Gönderen Konu: LinuxMint wireless bağlanamama  (Okunma sayısı 6752 defa)
Çevrimdışı GalipAktas
  • İleti: 6
  • Dağıtım: Linux mint 17.1
  • Grafik Kartı: nvidia gforce gt 525m
  • İşlemci: intel core i5
« : 14 Mart 2015, 22:31:05 »
Merhaba arkadaşlar , aranıza yeni katıldım. benim sorunumbilgisayarımın wifi ağlarını görmesine rağmen baglanamaması. Bir türlü çare bulamadım. Nasıl düzelir bu durum? Kodları aşağıya koydum.
Yardımlarınız için şimdiden teşekkürler.
DISTRIB_ID=LinuxMint
DISTRIB_RELEASE=17.1
DISTRIB_CODENAME=rebecca
DISTRIB_DESCRIPTION="Linux Mint 17.1 Rebecca" [code]
[code]3.13.0-37-generic x86_64
[code]
[code]09:00.0 Network controller [0280]: Qualcomm Atheros AR9285 Wireless Network Adapter (PCI-Express) [168c:002b] (rev 01)
Subsystem: Lite-On Communications Inc Device [11ad:6613]
Kernel driver in use: ath9k
0a:00.0 Ethernet controller [0200]: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet [1969:1083] (rev c0)
Subsystem: Toshiba America Info Systems Device [1179:fc50]
Kernel driver in use: atl1c
[code]
[code]Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 005: ID 0cf3:3005 Atheros Communications, Inc. AR3011 Bluetooth
Bus 001 Device 003: ID 04f2:b289 Chicony Electronics Co., Ltd
[code]
[code]0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
[code]
[code]*-network
       product: AR9285 Wireless Network Adapter (PCI-Express)
       vendor: Qualcomm Atheros
       physical id: 0
       bus info: pci@0000:09:00.0
       logical name: wlan0
       version: 01
       serial: 68:a3:c4:87:3e:a8
       width: 64 bits
       clock: 33MHz
       configuration: broadcast=yes driver=ath9k driverversion=3.13.0-37-generic firmware=N/A latency=0 link=no multicast=yes wireless=IEEE 802.11bgn
       resources: irq:17 memory:c3200000-c320ffff
  *-network
       product: AR8151 v2.0 Gigabit Ethernet
       physical id: 0
       bus info: pci@0000:0a:00.0
       logical name: eth0
       version: c0
       serial: e8:9a:8f:0b:15:9d
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress vpd bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=atl1c driverversion=1.0.1.1-NAPI duplex=full ip=192.168.1.6 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
       resources: irq:49 memory:c3100000-c313ffff ioport:2000(size=128)
[code]
[code]eth0      no wireless extensions.
          Mode:Managed  Access Point: Not-Associated   Tx-Power=16 dBm
          Power Management:off
[code]
[code]Network:   Card-1: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet driver: atl1c ver: 1.0.1.1-NAPI port: 2000 bus-ID: 0a:00.0
           Card-2: Qualcomm Atheros AR9285 Wireless Network Adapter (PCI-Express) driver: ath9k bus-ID: 09:00.0
[code]
[code]Module                  Size  Used by
rtl8192ce              53550  0
rtl_pci                26690  1 rtl8192ce
rtlwifi                63475  2 rtl_pci,rtl8192ce
rtl8192c_common        53172  1 rtl8192ce
snd_hda_codec_hdmi     46368  4
uvcvideo               80885  0
videobuf2_core         40664  1 uvcvideo
videodev              134688  2 uvcvideo,videobuf2_core
rfcomm                 69160  8
snd_hda_codec_conexant    57441  1
intel_rapl             18773  0
snd_hda_intel          56451  5
x86_pkg_temp_thermal    14205  0
intel_powerclamp       14705  0
snd_hda_codec         192906  3 snd_hda_codec_hdmi,snd_hda_codec_conexant,snd_hda_intel
coretemp               13435  0
snd_hwdep              13602  1 snd_hda_codec
snd_rawmidi            30144  1 snd_seq_midi
kvm_intel             143109  0
kvm                   451552  1 kvm_intel
crct10dif_pclmul       14289  0
crc32_pclmul           13113  0
ghash_clmulni_intel    13216  0
aesni_intel            55624  0
aes_x86_64             17131  1 aesni_intel
snd_seq                61560  2 snd_seq_midi_event,snd_seq_midi
lrw                    13286  1 aesni_intel
gf128mul               14951  1 lrw
glue_helper            13990  1 aesni_intel
ablk_helper            13597  1 aesni_intel
cryptd                 20359  3 ghash_clmulni_intel,aesni_intel,ablk_helper
