Gönderen Konu: Asus EEE PC 1215N GOOGLE EARTH SORUNU  (Okunma sayısı 5818 defa)
Çevrimdışı zeyneLAB
  • İleti: 3
« : 28 Eylül 2014, 23:16:54 »
Herkese merhaba!!
Google earth´ü kurdum ancak ekran kartımın yetersiz olduğuna dair mesaj alıyorum. Aynı sıkıntıyı win7´de yaşamıyorum. Nvidia Ion ekran kartı var cihazın üstünde. Ne yapabilirim?
« Son Düzenleme: 28 Eylül 2014, 23:20:05 Gönderen: zeyneLAB »
Ynt: Asus EEE PC 1215N GOOGLE EARTH SORUNU
« Yanıtla #1 : 28 Eylül 2014, 23:27:45 »
inxi -Fx
dpkg -l | grep earth
uname -rm
Çevrimdışı zeyneLAB
  • İleti: 3
« Yanıtla #2 : 29 Eylül 2014, 00:07:05 »
SIRASIYLA...
00:02.0 VGA compatible controller: Intel Corporation Atom Processor D4xx/D5xx/N4xx/N5xx Integrated Graphics Controller (rev 02)
00:02.1 Display controller: Intel Corporation Atom Processor D4xx/D5xx/N4xx/N5xx Integrated Graphics Controller (rev 02)
04:00.0 VGA compatible controller: NVIDIA Corporation GT218 [ION 2] (rev a2)
Xlib:  extension "GLX" missing on display ":0.0".
ystem:    Host: zeynelab-1215N Kernel: 3.11.0-12-generic i686 (32 bit, gcc: 4.8.1)
           Desktop: Xfce 4.10.2 (Gtk 2.24.20) Distro: Linux Mint 16 Petra
Machine:   System: ASUSTeK product: 1215N version: x.x
           Mobo: ASUSTeK model: 1215N version: x.xx Bios: American Megatrends version: 0203 date: 07/14/2010
CPU:       Dual core Intel Atom CPU D525 (-HT-MCP-) cache: 512 KB flags: (lm nx sse sse2 sse3 ssse3) bmips: 7217.02
           Clock Speeds: 1: 1804.257 MHz 2: 1804.257 MHz 3: 1804.257 MHz 4: 1804.257 MHz
Graphics:  Card-1: Intel Atom Processor D4xx/D5xx/N4xx/N5xx Integrated Graphics Controller bus-ID: 00:02.0
           Card-2: NVIDIA GT218 [ION 2] bus-ID: 04:00.0
           X.Org: 1.14.3 drivers: intel (unloaded: fbdev,vesa) Resolution: 1366x768@60.0hz
Audio:     Card: Intel NM10/ICH7 Family High Definition Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
           Sound: Advanced Linux Sound Architecture ver: k3.11.0-12-generic
Network:   Card-1: Qualcomm Atheros AR8152 v2.0 Fast Ethernet driver: atl1c ver: 1.0.1.1-NAPI port: dc00 bus-ID: 01:00.0
           IF: eth0 state: down mac: 20:cf:30:42:ef:cb
           Card-2: Broadcom BCM4313 802.11bgn Wireless Network Adapter driver: wl bus-ID: 02:00.0
           IF: eth2 state: up mac: 74:f0:6d:7e:d3:4f
Drives:    HDD Total Size: 250.1GB (7.0% used) 1: id: /dev/sda model: ST9250315AS size: 250.1GB temp: 36C
Partition: ID: / size: 115G used: 17G (16%) fs: ext4 ID: swap-1 size: 2.06GB used: 0.00GB (0%) fs: swap
Sensors:   System Temperatures: cpu: 57.0C mobo: N/A
Info:      Processes: 174 Uptime: 16 min Memory: 408.2/2006.6MB Runlevel: 2 Gcc sys: 4.8.1 Client: Shell inxi: 1.8.4
i  google-earth-stable                         7.1.2.2041-r0                           i386         Explore, search and discover the planet
« Yanıtla #3 : 29 Eylül 2014, 00:24:22 »
Öncelikle Linux Mint'in desteği biten biten bir sürümünü kullandığınızı hatırlatmak isterim. Linux Mint 16 artık herhangi bir güvenlik güncellemesi almıyor ve bu durum her zaman için bir güvenlik riski olasılığına sebep olacaktır.
Sisteminizi yeni kurdu iseniz iseniz, uzun süre destekli olan Linux Mint 17'yi yeniden kurmanız en makulu olacaktır. Linux Mint 17'yi kurduktan sonra burada anlatıldığı biçimde Bumblebee uygulamasını kurmayı deneyebilirsiniz.
Çevrimdışı zeyneLAB
  • İleti: 3
« Yanıtla #4 : 29 Eylül 2014, 00:35:50 »
OK. 17´yi kurarsam bütün verilerim diskten silinecek mi? Ya da güncelleme yaparak yükseltme mümkün mü?
« Son Düzenleme: 29 Eylül 2014, 00:39:33 Gönderen: zeyneLAB »
« Yanıtla #5 : 29 Eylül 2014, 09:21:58 »
Sistemi eğer Linux Mint 16 kurulu disk bölümüne yaparsanız, yeni kurulum sonrası bu bölümdeki verilerin üstüne yazılacaktır yani veriler silinecektir. Verilerinizi yedeklemek için 2. bir disk bölümünüz yoksa buradaki konuyu referans alarak yeni bir disk bölümü oluşturabilirsiniz. Sonrasında önemli verilerinizi bu yeni oluşturduğunuz disk bölümüne taşıyabilirsiniz.
Verilerinizi yedekledikten sonra yeni sürümü kurmanız için bir sorun kalmayacaktır.
Buna rağmen yeniden kurulum yerine sürümü güncellemek isterseniz, buradaki anlatımı uygulamayı deneyebilirsiniz. İlgili mesajdaki uyarıları dikkate almalısınız.
