Gönderen Konu: Nvidia Sürücü Hatası (Broken NVIDIA RandR detected)  (Okunma sayısı 7783 defa)
Çevrimdışı okan6067
  • İleti: 10
  • Dağıtım: linux mint 17 Kde
merhaba bende böyle bi sorun alıyorum "err:winediag:xrandr12_init_modes Broken NVIDIA RandR detected, falling back to RandR 1.0. Please consider using the Nouveau driver instead." daha önce league of legends oynayabiliyodum. fakat sistemi yeniledim. o zamanda çok uğraşmıştım ve işin  kötüsü nasıl yaptığımı hatırlamıyorum :(
okan[member=234]okan[/member]-Aspire-5739G:~ > lspci | egrep 'VGA|3D|Display'
01:00.0 VGA compatible controller: NVIDIA Corporation GT216M [GeForce GT 240M] (rev a2)
okan[member=234]okan[/member]-Aspire-5739G:~ > dpkg -l | egrep 'nvidia|prime|bumblebee'
ii  bumblebee                                   3.2.1-5                                           amd64        NVIDIA Optimus support for Linux
ii  nvidia-331                                  331.38-0ubuntu7.1                                 amd64        NVIDIA binary driver - version 331.38
ii  nvidia-common                               1:0.2.91.4linuxmint1                              amd64        transitional package for ubuntu-drivers-common
rc  nvidia-libopencl1-331                       331.38-0ubuntu7.1                                 amd64        NVIDIA OpenCL Driver and ICD Loader library
ii  nvidia-opencl-icd-331                       331.38-0ubuntu7.1                                 amd64        NVIDIA OpenCL ICD
ii  nvidia-prime                                0.6.2linuxmint1                                   amd64        Tools to enable NVIDIA's Prime
ii  nvidia-settings                             331.20-0ubuntu8                                   amd64        Tool for configuring the NVIDIA graphics driver
okan[member=234]okan[/member]-Aspire-5739G:~ > glxinfo | grep render
OpenGL renderer string: GeForce GT 240M/PCIe/SSE2
    GL_NVX_conditional_render, GL_NVX_gpu_memory_info,
    GL_NV_ES1_1_compatibility, GL_NV_blend_square, GL_NV_conditional_render,
okan[member=234]okan[/member]-Aspire-5739G:~ > inxi -Gx
Graphics:  Card: NVIDIA GT216M [GeForce GT 240M] bus-ID: 01:00.0
           X.Org: 1.15.1 drivers: nvidia (unloaded: fbdev,vesa,nouveau) Resolution: 1366x768@60.0hz
           GLX Renderer: GeForce GT 240M/PCIe/SSE2 GLX Version: 3.3.0 NVIDIA 331.38 Direct Rendering: Yes
okan[member=234]okan[/member]-Aspire-5739G:~ > cat /etc/X11/xorg.conf
Düzenleme : Mesajlar birleştirildi
« Son Düzenleme: 06 Eylül 2014, 15:20:51 Gönderen: Butterfly »
Ynt: Nvidia Sürücü Hatası (Broken NVIDIA RandR detected)
« Yanıtla #1 : 06 Eylül 2014, 16:14:00 »
[member=689]okan6067[/member], öncelikle belirteyim ki forumda aynı sorunla ilgili birden fazla konuya mesaj yazar ve size yeni konu açmanız belirtilince bu defa aynı sorun ile ilgili birden fazla konu açarsanız forum düzenini bozmuş olursunuz. Bu sebeple iletileriniz moderasyon kapsamına alınmıştır. Buna rağmen yeni bir üyelik açıp benzer davranışları sergilemeye devam ediyorsunuz. Açtığınız diğer üyelik yasak olması sebebiyle silinmiştir. Lütfen forum kurallarını okuyunuz.
Forum Kuralları
Sorunun kaynağı sisteminizde hibrid GPU (Nvidia + Intel Optimus) olmadığı halde Bumblebee'yi kurmanız olabilir. Aşağıdaki komut ile Bumblebee uygulamasını siliniz ve sisteminizi yeniden başlatınız.
sudo apt-get purge bumblebee nvidia-prime
Sisteminizi yeniden başlattıktan sonra aşağıdaki komutlar ile Nvidia sürücüsünü yeniden kurunuz.
sudo apt-get install --reinstall nvidia-331 nvidia-settings
sudo nvidia-xconfig
Sisteminizi yeniden başlatınız.
