Gönderen Konu: [Çözüldü] docky açılmıyor  (Okunma sayısı 5353 defa)
Çevrimdışı ssri
  • İleti: 49
  • Dağıtım: Ubuntu 14.04 LTS 64-bit
  • Masaüstü Ortamı: Unity
« : 22 Ağustos 2015, 07:15:21 »
Docky başlatmak istediğimde uçbirimde bu hatayı alıyorum.
[Info  07:13:46.656] Docky version: 2.2.0 Release
[Info  07:13:46.662] Kernel version: 4.0.9.40009
[Info  07:13:46.663] CLR version: 4.0.30319.17020
[Error 07:13:46.803] [SystemService] Could not initialize power manager dbus: 'org.freedesktop.DBus.Error.MatchRuleInvalid: Unknown key "ınterface" in match rule'
[Info  07:13:46.804] [SystemService]   at org.freedesktop.DBus.IBusProxy.AddMatch (System.String rule) [0x00000] in <filename unknown>:0
  at DBus.Bus.AddMatch (System.String rule) [0x00000] in <filename unknown>:0
  at DBus.BusObject.ToggleSignal (System.String iface, System.String member, System.Delegate dlg, Boolean adding) [0x00000] in <filename unknown>:0
  at Docky.Services.SystemService+IUPowerProxy.add_Changed (System.Action value) [0x00000] in <filename unknown>:0
  at Docky.Services.SystemService.InitializeBattery () [0x00000] in <filename unknown>:0
Unhandled Exception:
System.Exception: org.freedesktop.DBus.Error.MatchRuleInvalid: Unknown key "ınterface" in match rule
  at org.freedesktop.DBus.IBusProxy.add_NameOwnerChanged (org.freedesktop.DBus.NameOwnerChangedHandler value) [0x00000] in <filename unknown>:0
  at Docky.Services.SystemService.InitializeNetwork () [0x00000] in <filename unknown>:0
  at Docky.Services.SystemService.Initialize () [0x00000] in <filename unknown>:0
  at Docky.Services.DockServices.Init (Boolean disableHelpers) [0x00000] in <filename unknown>:0
  at Docky.Docky.Main (System.String[] args) [0x00000] in <filename unknown>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.Exception: org.freedesktop.DBus.Error.MatchRuleInvalid: Unknown key "ınterface" in match rule
Ayrıca "env LC_ALL=C docky" komutuyla deneyince de çalışıyor ama aşağıdaki çıktıyı alıyorum.Ayrıca Türkçe olarak açılmıyor.
[Info  07:16:20.697] Docky version: 2.2.0 Release
[Info  07:16:20.704] Kernel version: 4.0.9.40009
[Info  07:16:20.705] CLR version: 4.0.30319.17020
[Error 07:16:20.832] [SystemService] Could not initialize power manager dbus: 'org.freedesktop.DBus.Error.UnknownMethod: Method "Get" with signature "ss" on interface "org.freedesktop.UPower" doesn't exist
[Info  07:16:20.833] [SystemService]   at Docky.Services.SystemService+IUPowerProxy.Get (System.String interface, System.String propname) [0x00000] in <filename unknown>:0
  at Docky.Services.SystemService.HandleUPowerChanged () [0x00000] in <filename unknown>:0
[Info  07:16:20.840] [ThemeService] Setting theme: Classic
[Warn  07:16:20.852] [DesktopItemService] Could not find remap file '/home/kullanıcı-adı/.local/share/docky/remaps.ini'!
[Info  07:16:20.959] [DockServices] Dock services initialized.
[Info  07:16:21.063] [PluginManager] Loaded "Trash".
[Fatal 07:16:21.126] [GLib] Source ID 69 was not found when attempting to remove it
[Fatal 07:16:21.126] [GLib] Source ID 73 was not found when attempting to remove it
[Fatal 07:16:21.126] [GLib] Source ID 70 was not found when attempting to remove it
Cairo.Surface is leaking, programmer is missing a call to Dispose
Set MONO_CAIRO_DEBUG_DISPOSE to track allocation traces
Not: http://forum.linuxmint.net.tr/index.php?topic=55.msg288#msg288  adresindeki çözümü denedim hala aynı.Ek olarak örneğin chrome uygulamasını kullanırken docky'de youtube-dl gui simgesi gözüküyor.Bu gibi problemler mevcut.
« Son Düzenleme: 10 Ocak 2019, 14:02:50 Gönderen: Danny »
Ynt: docky açılmıyor
« Yanıtla #1 : 22 Ağustos 2015, 09:44:56 »
Aşağıdaki komutu uçbirimde çalıştrınız.
(Mate masaüstü için gedit yerine pluma yazmalısınız.
sudo gedit /etc/default/locale
Açılan dosyanın en altına aşağıdaki saıtırı ekleyip kaydedin.
LC_ALL=
Şimdi oturumu kapatıp tekrar açtıktan sonra Docky uygulaması sorunsuz ve Türkçe olarak açılacaktır.
Eğer sorundevam ediyorsa aşağıdaki komutların çıktılarını paylaşınız.
cat /etc/default/locale
cat /etc/environment
cat ~/.pam_environment
Çevrimdışı ssri
  • İleti: 49
« Yanıtla #2 : 22 Ağustos 2015, 22:02:53 »
Sorun çözülmüştür.Teşekkürler :)
« Son Düzenleme: 22 Ağustos 2015, 22:32:26 Gönderen: ssri »
Ynt: [Çözüldü] docky açılmıyor
« Yanıtla #3 : 22 Ağustos 2015, 22:34:32 »
Rica ederiz, gülegüle kullanın.
Sorun çözüldüğü için konu kilitlenmiştir.
