Gönderen Konu: Masaüstü Ekranında Oluşan Yırtılmalar  (Okunma sayısı 11543 defa)
Çevrimdışı alperberk
  • İleti: 52
  • Dağıtım: Linux Mint 18 - 64 bit
  • Grafik Kartı: Amd Radeon HD 6610M
  • İşlemci: i7 - İntel
« : 08 Ağustos 2015, 02:34:58 »
System:    Host: AlperBerk-LinuxMint Kernel: 3.16.0-38-generic x86_64 (64 bit, gcc: 4.8.2)
           Desktop: KDE 4.14.2 (Qt 4.8.6) Distro: Linux Mint 17.2 Rafaela
Machine:   Mobo: Casper Bilgisayar Sistemleri A.S. model: Casper Nirvana Notebook
           Bios: Phoenix version: 1.03.03.CAT2 date: 02/16/2012
CPU:       Quad core Intel Core i7-2670QM CPU (-HT-MCP-) cache: 6144 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 17560.9
           Clock Speeds: 1: 845.453 MHz 2: 1083.414 MHz 3: 904.664 MHz 4: 1340.195 MHz 5: 1482.507 MHz 6: 1499.695 MHz 7: 800.078 MHz 8: 800.765 MHz
           Card-2: Advanced Micro Devices [AMD/ATI] Whistler LE [Radeon HD 6610M/7610M] bus-ID: 01:00.0
           X.Org: 1.15.1 drivers: fglrx,intel Resolution: 1366x768@60.0hz
           GLX Renderer: AMD Radeon HD 7500/7600 Series GLX Version: 4.4.13374 - CPC 15.20.1013 Direct Rendering: Yes
Audio:     Card: Intel 6 Series/C200 Series Family High Definition Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
           driver: r8169 ver: 2.3LK-NAPI port: 4000 bus-ID: 04:00.0
           Card-2: Intel Centrino Wireless-N 1030 [Rainbow Peak] driver: iwlwifi ver: in-tree: bus-ID: 02:00.0
Drives:    HDD Total Size: 120.0GB (5.7% used) 1: id: /dev/sda model: KINGSTON_SV300S3 size: 120.0GB
Partition: ID: / size: 103G used: 6.4G (7%) fs: ext4 ID: swap-1 size: 8.43GB used: 0.00GB (0%) fs: swap
Sensors:   System Temperatures: cpu: 61.0C mobo: N/A gpu: 50.00C
Info:      Processes: 250 Uptime: 10 min Memory: 1054.2/7832.8MB Runlevel: 2 Gcc sys: 4.8.4
Section "ServerLayout"
    Identifier "amd-layout"
    Screen 0 "amd-screen" 0 0
    Identifier "intel"
    Driver "intel"
    Option "AccelMethod" "uxa"
    BusID "PCI:0@0:2:0"
    Identifier "amd-device"
    Driver "fglrx"
    BusID "PCI:1:0:0"
Section "Monitor"
    Identifier "amd-monitor"
    Option "VendorName" "ATI Proprietary Driver"
    Option "ModelName" "Generic Autodetecting Monitor"
    Option "DPMS" "true"
Section "Screen"
    Identifier "amd-screen"
    Device "amd-device"
    Monitor "amd-monitor"
    DefaultDepth 24
    SubSection "Display"
        Viewport   0 0
        Depth     24
    EndSubSection
   1366x768       60.0*+
   1360x768       59.8     60.0
   1024x768       60.0
   800x600        60.3     56.2
   640x480        59.9
Masaüstümde sürekli yırtılmalar oluyor.  Dosya yönetici penceresini hareket ettirdikçce kırılmalar oluşuyor ve aynı şekilde internet sayfalarında da bu sorunu yaşıyorum.
  http://forum.linuxmint.net.tr/index.php?topic=3585.0
Bu linkteki çözümü denedim fakat bir şey değişmedi. Yardımcı olursanız sevinirim.
Ynt: Masaüstü Ekranında Oluşan Yırtılmalar
« Yanıtla #1 : 08 Ağustos 2015, 11:14:27 »
Şu öneriyi deneyebilir misiniz?  [Nasıl] Video Yırtılmalarını Önleme
  • İleti: 52
« Yanıtla #2 : 08 Ağustos 2015, 18:12:30 »
Denedim bu da olmadı. Ben bu çözümü cinnamon kullanırken uygulamıştım sorunumu çözmüştü fakat kde de işe yaramadı. Bununla alakalı olabilir mi? Ayırıca http://forum.linuxmint.net.tr/index.php?topic=3585.0 şu çözümü tekrar denedim işe yaramadı ve sürücü yöneticisine girdiğimde önerilen şeçeneğini( xserver-xorg-video-ati) tıklayıp tekrar başlattığımda bilgisayar açlımıyor. Şu anda fglrx- updates seçeneği seçilmiş durumda. Tekrar  işletim sistemini kurmak zorunda kaldım. Cinnamon kullanırken o seçeneği seçtiğim zaman yırtılma sorunum çözülüyordu.
