Şuan sistem yeniden başlayınca düzeldi. Bazen çalışuyor bazen çalışmıyor.
inxi -Fx
System: Host: eu-MSI Kernel: 3.13.0-37-generic x86_64 (64 bit, gcc: 4.8.2) Desktop: N/A Distro: Linux Mint 17.1 Rebecca
Machine: System: Micro-Star (portable) product: GE620/GE620DX/FX620DX/FX623
Mobo: Micro-Star model: MS-16G5 Bios: American Megatrends version: E16G5IMS V3.0R date: 10/24/2012
CPU: Dual core Intel Core i5-2450M CPU (-HT-MCP-) cache: 3072 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9976.46
Clock Speeds: 1: 800.00 MHz 2: 800.00 MHz 3: 1800.00 MHz 4: 1600.00 MHz
Graphics: Card-1: Intel 2nd Generation Core Processor Family Integrated Graphics Controller bus-ID: 00:02.0
Card-2: NVIDIA GF116M [GeForce GT 555M/635M] bus-ID: 01:00.0
X.Org: 1.15.1 drivers: (unloaded: fbdev,vesa) FAILED: nouveau,intel Resolution: 1920x1080@60.0hz
GLX Renderer: Mesa DRI Intel Sandybridge Mobile GLX Version: 3.0 Mesa 10.1.3 Direct Rendering: Yes
Audio: Card: Intel 6 Series/C200 Series Chipset Family High Definition Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
Network: Card-1: Intel Centrino Wireless-N 130 driver: iwlwifi ver: in-tree: bus-ID: 04:00.0
IF: wlan0 state: up mac: b8:03:05:46:27:d3
driver: r8169 ver: 2.3LK-NAPI port: d000 bus-ID: 03:00.0
IF: eth0 state: down mac: 8c:89:a5:a6:ed:dd
Drives: HDD Total Size: 1120.2GB (0.7% used) 1: id: /dev/sda model: KINGSTON_SH103S3 size: 120.0GB
2: id: /dev/sdb model: WDC_WD10JPVX size: 1000.2GB
Partition: ID: / size: 142G used: 6.8G (6%) fs: ext4 ID: swap-1 size: 7.38GB used: 0.00GB (0%) fs: swap
RAID: No RAID devices detected - /proc/mdstat and md_mod kernel raid module present
Sensors: None detected - is lm-sensors installed and configured?Info: Processes: 267 Uptime: 16 min Memory: 1669.2/5876.4MB Runlevel: 2 Gcc sys: 4.8.2 Client: Shell inxi: 1.8.4
sudo blkid
[sudo] password for eu:
/dev/sda1: UUID="AEAC4D6DAC4D30DF" TYPE="ntfs"
/dev/sda2: UUID="2E563FA7563F6F29" TYPE="ntfs"
/dev/sdb1: LABEL="Sistem" UUID="7298F84798F80AFD" TYPE="ntfs"
/dev/sdb5: LABEL="Windows/Linux Ortak" UUID="FCC60503C604BFBE" TYPE="ntfs"
/dev/sdb6: UUID="a39d75bd-c51e-4e29-ba50-f7d9d6732542" TYPE="swap"
/dev/sdb7: UUID="df507316-0306-40a2-a357-aa15ec01c619" TYPE="ext4"
cat /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sdb7 during installation
UUID=df507316-0306-40a2-a357-aa15ec01c619 / ext4 errors=remount-ro 0 1
# swap was on /dev/sdb6 during installation
UUID=a39d75bd-c51e-4e29-ba50-f7d9d6732542 none swap sw 0 0
sudo fdisk -l
Disk /dev/sda: 120.0 GB, 120034123776 bytes
255 heads, 63 sectors/track, 14593 cylinders, total 234441648 sectors
Disk identifier: 0x0002dcc5
Device Boot Start End Blocks Id System
/dev/sda1 * 2048 206847 102400 7 HPFS/NTFS/exFAT
/dev/sda2 206848 234438655 117115904 7 HPFS/NTFS/exFAT
Disk /dev/sdb: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders, total 1953525168 sectors
Disk identifier: 0x000361ff
/dev/sdb1 2048 586133503 293065728 7 HPFS/NTFS/exFAT
/dev/sdb2 586135550 1953523711 683694081 5 Extended
Partition 2 does not start on physical sector boundary.
/dev/sdb5 903299072 1953523711 525112320 7 HPFS/NTFS/exFAT
/dev/sdb6 888870912 903286783 7207936 82 Linux swap / Solaris
/dev/sdb7 586135552 888867973 151366211 83 Linux
Partition table entries are not in disk order
sudo parted -l
Model: ATA KINGSTON SH103S3 (scsi)
Disk /dev/sda: 120GB
Partition Table: msdos
Number Start End Size Type File system Flags
1 1049kB 106MB 105MB primary ntfs boot
2 106MB 120GB 120GB primary ntfs
Model: ATA WDC WD10JPVX-00J (scsi)
Disk /dev/sdb: 1000GB
1 1049kB 300GB 300GB primary ntfs
2 300GB 1000GB 700GB extended
7 300GB 455GB 155GB logical ext4
6 455GB 462GB 7381MB logical linux-swap(v1)
5 462GB 1000GB 538GB logical ntfs
cat /etc/initramfs-tools/conf.d/resume
RESUME=UUID=a39d75bd-c51e-4e29-ba50-f7d9d6732542
