Gönderen Konu: Donma Ve Kasma Sorunları  (Okunma sayısı 3893 defa)
« : 18 Haziran 2015, 17:39:05 »
Yine donma sorunları başladı.  Daha önce kendiliğinden düzelmişti ama şimdi yine donmaya başlıyor. Donması için üç tane sekme açmam yetiyor.
Graphics:  Card: Intel Core Processor Integrated Graphics Controller bus-ID: 00:02.0
           X.Org: 1.15.1 driver: intel Resolution: 1366x768@60.0hz
           GLX Renderer: Mesa DRI Intel Ironlake Mobile x86/MMX/SSE2 GLX Version: 2.1 Mesa 10.1.3 Direct Rendering: Yes
00:02.0 VGA compatible controller: Intel Corporation Core Processor Integrated Graphics Controller (rev 18)
OpenGL renderer string: Mesa DRI Intel(R) Ironlake Mobile x86/MMX/SSE2
3.16.0-28-generic i686
System:    Host: Exper Kernel: 3.16.0-28-generic i686 (32 bit, gcc: 4.8.2)
Machine:   Mobo: Exper model: Karizma Bios: Phoenix version: 1.04.02.DA date: 08/27/2010
CPU:       Dual core Intel Pentium CPU P6100 (-MCP-) cache: 3072 KB flags: (lm nx sse sse2 sse3 ssse3) bmips: 7979.8
           Clock Speeds: 1: 933.00 MHz 2: 1199.00 MHz
Audio:     Card: Intel 5 Series/3400 Series Chipset High Definition Audio driver: snd_hda_intel bus-ID: 00:1b.0
           Sound: Advanced Linux Sound Architecture ver: k3.16.0-28-generic
Network:   Card-1: Realtek RTL8191SEvB Wireless LAN Controller driver: rtl8192se port: 4000 bus-ID: 06:00.0
           IF: wlan0 state: down mac: 1c:65:9d:13:33:8b
           driver: r8169 ver: 2.3LK-NAPI port: 3000 bus-ID: 04:00.0
           IF: eth0 state: up speed: 100 Mbps duplex: full mac: 00:03:0d:f9:40:73
Drives:    HDD Total Size: 250.1GB (7.6% used) 1: id: /dev/sda model: SAMSUNG_HM250HI size: 250.1GB
Partition: ID: / size: 40G used: 18G (48%) fs: ext4
Sensors:   System Temperatures: cpu: 60.0C mobo: N/A
Info:      Processes: 174 Uptime: 19 min Memory: 832.2/1752.6MB Runlevel: 2 Gcc sys: 4.9.2 Client: Shell inxi: 1.8.4
« Son Düzenleme: 18 Haziran 2015, 17:47:23 Gönderen: Reddet »
Ynt: Donma Ve Kasma Sorunları
« Yanıtla #1 : 18 Haziran 2015, 17:50:51 »
Donduktan bir süre sonra tekrar düzeliyorsa
dmesg çıktısına bakabilir miyiz?
« Yanıtla #3 : 19 Haziran 2015, 09:22:45 »
Bu sorun hazırda beklet/uyku kipi sonrasında mı ortaya çıkıyor?
« Yanıtla #4 : 19 Haziran 2015, 09:26:55 »
Hayır. Genelde Bir Kaç Uygulamayı Aynı Anda Çalıştırınca.
« Son Düzenleme: 19 Haziran 2015, 10:13:49 Gönderen: Reddet »
« Yanıtla #5 : 19 Haziran 2015, 10:27:26 »
Çekirdeği şu an depoda bulunan en son sürüm olan 3.19.0-21'e yükseltmeyi deneyebilir misiniz?
« Yanıtla #6 : 19 Haziran 2015, 23:39:01 »
Eskisine göre durum daha iyi. Yalnız Chrome yada Firefox ile gizli modda bir pencere açınca sorunu tekrar yaşıyorum.
Çevrimdışı Conqueror
  • İleti: 114
  • Dağıtım: LMDE 2
  • İşlemci: i7-4800MQ
« Yanıtla #7 : 07 Temmuz 2015, 09:35:02 »
tmpfs alanı yeteri kadar büyük mü? Donma yaşandığı an, anlık olarak kaç gb ram kalıyor? Makine swap'a düşüyor mu?
