Gönderen Konu: [Çözüldü] Cpu oranı %50 lerde geziyor ve Cihaz ısınma yapıyor  (Okunma sayısı 12832 defa)
Çevrimdışı Barun
  • İleti: 28
    • Barun006
  • Dağıtım: Linux Mint 17.1 "Rebecca"
Merhaba başlıkta da belirttiğim gibi çalışan bir uygulama olmamasına rağmen işlemci hızım %50 lerden aşağı düşmüyor
linkte anlatılanları denedim
http://forum.linuxmint.net.tr/index.php?topic=2526.msg15980#msg15980
barun[member=1595]Barun[/member]-JW6H ~ $ lspci | egrep 'VGA|3D|Display'
barun[member=1595]Barun[/member]-JW6H ~ $ inxi -Fx
System:    Host: barun-JW6H Kernel: 3.16.0-33-generic x86_64 (64 bit, gcc: 4.8.2)
           Desktop: N/A Distro: Linux Mint 17.1 Rebecca
Machine:   System: Quanta product: JW6H version: 03
           Mobo: Quanta model: JW6H version: TBD Bios: Insyde version: GU111 date: 07/05/2013
CPU:       Dual core Intel Core i3-3217U CPU (-HT-MCP-) cache: 3072 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 7183.52
           Clock Speeds: 1: 840.796 MHz 2: 1790.296 MHz 3: 1133.296 MHz 4: 1727.296 MHz
           X.Org: 1.15.1 drivers: intel (unloaded: fbdev,vesa) Resolution: 1366x768@60.1hz
Audio:     Card: Intel 7 Series/C210 Series Chipset Family High Definition Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
           Sound: Advanced Linux Sound Architecture ver: k3.16.0-33-generic
Network:   Card-1: Qualcomm Atheros AR8161 Gigabit Ethernet driver: alx port: 3000 bus-ID: 08:00.0
           IF: eth0 state: down mac: 08:9e:01:ca:9c:f5
           Card-2: Intel Centrino Wireless-N 2230 driver: iwlwifi ver: backported bus-ID: 07:00.0
           IF: wlan0 state: up mac: 68:17:29:5c:0a:f3
Drives:    HDD Total Size: 320.1GB (4.3% used) 1: id: /dev/sda model: Hitachi_HTS54503 size: 320.1GB
Partition: ID: / size: 163G used: 13G (9%) fs: ext4 ID: swap-1 size: 20.00GB used: 0.00GB (0%) fs: swap
Info:      Processes: 207 Uptime: 2:31 Memory: 820.6/7867.2MB Runlevel: 2 Gcc sys: 4.8.2 Client: Shell inxi: 1.8.4
barun[member=1595]Barun[/member]-JW6H ~ $ glxinfo | grep render
barun[member=1595]Barun[/member]-JW6H ~ $ dpkg -l | egrep 'nvidia|bumblebee|primus|prime'
barun[member=1595]Barun[/member]-JW6H ~ $ cat /etc/X11/xorg.conf
Düzenleme : Konu çözüldüğü için etiketlenmiştir.
« Son Düzenleme: 22 Ağustos 2015, 22:39:44 Gönderen: Butterfly »
Ynt: Cpu oranı %50 lerde geziyor ve Cihaz ısınma yapıyor
« Yanıtla #1 : 05 Nisan 2015, 20:11:25 »
[member=1595]Barun[/member], sizin sisteminizde sadece Intel GPU görünüyor. Bağlantısını verdiğiniz konuda Intel + Nvidia GPU için bir öneri sunulmuş.
Sistemi yeniden başlatıp, Grub menüsüne geldiğinizde Önceki Linux sürümleri (Previus Linux versions) seçeneğini seçiniz.
Burada kurulu eski çekirdeklerden birisi ile sistemi açmayı deneyiniz.
Sistemi eski çekirdek ile açtığınızda ısınma ile ilgili sorun devam ediyor mu?
