Gönderen Konu: HP Pavilion DM1 Radeon HD 6320 Isınma Sorunu  (Okunma sayısı 7036 defa)
Çevrimdışı pomakemir
  • İleti: 36
  • Dağıtım: Linux Mint 17.1 Mate
« : 16 Aralık 2014, 21:39:54 »
aynı sorun bende de vardı yeni konu acıp kirlilik yaratmak istemedim efendim.
inxi -Fx
[code]System:    Host: emir-HP Kernel: 3.13.0-37-generic x86_64 (64 bit, gcc: 4.8.2) Desktop: N/A Distro: Linux Mint 17.1 Rebecca
Machine:   System: Hewlett-Packard (portable) product: HP Pavilion dm1 Notebook PC version: 0694110000204610000420100
           Mobo: Hewlett-Packard model: 3387 version: 36.18 Bios: Hewlett-Packard version: F.18 date: 11/16/2012
CPU:       Dual core AMD E-450 APU with Radeon HD Graphics (-MCP-) cache: 1024 KB flags: (lm nx sse sse2 sse3 sse4a ssse3 svm) bmips: 6586.18
           Clock Speeds: 1: 825.00 MHz 2: 825.00 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Wrestler [Radeon HD 6320] bus-ID: 00:01.0
           X.Org: 1.15.1 drivers: ati,radeon (unloaded: fbdev,vesa) Resolution: 1366x768@60.0hz
           GLX Renderer: Gallium 0.4 on AMD PALM GLX Version: 3.0 Mesa 10.1.3 Direct Rendering: Yes
Audio:     Card-1: Advanced Micro Devices [AMD/ATI] Wrestler HDMI Audio driver: snd_hda_intel bus-ID: 00:01.1
           Card-2: Advanced Micro Devices [AMD/ATI] SBx00 Azalia (Intel HDA) driver: snd_hda_intel bus-ID: 00:14.2
           driver: r8169 ver: 2.3LK-NAPI port: 2000 bus-ID: 07:00.0
           IF: eth0 state: down mac: 80:c1:6e:51:e6:73
           Card-2: Broadcom BCM4313 802.11bgn Wireless Network Adapter driver: wl bus-ID: 03:00.0
           IF: wlan1 state: up mac: c0:18:85:45:a5:74
Drives:    HDD Total Size: 500.1GB (3.4% used) 1: id: /dev/sda model: ST9500420AS size: 500.1GB
Partition: ID: / size: 455G used: 17G (4%) fs: ext4
Sensors:   System Temperatures: cpu: 67.2C mobo: N/A gpu: 67.0
Info:      Processes: 175 Uptime: 12:16 Memory: 1510.3/3553.0MB Runlevel: 2 Gcc sys: 4.8.2 Client: Shell inxi: 1.8.4
[/code]
00:01.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Wrestler [Radeon HD 6320]
[b]
OpenGL renderer string: Gallium 0.4 on AMD PALM
    GL_NV_blend_square, GL_NV_conditional_render, GL_NV_depth_clamp, [/b]
Ynt: HP Pavilion DM1 Radeon HD 6320 Isınma Sorunu
« Yanıtla #1 : 16 Aralık 2014, 22:26:07 »
[member=1061]pomakemir[/member], mesajınız bölünerek yeni bir konu oluşturuldu. Forumda yeni konu açılması ile ilgili bir kısıtımız yok. Sizin mesaj göndediğiniz konudaki üyenin sistemindeki donanım (Intel + Nvidia GPU)  ile sizin sisteminizin donanınımı (ATI GPU) birbirinden farklı. Bu sebeple öenrilerde farklı olacaktır. Forumda her konunun belli bir sorun için benzer sorunları yaşayanlara rehber olacak bir mahiyeti olmasını istiyoruz. Aynı konuda birbirinden farklı hususlar ya da biribirine benzer ama önerileri farklı olabilecek iletilerin olması bu mahiyetin azalmasına sebep oluyor.
Sizin sisteminiz için aşağıdaki komutlar ile ATI GPU kapalı kaynak sürücüsünü kurup sisteminizi yeniden başlatmayı deneyiniz.
sudo amdconfig --initial -f
  • İleti: 36
« Yanıtla #2 : 19 Aralık 2014, 17:13:29 »
Çıktım şu şekilde herhangi bir driver falan eklemedim.
lspci | grep VGA
    GL_EXT_vertex_array_bgra, GL_NV_conditional_render,
« Yanıtla #3 : 19 Aralık 2014, 17:16:56 »
Aşağıdaki komutlar ile fglrx sürücüsünü kurup sistemi yeniden başlatmayı deneyin.
Düzenleme : Benzer bir konuyu daha önce açmışsınız, bu sebeple konular birleştirildi.
« Son Düzenleme: 19 Aralık 2014, 17:19:35 Gönderen: Butterfly »
  • İleti: 36
« Yanıtla #4 : 19 Aralık 2014, 17:21:25 »
Sizi çok uğraştırdım son günlerde ama hem kısayol tuşları hem de güç yönetimi bölümünden parlaklık ayarlamıyorum ve gözükmüyor parlaklık seçeneği. Bu ekran kartı ile ilgili mi bilmiyorum ama. [member=8]Butterfly[/member]
Using /etc/X11/xorg.conf
Saving back-up to /etc/X11/xorg.conf.original-0
« Son Düzenleme: 19 Aralık 2014, 17:36:15 Gönderen: pomakemir »
« Yanıtla #5 : 19 Aralık 2014, 19:59:19 »
Aşağıdaki komutların çıktılarına bir bakalım, ısınma sorunu şu an ne durumda?
fglrxinfo
Parlaklık sorunu ile ilgili buradaki düzenlemeyi yapmayı deneyin, sorun çözülmezse farklı bir konu açınız.
  • İleti: 36
« Yanıtla #6 : 19 Aralık 2014, 22:28:55 »
[member=8]Butterfly[/member]  parlaklığı o değil de şu çözdü hocam sağolun http://forum.linuxmint.net.tr/index.php?topic=800.msg4531#msg4531
fglrxinfo
display: :0.0  screen: 0
OpenGL renderer string: AMD Radeon HD 6320 Graphics
OpenGL version string: 4.3.12798 Compatibility Profile Context 13.35.1005
« Yanıtla #7 : 19 Aralık 2014, 23:05:41 »
ATI kapalı kaynak sürücüsü kurulmuş ve etkinleşmiş olarak görünüyor.
  • İleti: 36
« Yanıtla #8 : 19 Aralık 2014, 23:37:19 »
Termal macunu da yeniledim ısınma cözüldü sanırım, konuyu da cözüldü yapıyorum.
