Gönderen Konu: Lenovo Y 550 fan - ısınma sorunu  (Okunma sayısı 3665 defa)
Çevrimdışı sakata gintoki
  • İleti: 111
« : 06 Haziran 2015, 02:02:20 »
iyi günler yeni kurulum yaptım donanım yöneticisinden kapalı kaynak kodlu ekran kartı sürücüsünü kurdum ancak pcnin fazla ısındığını düşünüyorum. Pc boştayken fan tam devir olamasada hatırı sayılır şekilde çalışıyor.
System:    Host: IdeaPad-Y550 Kernel: 3.13.0-37-generic x86_64 (64 bit, gcc: 4.8.2)
           Desktop: KDE 4.14.2 (Qt 4.8.6) Distro: Linux Mint 17.1 Rebecca
Machine:   System: LENOVO (portable) product: 20017 version: Lenovo IdeaPad Y550
           Mobo: LENOVO model: KIWB1 version: REFERENCE Bios: LENOVO version: 15CN32WW(V2.05) date: 10/11/2009
CPU:       Dual core Intel Core2 Duo CPU P8700 (-MCP-) cache: 3072 KB flags: (lm nx sse sse2 sse3 sse4_1 ssse3 vmx) bmips: 10107.5
           Clock Speeds: 1: 1600.00 MHz 2: 1600.00 MHz
Graphics:  Card: NVIDIA GT216M [GeForce GT 240M] bus-ID: 01:00.0
           X.Org: 1.15.1 drivers: nvidia (unloaded: fbdev,vesa,nouveau) Resolution: 1366x768@59.8hz
           GLX Renderer: GeForce GT 240M/PCIe/SSE2 GLX Version: 3.3.0 NVIDIA 331.113 Direct Rendering: Yes
Audio:     Card-1: NVIDIA GT216 HDMI Audio Controller driver: snd_hda_intel bus-ID: 01:00.1
           Card-2: Intel 82801I (ICH9 Family) HD Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
Network:   Card-1: Broadcom NetLink BCM5784M Gigabit Ethernet PCIe driver: tg3 ver: 3.134 bus-ID: 08:00.0
           IF: eth0 state: down mac: 70:5a:b6:5a:7a:05
           Card-2: Intel PRO/Wireless 5100 AGN [Shiloh] Network Connection driver: iwlwifi ver: in-tree: bus-ID: 04:00.0
           IF: wlan0 state: up mac: 00:26:c6:a9:46:de
Drives:    HDD Total Size: 500.1GB (1.8% used) 1: id: /dev/sda model: ST9500325AS size: 500.1GB
Partition: ID: / size: 23G used: 8.4G (39%) fs: ext4 ID: /home size: 428G used: 299M (1%) fs: ext4
           ID: swap-1 size: 8.00GB used: 0.00GB (0%) fs: swap
Sensors:   System Temperatures: cpu: 51.0C mobo: N/A gpu: 0.0:59C
Info:      Processes: 169 Uptime: 15 min Memory: 996.7/7980.4MB Runlevel: 2 Gcc sys: 4.8.2 Client: Shell inxi: 1.8.4
Sistem boştayken
ystem Temperatures: cpu: 51.0C mobo: N/A gpu: 0.0:59C  değeri normalmidir ? değilse çözümünedir ?
Ynt: Lenovo Y 550 fan - ısınma sorunu
« Yanıtla #1 : 06 Haziran 2015, 08:53:06 »
Öncelikle aşağıdaki bağlantıdaki komutların çıktılarını da rica edelim.
http://forum.linuxmint.net.tr/index.php?topic=2738.0
  • İleti: 111
« Yanıtla #2 : 06 Haziran 2015, 11:25:32 »
uname -rm
inxi -Gx
OpenGL renderer string: GeForce GT 240M/PCIe/SSE2
    GL_NVX_conditional_render, GL_NVX_gpu_memory_info,
    GL_NV_ES1_1_compatibility, GL_NV_blend_square, GL_NV_conditional_render,
01:00.0 VGA compatible controller: NVIDIA Corporation GT216M [GeForce GT 240M] (rev a2)
Screen 0: minimum 8 x 8, current 1366 x 768, maximum 8192 x 8192
VGA-0 connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 410mm x 230mm
   1366x768       59.8*+
   1360x768       59.7
   1280x1024      75.0     60.0
   1024x768       75.0     70.1     60.0
   800x600        75.0     72.2     60.3     56.2
   640x480        75.0     72.8     59.9
LVDS-0 connected (normal left inverted right x axis y axis)
   1366x768       60.0 +
« Yanıtla #3 : 06 Haziran 2015, 12:22:35 »
sudo nvidia-xconfigkomutunu verdikten sonra bir değişiklik oluyor mu?
  • İleti: 111
« Yanıtla #4 : 06 Haziran 2015, 14:10:26 »
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 331.113  (buildmeister@swio-display-x64-rhel04-03)  Mon Dec  1 21:15:34 PST 2014
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0"
Section "Files"
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Identifier     "Keyboard0"
    Driver         "kbd"
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Unknown"
    HorizSync       28.0 - 33.0
    VertRefresh     43.0 - 72.0
    Option         "DPMS"
    Identifier     "Device0"
    Driver         "nvidia"
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    SubSection     "Display"
        Depth       24
    EndSubSection
« Yanıtla #5 : 06 Haziran 2015, 14:17:36 »
Sistemi yeniden başlattınız mı? Sistemi yeniden başlatınca ısınma durumu ile ilgili bir gelişme oldu mu?
