Gönderen Konu: [Çözüldü] Tarayıcıda video izlerken donuyor  (Okunma sayısı 12761 defa)
Çevrimdışı birol
  • İleti: 38
  • Dağıtım: Linux Mint 17.2
  • Masaüstü Ortamı: Cinnamon 64 Bit
« : 01 Mart 2015, 23:36:55 »
Selam arkadaşlar, tarayıcılardaki flaşh player sorununu bir türlü çözemedim yardımcı olursanız sevinirim. Video izlerken donmalar, kesilmeler var, akıcı bir görüntü alamıyorum bir türlü. Çıktılar aşağıda.
birol-AO725 birol # dpkg -l | grep flash
ii  adobe-flash-properties-gtk                  11.2.202.442-0trusty1                               amd64        GTK+ control panel for Adobe Flash Player plugin version 11
ii  adobe-flashplugin                           11.2.202.442-0trusty1                               amd64        Adobe Flash Player plugin version 11
rc  flashplugin-installer                       11.2.202.442ubuntu0.14.04.1                         amd64        Adobe Flash Player plugin installer
ii  pepperflashplugin-nonfree                   1.3ubuntu1                                          amd64        Pepper Flash Player - browser plugin[code]
[code]birol-AO725 birol # lspci | egrep 'VGA|3D|Display'
00:01.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Wrestler [Radeon HD 7290][code]
[code]birol-AO725 birol # glxinfo | grep render
OpenGL renderer string: Gallium 0.4 on AMD PALM
    GL_NV_blend_square, GL_NV_conditional_render, GL_NV_depth_clamp, [code]
[code]birol-AO725 birol # inxi -Fx
System:    Host: birol-AO725 Kernel: 3.13.0-37-generic x86_64 (64 bit, gcc: 4.8.2)
Machine:   System: Acer (portable) product: AO725 version: V2.04 serial: NUSGQEY004249112A67600
           Mobo: Acer model: ZA10_BZ version: Type2 - A01 Board Version serial: NBSGP11004249112A67600
           Bios: Insyde version: V2.04 date: 09/06/2012
CPU:       Dual core AMD C-70 APU with Radeon HD Graphics (-MCP-) cache: 1024 KB flags: (lm nx sse sse2 sse3 sse4a ssse3 svm) bmips: 3992.66
           Clock Speeds: 1: 800.00 MHz 2: 800.00 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Wrestler [Radeon HD 7290] bus-ID: 00:01.0
           X.org: 1.15.1 drivers: ati,radeon (unloaded: fbdev,vesa) tty size: 80x24 Advanced Data: N/A for root
Audio:     Card-1: Advanced Micro Devices [AMD] FCH Azalia Controller driver: snd_hda_intel bus-ID: 00:14.2
           Card-2: Advanced Micro Devices [AMD/ATI] Wrestler HDMI Audio driver: snd_hda_intel bus-ID: 00:01.1
Network:   Card-1: Qualcomm Atheros AR9485 Wireless Network Adapter driver: ath9k bus-ID: 02:00.0
           IF: wlan0 state: up mac: 9c:2a:70:1f:1b:7c
           Card-2: Realtek RTL8101E/RTL8102E PCI Express Fast Ethernet controller
           driver: r8169 ver: 2.3LK-NAPI port: 2000 bus-ID: 01:00.0
           IF: eth0 state: down mac: 08:9e:01:55:19:64
Drives:    HDD Total Size: 320.1GB (51.2% used) 1: id: /dev/sda model: TOSHIBA_MQ01ABD0 size: 320.1GB temp: 39C
Partition: ID: / size: 46G used: 7.6G (18%) fs: ext4 ID: /home size: 182G used: 145G (85%) fs: ext4
           ID: swap-1 size: 2.00GB used: 0.08GB (4%) fs: swap
Sensors:   System Temperatures: cpu: 78.2C mobo: N/A gpu: 78.0
Info:      Processes: 163 Uptime: 2:52 Memory: 1083.8/1699.4MB Runlevel: 2 Gcc sys: 4.8.2 Client: Shell inxi: 1.8.4
« Son Düzenleme: 04 Mart 2015, 21:22:41 Gönderen: birol »
Çevrimdışı birol
  • İleti: 38
Ynt: Tarayıcıda video izlerken donuyor
« Yanıtla #1 : 01 Mart 2015, 23:38:18 »
Bu paketide kurdum donanım hızlandırma tikinide kaldırıyorum fakat düzelme olmuyor.