joydev                 17381  0
serio_raw              13462  0
ath3k                  13318  0
btusb                  32412  0
snd_pcm               102099  3 snd_hda_codec_hdmi,snd_hda_codec,snd_hda_intel
ath9k                 164164  0
bluetooth             391136  23 bnep,ath3k,btusb,rfcomm
ath9k_common           13551  1 ath9k
ath9k_hw              453856  2 ath9k_common,ath9k
nvidia              10744943  42
ath                    28698  3 ath9k_common,ath9k,ath9k_hw
snd_page_alloc         18710  2 snd_pcm,snd_hda_intel
snd_timer              29482  2 snd_pcm,snd_seq
toshiba_acpi           22901  0
snd                    69322  21 snd_hwdep,snd_timer,snd_hda_codec_hdmi,snd_hda_codec_conexant,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec,snd_hda_intel,snd_seq_device,snd_seq_midi
drm                   303102  2 nvidia
sparse_keymap          13948  1 toshiba_acpi
lpc_ich                21080  0
mei_me                 18627  0
toshiba_bluetooth      12852  0
soundcore              12680  1 snd
mei                    82276  1 mei_me
binfmt_misc            17468  1
wmi                    19177  1 toshiba_acpi
dm_multipath           22873  0
scsi_dh                14882  1 dm_multipath
parport_pc             32701  0
b43                   387371  0
bcma                   52096  1 b43
mac80211              630653  5 b43,ath9k,rtl_pci,rtlwifi,rtl8192ce
cfg80211              484040  5 b43,ath,ath9k,mac80211,rtlwifi
ssb                    62379  1 b43
mac_hid                13205  0
dm_mirror              22135  0
dm_region_hash         20862  1 dm_mirror
dm_log                 18411  2 dm_region_hash,dm_mirror
ums_realtek            18029  0
usb_storage            62209  1 ums_realtek
psmouse               106678  0
ahci                   25819  2
atl1c                  46086  0
libahci                32716  1 ahci
video                  19476  0
[code]
  • İleti: 6
Ynt: LinuxMint wireless bağlanamama
« Yanıtla #1 : 14 Mart 2015, 22:33:06 »
Her bir kodu ayrı ayrı code bloğu  içine koydum. O da biraz görüntü olarak saçma olmuş kusuruma bakmayın acemilik :)
« Son Düzenleme: 14 Mart 2015, 22:51:32 Gönderen: GalipAktas »
« Yanıtla #2 : 14 Mart 2015, 22:52:06 »
Aşağıdaki öneriyi uygulamayı deneyiniz.
forum.linuxmint.net.tr/index.php?topic=53.0
  • İleti: 6
« Yanıtla #3 : 14 Mart 2015, 22:58:25 »
Denedim şimdi ancak olmadı. Windows 7 ile birlikte dual boot kullanıyorum alakası var mıdır sorunun bununla ? Genelde sadece Linux kurup dual boot yapmayanlarda bu sorun pek yok sanırım ?
« Yanıtla #4 : 14 Mart 2015, 23:22:00 »
Başka işletim sistemleriyle ilgili olduğunu sanmıyorum. TKIP şifrelemesi kullanıyorsanız AES'e çevirip deneyin. WPA ayarlarına girdiğinizde seçenekleri görebilirsiniz. Diğer adıyla WPA2 Kişisel/Wpa2 Kurumsal(Enterprise)
  • İleti: 6
« Yanıtla #5 : 14 Mart 2015, 23:24:39 »
Arkadaşlar yeni bir gelişme oldu. Ev arkadaşım da linux kurdu (ubuntu) o da bağlanamıyordu tamamen farklı donanımlar farklı bilgisayar, o da bağlanamadı.
Ben de bizim modemde mi sorun var diye düşünüp , akıllı telefonumun wifi paylaşımını açtım şimdi bağlandı bilgisayarım.
Meğer sorun demekki bizim modeme bağlanamıyor sistem. Modem de Turkcell seperonline ile gelen Huavei Hg552e  model modem.
Peki şimdi ne yapacağım ?
Modemi görüyor tıklıyoruz bağlanmaya çalışıyor ama bağlanamıyor işletim sistemi
  • İleti: 6
« Yanıtla #6 : 14 Mart 2015, 23:30:32 »
TKIP ve AES dediğiniz ayarlar nerede? bulamadım
« Yanıtla #7 : 14 Mart 2015, 23:31:44 »
Modeme bağlanabildiğiniz herhangi bir cihazdan, herhangi bir tarayıcıyı açıp(firefox,chrome) 192.168.1.1 adresine gidin . Modemin varsayılan kullanıcı adı admin, şifresi superonline'dır. Kablosuz ağ ayarları kısmında bahsedilen ayarı bulabilirsiniz.
  • İleti: 6
« Yanıtla #8 : 14 Mart 2015, 23:36:00 »
Tamamdır şimdi buldum tam da ona bakıyordum o da AES şu anda evet.
« Yanıtla #9 : 14 Mart 2015, 23:54:07 »
Sorun çözüldü mü? Bilgisayardan bağlanırken de AES'i seçtiniz mi?
