Gönderen Konu: [Çözüldü] Video ve oyunlarda ekran yırtılması sorunu(Screen tearing)  (Okunma sayısı 8379 defa)
Çevrimdışı Aurora
  • İleti: 12
Merhabalar.Linux makinemde ekran yırtılması sorunu yaşıyorum. Amd HD5500 ekran kartım mevcut.Sistemim 32bit
sudo gedit /etc/environment
CLUTTER_PAINT=disable-clipped-redraws:disable-culling
CLUTTER_VBLANK=True
ile hatamı çözemedim.
Kaynak  kodlarından daha önce enable olan kodu . Meta.disable_unredirect_for_screen(global.get_screen()) ile değiştirdim.
inxi -F
için çıktılarım bunlar
OpenGL renderer string: AMD Radeon HD 5500 Series
erdem@Terminal-MS-7309 ~ $ lspci | egrep 'VGA|3D|Display'
02:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Turks LE [Radeon HD 5570/6510/7510/8510]
erdem@Terminal-MS-7309 ~ $ inxi -F
System:    Host: Terminal-MS-7309 Kernel: 3.16.0-38-generic i686 (32 bit)
Machine:   Mobo: MSI model: K9N6PGM2-V2 (MS-7309) version: 2.0 Bios: American Megatrends version: V10.5 date: 04/01/2011
CPU:       Dual core AMD Athlon 64 X2 3800+ (-MCP-) cache: 1024 KB flags: (lm nx pae sse sse2 sse3 svm)
           Clock Speeds: 1: 1000.00 MHz 2: 1000.00 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Turks LE [Radeon HD 5570/6510/7510/8510]
           X.Org: 1.15.1 drivers: ati,fglrx (unloaded: fbdev,vesa,radeon) Resolution: 1360x768@60.0hz
           GLX Renderer: AMD Radeon HD 5500 Series GLX Version: 4.4.13374 - CPC 15.20.1013
Audio:     Card-1: NVIDIA MCP61 High Definition Audio driver: snd_hda_intel Sound: ALSA ver: k3.16.0-38-generic
           Card-2: Advanced Micro Devices [AMD/ATI] Turks/Whistler HDMI Audio [Radeon HD 6000 Series] driver: snd_hda_intel
Network:   Card: Realtek RTL8101E/RTL8102E PCI Express Fast Ethernet controller driver: r8169
           IF: eth0 state: up speed: 100 Mbps duplex: full mac: 8c:89:a5:66:aa:c8
Drives:    HDD Total Size: 160.0GB (4.6% used) 1: id: /dev/sda model: SAMSUNG_HD160HJ size: 160.0GB
Partition: ID: / size: 145G used: 6.8G (5%) fs: ext4 ID: /boot size: 236M used: 42M (19%) fs: ext2
           ID: swap-1 size: 2.15GB used: 0.35GB (16%) fs: swap
Sensors:   System Temperatures: cpu: 50.0C mobo: N/A
Info:      Processes: 197 Uptime: 59 min Memory: 1458.4/2019.0MB Client: Shell (bash) inxi: 1.9.17
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Turks LE [Radeon HD 5570/6510/7510/8510] bus-ID: 02:00.0
           X.org: 1.15.1 drivers: ati,fglrx (unloaded: fbdev,vesa,radeon) tty size: 80x24 Advanced Data: N/A for root
Screen 0: minimum 320 x 200, current 1360 x 768, maximum 16384 x 16384
DFP1 disconnected (normal left inverted right x axis y axis)
DFP2 disconnected (normal left inverted right x axis y axis)
CRT1 connected primary 1360x768+0+0 (normal left inverted right x axis y axis) 1360mm x 768mm
   1360x768       60.0*+
   1280x1024      60.0
   1280x960       60.0
   1280x900       60.0
   1280x800       60.0
   1280x768       59.9
   1280x720       59.9
   1024x768       75.0     70.1     60.0
   848x480        75.0     70.1     60.0
   720x480        72.2     75.0     60.3     56.2
   640x480        72.8     75.0     59.9
Yabancı forumlarda uzun bir süre aramama rağman pek farklı bir şey bulabilmiş değilim yardımcı olursanız minnettar olurum.
« Son Düzenleme: 09 Ağustos 2015, 22:13:35 Gönderen: Aurora »
the more quieter you become the more you are able to hear
Çevrimdışı Aurora
  • İleti: 12
Ynt: Video ve oyunlarda ekran yırtılması sorunu(Screen tearing)
« Yanıtla #2 : 09 Ağustos 2015, 20:06:46 »
 Teşekkürler ancak o konuya bakmıştım ;
sudo aticonfig --initial -f
karşısında
Using /etc/X11/xorg.conf
Saving back-up to /etc/X11/xorg.conf.fglrx-1
kodunu alıyorum.
Sürücümü kaldırıp Tekrar kurdum ancak yine aynı şekilde yırtılmalar devam etti.Dikey senkronizasyon ayarlarını yaptığım halde hale neden yırtılma oluşuyor anlamış değilim.Nvidia ekran kartlarında sorun oldukca basit çözülüyor gibi.Amd'nin bu konuda sıkıntılı olduğunu düşünüyorum.
« Yanıtla #3 : 09 Ağustos 2015, 20:57:29 »
Komutundan sonra sistemi yeniden başlatmanız gerekli.
Çevrimdışı Aurora
  • İleti: 12
« Yanıtla #4 : 09 Ağustos 2015, 21:34:39 »
Dediğiniz gibi sistemi reboot  ettim.Ancak halihazırda
Warning: Option 'TexturedVideoSync' doesn't affect running session.
Saving back-up to /etc/X11/xorg.conf.fglrx-7
gibi bir hata aldığım için bir işe yarayacağını düşünmüyorum bu hatanın sebebi nedir acaba driver doğru yüklenmemiş olabilir mi?
« Yanıtla #5 : 09 Ağustos 2015, 21:55:41 »
İlgili seçeneğin mevcut oturumda etkin olmayacağını söylüyor. Eğer bu komutu yeni çalıştırdı iseniz etkin olması için sistemi yeniden başlatınız.
Çevrimdışı Aurora
  • İleti: 12
« Yanıtla #6 : 09 Ağustos 2015, 22:13:24 »
ilginiz için teşekkürler .Sorun çözüldü