sudo apt-get install adobe-flash-properties-gtk
« Yanıtla #2 : 02 Mart 2015, 09:13:30 »
dpkg -l | grep fglrx
Çevrimdışı birol
  • İleti: 38
« Yanıtla #3 : 02 Mart 2015, 22:21:02 »
Bu uyarıyı verdi.
birol-AO725 birol # dpkg -l | grep fglrx
birol-AO725 birol # cat /etc/X11/xorg.conf
« Yanıtla #4 : 02 Mart 2015, 22:29:54 »
Aşağıdaki komutlar ile ATI kapalı kaynak sürücüsünü kurup sistemi yeniden başlatmayı dener misiniz?
sudo apt-get install fglrx-updates
sudo aticonfig --initial -f
« Son Düzenleme: 02 Mart 2015, 22:51:28 Gönderen: Butterfly »
Çevrimdışı birol
  • İleti: 38
« Yanıtla #5 : 02 Mart 2015, 22:59:00 »
Dediğiniz paketleri kurdum restarttan sonra en son komutu yazdım. Birde paketi kurarken şunu kurmanız önerilir diye uyarı verdi : sudo apt-get install fglrx-amdcccle-updates
birol # sudo aticonfig --sync-video=on
failed to set textured video sync
Warning: Option 'TexturedVideoSync' doesn't affect running session.
Using /etc/X11/xorg.conf
Saving back-up to /etc/X11/xorg.conf.fglrx-0
« Yanıtla #6 : 03 Mart 2015, 08:51:43 »
ATI kontrol merkezini yüklemek için öneri sunulmuş, aşağıdaki komut ile yükleyebilirsiniz.
Bu çıktı ayar değişikliğinin sonraki oturumda etkili olacağını söylüyor.
Tarayıcı ile ilgili son durum nedir?
Çevrimdışı birol
  • İleti: 38
« Yanıtla #7 : 03 Mart 2015, 20:17:58 »
Cromda mozillaya göre biraz daha  düzelme var fakat halen akıcı görüntü yok. İşlemci düşük olduğundan olabilirmi sorun acaba. Xubuntu kurmayı düşünüyorum daha az sistem kaynağı kullandığı söyleniyor. Siz ne dersiniz.
« Yanıtla #8 : 03 Mart 2015, 21:58:16 »
Sistemde donma, yavaş çalışma gibi bir sorun yaşıyor musunuz? Donma, yavaş çalışma sadece tarayıcıdan video izlerken mi yaşanıyor?
« Yanıtla #9 : 04 Mart 2015, 10:35:46 »
[member=1015]birol[/member], hangimasaüstü ortamını kullanıyorsunuz?
Firefox için, Düzen menüsü => Tercihler => Gelişmiş sekmesi => Genel sekmesi altında "Mümkün olduğunda donanım ivmelendirmesini kullan" seçeneği seçili ise bunun önündeki işareti de kaldırınız.
Çevrimdışı birol
  • İleti: 38
[Çözüldü] Ynt: Tarayıcıda video izlerken donuyor
« Yanıtla #10 : 04 Mart 2015, 21:22:05 »
Sadece tarayıcıda oluyor. Youtube da html 5 kullanıyorum flaşh tam anlamıyla düzelmedi. Dediğiniz ayarıda yaptım Butterfly hocam. Teşekkürler ilgilendiğiniz için konuyu kapatabiliriz.
Çevrimdışı dev@mehmet
  • İleti: 189
  • Dağıtım: Linux Mint 19
Ynt: [Çözüldü] Tarayıcıda video izlerken donuyor
« Yanıtla #11 : 04 Mart 2015, 22:04:05 »
Bende aynı sorunu yaşıyordum ama Chrome kullanınca düzeldi. (Flash sorunu) Video izleyeceğiniz zaman chrome kullanın bir etkisi olacak mı?
Çevrimdışı birol
  • İleti: 38
« Yanıtla #12 : 04 Mart 2015, 23:00:32 »
Ben mozillaya alışmışım kaç senedir. crom kullanmak zor geliyor :) Şimdi kurdum sırf denemek için chrome çok iyi sonuç verdi.
« Son Düzenleme: 04 Mart 2015, 23:31:34 Gönderen: birol »
