014, 21:41:27 »
Öncelikle aşağıdaki komutları sırasıyla uçbirimde çalıştırıp sisteminizi güncellemeyi denemenizi öneririm.
sudo apt-get upgrade
sudo apt-get dist-upgrade
Not : Bu güncellemeler ile daha güncel çekirdek de kurulacaktır. Güncelleme sırasında bazı dosyaların değiştirilmesi istenebilir. Bu durumda (N tuşu ile) varsayılan dosyaların korunmasını sağlamalısınız. Güncellemeler sonrası sisteminizi yeniden başlattığınızda, kurulan yeni çekirdek varsayılan olacaktır ve sistem yeni çekirdekle açılacaktır.
Çevrimdışı efulim
  • İleti: 26
« Yanıtla #4 : 14 Ağustos 2014, 22:38:31 »
Söylediğiniz gibi sistemi güncelledim. Fakat bahsettiğim sorunlar halen devam etmekte
« Yanıtla #5 : 15 Ağustos 2014, 09:36:22 »
Aşağıdaki komutların çıktılarını da rica edelim.
cat /etc/initramfs-tools/conf.d/resume
cat /etc/fstab | grep swap
sudo blkid
dpkg -l | grep fglrx
fglrxinfo
Çevrimdışı efulim
  • İleti: 26
« Yanıtla #6 : 15 Ağustos 2014, 21:03:58 »
# swap was on /dev/sda5 during installation
UUID=e5ea2c67-4858-45bc-9438-404dd614a4a3 none            swap    sw              0       0
sudo blkid
/dev/sda1: UUID="629FD242690D59D9" TYPE="ntfs"
/dev/sda2: UUID="6cfd16ce-c87b-42a3-a953-9183ff4cb614" TYPE="ext4"
/dev/sda5: UUID="e5ea2c67-4858-45bc-9438-404dd614a4a3" TYPE="swap"
OpenGL renderer string: AMD Radeon HD 7500M/7600M Series
Section "ServerLayout"
Section "Module"
Section "Monitor"
Option     "VendorName" "ATI Proprietary Driver"
Option     "ModelName" "Generic Autodetecting Monitor"
Option     "DPMS" "true"
Driver      "fglrx"
BusID       "PCI:1:0:0"
Section "Screen"
DefaultDepth     24
SubSection "Display"
Viewport   0 0
Depth     24
EndSubSection
rc  fglrx                                       2:13.101-0ubuntu3                       amd64        Video driver for the AMD graphics accelerators
ii  fglrx-amdcccle-updates                      2:13.101-0ubuntu3                       amd64        Catalyst Control Center for the AMD graphics accelerators
ii  fglrx-updates                               2:13.101-0ubuntu3                       amd64        Video driver for the AMD graphics accelerators
fglrxinfo
display: :0  screen: 0
OpenGL version string: 4.2.12337 Compatibility Profile Context 13.101
Kusura bakmayın iş yoğunluğu sebebi ile geç yanıt verdim.
« Son Düzenleme: 15 Ağustos 2014, 21:18:02 Gönderen: efulim »
« Yanıtla #7 : 15 Ağustos 2014, 22:07:58 »
Aşağıdaki komut ile /etc/initramfs-tools/conf.d/resume dosyaını açınız.
(Not: Mate masaüstü için gedit yerine pluma yazmayı deneyiniz.)
sudo gedit /etc/initramfs-tools/conf.d/resume
Açılan dosya içine aşağıdaki satırı ekleyip kaydediniz.
RESUME=UUID=e5ea2c67-4858-45bc-9438-404dd614a4a3
Düzenleme sonrası sistemi yeniden başlatmayı deneyiniz.
Çevrimdışı efulim
  • İleti: 26
« Yanıtla #8 : 15 Ağustos 2014, 22:15:29 »
Söylediklerinizi yaptım fakat hiç bir değişiklik olmadı.
« Yanıtla #9 : 15 Ağustos 2014, 22:29:27 »
Aşağıdaki komutu uçbirimde çalıştırıp sistemi yeniden başlatmayı deneyiniz.
sudo update-initramfs -u
Çevrimdışı efulim
  • İleti: 26
« Yanıtla #10 : 15 Ağustos 2014, 22:33:40 »
Bir hata verdi.
update-initramfs: Generating /boot/initrd.img-3.11.0-12-generic
Çevrimdışı Çağrı07
  • İleti: 391
    • Kayıt Formu
  • Masaüstü Ortamı: XFCE
« Yanıtla #11 : 15 Ağustos 2014, 22:36:45 »
Bir hata verdi.
  O tam olarak hata sayılmaz, Türkçe dil uyarısında bulunuyor
Türkçe dil uyarısını görmek istemiyorsanız şu komutu terminalde çalıştırmanız yeterli olacaktır.
sudo locale-gen --purge --no-archive
Bunun dışında üstündeki çıktı da normal gözüküyor
Sorun düzelmiş gibi
« Son Düzenleme: 15 Ağustos 2014, 22:44:35 Gönderen: Çağrı07 »
Yaşlanıyorum...
Çevrimdışı efulim
  • İleti: 26
« Yanıtla #12 : 15 Ağustos 2014, 22:45:51 »
sorun halen devam ediyor. Değişen bir şey yok
Çevrimdışı Çağrı07
  • İleti: 391
    • Kayıt Formu
« Yanıtla #13 : 15 Ağustos 2014, 23:00:42 »
  Linux çekirdekleri guncel mi ?
Eğer ki güncel değil ise güncelleme yöneticisinden yukaridaki bölümlerden görünüm>linux cekirdekleri, oradan son rakami cift ile biten rakami seçip yükle butonuna basin (Şuan güncel olan 3.13.0-34)
Yaşlanıyorum...
« Yanıtla #14 : 16 Ağustos 2014, 09:41:51 »
Güç ayarlarından baktığınızda, kapağı kapatınca hangi seçeneğin etkin görünüyor? Pil ile çalışırken ve güç kablosu takılıyken ayrı ayrı güç seçenekleri olmalı, ne gözüküyor?
Kapalı kaynak sürücüsü (ATI fglrx) kurulmadan önce sorun var mıydı?
Ek olarak sistem uyandığında CTRL+ALT+ F1, CTRL+ALT+ F7 ve CTRL+ALT+ F8 tuşlarına sırasıyla basmayı dener misiniz? Burasını referans için ekleyelim.
« Son Düzenleme: 16 Ağustos 2014, 09:53:56 Gönderen: Butterfly »