Çevrimdışı Barun
  • İleti: 28
    • Barun006
« Yanıtla #2 : 05 Nisan 2015, 21:25:56 »
hocam sorun güncellemeden sonra oluştu son çekirdek sürümüne güncellemiştik ayrıca grup menüsüne nasıl girilir
« Son Düzenleme: 05 Nisan 2015, 21:33:28 Gönderen: Barun »
« Yanıtla #3 : 06 Nisan 2015, 03:14:39 »
Bilgisayar açılırken shift tuşlarına basmayı deneyin, grub menüsü ekrana gelecektir.
Çevrimdışı Barun
  • İleti: 28
    • Barun006
« Yanıtla #4 : 06 Nisan 2015, 11:26:37 »
previous linux mode tarzı birşey yazıyordu ondan başlattım değişen herhangi bir şey olmadı
« Son Düzenleme: 06 Nisan 2015, 11:41:23 Gönderen: Barun »
« Yanıtla #5 : 06 Nisan 2015, 15:56:50 »
Aşağıdaki komutu uçbirimde çalıştırarak CPU'yu kullanan uygulama ya da servisi tespit etmeye çalışabilirsiniz.
top
Çevrimdışı Barun
  • İleti: 28
    • Barun006
« Yanıtla #6 : 06 Nisan 2015, 16:36:44 »
top - 16:31:47 up 10 min,  2 users,  load average: 0,17, 0,51, 0,37
Tasks: 206 total,   1 running, 205 sleeping,   0 stopped,   0 zombie
%Cpu(s):  1,0 us,  0,4 sy,  0,0 ni, 98,6 id,  0,0 wa,  0,0 hi,  0,0 si,  0,0 st
KiB Mem:   8056060 total,  3974988 used,  4081072 free,  1204432 buffers
KiB Swap: 19531772 total,        0 used, 19531772 free.  1852336 cached Mem
  PID USER      PR  NI    VIRT    RES    SHR S  %CPU %MEM     TIME+ COMMAND
 2897 barun     20   0  677072  25744  21060 S   3,2  0,3   0:01.58 mate-terminal
 2547 barun     20   0 1617048 171344  91344 S   2,4  2,1   0:40.47 chrome
 1468 root      20   0  288568  68644  59132 S   1,6  0,9   0:12.61 Xorg
 2883 barun     20   0  817584 141784  51416 S   0,8  1,8   0:05.89 chrome
 2914 barun     20   0   26316   2936   2412 R   0,8  0,0   0:00.41 top
    1 root      20   0   33868   4336   2668 S   0,0  0,1   0:01.68 init
    2 root      20   0       0      0      0 S   0,0  0,0   0:00.00 kthreadd
    3 root      20   0       0      0      0 S   0,0  0,0   0:00.01 ksoftirqd/0
    5 root       0 -20       0      0      0 S   0,0  0,0   0:00.00 kworker/0:0H
    7 root      20   0       0      0      0 S   0,0  0,0   0:00.59 rcu_sched
    8 root      20   0       0      0      0 S   0,0  0,0   0:00.20 rcuos/0
    9 root      20   0       0      0      0 S   0,0  0,0   0:00.18 rcuos/1
   10 root      20   0       0      0      0 S   0,0  0,0   0:00.14 rcuos/2
   11 root      20   0       0      0      0 S   0,0  0,0   0:00.17 rcuos/3
   12 root      20   0       0      0      0 S   0,0  0,0   0:00.00 rcuos/4
   13 root      20   0       0      0      0 S   0,0  0,0   0:00.00 rcuos/5
   14 root      20   0       0      0      0 S   0,0  0,0   0:00.00 rcuos/6
   15 root      20   0       0      0      0 S   0,0  0,0   0:00.00 rcuos/7
   16 root      20   0       0      0      0 S   0,0  0,0   0:00.00 rcu_bh
   17 root      20   0       0      0      0 S   0,0  0,0   0:00.00 rcuob/0
   18 root      20   0       0      0      0 S   0,0  0,0   0:00.00 rcuob/1
   19 root      20   0       0      0      0 S   0,0  0,0   0:00.00 rcuob/2
   20 root      20   0       0      0      0 S   0,0  0,0   0:00.00 rcuob/3
   21 root      20   0       0      0      0 S   0,0  0,0   0:00.00 rcuob/4
hocam pek bir şey anlamadım açıkçası küçük bir uygulama var ismini bilmiyorum saatin yanında işlemci çalışma frekansı  1.40 Ghz %60 lar da falan ama top komutu %cpu (s) 7 falanda geziyor acaba hangisi doğru işlemci %7 demi yoksa %60 damı çalışıyor
« Yanıtla #7 : 06 Nisan 2015, 17:24:45 »
[member=1595]Barun[/member], aşağıdaki komut ile grub ayar dosyasını açınız.