« Son Düzenleme: 08 Ağustos 2015, 18:36:37 Gönderen: alperberk »
« Yanıtla #3 : 08 Ağustos 2015, 18:36:07 »
KDE masaüstü efektlerini (Kwin ya da Compiz) kapatınca durum ne oluyor?
  • İleti: 52
« Yanıtla #4 : 08 Ağustos 2015, 18:42:08 »
Bu da olmadı.Bir önce attığım mesajı güncelledim bir daha onu okur musunuz? Belki başka çözüm yolu bulunabilir.
Çevrimdışı Liva
  • İleti: 300
  • Dağıtım: Mint 17.3
« Yanıtla #5 : 08 Ağustos 2015, 18:51:48 »
AMD sitesinde yeni bir güncelleme yayınlamış. Sürücülerin hepsini tek bir yerde toplamış. Sürücüyü elle kurmak çözüm olabilir diye düşünüyorum.
  • İleti: 52
« Yanıtla #6 : 08 Ağustos 2015, 18:59:18 »
Dediğiniz sürücüyü indirdim elle kurulumu nasıl yapabilirim yardımcı olursanız sevinirim. http://forum.linuxmint.net.tr/index.php?topic=3585.0 Bu linkte kurduğum sürücüyü silmem gerekiyor mu ?
« Yanıtla #7 : 08 Ağustos 2015, 19:47:04 »
Önce kurulu sürücüleri kaldırmakta fayda var, aşağıdaki komutlar ile fglrx sürücüsünü kaldırıp açık kaynak sürücüsünü etkinleştiriniz.
sudo apt-get remove --purge fglrx*
sudo rm -rf /etc/ati
Sonrasında sistemi yeniden başlatınız ve sitesinden indireceğiniz sürücüyü kurmayı deneyiniz.
  • İleti: 52
« Yanıtla #8 : 08 Ağustos 2015, 19:58:00 »
İndirdiğim sürücüyü nasıl kurabilirim? Araştırdım ama tam kavrayamadım yükleme işini.
« Yanıtla #9 : 08 Ağustos 2015, 20:07:53 »
İndirdiğiniz dosyaya sağ tıklayın. Özellikler>erişim hakları kısmından doyaya çalıştırma izni verin. Çift tıklayıp kuruluma geçin.
  • İleti: 52
« Yanıtla #10 : 08 Ağustos 2015, 20:13:29 »
Grafik kartım desteklenmiyor  şeklinde bir hata aldım.
« Son Düzenleme: 08 Ağustos 2015, 20:16:40 Gönderen: alperberk »
« Yanıtla #11 : 08 Ağustos 2015, 20:36:42 »
Doğru sürücüyü indirdiğinizden emin misiniz?
  • İleti: 52
« Yanıtla #12 : 08 Ağustos 2015, 20:45:37 »
Evet doğru sürücü olduğuna eminim. Ben bu ekran kartımda sürekli bir sürücü problemi yaşıyorum zaten. Araştırmama rağmen kalıcı bir çözüm bulamadım.
« Yanıtla #13 : 08 Ağustos 2015, 22:14:43 »
Aşağıdaki şekilde .run uzantılı dosyadan fgrlx paketleri oluşturup kurulum yapmayı deneyebilirsiniz. Bunun için indirdiğiniz dosyayı kullanıcı ev dizini altına atınız.
Paketleri oluşturmak için aşağıdaki komutlar ile bağımlılıkları yükleyiniz.
sudo apt-get install cdbs dh-make dkms execstack dh-modaliases linux-headers-generic libqtgui4 xserver-xorg-dev-lts-trusty
Sisteminiz 64 bit ise aşağıdaki paketi de yüklemelisiniz.
sudo apt-get install lib32gcc1
Şimdi aşağıdaki komut ile .run uzantılı dosyadan fglrx paketlerini oluşturmayı deneyiniz.
sudo ./amd-driver-installer*.run --buildpkg Ubuntu/trusty
Sonrasında aşağıdaki komut ile fglrx paketlerini kurabilirsiniz.
sudo dpkg -i fglrx*.deb
Aşağıdaki komutlar ile yapılandırma dosyalarını oluşturunuz.
sudo aticonfig --initial -f --adapter=all
  • İleti: 52
« Yanıtla #14 : 08 Ağustos 2015, 22:36:32 »
     Bu iki komutta " no supported adapters detected"  uyarısı alıyorum.
