Gönderen Konu: Sistemde Yavaşlık Sorunu  (Okunma sayısı 3026 defa)
Çevrimdışı bilalmarifet
  • İleti: 1
« : 03 Ocak 2015, 02:51:44 »
bende de aynı sorun var ubuntudan çok yavaş geldi
inxi -Fx 'in çıktısı:
System:    Host: marifet Kernel: 3.13.0-24-generic i686 (32 bit, gcc: 4.8.2) Desktop: Gnome Distro: Linux Mint 17 Qiana
Machine:   System: Acer product: Aspire 2920 version: 0100
           Mobo: Acer model: Calado version: Rev Bios: Phoenix version: V1.13 date: 02/14/2008
CPU:       Dual core Intel Pentium Dual CPU T2370 (-MCP-) cache: 1024 KB flags: (lm nx sse sse2 sse3 ssse3) bmips: 6916.98
           Clock Speeds: 1: 1333.00 MHz 2: 800.00 MHz
Graphics:  Card: Intel Mobile GM965/GL960 Integrated Graphics Controller (primary) bus-ID: 00:02.0
           X.Org: 1.15.1 drivers: intel (unloaded: fbdev,vesa) Resolution: 1280x800@60.0hz
           GLX Renderer: Mesa DRI Intel 965GM x86/MMX/SSE2 GLX Version: 2.1 Mesa 10.1.0 Direct Rendering: Yes
Audio:     Card: Intel 82801H (ICH8 Family) HD Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
Network:   Card-1: Broadcom BCM4311 802.11b/g WLAN driver: b43-pci-bridge bus-ID: 04:00.0
           IF: wlan0 state: up mac: 00:1f:3a:3e:c0:a7
           Card-2: Broadcom NetLink BCM5787M Gigabit Ethernet PCI Express driver: tg3 ver: 3.134 bus-ID: 02:00.0
           IF: eth0 state: down mac: 00:1d:72:23:39:99
Drives:    HDD Total Size: 320.1GB (1.2% used) 1: id: /dev/sda model: SAMSUNG_HM321HI size: 320.1GB
Partition: ID: / size: 20G used: 3.8G (21%) fs: ext4 ID: swap-1 size: 6.00GB used: 0.00GB (0%) fs: swap
Sensors:   System Temperatures: cpu: 65.0C mobo: 62.0C
Info:      Processes: 138 Uptime: 12 min Memory: 396.0/3020.8MB Runlevel: 2 Gcc sys: 4.8.2 Client: Shell inxi: 1.8.4
sudo lshw -C display 'in çıktısı
PCI (sysfs)
  *-display:0
       açıklama: VGA compatible controller
       ürün: Mobile GM965/GL960 Integrated Graphics Controller (primary)
       üretici: Intel Corporation
       physical id: 2
       bus info: pci@0000:00:02.0
       sürüm: 03
       genişlik: 64 bits
       saat: 33MHz
       kapasiteler: msi pm vga_controller bus_master cap_list rom
       yapılandırma: driver=i915 latency=0
       kaynaklar: irq:43 bellek:fc000000-fc0fffff bellek:d0000000-dfffffff ioport:1800(boyut=8)
  *-display:1 UNCLAIMED
       açıklama: Display controller
       ürün: Mobile GM965/GL960 Integrated Graphics Controller (secondary)
       physical id: 2.1
       bus info: pci@0000:00:02.1
       sürüm: 03
       genişlik: 64 bits
       saat: 33MHz
       kapasiteler: pm bus_master cap_list
       yapılandırma: latency=0
       kaynaklar: bellek:fc100000-fc1fffff
Ynt: Sistemde Yavaşlık Sorunu
« Yanıtla #1 : 03 Ocak 2015, 09:33:41 »
Hangi masaüstünü kullanıyorsunuz? Bu performans sorunu genel olarak mı var yoksa özellikle internette ya da VLC gibi bir ortamda video seyrederken mi yaşanıyor?
Buradaki düzenlemeyi yapıp GPU hızlandırma metodunu "uxa" olarak ayarlamayı deneyebilirsiniz.