sudo gedit /etc/default/grub
Açılan dosyada aşağıdaki satırı bulup,]
tırnak işaretleri arasına intel_pstate=enable değişkenini ekleyip dosyayı kaydediniz.
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash intel_pstate=disable"
Aşağıdaki komut ile grub ayar dosyasını güncelleyiniz.
sudo update-grub
Sistemi yeniden başlatmayı deneyiniz.
Çevrimdışı Barun
  • İleti: 28
    • Barun006
« Yanıtla #8 : 06 Nisan 2015, 18:20:04 »
[member=8]Butterfly[/member]  şuan 1.80 ghz %100 hiç  değişmiyor
« Son Düzenleme: 06 Nisan 2015, 22:44:31 Gönderen: Barun »
« Yanıtla #9 : 07 Nisan 2015, 11:06:43 »
Aşağıdaki komutlar ile TLP uygulamasını yüklemeyiniz.
sudo add-apt-repository ppa:linrunner/tlp
sudo apt-get install tlp
Buradaki mesajda anlatığı biçimde intel_pstate=enable başlangıç değişkenini etkinleştiriniz. Daha önce eklediğiniz intel_pstate=disable değişkenini silmeniz gerekecek.
Ek olarak aşağıdaki komut ile linux-tools-common ve linux-tools-generic paketlerini yükleyiniz.
sudo apt-get install linux-tools-common linux-tools-generic
Düzenlemeler sonrası sistemi yeniden başlatınız veaşağıdaki komutu uçbirimde çalıştırmayı deneyiniz.
sudo cpupower frequency-set -g powersave
Bu durumda bir değişiklik oluyor mu?
Çevrimdışı Barun
  • İleti: 28
    • Barun006
« Yanıtla #10 : 07 Nisan 2015, 11:56:50 »
[member=8]Butterfly[/member] hocam komutları çalıştırdığımda yükleyecek ilk verdiğiniz 3 komutu çalıştırıyım mı çalıştırmayım mı
« Yanıtla #11 : 07 Nisan 2015, 11:58:52 »
TLP'yi kastediyorsunuz sanırım, TLP mobil sistemlerde güç tasaruffu sağlamak için kullanılan bir servistir. Komutları sırasıyla uçbirimde çalıştırarak kurabilirsiniz. Herhangibir arayüzü yoktur, arkaplanda çalışan bir servistir.
Çevrimdışı Barun
  • İleti: 28
    • Barun006
« Yanıtla #12 : 07 Nisan 2015, 12:00:37 »
[member=8]Butterfly[/member] söylenenleri yaptım ve 800 mhz min %49 cpu görünüyor
« Son Düzenleme: 07 Nisan 2015, 12:12:40 Gönderen: Barun »
« Yanıtla #13 : 07 Nisan 2015, 12:48:09 »
GPU ile ilgilidüzenleme yaptınız mı hiç? Cinnamon masaüstü 2D (yazılımsal) kipte çalışıyor olabilir mi? Komutun çıktısına bakalım. 800 Mhz'de sistem boşda iken mi %50 kullanım oluyor?
Çevrimdışı Barun
  • İleti: 28
    • Barun006
« Yanıtla #14 : 07 Nisan 2015, 12:55:15 »
[member=8]Butterfly[/member]   Evet hocam sistem boştayken oluyor
« Son Düzenleme: 07 Nisan 2015, 12:59:31 Gönderen: Barun »
