Gönderen Konu: Ram Sorunu Linux Mint 17.1 Cinnamon 64 Bit  (Okunma sayısı 3817 defa)
Çevrimdışı own
  • İleti: 38
« : 02 Mayıs 2015, 19:57:50 »
Merhaba;
Bios da 6gb ram gözükmesine rağmen işletim sistemim 3gb görüyor. Bu sorunu nasıl düzeltirim bu şekilde kullanmamım performansa etkisi varmıdır ?
free
             total       used       free     shared    buffers     cached
Mem:       3330824    1990516    1340308      27640      76728     878856
-/+ buffers/cache:    1034932    2295892
Swap:            0          0          0
Düzenleme: İmla
« Son Düzenleme: 02 Mayıs 2015, 22:52:46 Gönderen: Reddet »
Ynt: Ram Sorunu Linux Mint 17.1 Cinnamon 64 Bit
« Yanıtla #1 : 02 Mayıs 2015, 23:52:23 »
inxi -Fxzçıktısına bakabilir miyiz? Sisteminiz kaç bit?
Çevrimdışı own
  • İleti: 38
« Yanıtla #2 : 03 Mayıs 2015, 23:22:32 »
own # inxi -Fxz
System:    Host: own-desktop Kernel: 3.13.0-37-generic x86_64 (64 bit, gcc: 4.8.2)
Machine:   Mobo: Foxconn model: H55MXV Series version: 1.0 Bios: American Megatrends version: 080015 date: 06/19/2010
CPU:       Dual core Intel Core i5 CPU 650 (-HT-MCP-) cache: 4096 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 12767.4
           Clock Speeds: 1: 3191.850 MHz 2: 3191.850 MHz 3: 3191.850 MHz 4: 3191.850 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Cedar [Radeon HD 5000/6000/7350/8350 Series] bus-ID: 01:00.0
           X.org: 1.15.1 driver: fglrx tty size: 80x24 Advanced Data: N/A for root
Audio:     Card-1: Intel 5 Series/3400 Series Chipset High Definition Audio driver: snd_hda_intel bus-ID: 00:1b.0
           Card-2: Advanced Micro Devices [AMD/ATI] Cedar HDMI Audio [Radeon HD 5400/6300 Series] driver: snd_hda_intel bus-ID: 01:00.1
Network:   Card-1: Sundance / IC Plus IC Plus IP100A Integrated 10/100 Ethernet MAC + PHY
           driver: sundance port: ec00 bus-ID: 04:01.0
           IF: eth1 state: unknown speed: 100 Mbps duplex: full mac: <filter>
           driver: r8169 ver: 2.3LK-NAPI port: d800 bus-ID: 03:00.0
Drives:    HDD Total Size: 820.2GB (1.0% used) 1: id: /dev/sda model: SAMSUNG_HM321HI size: 320.1GB temp: 32C
           2: id: /dev/sdb model: WDC_WD5000AAKS size: 500.1GB temp: 40C
Partition: ID: / size: 92G used: 6.3G (8%) fs: ext4 ID: /home size: 196G used: 1.7G (1%) fs: ext4
Sensors:   System Temperatures: cpu: 46.0C mobo: N/A gpu: 58.00C
Info:      Processes: 210 Uptime: 3:41 Memory: 1912.5/3252.8MB Runlevel: 2 Gcc sys: 4.8.2 Client: Shell inxi: 1.8.4
« Yanıtla #3 : 03 Mayıs 2015, 23:39:21 »
Bellekleri(ram) çıkarıp tekrar takmayı dener misiniz? 2GBlık belleğin yuvasında sorun olabilir. Mümkünse 4GB'lık belleği 2'liğin yuvasına takın. Sadece 4GB'lık bellekle sistemi başlatmayı deneyin.
Çevrimdışı own
  • İleti: 38
« Yanıtla #4 : 04 Mayıs 2015, 00:31:56 »
Dediklerinizi yaptım ve şöyle bir sorunla karşılaştım;
Tek 4 GB RAM ile sorunsuz açılıyor sistem. Tek 2 GB RAM hiç bir şekilde açılmıyor. İkisini birlikte takınca da açılıyor ve 6 GB olarak görüyor.
Düzenleme: İmla
« Son Düzenleme: 04 Mayıs 2015, 23:52:46 Gönderen: Reddet »
« Yanıtla #5 : 04 Mayıs 2015, 00:56:45 »
İlginç. Bu belleklerin marka ve modeli nedir? Frekansları farklı mı? Eğer farklıysa BIOS'tan aynı frekansa getirip dener misiniz? 2GB'lık bellek yeni mi? Daha önceden böyle bir sorun var mıydı?
Çevrimdışı own
  • İleti: 38
« Yanıtla #6 : 05 Mayıs 2015, 02:43:11 »
Ramlerin markası Kingston ile Elixir. İkiside 1333Mhz. Windows 6 GB olarak görüyor. Daha önce farketmedim ikiside eski Ram çünkü. Fakat daha öncede başıma gelmişti DDR2 Ram'lerde böyle Ram uyuşmazlığı tek ramle çalışmayıp 2 Ram ile çalışması.
Düzenleme: İmla
« Son Düzenleme: 05 Mayıs 2015, 10:45:10 Gönderen: Reddet »
