Gönderen Konu: Docky Açılmıyor  (Okunma sayısı 8046 defa)
Çevrimdışı varulven
  • İleti: 123
  • non me tenent vincula, non me tenet clavis
  • Dağıtım: Linux Mint 16 Cinnamon Edition 32-Bit
Docky Açılmıyor
« : 05 Mart 2014, 00:28:18 »
Hem yazılım yöneticisinden hem de
sudo apt-get install docky
kodu ile denedim, malesef ikisinde de açılmadı.
Uçbirimden docky yazıp çalıştırınca böyle bir çıktı veriyor.
[Info  00:25:27.001] Docky version: 2.2.0 Release
[Info  00:25:27.005] Kernel version: 3.11.0.12
[Info  00:25:27.008] CLR version: 4.0.30319.1
[Error 00:25:27.242] [SystemService] Could not initialize power manager dbus: 'org.freedesktop.DBus.Error.MatchRuleInvalid: Unknown key "ınterface" in match rule'
[Info  00:25:27.243] [SystemService]   at org.freedesktop.DBus.IBusProxy.AddMatch (System.String rule) [0x00000] in <filename unknown>:0
  at DBus.Bus.AddMatch (System.String rule) [0x00000] in <filename unknown>:0
  at DBus.BusObject.ToggleSignal (System.String iface, System.String member, System.Delegate dlg, Boolean adding) [0x00000] in <filename unknown>:0
  at Docky.Services.SystemService+IUPowerProxy.add_Changed (System.Action value) [0x00000] in <filename unknown>:0
  at Docky.Services.SystemService.InitializeBattery () [0x00000] in <filename unknown>:0
Unhandled Exception: System.Exception: org.freedesktop.DBus.Error.MatchRuleInvalid: Unknown key "ınterface" in match rule
  at org.freedesktop.DBus.IBusProxy.add_NameOwnerChanged (org.freedesktop.DBus.NameOwnerChangedHandler value) [0x00000] in <filename unknown>:0
  at Docky.Services.SystemService.InitializeNetwork () [0x00000] in <filename unknown>:0
  at Docky.Services.SystemService.Initialize () [0x00000] in <filename unknown>:0
  at Docky.Services.DockServices.Init (Boolean disableHelpers) [0x00000] in <filename unknown>:0
  at Docky.Docky.Main (System.String[] args) [0x00000] in <filename unknown>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.Exception: org.freedesktop.DBus.Error.MatchRuleInvalid: Unknown key "ınterface" in match rule
Yardımlarınız için şimdiden teşekkürler.
Ynt: Docky Açılmıyor
« Yanıtla #1 : 05 Mart 2014, 08:52:20 »
Burayı inceler misiniz?
Çevrimdışı candancelik
  • İleti: 22
  • C.
    • candaancelik
  • Dağıtım: Linux Mint 19
  • Masaüstü Ortamı: Xfce
  • İşlemci: Intel
« Yanıtla #2 : 13 Ağustos 2016, 20:28:58 »
LM 18 Xfce kullanıyorum bugün benim de başıma geldi docky açılmadı. Butterfly'ın dediklerini yaptım yine olmadı. Fakat şu komutla çalıştı:
env LC_ALL=C docky
ol mahiler ki derya içredir deryayı bilmezler
« Yanıtla #3 : 13 Ağustos 2016, 20:48:45 »
Buradaki yapılandırma dosyası ile ilgili düzenlemeyi yapıp, oturumu kapatıp açmayı deneyiniz.
