Gönderen Konu: CD-ROM'dan HDD Bağlanması  (Okunma sayısı 7013 defa)
Çevrimdışı rainidarko
  • İleti: 12
  • Dağıtım: Mint 17.1
  • Grafik Kartı: ATI Radeon HD 6370M
  • İşlemci: Intel Core i5 480m
« : 12 Nisan 2014, 17:46:22 »
Arkadaşlar merhaba.
Bilgisayarımın CD-ROM'unu sökerek eski HHD'mi buraya bağladım fakat buradaki sürücüleri açmaya çalışırken
215 GB Birimi bağlanamıyor
Error mounting /dev/sdb2 at /media/rainidarko/9C18A95518A92EE8: Command-line `mount -t "ntfs" -o "uhelper=udisks2,nodev,nosuid,uid=1000,gid=1000,dmask=0077,fmask=0177" "/dev/sdb2" "/media/rainidarko/9C18A95518A92EE8"' exited with non-zero exit status 12: Failed to read last sector (625129471): Invalid argument
HINTS: Either the volume is a RAID/LDM but it wasn't setup yet,
   or it was not setup correctly (e.g. by not using mdadm --build ...),
   or a wrong device is tried to be mounted,
   or the partition table is corrupt (partition is smaller than NTFS),
   or the NTFS boot sector is corrupt (NTFS size is not valid).
Failed to mount '/dev/sdb2': Invalid argument
The device '/dev/sdb2' doesn't seem to have a valid NTFS.
Maybe the wrong device is used? Or the whole disk instead of a
partition (e.g. /dev/sda, not /dev/sda1)? Or the other way around?
Sistem Ayrıldı bağlanamıyor
Error mounting /dev/sdb1 at /media/rainidarko/Sistem Ayrıldı1: Command-line `mount -t "ntfs" -o "uhelper=udisks2,nodev,nosuid,uid=1000,gid=1000,dmask=0077,fmask=0177" "/dev/sdb1" "/media/rainidarko/Sistem Ayrıldı1"' exited with non-zero exit status 12: Failed to read last sector (204799): Invalid argument
Failed to mount '/dev/sdb1': Invalid argument
The device '/dev/sdb1' doesn't seem to have a valid NTFS.
26 GB Birimi bağlanamıyor
Error mounting /dev/sdb4 at /media/rainidarko/140ffc0e-1c68-4229-9e8d-c709d76cd36b: Command-line `mount -t "ext4" -o "uhelper=udisks2,nodev,nosuid" "/dev/sdb4" "/media/rainidarko/140ffc0e-1c68-4229-9e8d-c709d76cd36b"' exited with non-zero exit status 32: mount: wrong fs type, bad option, bad superblock on /dev/sdb4,
       missing codepage or helper program, or other error
       In some cases useful info is found in syslog - try
       dmesg | tail  or so
Uyarılarını alıyorum.
fdisk -l çıktısı şu şekilde;
Disk /dev/sdb: 320.1 GB, 320072933376 bytes
255 heads, 63 sectors/track, 38913 cylinders, toplam 625142448 sektör
Disk kimlikleyicisi: 0xf40ae7c2
/dev/sdb1              63   625140399   312570168+  42  SFS
Disk /dev/sda: 120.0 GB, 120034123776 bytes
255 heads, 63 sectors/track, 14593 cylinders, toplam 234441648 sektör
Disk kimlikleyicisi: 0x736d26cf
/dev/sda1   *        2048      206847      102400    7  HPFS/NTFS/exFAT
/dev/sda2          206848    40962047    20377600   83  Linux
/dev/sda3        40962048   234438655    96738304    7  HPFS/NTFS/exFAT
Disk /dev/sdc: 2000.4 GB, 2000365289472 bytes
255 heads, 63 sectors/track, 243197 cylinders, toplam 3906963456 sektör
Disk kimlikleyicisi: 0x00021365
/dev/sdc1            2048  3906963455  1953480704    7  HPFS/NTFS/exFAT
Bu konuda yardımcı olabilecek olan var mı?
'Yalnızca paranoyaklar hayatta kalır.'
Ynt: CD-ROM'dan HDD Bağlanması
« Yanıtla #1 : 12 Nisan 2014, 18:18:31 »
/dev/sdb diskinizde veri yoksa yeniden biçimlendirmeniz sorunu çözebilir, sorun sanırım SFS dosya sisteminden kaynaklanıyor. Bu Windows altında kullanılan bir disk sanırım ve dinamik kullanıma atanmış. Bu diske basit kullanım ataması yapmanız sorunu çözebilir. Bunu Windows altında yapabilir ya da Partition Wizard isimli uygulama ile yapabilirsiniz.
http://www.partitionwizard.com/video-help/diskconvertdynamic/diskconvertdynamic.html
http://www.partitionwizard.com/help/convert-dynamic-disk-to-basic-disk.html
Partition Wizard'ın bir ISO sürümü mevcut, bu ISO dosyasını Unetbootin ile USB belleğe yazdırıp kullanabilirsniz.
http://www.partitionwizard.com/download/pwhe7.iso
« Son Düzenleme: 12 Nisan 2014, 18:22:46 Gönderen: Butterfly »
  • İleti: 12
« Yanıtla #2 : 13 Nisan 2014, 00:24:27 »
Teşekkür ederim Butterfly.
Fakat bu HDD üzerinde yedeklerim ve DropBox gibi paylaşım klasörleri var. Diski formatlamadan başka bir yolla çözme imkanım var mı?
« Yanıtla #3 : 13 Nisan 2014, 00:25:37 »
Basit disk olarak atama yapmayı deneyebilirsiniz. Bunun veri kaybına neden olup olmayacağı konusunda bir tecrübem yok. İyice araştırma yapmanızı öneririm.
« Son Düzenleme: 13 Nisan 2014, 00:36:51 Gönderen: Butterfly »
  • İleti: 12
« Yanıtla #4 : 13 Nisan 2014, 00:59:16 »
Tamam bir deneyeyim deneyimlerimi aktarayım (:
Teşekkür ederim.
  • İleti: 12
« Yanıtla #5 : 15 Aralık 2014, 19:01:49 »
Uzun bir süre uğraşamadım korkumdan ama konuyu hortlatmak gibi olmasın. Sadece eğer başka birinin başına gelirse diye yazıyorum. Sorunun çözümü diski biçimlendirip Windows üzerinden Basic Disk yapmaktan ibaret (:
