Gönderen Konu: [Çözüldü] HP Pavilion m6 isinma sorunu  (Okunma sayısı 12888 defa)
Çevrimdışı Unal
  • İleti: 66
  • Dağıtım: Linux Mint 17.3
  • Grafik Kartı: ATI RADEON 7600M
  • İşlemci: Intel core i5
« : 23 Temmuz 2015, 02:58:08 »
Merhaba Arkadaslar,
19.Temmuz da bir konu acmistim (ATI RADEON HD 7600M isinma)
Butterfly saolsun bana yardimci olmustu konu cözülmüstü.
Fakat isinma sorunu hala var yardimci olursaniz cok sevinirim.
Linux Mint 17.2 Cinnamon 64 bit
nerde komut bulduysam yapistirdim umarim yardimci olur.
System:    Host: UENALPC Kernel: 3.16.0-38-generic x86_64 (64 bit, gcc: 4.8.2)
Machine:   System: Hewlett-Packard product: HP Pavilion m6 Notebook PC version: 0791100000205610000620100
           Mobo: Hewlett-Packard model: 18A5 version: 73.50 Bios: Insyde version: F.25 date: 01/21/2013
CPU:       Dual core Intel Core i5-3210M CPU (-HT-MCP-) cache: 3072 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9977.72
           Clock Speeds: 1: 1356.152 MHz 2: 1247.363 MHz 3: 1318.261 MHz 4: 2193.945 MHz
           X.Org: 1.15.1 drivers: fglrx,intel Resolution: 1366x768@60.0hz
Audio:     Card: Intel 7 Series/C210 Series Family High Definition Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
Network:   Card-1: Intel Centrino Wireless-N 2230 driver: iwlwifi ver: in-tree: bus-ID: 08:00.0
           driver: r8169 ver: 2.3LK-NAPI port: 2000 bus-ID: 07:00.2
Drives:    HDD Total Size: 1000.2GB (1.2% used) 1: id: /dev/sda model: TOSHIBA_MQ01ABD1 size: 1000.2GB
Partition: ID: / size: 909G used: 12G (2%) fs: ext4 ID: swap-1 size: 8.48GB used: 0.00GB (0%) fs: swap
Sensors:   System Temperatures: cpu: 55.0C mobo: 55.0C
Info:      Processes: 194 Uptime: 1:39 Memory: 875.1/7881.2MB Runlevel: 2 Gcc sys: 4.8.4
dpkg -l | grep fglrx
ii  fglrx                                       2:15.200-0ubuntu0.3                                 amd64        Video driver for the AMD graphics accelerators
ii  fglrx-amdcccle                              2:15.200-0ubuntu0.3                                 amd64        Catalyst Control Center for the AMD graphics accelerators
ii  fglrx-core                                  2:15.200-0ubuntu0.3                                 amd64        Minimal video driver for the AMD graphics accelerators
rc  fglrx-updates                               2:15.200-0ubuntu0.3                                 amd64        Video driver for the AMD graphics accelerators
rc  fglrx-updates-core                          2:15.200-0ubuntu0.3                                 amd64        Minimal video driver for the AMD graphics accelerators
Section "ServerLayout"
    Identifier "amd-layout"
    Screen 0 "amd-screen" 0 0
    Identifier "intel"
    Driver "intel"
    Option "AccelMethod" "uxa"
    BusID "PCI:0@0:2:0"
    Identifier "amd-device"
    Driver "fglrx"
    BusID "PCI:1:0:0"
Section "Monitor"
    Identifier "amd-monitor"
    Option "VendorName" "ATI Proprietary Driver"
    Option "ModelName" "Generic Autodetecting Monitor"
    Option "DPMS" "true"
Section "Screen"
    Identifier "amd-screen"
    Device "amd-device"
    Monitor "amd-monitor"
    DefaultDepth 24
    SubSection "Display"
        Viewport   0 0
        Depth     24
    EndSubSection
lspci | egrep 'VGA|3D'
« Son Düzenleme: 29 Temmuz 2015, 18:07:39 Gönderen: Unal »
Ey gönül üzülme, Ne bu dertler baki ne de bu dünya....
Ynt: HP Pavilion m6 isinma sorunu
« Yanıtla #1 : 23 Temmuz 2015, 08:52:57 »
Aşağıdaki komutun çıktısını ne diyor?
aticonfig --pxl
Çevrimdışı Unal
  • İleti: 66
« Yanıtla #2 : 23 Temmuz 2015, 12:55:10 »
aticonfig --pxl
aticonfig: No supported adapters detected
« Yanıtla #3 : 23 Temmuz 2015, 15:07:25 »
Aşağıdaki komutla ATI kontrol merkezini açıp GPU değiştirip sistemi yeniden başlatmayı deneyiniz.
gksudo env LC_ALL=C amdcccle
Sistemi yeniden başlattığınızda GPU değiştiğini aşağıdaki komutla kontrol ediniz.
Bu şekilde GPU değişimi ile ilgili sıkıntı olup olmadığını anlamaya çalışalım, çünkü yukarıda komutun çıktısı bir sıkıntı olduğu ihtimalini işaret ediyor gibi.