« Son Düzenleme: 06 Eylül 2014, 16:16:50 Gönderen: Butterfly »
Çevrimdışı okan6067
  • İleti: 10
« Yanıtla #2 : 06 Eylül 2014, 16:24:58 »
Şimdi 1.si bilerek yapmadım. Daha dogrusu ilk actıgım yerin alakasız oldugunu düşünüp ekran kartı ile ilgili yere açtım ama diğerini kaldıramadım. Diğerine aslında bunu daha önce sizin söylediklerinizi yaparak aşmıştım harddisk bad sectorverdi mecbur yeni hddye seni sistem kurdum busefer yapamadım. Daha önce ilk yaptıklarımı hatırlamıyorum ama en son nomodeset yaptıktan sonra düzeldi fakat şimdi açılışta hep siyah ekranda yazılar gelip öyle açılıyor
« Yanıtla #3 : 06 Eylül 2014, 18:08:57 »
Masaüstüne ulaşabiliyor musunuz?
Çevrimdışı okan6067
  • İleti: 10
« Yanıtla #4 : 06 Eylül 2014, 18:57:32 »
evet ulaşabiliyorum. ama uygulamalarda sıkıntı oluyo playonlinux wine uygulamalarında. Dediğinizi yaptım ama hala aynı hatayı veriyor. onuda şöyle veriyor. sudo apt-get install winetricks yapıp sonra winetricks adobeair yüklerken çıkıyo bu broken nvidia randR detected.
Dediğim gibi hdd bad sector vermeden önce mint 17 kde vardı. onlada çok uğrasmıstım en son başlangıcta. quite splash silip yerine nomodeset yaptım ver düzelmişti ama şimdi olmuyor  :(
« Yanıtla #5 : 06 Eylül 2014, 19:32:23 »
Aşağıdaki komutlar ile Wine ile ilgili dizinleri silip, Wine ayarlarını sıfırlamayı deneyebilirsiniz.
rm -rf ~/.wine
rm -rf ~/.config/winetricks
Çevrimdışı okan6067
  • İleti: 10
« Yanıtla #6 : 06 Eylül 2014, 19:38:36 »
Malesef hiç bir tepki vermedi :(
okan[member=234]okan[/member]-Aspire-5739G ~ $ rm -rf ~/.wine
okan[member=234]okan[/member]-Aspire-5739G ~ $ rm -rf ~/.config/winetricks
« Yanıtla #7 : 06 Eylül 2014, 20:51:04 »
Hiç bir tepki vermeyecek zaten, Wine ile ilgili ayarların ve depolamaların bulunduğu dizinleri sildiniz. Şimdi uygulamayı tekrar kurmayı deneyiniz.
Çevrimdışı okan6067
  • İleti: 10
« Yanıtla #8 : 06 Eylül 2014, 21:19:15 »
malesef yine olmadı :(  ya daha önce nasıl oldu bilmiyorum aynı şeyleri şimdide yapıyorum fakat olmuyor. playonlinux üzerinden league of legends yükledim sonra winetricks yükledim. adobeair, ie8, vcrun2005, vcrun2008, wininet, corefonts, d3dx9. bunlar sonra oyunu acıyorum client de sorun yok Fakat oyuna girince siyah ekran var. birde bilgisayarı her yeniden başlattığımda nomodeset değişmiş yerine, yeniden quiet splash geliyor.
Çevrimdışı okan6067
  • İleti: 10
« Yanıtla #9 : 06 Eylül 2014, 21:22:49 »
Bu arada sitemim p7370 2.0ghz işlemci
Geforge gt240 ekran kartı.
4gb ram
Sizce hangi sürümü yüklemeliyim.
yada hangisinde böyle sorunları daha az yaşarım.
Kde de bikez bu sorunu aşmıştım. ama şimdi aşamadım.
« Yanıtla #10 : 06 Eylül 2014, 23:11:14 »
Oyun oynadığınızı da gözönüne alarak, Linux Mint 17 Mate 32 bit sürümü önerebilirim.
Mate masaüstü sistem kaynaklarını oldukça az kullanan, geleneksel ve hızlı bir ortam sunmakta.
Çevrimdışı okan6067
  • İleti: 10
« Yanıtla #11 : 07 Eylül 2014, 06:08:37 »
öncelikle ilginiz için teşekkür ederim. sorun çözüldü. ben novua driver aktifken yüklemeleri yapınca ve nvidia geçince playonlinux'u sistem kadırıyordu. Önce söylediğiniz sekilde yüklemeleri yaptım. Sonra uygulamaları ve oyunları kurdum bi problem çıkmadı  :) Ama 2 günümü aldı. Pes etmemek de güzel bi duygu :)
