Gönderen Konu: minecraft kasma  (Okunma sayısı 8468 defa)
Çevrimdışı cmertkucuk
  • İleti: 492
minecraft kasma
« : 11 Mart 2015, 17:10:32 »
Linux Mint Mate sistemini kullanıyorum, Minecraft kurdum fakat kasmaya başladı. Yardımcı olursanız sevinirim.
Acaba ekran kartı ile mi alakalı, yoksa başka bir sebep mi vardır? Yardım edin.
Düzenleme : İmla
Lütfen imla kurallarına özen gösteriniz.
Forum Kuralları
« Son Düzenleme: 11 Mart 2015, 17:23:54 Gönderen: Butterfly »
ϜϓſϞ EY TÜRK!
(Bilge Kağan)ϜϓſϞ
Ynt: minecraft kasma
« Yanıtla #1 : 11 Mart 2015, 17:24:19 »
inxi -Fx
  • İleti: 492
« Yanıtla #2 : 11 Mart 2015, 17:28:07 »
~ $ inxi -Fx
System:    Host: mert-VirtualBox Kernel: 3.13.0-24-generic i686 (32 bit, gcc: 4.8.2)
           Desktop: N/A Distro: Linux Mint 17 Qiana
Machine:   System: innotek product: VirtualBox version: 1.2
           Mobo: Oracle model: VirtualBox version: 1.2 Bios: innotek version: VirtualBox date: 12/01/2006
CPU:       Single core Intel Pentium CPU P6100 (-UP-) cache: 6144 KB flags: (sse sse2 sse3 ssse3) bmips: 4000.74 clocked at 2000.373 MHz
Graphics:  Card: InnoTek Systemberatung VirtualBox Graphics Adapter bus-ID: 00:02.0
           X.Org: 1.15.1 drivers: ati,vboxvideo (unloaded: fbdev,vesa) Resolution: 1366x768@60.0hz
           GLX Renderer: Gallium 0.4 on llvmpipe (LLVM 3.4, 128 bits) GLX Version: 2.1 Mesa 10.1.0 Direct Rendering: Yes
Audio:     Card: Intel 82801AA AC'97 Audio Controller driver: snd_intel8x0 ports: d100 d200 bus-ID: 00:05.0
Network:   Card: Intel 82540EM Gigabit Ethernet Controller driver: e1000 ver: 7.3.21-k8-NAPI port: d010 bus-ID: 00:03.0
           IF: eth0 state: up speed: 1000 Mbps duplex: full mac: 08:00:27:58:f0:f4
Drives:    HDD Total Size: 17.2GB (28.2% used) 1: id: /dev/sda model: VBOX_HARDDISK size: 17.2GB
Partition: ID: / size: 15G used: 4.6G (33%) fs: ext4 ID: swap-1 size: 0.94GB used: 0.14GB (15%) fs: swap
Info:      Processes: 142 Uptime: 40 min Memory: 350.8/879.2MB Runlevel: 2 Gcc sys: 4.8.2 Client: Shell inxi: 1.8.4
ϜϓſϞ EY TÜRK!
(Bilge Kağan)ϜϓſϞ
« Yanıtla #3 : 11 Mart 2015, 17:39:24 »
Linux Mint'i Virtualbox üzerinde çalıştırıyorsunuz, performans ile ilgili sorunlar olması normal olabilir.
  • İleti: 492
« Yanıtla #4 : 11 Mart 2015, 17:43:33 »
sanal makineyi kapattım kendi makinemde çalıştırınca da biraz kasma oluyor  bunu çözebilirmiyiz
ϜϓſϞ EY TÜRK!
(Bilge Kağan)ϜϓſϞ
« Yanıtla #5 : 11 Mart 2015, 17:46:40 »
inxi -Fx
Not: İmla kurallarına elinizden geldiğince uymanızı rica ediyorum.
  • İleti: 492
« Yanıtla #6 : 11 Mart 2015, 17:47:07 »
bu arada minecraft kendi sitesinden değilde başka bir yerden crack lı indirdim biliyorum legal değil ama sorun olur mu makinem için
ϜϓſϞ EY TÜRK!
(Bilge Kağan)ϜϓſϞ
  • İleti: 492
« Yanıtla #7 : 11 Mart 2015, 17:47:53 »
~ $ inxi -Fx
System:    Host: CASPER-H36Y Kernel: 3.13.0-24-generic i686 (32 bit, gcc: 4.8.2)
Machine:   Mobo: PEGATRON model: H36Y version: 1.0 Bios: American Megatrends version: 203 date: 11/18/2010
CPU:       Dual core Intel Pentium CPU P6100 (-MCP-) cache: 3072 KB flags: (lm nx sse sse2 sse3 ssse3) bmips: 7981.14
           Clock Speeds: 1: 1066.00 MHz 2: 933.00 MHz
Graphics:  Card: Intel Core Processor Integrated Graphics Controller bus-ID: 00:02.0
           X.Org: 1.15.1 drivers: intel (unloaded: fbdev,vesa) Resolution: 1366x768@59.6hz
           GLX Renderer: Mesa DRI Intel Ironlake Mobile x86/MMX/SSE2 GLX Version: 2.1 Mesa 10.1.0 Direct Rendering: Yes
Audio:     Card: Intel 5 Series/3400 Series Chipset High Definition Audio driver: snd_hda_intel bus-ID: 00:1b.0
Network:   Card-1: Qualcomm Atheros AR8131 Gigabit Ethernet driver: atl1c ver: 1.0.1.1-NAPI port: c000 bus-ID: 05:00.0
           IF: eth0 state: down mac: 70:71:bc:b2:14:32
           Card-2: Qualcomm Atheros AR9285 Wireless Network Adapter (PCI-Express) driver: ath9k bus-ID: 02:00.0
           IF: wlan0 state: up mac: 48:5d:60:5e:de:29
Drives:    HDD Total Size: 250.1GB (54.1% used) 1: id: /dev/sda model: TOSHIBA_MK2555GS size: 250.1GB
Partition: ID: / size: 228G used: 126G (59%) fs: ext4 ID: swap-1 size: 2.00GB used: 0.15GB (7%) fs: swap
Sensors:   System Temperatures: cpu: 39.0C mobo: N/A
Info:      Processes: 148 Uptime: 2 days Memory: 446.7/1878.5MB Runlevel: 2 Gcc sys: 4.8.2 Client: Shell inxi: 1.8.4
ϜϓſϞ EY TÜRK!
(Bilge Kağan)ϜϓſϞ
« Yanıtla #8 : 11 Mart 2015, 17:50:59 »
Daha önce bahsetmiştik, konuyu kilitlemek zorundayım. Yasal olmayan bir içeriği beyan ettikten sonra konuya cevap veremeyiz.