Çevrimdışı Unal
  • İleti: 66
« Yanıtla #4 : 23 Temmuz 2015, 18:30:08 »
OpenGL renderer string: AMD Radeon HD 7600M Series
Dediğiniz gibi uçbirimden açıp gpu değiştirdim şu an çıktısı bu şekil de.
Düzenleme:Yazım
karakartala
« Son Düzenleme: 23 Temmuz 2015, 18:38:36 Gönderen: karakartala »
« Yanıtla #5 : 23 Temmuz 2015, 18:35:13 »
GPU değiştirmede sıkıntı yok o zaman. Sorun GPU'nun ısınması ile ilgili olmayabilir, burada anlatıldığı biçimde TLP uygulamasını kurmayı denediniz mi?
Çevrimdışı Unal
  • İleti: 66
« Yanıtla #6 : 23 Temmuz 2015, 18:39:43 »
sudo apt-get install tlp
sudo apt-get install tlp-rdwBu uygulamayı ilk defa duyuyorum deneyeceğim.
Bu ikisini ayrı ayrı mı kurmam gerekiyor? Yoksa sonuncusu yeterli olacak mı?
Düzenleme: Yazım.
karakartala
« Son Düzenleme: 23 Temmuz 2015, 19:15:51 Gönderen: karakartala »
Ynt: [Çözüldü] HP Pavilion m6 isinma sorunu
« Yanıtla #7 : 23 Temmuz 2015, 19:21:03 »
İkincisini kurmak size kalmış. İkincisinin ekran kartı işlemci gibi aygıtları etkileyeceğini sanmıyorum. Bu yüzden ısınma konusunda da pek bir etki göstermez.
(rdw=radio device wizard, yani ikincisi radyo sinyali ile çalışan aygıtlarla ilgili)
Çevrimdışı Unal
  • İleti: 66
« Yanıtla #8 : 23 Temmuz 2015, 20:09:06 »
Tekrar Intel'e geçtim ve şu an durum bu inşaallah hep böyle kalır.
sensors
acpitz-virtual-0
Adapter: Virtual device
temp1:        +55.0°C  (crit = +104.0°C)
temp2:        +55.0°C  (crit = +104.0°C)
temp3:        +27.8°C
coretemp-isa-0000
Adapter: ISA adapter
Physical id 0:  +55.0°C  (high = +87.0°C, crit = +105.0°C)
Core 0:         +55.0°C  (high = +87.0°C, crit = +105.0°C)
Core 1:         +54.0°C  (high = +87.0°C, crit = +105.0°C)
Ekran Aydınlatması 75& de kalan pil 1 saat 27 dk
Teşekkürler, Butterfly ve karakartala
Düzenleme:Yazım
karakartala
« Son Düzenleme: 23 Temmuz 2015, 20:36:21 Gönderen: karakartala »
« Yanıtla #9 : 23 Temmuz 2015, 20:11:29 »
İsterseniz başlığın etiketini silip bir süre ısınmayı gözlemleyin. Konuyu kilitlemeyelim. Sorun devam ederse tekrar yazarsınız.
Çevrimdışı Unal
  • İleti: 66
« Yanıtla #10 : 23 Temmuz 2015, 20:14:29 »
Tavsiyeniz üzere başlığı değiştirdim.
Haklısınız! Bir süre gözlemlemek gerekir.
Sizce Intelde mi yoksa Atide mi dursun bir süre?
Düzenleme:Yazım
karakartala
« Son Düzenleme: 23 Temmuz 2015, 20:37:44 Gönderen: karakartala »
« Yanıtla #11 : 23 Temmuz 2015, 20:19:03 »
Tavsiyeniz üzere basligi degistirdim.
Haklisiniz! Bir süre gözlemlemek gerekir.
Sizce intel demi yoksa Ati demi dursun bir süre?
Oyun oynamıyorsanız, tasarım yazılımları, video işleme yazılımları vb. yazılımlar kullanmıyorsanız Intel'de durmasını öneririm. Eğer grafiksel işlem gücü gerektiren uygulamalar kullanıyorsanız(saydıklarım vb.) ATI kullanabilirsiniz.
Çevrimdışı Unal
  • İleti: 66
« Yanıtla #12 : 23 Temmuz 2015, 20:22:26 »
Sadece Gimp ve Inkscape kullanıyorum. Oyun hiç oynamıyorum.
Gimp ve Inkscape için ATI geçmem gerekecek sanırım.
Düzenleme:Yazım
karakartala
« Son Düzenleme: 23 Temmuz 2015, 20:39:03 Gönderen: karakartala »
« Yanıtla #13 : 23 Temmuz 2015, 20:34:31 »
Sadece gimp ve inkscape kullaniyorum. Oyun hic oynamiyorum.
Gimp ve Inkscape icin ATI gecmem gerekecek sanirim.
Eğer performansın yetersiz geldiğini gözlemlerseniz geçebilirsiniz.
Çevrimdışı Unal
  • İleti: 66
« Yanıtla #14 : 23 Temmuz 2015, 20:40:13 »
Teşekkürler tavsiyeleriniz için.
Başka öneriniz varsa memnuniyetle kabul ederim :)
Düzenleme:Yazım
karakartala
« Son Düzenleme: 23 Temmuz 2015, 21:33:19 Gönderen: karakartala »
